Hi Shane ,
I’ve tried with another Pi V2 camera and this is what i got.
Appreciate if you can give me other direction that i should check.
1.099890] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.099968] tegradc tegradc.1: No lt-data, using default setting
[ 1.099997] tegradc tegradc.1: No hpd-gpio in DT
[ 1.100030] tegradc tegradc.1: DT parsed successfully
[ 1.100094] tegradc tegradc.1: Display dc.ffffff800d4c0000 registered with id=1
[ 1.101584] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.105705] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 1.105854] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e6:01:34 from device tree
[ 1.106528] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.106587] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 1.107523] PPP generic driver version 2.4.2
[ 1.107756] PPP BSD Compression module registered
[ 1.107762] PPP Deflate Compression module registered
[ 1.107804] PPP MPPE Compression module registered
[ 1.107812] NET: Registered protocol family 24
[ 1.107902] usbcore: registered new interface driver r8152
[ 1.107953] usbcore: registered new interface driver asix
[ 1.108024] usbcore: registered new interface driver ax88179_178a
[ 1.108066] usbcore: registered new interface driver cdc_ether
[ 1.108099] usbcore: registered new interface driver net1080
[ 1.108132] usbcore: registered new interface driver cdc_subset
[ 1.108171] usbcore: registered new interface driver zaurus
[ 1.108228] usbcore: registered new interface driver cdc_ncm
[ 1.108414] VFIO - User Level meta-driver version: 0.3
[ 1.109845] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.109870] ehci-pci: EHCI PCI platform driver
[ 1.109917] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.109930] ohci-pci: OHCI PCI platform driver
[ 1.109976] ohci-platform: OHCI generic platform driver
[ 1.111734] tegradc tegradc.1: probed
[ 1.113813] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.114677] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.116173] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f915c400 id
[ 1.119940] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-05-08 09:42:10 UTC, Version: 50.22 release
[ 1.120082] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.120135] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.121223] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.121321] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.121616] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.121625] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.121632] usb usb1: Product: xHCI Host Controller
[ 1.121637] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.121642] usb usb1: SerialNumber: 70090000.xusb
[ 1.122906] usbcore: registered new interface driver uas
[ 1.122983] hub 1-0:1.0: USB hub found
[ 1.123105] usbcore: registered new interface driver usb-storage
[ 1.123318] usbcore: registered new interface driver usbserial
[ 1.123849] hub 1-0:1.0: 5 ports detected
[ 1.124865] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.124891] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.125345] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.125464] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.125470] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.125477] usb usb2: Product: xHCI Host Controller
[ 1.125482] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.125486] usb usb2: SerialNumber: 70090000.xusb
[ 1.126977] hub 2-0:1.0: USB hub found
[ 1.127034] hub 2-0:1.0: 4 ports detected
[ 1.129210] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.131332] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.131359] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.131420] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.131726] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.133249] mousedev: PS/2 mouse device common for all mice
[ 1.133437] usbcore: registered new interface driver xpad
[ 1.139469] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.142629] tegradc tegradc.1: fb registered
[ 1.145868] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.145876] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.145885] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.145903] tegradc tegradc.1: blank - powerdown
[ 1.145926] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.145931] Extcon DP: HPD disabled
[ 1.145935] hpd: hpd_switch 0
[ 1.145940] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.145948] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.145955] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.226529] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.226596] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 1.233958] tegradc tegradc.0: blank - powerdown
[ 1.263777] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.266493] rtc rtc1: alarm rtc device
[ 1.266511] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.266546] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.267231] i2c /dev entries driver
[ 1.269731] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.278290] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.278293] Extcon AUX1(HDMI) disable
[ 1.295389] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.298028] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.298033] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.298521] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.298537] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.298547] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.298695] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.298705] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.298710] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.298859] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.298869] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.298874] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.299083] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.300117] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.300179] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.300206] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.300223] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.300233] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.301468] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.301490] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.301748] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.301781] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.302363] parse_throttle_dt_data: Num cap clks = 6
[ 1.302369] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.302385] parse_throttle_dt_data: clk=gpu type=4
[ 1.302450] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.302471] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.302494] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.302497] parse_throttle_dt_data: clk=emc type=3
[ 1.302971] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.303135] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.303358] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.304378] FAN dev name: pwm-fan
[ 1.304443] FAN:gpio request success.
[ 1.304524] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.304855] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.305079] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.305088] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.305187] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.305192] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.305196] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.305201] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.305205] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.305209] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.305212] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.305216] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.305220] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.305224] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.305999] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.306467] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.307599] device-mapper: uevent: version 1.0.3
[ 1.308192] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.310186] tegradc tegradc.0: unblank
[ 1.313635] tegra210-cpufreq cpufreq: probe()…completed
[ 1.314617] sdhci: Secure Digital Host Controller Interface driver
[ 1.314618] sdhci: Copyright(c) Pierre Ossman
[ 1.314620] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.315184] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.315629] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.315753] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.320710] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.321323] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.322560] usbcore: registered new interface driver usbhid
[ 1.322562] usbhid: USB HID core driver
[ 1.324899] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.325085] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.327114] nvpmodel: initialized successfully
[ 1.328158] usbcore: registered new interface driver snd-usb-audio
[ 1.328214] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.328218] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.328237] iommu: Adding device snd-soc-dummy to group 36
[ 1.341281] OPE platform probe
[ 1.341369] OPE platform probe successful
[ 1.341395] OPE platform probe
[ 1.341476] OPE platform probe successful
[ 1.353664] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.353724] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.354612] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.354724] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.354731] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.362555] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.368980] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.369105] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.369228] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.369388] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.369507] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.369640] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.369759] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.369877] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.369995] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.370113] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.382056] u32 classifier
[ 1.382058] Actions configured
[ 1.382128] Initializing XFRM netlink socket
[ 1.382885] NET: Registered protocol family 10
[ 1.383602] NET: Registered protocol family 17
[ 1.383614] NET: Registered protocol family 15
[ 1.383692] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.383740] Bluetooth: RFCOMM socket layer initialized
[ 1.383750] Bluetooth: RFCOMM ver 1.11
[ 1.383754] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.383758] Bluetooth: HIDP socket layer initialized
[ 1.383776] 9pnet: Installing 9P2000 support
[ 1.383814] Key type dns_resolver registered
[ 1.384282] Registered cp15_barrier emulation handler
[ 1.384289] Registered setend emulation handler
[ 1.385395] registered taskstats version 1
[ 1.386018] Adding domain ve2-pd to PM domain host1x-pd
[ 1.386258] Adding domain ve-pd to PM domain host1x-pd
[ 1.388337] isp 54600000.isp: initialized
[ 1.389274] isp 54680000.isp: initialized
[ 1.389318] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.389320] Extcon AUX1(HDMI) enable
[ 1.390276] tegradc tegradc.0: sync windows ret = 250
[ 1.398914] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 1.398918] Extcon HDMI: HPD enabled
[ 1.398932] tegradc tegradc.0: hdmi: plugged
[ 1.399855] last reset is due to software reset
[ 1.399859] KERNEL: PMC reset status reg: 0x3
[ 1.399937] BL: PMC reset status reg: 0x3
[ 1.399939] BL: PMIC poweroff Event Recorder: 0x0
[ 1.401403] clk_cbus_recalc_rate: no gbus parent
[ 1.401409] clk_cbus_round_rate: no gbus parent
[ 1.401411] clk_cbus_round_rate: no gbus parent
[ 1.401420] clk_cbus_recalc_rate: no gbus parent
[ 1.401524] clk_cbus_recalc_rate: no gbus parent
[ 1.401528] clk_cbus_round_rate: no gbus parent
[ 1.401530] clk_cbus_round_rate: no gbus parent
[ 1.401534] clk_cbus_recalc_rate: no gbus parent
[ 1.402211] tegra_dvfs: GPU-cap: registered
[ 1.402265] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.402268] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.402270] tegra dvfs: vdd-gpu: nominal 1078mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.403707] tegra_dvfs: vdd-gpu-vts: registered
[ 1.404454] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.405117] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.405685] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.436023] tegra_rtc 7000e000.rtc: setting system clock to 2020-05-06 18:00:39 UTC (1588788039)
[ 1.437079] vi 54080000.vi: vi_probe: ++
[ 1.440612] vi 54080000.vi: initialized
[ 1.442632] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.442650] vi 54080000.vi: subdev imx219 6-0010 bound
[ 1.444905] Disable partitions left on by BL
[ 1.444909] disb
[ 1.444957] bwmgr: missing cdev-type property
[ 1.445054] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.445060] DRAM derating cdev registered.
[ 1.446088] vdd-fan: disabling
[ 1.446092] vdd-usb-vbus: disabling
[ 1.446094] vdd-usb-vbus2: disabling
[ 1.446104] avdd-io-edp-1v05: disabling
[ 1.446200] ALSA device list:
[ 1.446203] #0: tegra-hda at 0x70038000 irq 83
[ 1.446206] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.449360] Freeing unused kernel memory: 8576K
[ 1.450948] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.468181] L4T-INITRD Build DATE: Wed May 6 18:00:39 UTC 2020
[ 1.472569] Root device found: mmcblk0p1
[ 1.489031] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.489037] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.489040] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.489043] usb 1-2: Manufacturer: Generic
[ 1.492548] hub 1-2:1.0: USB hub found
[ 1.493626] hub 1-2:1.0: 4 ports detected
[ 1.558239] mmc0: hw tuning done …
[ 1.558272] mmc0: new ultra high speed SDR104 SDXC card at address 0001
[ 1.558592] mmcblk0: mmc0:0001 GC2QT 59.6 GiB
[ 1.562160] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 1.622458] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 1.645079] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 1.645083] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.677196] Found dev node: /dev/mmcblk0p1
[ 1.728230] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.729052] Rootfs mounted over mmcblk0p1
[ 1.748556] Switching from initrd to actual rootfs
[ 1.786479] usb 1-2.1: new low-speed USB device number 4 using tegra-xusb
[ 1.810311] usb 1-2.1: New USB device found, idVendor=0461, idProduct=4dfb
[ 1.810316] usb 1-2.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.810320] usb 1-2.1: Product: USB Optical Mouse
[ 1.813773] input: USB Optical Mouse as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:0461:4DFB.0001/input/input2
[ 1.814052] hid-generic 0003:0461:4DFB.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-70090000.xusb-2.1/input0
[ 1.894484] usb 1-2.3: new low-speed USB device number 5 using tegra-xusb
[ 1.920933] usb 1-2.3: New USB device found, idVendor=046d, idProduct=c31c
[ 1.920938] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.920941] usb 1-2.3: Product: USB Keyboard
[ 1.920943] usb 1-2.3: Manufacturer: Logitech
[ 1.927219] input: Logitech USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:046D:C31C.0002/input/input3
[ 1.952756] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.965488] cgroup: cgroup2: unknown option “nsdelegate”
[ 1.986991] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-70090000.xusb-2.3/input0
[ 1.987583] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.988437] systemd[1]: Detected architecture arm64.
[ 1.995436] input: Logitech USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.1/0003:046D:C31C.0003/input/input4
[ 2.014382] systemd[1]: Set hostname to .
[ 2.054636] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-70090000.xusb-2.3/input1
[ 2.115401] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.115411] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.259214] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.259246] systemd[1]: Reached target User and Group Name Lookups.
[ 2.259489] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.261505] systemd[1]: Created slice System Slice.
[ 2.261563] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.261732] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.261973] systemd[1]: Listening on Journal Socket.
[ 2.264272] systemd[1]: Mounting POSIX Message Queue File System…
[ 2.303491] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.406882] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.725882] Adding 4194300k swap on /var/swapfile. Priority:-1 extents:19 across:13328380k SS
[ 2.764119] systemd-journald[1959]: Received request to flush runtime journal from PID 1
[ 3.284959] using random self ethernet address
[ 3.289672] using random host ethernet address
[ 3.328698] Mass Storage Function, version: 2009/09/11
[ 3.328704] LUN: removable file: (no medium)
[ 3.337770] using random self ethernet address
[ 3.342480] using random host ethernet address
[ 3.369641] rndis0: HOST MAC 2a:36:d7:bc:53:70
[ 3.369794] rndis0: MAC 2a:36:d7:bc:53:71
[ 3.374904] usb0: HOST MAC 2a:36:d7:bc:53:72
[ 3.375037] usb0: MAC 2a:36:d7:bc:53:73
[ 3.375059] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 3.375632] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 3.375822] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 3.375851] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.376134] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.376295] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 3.376811] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 3.376828] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.377038] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.381710] l4tbr0: port 1(rndis0) entered blocking state
[ 3.381716] l4tbr0: port 1(rndis0) entered disabled state
[ 3.382117] device rndis0 entered promiscuous mode
[ 3.393946] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 3.511085] l4tbr0: port 2(usb0) entered blocking state
[ 3.511090] l4tbr0: port 2(usb0) entered disabled state
[ 3.511475] device usb0 entered promiscuous mode
[ 3.519538] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 3.675941] random: crng init done
[ 3.679385] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.573156] Intel(R) Wireless WiFi driver for Linux
[ 4.573161] Copyright(c) 2003- 2015 Intel Corporation
[ 4.573390] iwlwifi 0000:01:00.0: enabling device (0000 → 0002)
[ 4.602427] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 4.612008] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.037112] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.038272] eth0: 0xffffff800a37e000, 00:04:4b:e6:01:34, IRQ 404
[ 5.114621] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.235006] zram: Added device: zram0
[ 5.238027] zram: Added device: zram1
[ 5.241205] zram: Added device: zram2
[ 5.243103] zram: Added device: zram3
[ 5.286145] zram0: detected capacity change from 0 to 518569984
[ 5.294254] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.294262] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.337082] Adding 506412k swap on /dev/zram0. Priority:5 extents:1 across:506412k SS
[ 5.383297] zram1: detected capacity change from 0 to 518569984
[ 5.404976] Adding 506412k swap on /dev/zram1. Priority:5 extents:1 across:506412k SS
[ 5.413649] zram2: detected capacity change from 0 to 518569984
[ 5.446097] Adding 506412k swap on /dev/zram2. Priority:5 extents:1 across:506412k SS
[ 5.450128] zram3: detected capacity change from 0 to 518569984
[ 5.462937] Adding 506412k swap on /dev/zram3. Priority:5 extents:1 across:506412k SS
[ 5.563284] usbcore: registered new interface driver btusb
[ 5.566622] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 5.567618] Bluetooth: hci0: Device revision is 16
[ 5.567622] Bluetooth: hci0: Secure boot is enabled
[ 5.567625] Bluetooth: hci0: OTP lock is enabled
[ 5.567627] Bluetooth: hci0: API lock is enabled
[ 5.567629] Bluetooth: hci0: Debug lock is disabled
[ 5.567632] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 5.597166] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 5.615596] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.650072] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.650080] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.650084] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.650087] usb 2-1: Manufacturer: Generic
[ 5.655611] hub 2-1:1.0: USB hub found
[ 5.657046] hub 2-1:1.0: 4 ports detected
[ 5.682645] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 5.692623] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.818457] usb 2-1: usb_suspend_both: status 0
[ 5.818648] usb usb2: usb_suspend_both: status 0
[ 6.032163] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 6.042163] iwlwifi 0000:01:00.0: Falling back to user helper
[ 6.058323] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 6.066827] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.066837] Bluetooth: BNEP socket layer initialized
[ 6.068379] iwlwifi 0000:01:00.0: Falling back to user helper
[ 6.105423] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 6.181701] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 6.184144] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.184775] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.308715] ieee80211 phy0: Selected rate control algorithm ‘iwl-mvm-rs’
[ 6.309865] thermal thermal_zone6: failed to read out thermal zone (-5)
[ 6.316696] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
[ 6.368623] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.370748] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.371193] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.489072] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.489513] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.547927] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.689015] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.090185] tegradc tegradc.0: blank - powerdown
[ 7.138222] Bluetooth: hci0: Waiting for firmware download to complete
[ 7.138599] Bluetooth: hci0: Firmware loaded in 1538498 usecs
[ 7.138760] Bluetooth: hci0: Waiting for device to boot
[ 7.150608] Bluetooth: hci0: Device booted in 11648 usecs
[ 7.153191] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 7.155085] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 7.155087] Extcon AUX1(HDMI) disable
[ 7.155629] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 7.175451] tegradc tegradc.0: unblank
[ 7.188987] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 7.189063] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 7.190079] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 7.190087] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 7.224856] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 7.224859] Extcon AUX1(HDMI) enable
[ 7.230819] tegradc tegradc.0: unblank
[ 7.231142] tegradc tegradc.1: blank - powerdown
[ 53.799345] tegradc tegradc.0: blank - powerdown
[ 53.860917] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 53.860920] Extcon AUX1(HDMI) disable
[ 53.877570] tegradc tegradc.1: blank - powerdown
[ 54.009982] tegradc tegradc.0: blank - powerdown
[ 54.010005] tegradc tegradc.0: unblank
[ 54.016362] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 54.016452] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 54.017485] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 54.017492] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 54.054450] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 54.054453] Extcon AUX1(HDMI) enable
[ 54.061821] tegradc tegradc.0: unblank
[ 54.061840] tegradc tegradc.1: blank - powerdown
[ 54.648620] wlan0: authenticate with 8c:59:c3:b7:01:cc
[ 54.658679] wlan0: send auth to 8c:59:c3:b7:01:cc (try 1/3)
[ 54.663736] wlan0: authenticated
[ 54.667720] wlan0: associate with 8c:59:c3:b7:01:cc (try 1/3)
[ 54.668906] wlan0: RX AssocResp from 8c:59:c3:b7:01:cc (capab=0x11 status=0 aid=2)
[ 54.672578] wlan0: associated
[ 54.684759] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 54.857174] wlan0: Limiting TX power to 23 (23 - 0) dBm as advertised by 8c:59:c3:b7:01:cc
[ 58.384326] fuse init (API version 7.26)
[ 58.502575] tegradc tegradc.0: unblank
[ 58.502732] tegradc tegradc.1: blank - powerdown
[ 79.287149] fence timeout on [ffffffc0793d6480] after 1500ms
[ 79.287216] fence timeout on [ffffffc0793d6300] after 1500ms
[ 79.287239] name=[nvhost_sync:24], current value=0 waiting value=1
[ 79.287281] ---- mlocks ----
[ 79.287304] name=[nvhost_sync:25], current value=0 waiting value=1
[ 79.287339] ---- mlocks ----
[ 79.287373] ---- syncpts ----
[ 79.287428] ---- syncpts ----
[ 79.287450] id 1 (disp0_a) min 253 max 253 refs 1 (previous client : )
[ 79.287496] id 2 (disp0_b) min 3 max 3 refs 1 (previous client : )
[ 79.287538] id 3 (disp0_c) min 3 max 3 refs 1 (previous client : )
[ 79.287579] id 4 (disp0_d) min 3 max 3 refs 1 (previous client : )
[ 79.287636] id 9 (gm20b_507) min 498 max 498 refs 1 (previous client : )
[ 79.287683] id 11 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 79.287730] id 12 (gm20b_505) min 546 max 546 refs 1 (previous client : gm20b_505)
[ 79.287774] id 13 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 79.287821] id 14 (gm20b_503) min 16254 max 16254 refs 1 (previous client : )
[ 79.287864] id 15 (gm20b_502) min 16 max 16 refs 1 (previous client : )
[ 79.287913] id 16 (gm20b_501) min 1000 max 1000 refs 1 (previous client : gm20b_501)
[ 79.287978] id 24 (54680000.isp_0) min 0 max 3 refs 4 (previous client : )
[ 79.288020] id 25 (54680000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 79.288064] id 26 (vblank0) min 1512 max -6 refs 1 (previous client : )
[ 79.288112] id 28 (54680000.isp_2) min 7 max 15 refs 10 (previous client : )
[ 79.288154] id 29 (54680000.isp_3) min 0 max 3 refs 4 (previous client : )
[ 79.288196] id 30 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 79.288241] id 31 (gm20b_499) min 686 max 686 refs 1 (previous client : )
[ 79.288286] id 32 (gm20b_498) min 4 max 4 refs 1 (previous client : )
[ 79.288327] id 33 (gm20b_497) min 2 max 2 refs 1 (previous client : )
[ 79.288368] id 34 (gm20b_496) min 2 max 2 refs 1 (previous client : )
[ 79.288410] id 35 (gm20b_495) min 4 max 4 refs 1 (previous client : )
[ 79.288457] id 37 (54080000.vi_1) min 0 max 3 refs 4 (previous client : 54080000.vi_1)
[ 79.288501] id 38 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 79.288552] id 41 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 79.288599] id 44 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 79.288641] id 45 (gm20b_493) min 8 max 8 refs 1 (previous client : )
[ 79.288682] id 46 (gm20b_492) min 6 max 6 refs 1 (previous client : )
[ 79.288723] id 47 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 79.288767] id 48 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 79.288808] id 49 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 79.289292] ---- channels ----
[ 79.289304] id 1 (disp0_a) min 253 max 253 refs 1 (previous client : )
[ 79.289338] id 2 (disp0_b) min 3 max 3 refs 1 (previous client : )
[ 79.289378]
channel 0 - 54600000.isp
[ 79.289387] id 3 (disp0_c) min 3 max 3 refs 1 (previous client : )
[ 79.289419] id 4 (disp0_d) min 3 max 3 refs 1 (previous client : )
[ 79.289430] 0-54600000.isp (1):
[ 79.289453] inactive
[ 79.289485] id 9 (gm20b_507) min 498 max 498 refs 1 (previous client : )
[ 79.289495]
channel 1 - 54680000.isp
[ 79.289541] 1-54680000.isp (18):
[ 79.289544] id 11 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 79.289581] id 12 (gm20b_505) min 546 max 546 refs 1 (previous client : gm20b_505)
[ 79.289591] active class 01, offset 0050, val 00000018
[ 79.289621] DMAPUT 00000198, DMAGET 00000110, DMACTL 00000000
[ 79.289632] id 13 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 79.289662] CBREAD 00000018, CBSTAT 00010050
[ 79.289672] id 14 (gm20b_503) min 16254 max 16254 refs 1 (previous client : )
[ 79.289707] id 15 (gm20b_502) min 16 max 16 refs 1 (previous client : )
[ 79.289738]
ffffffc0826e4c00: JOB, syncpt_id=24, syncpt_val=1, first_get=00000090, timeout=10000, num_slots=3, num_handles=1
[ 79.289755] id 16 (gm20b_501) min 1000 max 1000 refs 1 (previous client : gm20b_501)
[ 79.289811] id 24 (54680000.isp_0) min 0 max 3 refs 4 (previous client : )
[ 79.289846] GATHER at ffc98000+4c48, 8 words
[ 79.289854] id 25 (54680000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 79.289890] 20000001
[ 79.289893] id 26 (vblank0) min 1512 max -6 refs 1 (previous client : )
[ 79.289916] 00000418
[ 79.289935] id 28 (54680000.isp_2) min 7 max 15 refs 10 (previous client : )
[ 79.289959] 20000001
[ 79.289969] id 29 (54680000.isp_3) min 0 max 3 refs 4 (previous client : )
[ 79.290002] 00000519
[ 79.290005] id 30 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 79.290041] 20000001
[ 79.290043] id 31 (gm20b_499) min 686 max 686 refs 1 (previous client : )
[ 79.290077] 0000061d
[ 79.290079] id 32 (gm20b_498) min 4 max 4 refs 1 (previous client : )
[ 79.290110] 200c0001
[ 79.290112] id 33 (gm20b_497) min 2 max 2 refs 1 (previous client : )
[ 79.290143] 00000005
[ 79.290145] id 34 (gm20b_496) min 2 max 2 refs 1 (previous client : )
[ 79.290177] id 35 (gm20b_495) min 4 max 4 refs 1 (previous client : )
[ 79.290215] id 37 (54080000.vi_1) min 0 max 3 refs 4 (previous client : 54080000.vi_1)
[ 79.290226] GATHER at ffc98000+4c68, 2 words
[ 79.290243] 20000001
[ 79.290269] id 38 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 79.290277] 0000001c
[ 79.290334] id 41 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 79.290373] id 44 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 79.290381]
channel 2 - 54080000.vi
[ 79.290809] 2-54080000.vi (13):
[ 79.290855] active class 01, offset 0050, val 00000025
[ 79.290895] DMAPUT 00000100, DMAGET 00000100, DMACTL 00000000
[ 79.290928] CBREAD 00000025, CBSTAT 00010050
[ 79.290993]
ffffffc0826e4800: JOB, syncpt_id=37, syncpt_val=1, first_get=00000018, timeout=10000, num_slots=7, num_handles=1
[ 79.291058] GATHER at ffc18000+0000, 35 words
[ 79.291071] 10620001
[ 79.291083] 0000001f
[ 79.291094] 10630002
[ 79.291105] 00000000
[ 79.291114] 00000000
[ 79.291125] 103a0001
[ 79.291134] 10100010
[ 79.291144] 103c0001
[ 79.291154] 10101010
[ 79.291164] 10420001
[ 79.291173] 00000001
[ 79.291182] 10430006
[ 79.291190] 00000000
[ 79.291199] 001c984c
[ 79.291207] 00000000
[ 79.291216] 00000000
[ 79.291225] 00000000
[ 79.291234] 00000000
[ 79.291243] 10590001
[ 79.291252] 00000003
[ 79.291260] 120e0006
[ 79.291270] 007f0015
[ 79.291295] 080301f0
[ 79.291319] 00000000
[ 79.291336] 00140000
[ 79.291354] 0000f005
[ 79.291370] 00000000
[ 79.291389] 12420001
[ 79.291407] 00000001
[ 79.291426] 124b0003
[ 79.291446] 00000000
[ 79.291466] 00000000
[ 79.291488] 00000000
[ 79.291511] 128b0001
[ 79.291532] 00000000
[ 79.291579] GATHER at ffc18000+008c, 3 words
[ 79.291600] 304e0005
[ 79.291623] 00000007
[ 79.291647] 0000001c
[ 79.291695] GATHER at ffc18000+0098, 17 words
[ 79.291728] 10430006
[ 79.291753] 00200004
[ 79.291788] 001c984c
[ 79.291813] 00000000
[ 79.291841] 09a00cc0
[ 79.291879] 00000ff0
[ 79.291904] 0000002b
[ 79.291930] 124b0003
[ 79.291955] 00000000
[ 79.291981] 00000000
[ 79.292013] 00000008
[ 79.292041] 20000001
[ 79.292065] 00001d25
[ 79.292091] 20000001
[ 79.292114] 00000529
[ 79.292140] 20410001
[ 79.292163] 00000001
[ 79.292215] GATHER at ffc18000+00dc, 2 words
[ 79.292239] 20000001
[ 79.292265] 00000026
[ 79.292341]
---- host general irq ----
[ 79.292367] sync_hintmask_ext = 0xc0000000
[ 79.292391] sync_hintmask = 0x80000000
[ 79.292429] sync_intc0mask = 0x00000001
[ 79.292454] sync_intmask = 0x00000011
[ 79.292480]
---- host syncpt irq mask ----
[ 79.292513] syncpt_thresh_int_mask(0) = 0x00000001
[ 79.292538] syncpt_thresh_int_mask(1) = 0x05050000
[ 79.292562] syncpt_thresh_int_mask(2) = 0x00041400
[ 79.292586] syncpt_thresh_int_mask(3) = 0x00000000
[ 79.292610] syncpt_thresh_int_mask(4) = 0x00000000
[ 79.292634] syncpt_thresh_int_mask(5) = 0x00000000
[ 79.292658] syncpt_thresh_int_mask(6) = 0x00000000
[ 79.292682] syncpt_thresh_int_mask(7) = 0x00000000
[ 79.292706] syncpt_thresh_int_mask(8) = 0x00000000
[ 79.292730] syncpt_thresh_int_mask(9) = 0x00000000
[ 79.292754] syncpt_thresh_int_mask(10) = 0x00000000
[ 79.292778] syncpt_thresh_int_mask(11) = 0x00000000
[ 79.292802]
---- host syncpt irq status ----
[ 79.292827] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 79.292851] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 79.292875] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 79.292900] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 79.292923] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 79.292947] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 79.292974]
---- host syncpt thresh ----
[ 79.292999] syncpt_int_thresh_thresh_0(0) = 1
[ 79.293045] syncpt_int_thresh_thresh_0(24) = 1
[ 79.293068] syncpt_int_thresh_thresh_0(25) = 1
[ 79.293094] syncpt_int_thresh_thresh_0(28) = 8
[ 79.293118] syncpt_int_thresh_thresh_0(29) = 1
[ 79.293149] syncpt_int_thresh_thresh_0(37) = 1
[ 79.293166] syncpt_int_thresh_thresh_0(38) = 3
[ 79.293184] syncpt_int_thresh_thresh_0(41) = 1
[ 79.294921] id 45 (gm20b_493) min 8 max 8 refs 1 (previous client : )
[ 79.294937] id 46 (gm20b_492) min 6 max 6 refs 1 (previous client : )
[ 79.294947] id 47 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 79.294959] id 48 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 79.294968] id 49 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 79.295122] ---- channels ----
[ 79.295142]
[ 79.295156] 0-54600000.isp (1):
[ 79.295163] inactive
[ 79.295172]
[ 79.295183] 1-54680000.isp (18):
[ 79.295195] active class 01, offset 0050, val 00000018
[ 79.295204] DMAPUT 00000198, DMAGET 00000110, DMACTL 00000000
[ 79.295213] CBREAD 00000018, CBSTAT 00010050
[ 79.295230]
[ 79.295245] GATHER at ffc98000+4c48, 8 words
[ 79.295254] 20000001
[ 79.295263] 00000418
[ 79.295270] 20000001
[ 79.295277] 00000519
[ 79.295284] 20000001
[ 79.295292] 0000061d
[ 79.295299] 200c0001
[ 79.295306] 00000005
[ 79.295326] GATHER at ffc98000+4c68, 2 words
[ 79.295333] 20000001
[ 79.295341] 0000001c
[ 79.295366]
[ 79.295379] 2-54080000.vi (13):
[ 79.295391] active class 01, offset 0050, val 00000025
[ 79.295401] DMAPUT 00000100, DMAGET 00000100, DMACTL 00000000
[ 79.295411] CBREAD 00000025, CBSTAT 00010050
[ 79.295428]
[ 79.295442] GATHER at ffc18000+0000, 35 words
[ 79.295450] 10620001
[ 79.295459] 0000001f
[ 79.295467] 10630002
[ 79.295476] 00000000
[ 79.295483] 00000000
[ 79.295507] 103a0001
[ 79.295528] 10100010
[ 79.295554] 103c0001
[ 79.295577] 10101010
[ 79.295602] 10420001
[ 79.295624] 00000001
[ 79.295650] 10430006
[ 79.295676] 00000000
[ 79.295701] 001c984c
[ 79.295718] 00000000
[ 79.295735] 00000000
[ 79.295752] 00000000
[ 79.295769] 00000000
[ 79.295785] 10590001
[ 79.295803] 00000003
[ 79.295828] 120e0006
[ 79.295845] 007f0015
[ 79.295862] 080301f0
[ 79.295887] 00000000
[ 79.295904] 00140000
[ 79.295921] 0000f005
[ 79.295938] 00000000
[ 79.295955] 12420001
[ 79.295972] 00000001
[ 79.295990] 124b0003
[ 79.296006] 00000000
[ 79.296033] 00000000
[ 79.296054] 00000000
[ 79.296089] 128b0001
[ 79.296105] 00000000
[ 79.296157] GATHER at ffc18000+008c, 3 words
[ 79.296173] 304e0005
[ 79.296189] 00000007
[ 79.296212] 0000001c
[ 79.296254] GATHER at ffc18000+0098, 17 words
[ 79.296278] 10430006
[ 79.296296] 00200004
[ 79.296317] 001c984c
[ 79.296335] 00000000
[ 79.296350] 09a00cc0
[ 79.296367] 00000ff0
[ 79.296382] 0000002b
[ 79.296399] 124b0003
[ 79.296415] 00000000
[ 79.296431] 00000000
[ 79.296447] 00000008
[ 79.296463] 20000001
[ 79.296479] 00001d25
[ 79.296496] 20000001
[ 79.296511] 00000529
[ 79.296528] 20410001
[ 79.296544] 00000001
[ 79.296578] GATHER at ffc18000+00dc, 2 words
[ 79.296603] 20000001
[ 79.296619] 00000026
[ 79.296670]
[ 79.296687] sync_hintmask_ext = 0xc0000000
[ 79.296703] sync_hintmask = 0x80000000
[ 79.296719] sync_intc0mask = 0x00000001
[ 79.296735] sync_intmask = 0x00000011
[ 79.296752]
[ 79.296768] syncpt_thresh_int_mask(0) = 0x00000001
[ 79.296784] syncpt_thresh_int_mask(1) = 0x05050000
[ 79.296800] syncpt_thresh_int_mask(2) = 0x00041400
[ 79.296816] syncpt_thresh_int_mask(3) = 0x00000000
[ 79.296834] syncpt_thresh_int_mask(4) = 0x00000000
[ 79.296850] syncpt_thresh_int_mask(5) = 0x00000000
[ 79.296866] syncpt_thresh_int_mask(6) = 0x00000000
[ 79.296892] syncpt_thresh_int_mask(7) = 0x00000000
[ 79.296909] syncpt_thresh_int_mask(8) = 0x00000000
[ 79.296934] syncpt_thresh_int_mask(9) = 0x00000000
[ 79.296952] syncpt_thresh_int_mask(10) = 0x00000000
[ 79.296968] syncpt_thresh_int_mask(11) = 0x00000000
[ 79.296985]
[ 79.297010] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 79.297026] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 79.297043] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 79.297069] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 79.297085] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 79.297103] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 79.297117]
[ 79.297129] syncpt_int_thresh_thresh_0(0) = 1
[ 79.297160] syncpt_int_thresh_thresh_0(24) = 1
[ 79.297171] syncpt_int_thresh_thresh_0(25) = 1
[ 79.297184] syncpt_int_thresh_thresh_0(28) = 8
[ 79.297195] syncpt_int_thresh_thresh_0(29) = 1
[ 79.297211] syncpt_int_thresh_thresh_0(37) = 1
[ 79.297222] syncpt_int_thresh_thresh_0(38) = 3
[ 79.297234] syncpt_int_thresh_thresh_0(41) = 1
[ 79.318509] fence timeout on [ffffffc0793d6900] after 1500ms
[ 79.318516] name=[nvhost_sync:41], current value=0 waiting value=1
[ 79.318520] ---- mlocks ----
[ 79.318532] ---- syncpts ----
[ 79.318538] id 1 (disp0_a) min 253 max 253 refs 1 (previous client : )
[ 79.318542] id 2 (disp0_b) min 3 max 3 refs 1 (previous client : )
[ 79.318545] id 3 (disp0_c) min 3 max 3 refs 1 (previous client : )
[ 79.318549] id 4 (disp0_d) min 3 max 3 refs 1 (previous client : )
[ 79.318555] id 9 (gm20b_507) min 498 max 498 refs 1 (previous client : )
[ 79.318559] id 11 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 79.318563] id 12 (gm20b_505) min 546 max 546 refs 1 (previous client : gm20b_505)
[ 79.318567] id 13 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 79.318570] id 14 (gm20b_503) min 16254 max 16254 refs 1 (previous client : )
[ 79.318573] id 15 (gm20b_502) min 16 max 16 refs 1 (previous client : )
[ 79.318578] id 16 (gm20b_501) min 1000 max 1000 refs 1 (previous client : gm20b_501)
[ 79.318585] id 24 (54680000.isp_0) min 0 max 3 refs 4 (previous client : )
[ 79.318589] id 25 (54680000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 79.318592] id 26 (vblank0) min 1514 max -6 refs 1 (previous client : )
[ 79.318596] id 28 (54680000.isp_2) min 7 max 15 refs 10 (previous client : )
[ 79.318600] id 29 (54680000.isp_3) min 0 max 3 refs 4 (previous client : )
[ 79.318603] id 30 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 79.318607] id 31 (gm20b_499) min 686 max 686 refs 1 (previous client : )
[ 79.318610] id 32 (gm20b_498) min 4 max 4 refs 1 (previous client : )
[ 79.318615] id 33 (gm20b_497) min 2 max 2 refs 1 (previous client : )
[ 79.318618] id 34 (gm20b_496) min 2 max 2 refs 1 (previous client : )
[ 79.318622] id 35 (gm20b_495) min 4 max 4 refs 1 (previous client : )
[ 79.318626] id 37 (54080000.vi_1) min 0 max 3 refs 4 (previous client : 54080000.vi_1)
[ 79.318630] id 38 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 79.318634] id 41 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 79.318639] id 44 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 79.318642] id 45 (gm20b_493) min 8 max 8 refs 1 (previous client : )
[ 79.318645] id 46 (gm20b_492) min 6 max 6 refs 1 (previous client : )
[ 79.318648] id 47 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 79.318652] id 48 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 79.318655] id 49 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 79.318741] ---- channels ----
[ 79.318747]
[ 79.318753] 0-54600000.isp (1):
[ 79.318755] inactive
[ 79.318759]
[ 79.318764] 1-54680000.isp (18):
[ 79.318768] active class 01, offset 0050, val 00000018
[ 79.318771] DMAPUT 00000198, DMAGET 00000110, DMACTL 00000000
[ 79.318773] CBREAD 00000018, CBSTAT 00010050
[ 79.318778]
[ 79.318783] GATHER at ffc98000+4c48, 8 words
[ 79.318785] 20000001
[ 79.318787] 00000418
[ 79.318789] 20000001
[ 79.318791] 00000519
[ 79.318793] 20000001
[ 79.318795] 0000061d
[ 79.318797] 200c0001
[ 79.318799] 00000005
[ 79.318804] GATHER at ffc98000+4c68, 2 words
[ 79.318806] 20000001
[ 79.318808] 0000001c
[ 79.318815]
[ 79.318820] 2-54080000.vi (13):
[ 79.318823] active class 01, offset 0050, val 00000025
[ 79.318826] DMAPUT 00000100, DMAGET 00000100, DMACTL 00000000
[ 79.318828] CBREAD 00000025, CBSTAT 00010050
[ 79.318832]
[ 79.318835] GATHER at ffc18000+0000, 35 words
[ 79.318837] 10620001
[ 79.318839] 0000001f
[ 79.318841] 10630002
[ 79.318843] 00000000
[ 79.318845] 00000000
[ 79.318847] 103a0001
[ 79.318849] 10100010
[ 79.318851] 103c0001
[ 79.318853] 10101010
[ 79.318855] 10420001
[ 79.318857] 00000001
[ 79.318859] 10430006
[ 79.318861] 00000000
[ 79.318864] 001c984c
[ 79.318866] 00000000
[ 79.318868] 00000000
[ 79.318870] 00000000
[ 79.318872] 00000000
[ 79.318874] 10590001
[ 79.318876] 00000003
[ 79.318878] 120e0006
[ 79.318880] 007f0015
[ 79.318882] 080301f0
[ 79.318884] 00000000
[ 79.318886] 00140000
[ 79.318888] 0000f005
[ 79.318890] 00000000
[ 79.318892] 12420001
[ 79.318894] 00000001
[ 79.318896] 124b0003
[ 79.318898] 00000000
[ 79.318900] 00000000
[ 79.318902] 00000000
[ 79.318904] 128b0001
[ 79.318906] 00000000
[ 79.318911] GATHER at ffc18000+008c, 3 words
[ 79.318913] 304e0005
[ 79.318915] 00000007
[ 79.318917] 0000001c
[ 79.318922] GATHER at ffc18000+0098, 17 words
[ 79.318924] 10430006
[ 79.318926] 00200004
[ 79.318928] 001c984c
[ 79.318930] 00000000
[ 79.318932] 09a00cc0
[ 79.318934] 00000ff0
[ 79.318935] 0000002b
[ 79.318937] 124b0003
[ 79.318939] 00000000
[ 79.318941] 00000000
[ 79.318943] 00000008
[ 79.318945] 20000001
[ 79.318949] 00001d25
[ 79.318951] 20000001
[ 79.318953] 00000529
[ 79.318955] 20410001
[ 79.318956] 00000001
[ 79.318961] GATHER at ffc18000+00dc, 2 words
[ 79.318963] 20000001
[ 79.318965] 00000026
[ 79.318970]
[ 79.318973] sync_hintmask_ext = 0xc0000000
[ 79.318976] sync_hintmask = 0x80000000
[ 79.318978] sync_intc0mask = 0x00000001
[ 79.318981] sync_intmask = 0x00000011
[ 79.318983]
[ 79.318985] syncpt_thresh_int_mask(0) = 0x00000001
[ 79.318988] syncpt_thresh_int_mask(1) = 0x05050000
[ 79.318991] syncpt_thresh_int_mask(2) = 0x00041400
[ 79.318993] syncpt_thresh_int_mask(3) = 0x00000000
[ 79.318996] syncpt_thresh_int_mask(4) = 0x00000000
[ 79.318999] syncpt_thresh_int_mask(5) = 0x00000000
[ 79.319001] syncpt_thresh_int_mask(6) = 0x00000000
[ 79.319004] syncpt_thresh_int_mask(7) = 0x00000000
[ 79.319006] syncpt_thresh_int_mask(8) = 0x00000000
[ 79.319009] syncpt_thresh_int_mask(9) = 0x00000000
[ 79.319011] syncpt_thresh_int_mask(10) = 0x00000000
[ 79.319014] syncpt_thresh_int_mask(11) = 0x00000000
[ 79.319016]
[ 79.319019] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 79.319022] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 79.319024] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 79.319027] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 79.319029] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 79.319032] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 79.319034]
[ 79.319039] syncpt_int_thresh_thresh_0(0) = 1
[ 79.319053] syncpt_int_thresh_thresh_0(24) = 1
[ 79.319056] syncpt_int_thresh_thresh_0(25) = 1
[ 79.319060] syncpt_int_thresh_thresh_0(28) = 8
[ 79.319063] syncpt_int_thresh_thresh_0(29) = 1
[ 79.319069] syncpt_int_thresh_thresh_0(37) = 1
[ 79.319072] syncpt_int_thresh_thresh_0(38) = 3
[ 79.319076] syncpt_int_thresh_thresh_0(41) = 1
[ 80.822442] fence timeout on [ffffffc0793d6780] after 1500ms
[ 80.822451] name=[nvhost_sync:25], current value=0 waiting value=2
[ 80.822457] ---- mlocks ----
[ 80.822469] ---- syncpts ----
[ 80.822475] id 1 (disp0_a) min 269 max 270 refs 1 (previous client : )
[ 80.822479] id 2 (disp0_b) min 3 max 3 refs 1 (previous client : )
[ 80.822483] id 3 (disp0_c) min 3 max 3 refs 1 (previous client : )
[ 80.822486] id 4 (disp0_d) min 3 max 3 refs 1 (previous client : )
[ 80.822491] id 9 (gm20b_507) min 498 max 498 refs 1 (previous client : )
[ 80.822495] id 11 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 80.822499] id 12 (gm20b_505) min 546 max 546 refs 1 (previous client : gm20b_505)
[ 80.822503] id 13 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 80.822506] id 14 (gm20b_503) min 16612 max 16612 refs 1 (previous client : )
[ 80.822509] id 15 (gm20b_502) min 16 max 16 refs 1 (previous client : )
[ 80.822513] id 16 (gm20b_501) min 1084 max 1086 refs 1 (previous client : gm20b_501)
[ 80.822521] id 24 (54680000.isp_0) min 0 max 4 refs 5 (previous client : )
[ 80.822524] id 25 (54680000.isp_1) min 0 max 4 refs 5 (previous client : )
[ 80.822527] id 26 (vblank0) min 1604 max -6 refs 1 (previous client : )
[ 80.822531] id 28 (54680000.isp_2) min 7 max 18 refs 13 (previous client : )
[ 80.822535] id 29 (54680000.isp_3) min 0 max 4 refs 5 (previous client : )
[ 80.822538] id 30 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 80.822541] id 31 (gm20b_499) min 686 max 686 refs 1 (previous client : )
[ 80.822545] id 32 (gm20b_498) min 4 max 4 refs 1 (previous client : )
[ 80.822548] id 33 (gm20b_497) min 2 max 2 refs 1 (previous client : )
[ 80.822551] id 34 (gm20b_496) min 2 max 2 refs 1 (previous client : )
[ 80.822554] id 35 (gm20b_495) min 4 max 4 refs 1 (previous client : )
[ 80.822558] id 37 (54080000.vi_1) min 0 max 4 refs 5 (previous client : 54080000.vi_1)
[ 80.822562] id 38 (54080000.vi_2) min 2 max 9 refs 9 (previous client : 54080000.vi_2)
[ 80.822566] id 41 (54080000.vi_4) min 0 max 4 refs 5 (previous client : 54080000.vi_4)
[ 80.822570] id 44 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 80.822574] id 45 (gm20b_493) min 8 max 8 refs 1 (previous client : )
[ 80.822577] id 46 (gm20b_492) min 6 max 6 refs 1 (previous client : )
[ 80.822580] id 47 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 80.822584] id 48 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 80.822587] id 49 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 80.822671] ---- channels ----
[ 80.822678]
[ 80.822683] 0-54600000.isp (1):
[ 80.822686] inactive
[ 80.822689]
[ 80.822694] 1-54680000.isp (24):
[ 80.822698] active class 01, offset 0050, val 00000018
[ 80.822701] DMAPUT 000001f0, DMAGET 00000110, DMACTL 00000000
[ 80.822703] CBREAD 00000018, CBSTAT 00010050
[ 80.822708]
[ 80.822714] GATHER at ffc98000+4c48, 8 words
[ 80.822716] 20000001
[ 80.822719] 00000418
[ 80.822721] 20000001
[ 80.822723] 00000519
[ 80.822725] 20000001
[ 80.822727] 0000061d
[ 80.822729] 200c0001
[ 80.822731] 00000005
[ 80.822737] GATHER at ffc98000+4c68, 2 words
[ 80.822738] 20000001
[ 80.822741] 0000001c
[ 80.822748]
[ 80.822753] 2-54080000.vi (17):
[ 80.822756] active class 01, offset 0050, val 00000025
[ 80.822759] DMAPUT 00000148, DMAGET 00000120, DMACTL 00000000
[ 80.822761] CBREAD 00000025, CBSTAT 00010050
[ 80.822765]
[ 80.822769] GATHER at ffc18000+0000, 35 words
[ 80.822771] 10620001
[ 80.822773] 0000001f
[ 80.822775] 10630002
[ 80.822777] 00000000
[ 80.822779] 00000000
[ 80.822781] 103a0001
[ 80.822783] 10100010
[ 80.822785] 103c0001
[ 80.822787] 10101010
[ 80.822789] 10420001
[ 80.822791] 00000001
[ 80.822793] 10430006
[ 80.822794] 00000000
[ 80.822796] 001c984c
[ 80.822798] 00000000
[ 80.822800] 00000000
[ 80.822802] 00000000
[ 80.822804] 00000000
[ 80.822806] 10590001
[ 80.822808] 00000003
[ 80.822810] 120e0006
[ 80.822812] 007f0015
[ 80.822814] 080301f0
[ 80.822816] 00000000
[ 80.822818] 00140000
[ 80.822820] 0000f005
[ 80.822822] 00000000
[ 80.822824] 12420001
[ 80.822825] 00000001
[ 80.822827] 124b0003
[ 80.822829] 00000000
[ 80.822831] 00000000
[ 80.822833] 00000000
[ 80.822835] 128b0001
[ 80.822837] 00000000
[ 80.822842] GATHER at ffc18000+008c, 3 words
[ 80.822844] 304e0005
[ 80.822846] 00000007
[ 80.822848] 0000001c
[ 80.822852] GATHER at ffc18000+0098, 17 words
[ 80.822854] 10430006
[ 80.822856] 00200004
[ 80.822858] 001c984c
[ 80.822860] 00000000
[ 80.822862] 09a00cc0
[ 80.822864] 00000ff0
[ 80.822866] 0000002b
[ 80.822868] 124b0003
[ 80.822870] 00000000
[ 80.822872] 00000000
[ 80.822873] 00000008
[ 80.822875] 20000001
[ 80.822877] 00001d25
[ 80.822879] 20000001
[ 80.822881] 00000529
[ 80.822883] 20410001
[ 80.822885] 00000001
[ 80.822889] GATHER at ffc18000+00dc, 2 words
[ 80.822891] 20000001
[ 80.822893] 00000026
[ 80.822899]
[ 80.822902] sync_hintmask_ext = 0xc0000000
[ 80.822904] sync_hintmask = 0x80000000
[ 80.822907] sync_intc0mask = 0x00000001
[ 80.822909] sync_intmask = 0x00000011
[ 80.822911]
[ 80.822914] syncpt_thresh_int_mask(0) = 0x00000001
[ 80.822917] syncpt_thresh_int_mask(1) = 0x05050001
[ 80.822919] syncpt_thresh_int_mask(2) = 0x00041400
[ 80.822922] syncpt_thresh_int_mask(3) = 0x00000000
[ 80.822924] syncpt_thresh_int_mask(4) = 0x00000000
[ 80.822927] syncpt_thresh_int_mask(5) = 0x00000000
[ 80.822929] syncpt_thresh_int_mask(6) = 0x00000000
[ 80.822932] syncpt_thresh_int_mask(7) = 0x00000000
[ 80.822934] syncpt_thresh_int_mask(8) = 0x00000000
[ 80.822937] syncpt_thresh_int_mask(9) = 0x00000000
[ 80.822939] syncpt_thresh_int_mask(10) = 0x00000000
[ 80.822942] syncpt_thresh_int_mask(11) = 0x00000000
[ 80.822944]
[ 80.822947] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 80.822950] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 80.822952] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 80.822955] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 80.822957] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 80.822960] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 80.822962]
[ 80.822965] syncpt_int_thresh_thresh_0(0) = 1
[ 80.822975] syncpt_int_thresh_thresh_0(16) = 1086
[ 80.822982] syncpt_int_thresh_thresh_0(24) = 1
[ 80.822985] syncpt_int_thresh_thresh_0(25) = 1
[ 80.822989] syncpt_int_thresh_thresh_0(28) = 8
[ 80.822992] syncpt_int_thresh_thresh_0(29) = 1
[ 80.822998] syncpt_int_thresh_thresh_0(37) = 1
[ 80.823001] syncpt_int_thresh_thresh_0(38) = 3
[ 80.823005] syncpt_int_thresh_thresh_0(41) = 1
[ 80.854499] fence timeout on [ffffffc08a83fa80] after 1500ms
[ 80.854506] name=[nvhost_sync:41], current value=0 waiting value=4
[ 80.854510] ---- mlocks ----
[ 80.854522] ---- syncpts ----
[ 80.854528] id 1 (disp0_a) min 271 max 272 refs 1 (previous client : )
[ 80.854531] id 2 (disp0_b) min 3 max 3 refs 1 (previous client : )
[ 80.854534] id 3 (disp0_c) min 3 max 3 refs 1 (previous client : )
[ 80.854537] id 4 (disp0_d) min 3 max 3 refs 1 (previous client : )
[ 80.854543] id 9 (gm20b_507) min 498 max 498 refs 1 (previous client : )
[ 80.854547] id 11 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 80.854550] id 12 (gm20b_505) min 546 max 546 refs 1 (previous client : gm20b_505)
[ 80.854553] id 13 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 80.854556] id 14 (gm20b_503) min 16622 max 16622 refs 1 (previous client : )
[ 80.854559] id 15 (gm20b_502) min 16 max 16 refs 1 (previous client : )
[ 80.854563] id 16 (gm20b_501) min 1092 max 1096 refs 1 (previous client : gm20b_501)
[ 80.854570] id 24 (54680000.isp_0) min 0 max 4 refs 5 (previous client : )
[ 80.854573] id 25 (54680000.isp_1) min 0 max 4 refs 5 (previous client : )
[ 80.854576] id 26 (vblank0) min 1606 max -6 refs 1 (previous client : )
[ 80.854580] id 28 (54680000.isp_2) min 7 max 18 refs 13 (previous client : )
[ 80.854583] id 29 (54680000.isp_3) min 0 max 4 refs 5 (previous client : )
[ 80.854586] id 30 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 80.854589] id 31 (gm20b_499) min 686 max 686 refs 1 (previous client : )
[ 80.854592] id 32 (gm20b_498) min 4 max 4 refs 1 (previous client : )
[ 80.854595] id 33 (gm20b_497) min 2 max 2 refs 1 (previous client : )
[ 80.854598] id 34 (gm20b_496) min 2 max 2 refs 1 (previous client : )
[ 80.854601] id 35 (gm20b_495) min 4 max 4 refs 1 (previous client : )
[ 80.854605] id 37 (54080000.vi_1) min 0 max 4 refs 5 (previous client : 54080000.vi_1)
[ 80.854608] id 38 (54080000.vi_2) min 2 max 9 refs 9 (previous client : 54080000.vi_2)
[ 80.854612] id 41 (54080000.vi_4) min 0 max 4 refs 5 (previous client : 54080000.vi_4)
[ 80.854616] id 44 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 80.854619] id 45 (gm20b_493) min 8 max 8 refs 1 (previous client : )
[ 80.854622] id 46 (gm20b_492) min 6 max 6 refs 1 (previous client : )
[ 80.854625] id 47 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 80.854629] id 48 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 80.854632] id 49 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 80.854714] ---- channels ----
[ 80.854721]
[ 80.854726] 0-54600000.isp (1):
[ 80.854728] inactive
[ 80.854731]
[ 80.854736] 1-54680000.isp (24):
[ 80.854740] active class 01, offset 0050, val 00000018
[ 80.854743] DMAPUT 000001f0, DMAGET 00000110, DMACTL 00000000
[ 80.854745] CBREAD 00000018, CBSTAT 00010050
[ 80.854749]
[ 80.854754] GATHER at ffc98000+4c48, 8 words
[ 80.854756] 20000001
[ 80.854758] 00000418
[ 80.854760] 20000001
[ 80.854762] 00000519
[ 80.854763] 20000001
[ 80.854765] 0000061d
[ 80.854767] 200c0001
[ 80.854769] 00000005
[ 80.854774] GATHER at ffc98000+4c68, 2 words
[ 80.854775] 20000001
[ 80.854777] 0000001c
[ 80.854783]
[ 80.854789] 2-54080000.vi (17):
[ 80.854791] active class 01, offset 0050, val 00000025
[ 80.854794] DMAPUT 00000148, DMAGET 00000120, DMACTL 00000000
[ 80.854796] CBREAD 00000025, CBSTAT 00010050
[ 80.854800]
[ 80.854803] GATHER at ffc18000+0000, 35 words
[ 80.854805] 10620001
[ 80.854807] 0000001f
[ 80.854809] 10630002
[ 80.854811] 00000000
[ 80.854813] 00000000
[ 80.854814] 103a0001
[ 80.854816] 10100010
[ 80.854818] 103c0001
[ 80.854820] 10101010
[ 80.854822] 10420001
[ 80.854824] 00000001
[ 80.854826] 10430006
[ 80.854827] 00000000
[ 80.854829] 001c984c
[ 80.854831] 00000000
[ 80.854833] 00000000
[ 80.854835] 00000000
[ 80.854836] 00000000
[ 80.854838] 10590001
[ 80.854840] 00000003
[ 80.854841] 120e0006
[ 80.854843] 007f0015
[ 80.854845] 080301f0
[ 80.854847] 00000000
[ 80.854849] 00140000
[ 80.854851] 0000f005
[ 80.854853] 00000000
[ 80.854855] 12420001
[ 80.854857] 00000001
[ 80.854858] 124b0003
[ 80.854860] 00000000
[ 80.854862] 00000000
[ 80.854864] 00000000
[ 80.854866] 128b0001
[ 80.854867] 00000000
[ 80.854872] GATHER at ffc18000+008c, 3 words
[ 80.854874] 304e0005
[ 80.854875] 00000007
[ 80.854877] 0000001c
[ 80.854882] GATHER at ffc18000+0098, 17 words
[ 80.854883] 10430006
[ 80.854885] 00200004
[ 80.854887] 001c984c
[ 80.854889] 00000000
[ 80.854891] 09a00cc0
[ 80.854893] 00000ff0
[ 80.854894] 0000002b
[ 80.854896] 124b0003
[ 80.854898] 00000000
[ 80.854900] 00000000
[ 80.854902] 00000008
[ 80.854903] 20000001
[ 80.854905] 00001d25
[ 80.854907] 20000001
[ 80.854909] 00000529
[ 80.854911] 20410001
[ 80.854912] 00000001
[ 80.854916] GATHER at ffc18000+00dc, 2 words
[ 80.854918] 20000001
[ 80.854920] 00000026
[ 80.854926]
[ 80.854929] sync_hintmask_ext = 0xc0000000
[ 80.854931] sync_hintmask = 0x80000000
[ 80.854933] sync_intc0mask = 0x00000001
[ 80.854936] sync_intmask = 0x00000011
[ 80.854938]
[ 80.854940] syncpt_thresh_int_mask(0) = 0x00000001
[ 80.854943] syncpt_thresh_int_mask(1) = 0x05050001
[ 80.854946] syncpt_thresh_int_mask(2) = 0x00041400
[ 80.854948] syncpt_thresh_int_mask(3) = 0x00000000
[ 80.854951] syncpt_thresh_int_mask(4) = 0x00000000
[ 80.854953] syncpt_thresh_int_mask(5) = 0x00000000
[ 80.854955] syncpt_thresh_int_mask(6) = 0x00000000
[ 80.854958] syncpt_thresh_int_mask(7) = 0x00000000
[ 80.854960] syncpt_thresh_int_mask(8) = 0x00000000
[ 80.854963] syncpt_thresh_int_mask(9) = 0x00000000
[ 80.854965] syncpt_thresh_int_mask(10) = 0x00000000
[ 80.854967] syncpt_thresh_int_mask(11) = 0x00000000
[ 80.854969]
[ 80.854972] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 80.854975] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 80.854977] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 80.854980] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 80.854982] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 80.854985] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 80.854986]
[ 80.854990] syncpt_int_thresh_thresh_0(0) = 1
[ 80.855000] syncpt_int_thresh_thresh_0(16) = 1094
[ 80.855006] syncpt_int_thresh_thresh_0(24) = 1
[ 80.855009] syncpt_int_thresh_thresh_0(25) = 1
[ 80.855013] syncpt_int_thresh_thresh_0(28) = 8
[ 80.855016] syncpt_int_thresh_thresh_0(29) = 1
[ 80.855022] syncpt_int_thresh_thresh_0(37) = 1
[ 80.855025] syncpt_int_thresh_thresh_0(38) = 3
[ 80.855028] syncpt_int_thresh_thresh_0(41) = 1
[ 82.326462] fence timeout on [ffffffc0793de000] after 1500ms
[ 82.326471] name=[nvhost_sync:25], current value=0 waiting value=3
[ 82.326475] ---- mlocks ----
[ 82.326488] ---- syncpts ----
[ 82.326495] id 1 (disp0_a) min 316 max 316 refs 1 (previous client : )
[ 82.326499] id 2 (disp0_b) min 3 max 3 refs 1 (previous client : )
[ 82.326502] id 3 (disp0_c) min 3 max 3 refs 1 (previous client : )
[ 82.326506] id 4 (disp0_d) min 3 max 3 refs 1 (previous client : )
[ 82.326512] id 9 (gm20b_507) min 498 max 498 refs 1 (previous client : )
[ 82.326517] id 11 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 82.326521] id 12 (gm20b_505) min 546 max 546 refs 1 (previous client : gm20b_505)
[ 82.326524] id 13 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 82.326528] id 14 (gm20b_503) min 16942 max 16942 refs 1 (previous client : )
[ 82.326532] id 15 (gm20b_502) min 16 max 16 refs 1 (previous client : )
[ 82.326536] id 16 (gm20b_501) min 1324 max 1324 refs 1 (previous client : gm20b_501)
[ 82.326544] id 24 (54680000.isp_0) min 0 max 4 refs 5 (previous client : )
[ 82.326547] id 25 (54680000.isp_1) min 0 max 4 refs 5 (previous client : )
[ 82.326551] id 26 (vblank0) min 1694 max -6 refs 1 (previous client : )
[ 82.326555] id 28 (54680000.isp_2) min 7 max 18 refs 13 (previous client : )
[ 82.326559] id 29 (54680000.isp_3) min 0 max 4 refs 5 (previous client : )
[ 82.326562] id 30 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 82.326566] id 31 (gm20b_499) min 686 max 686 refs 1 (previous client : )
[ 82.326570] id 32 (gm20b_498) min 4 max 4 refs 1 (previous client : )
[ 82.326574] id 33 (gm20b_497) min 2 max 2 refs 1 (previous client : )
[ 82.326577] id 34 (gm20b_496) min 2 max 2 refs 1 (previous client : )
[ 82.326580] id 35 (gm20b_495) min 4 max 4 refs 1 (previous client : )
[ 82.326584] id 37 (54080000.vi_1) min 0 max 4 refs 5 (previous client : 54080000.vi_1)
[ 82.326588] id 38 (54080000.vi_2) min 2 max 9 refs 9 (previous client : 54080000.vi_2)
[ 82.326593] id 41 (54080000.vi_4) min 0 max 4 refs 5 (previous client : 54080000.vi_4)
[ 82.326597] id 44 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 82.326601] id 45 (gm20b_493) min 8 max 8 refs 1 (previous client : )
[ 82.326604] id 46 (gm20b_492) min 6 max 6 refs 1 (previous client : )
[ 82.326607] id 47 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 82.326611] id 48 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 82.326615] id 49 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 82.326701] ---- channels ----
[ 82.326709]
[ 82.326714] 0-54600000.isp (1):
[ 82.326717] inactive
[ 82.326720]
[ 82.326726] 1-54680000.isp (24):
[ 82.326730] active class 01, offset 0050, val 00000018
[ 82.326733] DMAPUT 000001f0, DMAGET 00000110, DMACTL 00000000
[ 82.326735] CBREAD 00000018, CBSTAT 00010050
[ 82.326741]
[ 82.326747] GATHER at ffc98000+4c48, 8 words
[ 82.326750] 20000001
[ 82.326752] 00000418
[ 82.326754] 20000001
[ 82.326756] 00000519
[ 82.326758] 20000001
[ 82.326760] 0000061d
[ 82.326762] 200c0001
[ 82.326764] 00000005
[ 82.326770] GATHER at ffc98000+4c68, 2 words
[ 82.326772] 20000001
[ 82.326774] 0000001c
[ 82.326782]
[ 82.326787] 2-54080000.vi (17):
[ 82.326790] active class 01, offset 0050, val 00000025
[ 82.326793] DMAPUT 00000148, DMAGET 00000120, DMACTL 00000000
[ 82.326795] CBREAD 00000025, CBSTAT 00010050
[ 82.326799]
[ 82.326803] GATHER at ffc18000+0000, 35 words
[ 82.326805] 10620001
[ 82.326807] 0000001f
[ 82.326809] 10630002
[ 82.326811] 00000000
[ 82.326813] 00000000
[ 82.326815] 103a0001
[ 82.326817] 10100010
[ 82.326819] 103c0001
[ 82.326821] 10101010
[ 82.326823] 10420001
[ 82.326825] 00000001
[ 82.326827] 10430006
[ 82.326829] 00000000
[ 82.326831] 001c984c
[ 82.326832] 00000000
[ 82.326834] 00000000
[ 82.326836] 00000000
[ 82.326838] 00000000
[ 82.326840] 10590001
[ 82.326842] 00000003
[ 82.326844] 120e0006
[ 82.326846] 007f0015
[ 82.326848] 080301f0
[ 82.326850] 00000000
[ 82.326852] 00140000
[ 82.326854] 0000f005
[ 82.326856] 00000000
[ 82.326859] 12420001
[ 82.326861] 00000001
[ 82.326863] 124b0003
[ 82.326865] 00000000
[ 82.326867] 00000000
[ 82.326869] 00000000
[ 82.326871] 128b0001
[ 82.326873] 00000000
[ 82.326878] GATHER at ffc18000+008c, 3 words
[ 82.326880] 304e0005
[ 82.326883] 00000007
[ 82.326885] 0000001c
[ 82.326890] GATHER at ffc18000+0098, 17 words
[ 82.326892] 10430006
[ 82.326894] 00200004
[ 82.326896] 001c984c
[ 82.326898] 00000000
[ 82.326900] 09a00cc0
[ 82.326902] 00000ff0
[ 82.326904] 0000002b
[ 82.326906] 124b0003
[ 82.326908] 00000000
[ 82.326910] 00000000
[ 82.326912] 00000008
[ 82.326914] 20000001
[ 82.326917] 00001d25
[ 82.326919] 20000001
[ 82.326921] 00000529
[ 82.326923] 20410001
[ 82.326925] 00000001
[ 82.326930] GATHER at ffc18000+00dc, 2 words
[ 82.326932] 20000001
[ 82.326934] 00000026
[ 82.326940]
[ 82.326943] sync_hintmask_ext = 0xc0000000
[ 82.326945] sync_hintmask = 0x80000000
[ 82.326948] sync_intc0mask = 0x00000001
[ 82.326951] sync_intmask = 0x00000011
[ 82.326953]
[ 82.326956] syncpt_thresh_int_mask(0) = 0x00000001
[ 82.326959] syncpt_thresh_int_mask(1) = 0x05050000
[ 82.326962] syncpt_thresh_int_mask(2) = 0x00041400
[ 82.326964] syncpt_thresh_int_mask(3) = 0x00000000
[ 82.326967] syncpt_thresh_int_mask(4) = 0x00000000
[ 82.326970] syncpt_thresh_int_mask(5) = 0x00000000
[ 82.326972] syncpt_thresh_int_mask(6) = 0x00000000
[ 82.326975] syncpt_thresh_int_mask(7) = 0x00000000
[ 82.326978] syncpt_thresh_int_mask(8) = 0x00000000
[ 82.326980] syncpt_thresh_int_mask(9) = 0x00000000
[ 82.326983] syncpt_thresh_int_mask(10) = 0x00000000
[ 82.326985] syncpt_thresh_int_mask(11) = 0x00000000
[ 82.326988]
[ 82.326990] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 82.326993] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 82.326996] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 82.326998] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 82.327001] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 82.327004] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 82.327005]
[ 82.327009] syncpt_int_thresh_thresh_0(0) = 1
[ 82.327023] syncpt_int_thresh_thresh_0(24) = 1
[ 82.327026] syncpt_int_thresh_thresh_0(25) = 1
[ 82.327029] syncpt_int_thresh_thresh_0(28) = 8
[ 82.327032] syncpt_int_thresh_thresh_0(29) = 1
[ 82.327039] syncpt_int_thresh_thresh_0(37) = 1
[ 82.327042] syncpt_int_thresh_thresh_0(38) = 3
[ 82.327046] syncpt_int_thresh_thresh_0(41) = 1
[ 84.470469] fence timeout on [ffffffc08a83f480] after 1500ms
[ 84.470479] name=[nvhost_sync:25], current value=0 waiting value=4
[ 84.470483] ---- mlocks ----
[ 84.470495] ---- syncpts ----
[ 84.470502] id 1 (disp0_a) min 352 max 353 refs 1 (previous client : )
[ 84.470506] id 2 (disp0_b) min 3 max 3 refs 1 (previous client : )
[ 84.470509] id 3 (disp0_c) min 3 max 3 refs 1 (previous client : )
[ 84.470513] id 4 (disp0_d) min 3 max 3 refs 1 (previous client : )
[ 84.470519] id 9 (gm20b_507) min 498 max 498 refs 1 (previous client : )
[ 84.470523] id 11 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 84.470527] id 12 (gm20b_505) min 546 max 546 refs 1 (previous client : gm20b_505)
[ 84.470531] id 13 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 84.470535] id 14 (gm20b_503) min 17770 max 17772 refs 1 (previous client : )
[ 84.470539] id 15 (gm20b_502) min 16 max 16 refs 1 (previous client : )
[ 84.470543] id 16 (gm20b_501) min 1512 max 1516 refs 1 (previous client : gm20b_501)
[ 84.470551] id 24 (54680000.isp_0) min 0 max 4 refs 5 (previous client : )
[ 84.470554] id 25 (54680000.isp_1) min 0 max 4 refs 5 (previous client : )
[ 84.470558] id 26 (vblank0) min 1823 max -6 refs 1 (previous client : )
[ 84.470562] id 28 (54680000.isp_2) min 7 max 18 refs 13 (previous client : )
[ 84.470565] id 29 (54680000.isp_3) min 0 max 4 refs 5 (previous client : )
[ 84.470569] id 30 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 84.470573] id 31 (gm20b_499) min 686 max 686 refs 1 (previous client : )
[ 84.470577] id 32 (gm20b_498) min 4 max 4 refs 1 (previous client : )
[ 84.470580] id 33 (gm20b_497) min 2 max 2 refs 1 (previous client : )
[ 84.470583] id 34 (gm20b_496) min 2 max 2 refs 1 (previous client : )
[ 84.470587] id 35 (gm20b_495) min 4 max 4 refs 1 (previous client : )
[ 84.470591] id 37 (54080000.vi_1) min 0 max 4 refs 5 (previous client : 54080000.vi_1)
[ 84.470595] id 38 (54080000.vi_2) min 2 max 9 refs 9 (previous client : 54080000.vi_2)
[ 84.470600] id 41 (54080000.vi_4) min 0 max 4 refs 5 (previous client : 54080000.vi_4)
[ 84.470605] id 44 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 84.470608] id 45 (gm20b_493) min 8 max 8 refs 1 (previous client : )
[ 84.470612] id 46 (gm20b_492) min 6 max 6 refs 1 (previous client : )
[ 84.470615] id 47 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 84.470619] id 48 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 84.470622] id 49 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 84.470709] ---- channels ----
[ 84.470717]
[ 84.470723] 0-54600000.isp (1):
[ 84.470725] inactive
[ 84.470729]
[ 84.470734] 1-54680000.isp (24):
[ 84.470738] active class 01, offset 0050, val 00000018
[ 84.470741] DMAPUT 000001f0, DMAGET 00000110, DMACTL 00000000
[ 84.470744] CBREAD 00000018, CBSTAT 00010050
[ 84.470749]
[ 84.470755] GATHER at ffc98000+4c48, 8 words
[ 84.470757] 20000001
[ 84.470759] 00000418
[ 84.470761] 20000001
[ 84.470764] 00000519
[ 84.470766] 20000001
[ 84.470768] 0000061d
[ 84.470770] 200c0001
[ 84.470772] 00000005
[ 84.470777] GATHER at ffc98000+4c68, 2 words
[ 84.470779] 20000001
[ 84.470781] 0000001c
[ 84.470788]
[ 84.470794] 2-54080000.vi (17):
[ 84.470797] active class 01, offset 0050, val 00000025
[ 84.470800] DMAPUT 00000148, DMAGET 00000120, DMACTL 00000000
[ 84.470802] CBREAD 00000025, CBSTAT 00010050
[ 84.470807]
[ 84.470811] GATHER at ffc18000+0000, 35 words
[ 84.470813] 10620001
[ 84.470815] 0000001f
[ 84.470817] 10630002
[ 84.470819] 00000000
[ 84.470821] 00000000
[ 84.470823] 103a0001
[ 84.470825] 10100010
[ 84.470827] 103c0001
[ 84.470829] 10101010
[ 84.470831] 10420001
[ 84.470833] 00000001
[ 84.470834] 10430006
[ 84.470836] 00000000
[ 84.470838] 001c984c
[ 84.470840] 00000000
[ 84.470842] 00000000
[ 84.470844] 00000000
[ 84.470846] 00000000
[ 84.470848] 10590001
[ 84.470850] 00000003
[ 84.470851] 120e0006
[ 84.471030] 007f0015
[ 84.471032] 080301f0
[ 84.471034] 00000000
[ 84.471036] 00140000
[ 84.471039] 0000f005
[ 84.471041] 00000000
[ 84.471043] 12420001
[ 84.471044] 00000001
[ 84.471047] 124b0003
[ 84.471048] 00000000
[ 84.471050] 00000000
[ 84.471052] 00000000
[ 84.471054] 128b0001
[ 84.471056] 00000000
[ 84.471062] GATHER at ffc18000+008c, 3 words
[ 84.471064] 304e0005
[ 84.471066] 00000007
[ 84.471068] 0000001c
[ 84.471073] GATHER at ffc18000+0098, 17 words
[ 84.471075] 10430006
[ 84.471077] 00200004
[ 84.471079] 001c984c
[ 84.471081] 00000000
[ 84.471083] 09a00cc0
[ 84.471085] 00000ff0
[ 84.471087] 0000002b
[ 84.471089] 124b0003
[ 84.471091] 00000000
[ 84.471093] 00000000
[ 84.471095] 00000008
[ 84.471097] 20000001
[ 84.471099] 00001d25
[ 84.471101] 20000001
[ 84.471103] 00000529
[ 84.471104] 20410001
[ 84.471106] 00000001
[ 84.471111] GATHER at ffc18000+00dc, 2 words
[ 84.471113] 20000001
[ 84.471114] 00000026
[ 84.471121]
[ 84.471123] sync_hintmask_ext = 0xc0000000
[ 84.471126] sync_hintmask = 0x80000000
[ 84.471129] sync_intc0mask = 0x00000001
[ 84.471132] sync_intmask = 0x00000011
[ 84.471134]
[ 84.471137] syncpt_thresh_int_mask(0) = 0x00000001
[ 84.471140] syncpt_thresh_int_mask(1) = 0x05050001
[ 84.471143] syncpt_thresh_int_mask(2) = 0x00041400
[ 84.471145] syncpt_thresh_int_mask(3) = 0x00000000
[ 84.471148] syncpt_thresh_int_mask(4) = 0x00000000
[ 84.471151] syncpt_thresh_int_mask(5) = 0x00000000
[ 84.471154] syncpt_thresh_int_mask(6) = 0x00000000
[ 84.471156] syncpt_thresh_int_mask(7) = 0x00000000
[ 84.471159] syncpt_thresh_int_mask(8) = 0x00000000
[ 84.471161] syncpt_thresh_int_mask(9) = 0x00000000
[ 84.471164] syncpt_thresh_int_mask(10) = 0x00000000
[ 84.471167] syncpt_thresh_int_mask(11) = 0x00000000
[ 84.471169]
[ 84.471172] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 84.471175] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 84.471178] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 84.471180] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 84.471183] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 84.471186] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 84.471188]
[ 84.471191] syncpt_int_thresh_thresh_0(0) = 1
[ 84.471201] syncpt_int_thresh_thresh_0(16) = 1516
[ 84.471208] syncpt_int_thresh_thresh_0(24) = 1
[ 84.471211] syncpt_int_thresh_thresh_0(25) = 1
[ 84.471215] syncpt_int_thresh_thresh_0(28) = 8
[ 84.471218] syncpt_int_thresh_thresh_0(29) = 1
[ 84.471224] syncpt_int_thresh_thresh_0(37) = 1
[ 84.471227] syncpt_int_thresh_thresh_0(38) = 3
[ 84.471231] syncpt_int_thresh_thresh_0(41) = 1
[ 87.926452] host1x 50000000.host1x: cdma_handle_timeout: timeout: 37 (54080000.vi_1) client 12, HW thresh 0, done 1
[ 87.937636] host1x 50000000.host1x: cdma_handle_timeout: timeout: 41 (54080000.vi_4) client 12, HW thresh 0, done 1
[ 87.948718] host1x 50000000.host1x: cdma_handle_timeout: timeout: 38 (54080000.vi_2) client 12, HW thresh 2, done 2
[ 87.959279] ---- mlocks ----
[ 87.959293] ---- syncpts ----
[ 87.959301] id 1 (disp0_a) min 466 max 467 refs 1 (previous client : )
[ 87.959305] id 2 (disp0_b) min 3 max 3 refs 1 (previous client : )
[ 87.959309] id 3 (disp0_c) min 3 max 3 refs 1 (previous client : )
[ 87.959312] id 4 (disp0_d) min 3 max 3 refs 1 (previous client : )
[ 87.959322] id 9 (gm20b_507) min 498 max 498 refs 1 (previous client : )
[ 87.959326] id 11 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 87.959330] id 12 (gm20b_505) min 546 max 546 refs 1 (previous client : gm20b_505)
[ 87.959334] id 13 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 87.959338] id 14 (gm20b_503) min 18892 max 18896 refs 1 (previous client : )
[ 87.959342] id 15 (gm20b_502) min 16 max 16 refs 1 (previous client : )
[ 87.959347] id 16 (gm20b_501) min 2102 max 2104 refs 1 (previous client : gm20b_501)
[ 87.959358] id 24 (54680000.isp_0) min 0 max 4 refs 5 (previous client : )
[ 87.959362] id 25 (54680000.isp_1) min 0 max 4 refs 5 (previous client : )
[ 87.959367] id 26 (vblank0) min 2032 max -6 refs 1 (previous client : )
[ 87.959374] id 28 (54680000.isp_2) min 7 max 18 refs 13 (previous client : )
[ 87.959380] id 29 (54680000.isp_3) min 0 max 4 refs 5 (previous client : )
[ 87.959385] id 30 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 87.959391] id 31 (gm20b_499) min 686 max 686 refs 1 (previous client : )
[ 87.959397] id 32 (gm20b_498) min 4 max 4 refs 1 (previous client : )
[ 87.959403] id 33 (gm20b_497) min 2 max 2 refs 1 (previous client : )
[ 87.959408] id 34 (gm20b_496) min 2 max 2 refs 1 (previous client : )
[ 87.959411] id 35 (gm20b_495) min 4 max 4 refs 1 (previous client : )
[ 87.959415] id 37 (54080000.vi_1) min 0 max 4 refs 5 (previous client : 54080000.vi_1)
[ 87.959419] id 38 (54080000.vi_2) min 2 max 9 refs 9 (previous client : 54080000.vi_2)
[ 87.959424] id 41 (54080000.vi_4) min 0 max 4 refs 5 (previous client : 54080000.vi_4)
[ 88.109865]
[ 88.109871] 0-54600000.isp (1):
[ 88.109873] inactive
[ 88.109877]
[ 88.109883] 1-54680000.isp (24):
[ 88.109887] active class 01, offset 0050, val 00000018
[ 88.109890] DMAPUT 000001f0, DMAGET 00000110, DMACTL 00000000
[ 88.109893] CBREAD 00000018, CBSTAT 00010050
[ 88.109898]
[ 88.109903] GATHER at ffc98000+4c48, 8 words
[ 88.109906] 20000001
[ 88.109908] 00000418
[ 88.109910] 20000001
[ 88.109912] 00000519
[ 88.109914] 20000001
[ 88.109916] 0000061d
[ 88.109918] 200c0001
[ 88.109920] 00000005
[ 88.109926] GATHER at ffc98000+4c68, 2 words
[ 88.109928] 20000001
[ 88.109930] 0000001c
[ 88.109937]
[ 88.109942] 2-54080000.vi (2):
[ 88.109945] active class 01, offset 0000, val 20000000
[ 88.109948] DMAPUT 00000148, DMAGET 00000148, DMACTL 00000000
[ 88.109950] CBREAD 20000000, CBSTAT 00010000
[ 88.109953] The CDMA sync queue is empty.
[ 88.109957]
[ 88.109964] sync_hintmask_ext = 0xc0000000
[ 88.109968] sync_hintmask = 0x80000000
[ 88.109973] sync_intc0mask = 0x00000001
[ 88.109977] sync_intmask = 0x00000011
[ 88.109985]
[ 88.109989] syncpt_thresh_int_mask(0) = 0x00000001
[ 88.109993] syncpt_thresh_int_mask(1) = 0x05050001
[ 88.109997] syncpt_thresh_int_mask(2) = 0x00000000
[ 88.110001] syncpt_thresh_int_mask(3) = 0x00000000
[ 88.110005] syncpt_thresh_int_mask(4) = 0x00000000
[ 88.110009] syncpt_thresh_int_mask(5) = 0x00000000
[ 88.110013] syncpt_thresh_int_mask(6) = 0x00000000
[ 88.110017] syncpt_thresh_int_mask(7) = 0x00000000
[ 88.110021] syncpt_thresh_int_mask(8) = 0x00000000
[ 88.110024] syncpt_thresh_int_mask(9) = 0x00000000
[ 88.110028] syncpt_thresh_int_mask(10) = 0x00000000
[ 88.110032] syncpt_thresh_int_mask(11) = 0x00000000
[ 88.110038]
[ 88.110044] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 88.110048] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 88.110052] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 88.110057] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 88.110060] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 88.110094] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 88.110096]
[ 88.110100] syncpt_int_thresh_thresh_0(0) = 1
[ 88.110113] syncpt_int_thresh_thresh_0(24) = 1
[ 88.110116] syncpt_int_thresh_thresh_0(25) = 1
[ 88.110120] syncpt_int_thresh_thresh_0(28) = 8
[ 88.110124] syncpt_int_thresh_thresh_0(29) = 1
[ 88.110234] isp 54680000.isp: SYNCPT_ID 24
[ 88.110238] isp 54680000.isp: SYNCPT_VAL 1
[ 88.110241] isp 54680000.isp: FIRST_GET 0x90
[ 88.110244] isp 54680000.isp: TIMEOUT 10000
[ 88.110247] isp 54680000.isp: NUM_SLOTS 3
[ 88.110251] isp 54680000.isp: NUM_HANDLES 1
[ 88.110332] isp 54680000.isp: SYNCPT_ID 28
[ 88.110335] isp 54680000.isp: SYNCPT_VAL 8
[ 88.110338] isp 54680000.isp: FIRST_GET 0xa8
[ 88.110341] isp 54680000.isp: TIMEOUT 10000
[ 88.110344] isp 54680000.isp: NUM_SLOTS 5
[ 88.110347] isp 54680000.isp: NUM_HANDLES 1
[ 88.110372] isp 54680000.isp: SYNCPT_ID 28
[ 88.110375] isp 54680000.isp: SYNCPT_VAL 9
[ 88.110377] isp 54680000.isp: FIRST_GET 0xd0
[ 88.110380] isp 54680000.isp: TIMEOUT 10000
[ 88.110383] isp 54680000.isp: NUM_SLOTS 3
[ 88.110386] isp 54680000.isp: NUM_HANDLES 1
[ 88.110428] isp 54680000.isp: SYNCPT_ID 28
[ 88.110431] isp 54680000.isp: SYNCPT_VAL 10
[ 88.110434] isp 54680000.isp: FIRST_GET 0xe8
[ 88.110437] isp 54680000.isp: TIMEOUT 10000
[ 88.110439] isp 54680000.isp: NUM_SLOTS 3
[ 88.110442] isp 54680000.isp: NUM_HANDLES 3
[ 88.110462] isp 54680000.isp: SYNCPT_ID 24
[ 88.110465] isp 54680000.isp: SYNCPT_VAL 2
[ 88.110468] isp 54680000.isp: FIRST_GET 0x100
[ 88.110471] isp 54680000.isp: TIMEOUT 10000
[ 88.110474] isp 54680000.isp: NUM_SLOTS 3
[ 88.110476] isp 54680000.isp: NUM_HANDLES 1
[ 88.110557] isp 54680000.isp: SYNCPT_ID 28
[ 88.110561] isp 54680000.isp: SYNCPT_VAL 12
[ 88.110565] isp 54680000.isp: FIRST_GET 0x118
[ 88.110569] isp 54680000.isp: TIMEOUT 10000
[ 88.110574] isp 54680000.isp: NUM_SLOTS 5
[ 88.110578] isp 54680000.isp: NUM_HANDLES 1
[ 88.110599] isp 54680000.isp: SYNCPT_ID 28
[ 88.110602] isp 54680000.isp: SYNCPT_VAL 13
[ 88.110605] isp 54680000.isp: FIRST_GET 0x140
[ 88.110607] isp 54680000.isp: TIMEOUT 10000
[ 88.110610] isp 54680000.isp: NUM_SLOTS 3
[ 88.110613] isp 54680000.isp: NUM_HANDLES 3
[ 88.110633] isp 54680000.isp: SYNCPT_ID 24
[ 88.110635] isp 54680000.isp: SYNCPT_VAL 3
[ 88.110638] isp 54680000.isp: FIRST_GET 0x158
[ 88.110641] isp 54680000.isp: TIMEOUT 10000
[ 88.110643] isp 54680000.isp: NUM_SLOTS 3
[ 88.110646] isp 54680000.isp: NUM_HANDLES 1
[ 88.110714] isp 54680000.isp: SYNCPT_ID 28
[ 88.110717] isp 54680000.isp: SYNCPT_VAL 15
[ 88.110720] isp 54680000.isp: FIRST_GET 0x170
[ 88.110723] isp 54680000.isp: TIMEOUT 10000
[ 88.110726] isp 54680000.isp: NUM_SLOTS 5
[ 88.110728] isp 54680000.isp: NUM_HANDLES 1
[ 88.110749] isp 54680000.isp: SYNCPT_ID 28
[ 88.110752] isp 54680000.isp: SYNCPT_VAL 16
[ 88.110757] isp 54680000.isp: FIRST_GET 0x198
[ 88.110759] isp 54680000.isp: TIMEOUT 10000
[ 88.110762] isp 54680000.isp: NUM_SLOTS 3
[ 88.110765] isp 54680000.isp: NUM_HANDLES 3
[ 88.110784] isp 54680000.isp: SYNCPT_ID 24
[ 88.110787] isp 54680000.isp: SYNCPT_VAL 4
[ 88.110789] isp 54680000.isp: FIRST_GET 0x1b0
[ 88.110792] isp 54680000.isp: TIMEOUT 10000
[ 88.110795] isp 54680000.isp: NUM_SLOTS 3
[ 88.110798] isp 54680000.isp: NUM_HANDLES 1
[ 88.110867] isp 54680000.isp: SYNCPT_ID 28
[ 88.110870] isp 54680000.isp: SYNCPT_VAL 18
[ 88.110874] isp 54680000.isp: FIRST_GET 0x1c8
[ 88.110876] isp 54680000.isp: TIMEOUT 10000
[ 88.110879] isp 54680000.isp: NUM_SLOTS 5
[ 88.110882] isp 54680000.isp: NUM_HANDLES 1
[ 101.828752] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 101.838439] regmap_util_write_table_8:regmap_util_write_table:-121
[ 101.896559] imx219 6-0010: Error turning off streaming
