I cannot run a simple command to run IMX219 camera module on my Jetson Nano.
when entering command " ls /dev/video0" , It returns :
“/dev/video0” - camera module is detected by the system.
When i try to run :
“gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=616’ ! nvvidconv ! nvegltransform ! nveglglessink -e”
gst-launch-1.0 window is popping out and it appears “transparent” - no image from the sensor.
what am i’m doing wrong? appreciate your kind support.
Thanks,
Chen
this is my “dmesg” log:
1.083319] tegradc tegradc.1: No hpd-gpio in DT
[ 1.083350] tegradc tegradc.1: DT parsed successfully
[ 1.083405] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 1.084873] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.091690] r8168 0000:02:00.0: enabling device (0000 → 0003)
[ 1.091724] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 1.095255] tegradc tegradc.1: probed
[ 1.095597] tegradc tegradc.1: fb registered
[ 1.098778] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.098785] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.098794] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.098809] tegradc tegradc.1: blank - powerdown
[ 1.098832] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.098837] Extcon DP: HPD disabled
[ 1.098841] hpd: hpd_switch 0
[ 1.098846] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.098854] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.098861] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.111012] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 1.111194] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e6:01:34 from device tree
[ 1.111845] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.111904] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 1.112478] PPP generic driver version 2.4.2
[ 1.112821] PPP BSD Compression module registered
[ 1.112826] PPP Deflate Compression module registered
[ 1.112867] PPP MPPE Compression module registered
[ 1.112874] NET: Registered protocol family 24
[ 1.112955] usbcore: registered new interface driver r8152
[ 1.113008] usbcore: registered new interface driver asix
[ 1.113085] usbcore: registered new interface driver ax88179_178a
[ 1.113122] usbcore: registered new interface driver cdc_ether
[ 1.113154] usbcore: registered new interface driver net1080
[ 1.113202] usbcore: registered new interface driver cdc_subset
[ 1.113260] usbcore: registered new interface driver zaurus
[ 1.113335] usbcore: registered new interface driver cdc_ncm
[ 1.113529] VFIO - User Level meta-driver version: 0.3
[ 1.114990] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.115016] ehci-pci: EHCI PCI platform driver
[ 1.115068] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.115083] ohci-pci: OHCI PCI platform driver
[ 1.115125] ohci-platform: OHCI generic platform driver
[ 1.117832] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.118474] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.119646] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9bd3400 id
[ 1.121934] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.122016] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.122045] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.122824] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.122889] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.123097] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.123104] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.123109] usb usb1: Product: xHCI Host Controller
[ 1.123115] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.123120] usb usb1: SerialNumber: 70090000.xusb
[ 1.123428] usbcore: registered new interface driver uas
[ 1.123752] hub 1-0:1.0: USB hub found
[ 1.123796] hub 1-0:1.0: 5 ports detected
[ 1.124273] usbcore: registered new interface driver usb-storage
[ 1.124449] usbcore: registered new interface driver usbserial
[ 1.124520] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.124538] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.124638] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.124734] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.124741] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.124745] usb usb2: Product: xHCI Host Controller
[ 1.124749] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.124754] usb usb2: SerialNumber: 70090000.xusb
[ 1.125414] hub 2-0:1.0: USB hub found
[ 1.125448] hub 2-0:1.0: 4 ports detected
[ 1.126919] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.127878] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.128827] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.128837] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.128862] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.129085] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.130041] mousedev: PS/2 mouse device common for all mice
[ 1.130101] usbcore: registered new interface driver xpad
[ 1.217310] tegradc tegradc.0: blank - powerdown
[ 1.225935] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.225990] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 1.262948] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.263494] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.263496] Extcon AUX1(HDMI) disable
[ 1.265112] rtc rtc1: alarm rtc device
[ 1.265125] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.265141] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.265506] i2c /dev entries driver
[ 1.266992] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.293124] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.295406] tegradc tegradc.0: unblank
[ 1.295825] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.295830] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.296280] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.296296] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.296304] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.296446] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.296455] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.296462] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.296617] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.296627] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.296631] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.296842] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.297811] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.297933] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.297958] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.297976] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.297985] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.299096] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.299117] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.299301] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.299333] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.299796] parse_throttle_dt_data: Num cap clks = 6
[ 1.299800] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.299815] parse_throttle_dt_data: clk=gpu type=4
[ 1.299843] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.299864] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.299887] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.299890] parse_throttle_dt_data: clk=emc type=3
[ 1.300485] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.300659] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.300816] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.301763] FAN dev name: pwm-fan
[ 1.301887] FAN:gpio request success.
[ 1.301971] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.302290] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.302464] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.302472] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.302574] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.302579] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.302583] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.302587] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.302591] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.302595] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.302599] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.302602] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.302606] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.302610] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.303537] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.303949] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.305079] device-mapper: uevent: version 1.0.3
[ 1.305633] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.310528] tegra210-cpufreq cpufreq: probe()…completed
[ 1.311364] sdhci: Secure Digital Host Controller Interface driver
[ 1.311365] sdhci: Copyright(c) Pierre Ossman
[ 1.311366] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.311907] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.312288] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.312408] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.316913] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.317410] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.318537] usbcore: registered new interface driver usbhid
[ 1.318538] usbhid: USB HID core driver
[ 1.320597] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.320758] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.322666] nvpmodel: initialized successfully
[ 1.323734] usbcore: registered new interface driver snd-usb-audio
[ 1.323788] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.323792] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.323809] iommu: Adding device snd-soc-dummy to group 36
[ 1.338402] OPE platform probe
[ 1.338498] OPE platform probe successful
[ 1.338791] OPE platform probe
[ 1.338864] OPE platform probe successful
[ 1.338898] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.338952] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.339709] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.339945] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.339952] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.358435] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.362205] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.362331] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.362449] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.362565] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.362686] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.362824] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.362936] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.363063] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.363237] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.363353] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.374684] u32 classifier
[ 1.374686] Actions configured
[ 1.374756] Initializing XFRM netlink socket
[ 1.374945] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.374947] Extcon AUX1(HDMI) enable
[ 1.375298] tegradc tegradc.0: sync windows ret = 250
[ 1.375476] NET: Registered protocol family 10
[ 1.376184] NET: Registered protocol family 17
[ 1.376195] NET: Registered protocol family 15
[ 1.376269] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.376318] Bluetooth: RFCOMM socket layer initialized
[ 1.376327] Bluetooth: RFCOMM ver 1.11
[ 1.376331] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.376335] Bluetooth: HIDP socket layer initialized
[ 1.376353] 9pnet: Installing 9P2000 support
[ 1.376386] Key type dns_resolver registered
[ 1.376774] Registered cp15_barrier emulation handler
[ 1.376785] Registered setend emulation handler
[ 1.380992] registered taskstats version 1
[ 1.381637] Adding domain ve2-pd to PM domain host1x-pd
[ 1.381901] Adding domain ve-pd to PM domain host1x-pd
[ 1.383114] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.383117] Extcon HDMI: HPD enabled
[ 1.383136] tegradc tegradc.0: hdmi: plugged
[ 1.383966] isp 54600000.isp: initialized
[ 1.384933] isp 54680000.isp: initialized
[ 1.395281] last reset is due to software reset
[ 1.395286] KERNEL: PMC reset status reg: 0x3
[ 1.395364] BL: PMC reset status reg: 0x3
[ 1.395366] BL: PMIC poweroff Event Recorder: 0x0
[ 1.396863] clk_cbus_recalc_rate: no gbus parent
[ 1.396868] clk_cbus_round_rate: no gbus parent
[ 1.396871] clk_cbus_round_rate: no gbus parent
[ 1.396878] clk_cbus_recalc_rate: no gbus parent
[ 1.396978] clk_cbus_recalc_rate: no gbus parent
[ 1.396982] clk_cbus_round_rate: no gbus parent
[ 1.396984] clk_cbus_round_rate: no gbus parent
[ 1.396988] clk_cbus_recalc_rate: no gbus parent
[ 1.397665] tegra_dvfs: GPU-cap: registered
[ 1.397721] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.397723] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.397726] tegra dvfs: vdd-gpu: nominal 1078mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.399159] tegra_dvfs: vdd-gpu-vts: registered
[ 1.399818] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.400419] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.400893] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.434510] tegra_rtc 7000e000.rtc: setting system clock to 2020-10-08 15:13:28 UTC (1602170008)
[ 1.435530] vi 54080000.vi: vi_probe: ++
[ 1.438855] vi 54080000.vi: initialized
[ 1.440844] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.440869] vi 54080000.vi: subdev imx219 6-0010 bound
[ 1.442965] Disable partitions left on by BL
[ 1.442970] disb
[ 1.443016] bwmgr: missing cdev-type property
[ 1.443110] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.443116] DRAM derating cdev registered.
[ 1.444111] vdd-fan: disabling
[ 1.444114] vdd-usb-vbus: disabling
[ 1.444116] vdd-usb-vbus2: disabling
[ 1.444126] avdd-io-edp-1v05: disabling
[ 1.444226] ALSA device list:
[ 1.444229] #0: tegra-hda at 0x70038000 irq 83
[ 1.444231] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.447343] Freeing unused kernel memory: 8576K
[ 1.449910] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.471732] Root device found: mmcblk0p1
[ 1.485723] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.485729] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.485732] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.485735] usb 1-2: Manufacturer: Generic
[ 1.487078] hub 1-2:1.0: USB hub found
[ 1.488148] hub 1-2:1.0: 4 ports detected
[ 1.553908] mmc0: hw tuning done …
[ 1.553952] mmc0: new ultra high speed SDR104 SDXC card at address 0001
[ 1.554299] mmcblk0: mmc0:0001 GC2QT 59.6 GiB
[ 1.558471] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.609885] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 1.631840] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 1.631844] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.676397] Found dev node: /dev/mmcblk0p1
[ 1.727360] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.728159] Rootfs mounted over mmcblk0p1
[ 1.751991] Switching from initrd to actual rootfs
[ 1.781934] usb 1-2.1: new full-speed USB device number 4 using tegra-xusb
[ 1.808084] usb 1-2.1: New USB device found, idVendor=045e, idProduct=0745
[ 1.808089] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.808094] usb 1-2.1: Product: Microsoft® 2.4GHz Transceiver v7.0
[ 1.808098] usb 1-2.1: Manufacturer: Microsoft
[ 1.813368] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:045E:0745.0001/input/input2
[ 1.870418] hid-generic 0003:045E:0745.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-70090000.xusb-2.1/input0
[ 1.876529] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.1/0003:045E:0745.0002/input/input3
[ 1.934293] hid-generic 0003:045E:0745.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-70090000.xusb-2.1/input1
[ 1.950974] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.2/0003:045E:0745.0003/input/input4
[ 1.962715] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.975027] cgroup: cgroup2: unknown option “nsdelegate”
[ 1.993761] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.994566] systemd[1]: Detected architecture arm64.
[ 2.010118] hid-generic 0003:045E:0745.0003: input,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-70090000.xusb-2.1/input2
[ 2.017119] systemd[1]: Set hostname to .
[ 2.037934] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[ 2.093892] usb 1-2.3: new low-speed USB device number 5 using tegra-xusb
[ 2.102506] tegra_cec 70015000.tegra_cec: Sent res: -113.
[ 2.102511] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.120142] usb 1-2.3: New USB device found, idVendor=046d, idProduct=c31c
[ 2.120148] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.120151] usb 1-2.3: Product: USB Keyboard
[ 2.120155] usb 1-2.3: Manufacturer: Logitech
[ 2.126037] input: Logitech USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:046D:C31C.0004/input/input5
[ 2.127233] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.127242] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.186476] hid-generic 0003:046D:C31C.0004: input,hidraw3: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-70090000.xusb-2.3/input0
[ 2.194764] input: Logitech USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.1/0003:046D:C31C.0005/input/input6
[ 2.254324] hid-generic 0003:046D:C31C.0005: input,hidraw4: USB HID v1.10 Device [Logitech USB Keyboard] on usb-70090000.xusb-2.3/input1
[ 2.279637] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.281188] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.281298] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.281411] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.281460] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.283450] systemd[1]: Created slice User and Session Slice.
[ 2.284263] systemd[1]: Created slice System Slice.
[ 2.284559] systemd[1]: Listening on Journal Socket.
[ 2.337432] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.480388] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.656321] systemd-journald[2015]: Received request to flush runtime journal from PID 1
[ 2.694987] Adding 4194300k swap on /var/swapfile. Priority:-1 extents:4 across:4464636k SS
[ 3.618681] random: crng init done
[ 3.622114] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.934035] Intel(R) Wireless WiFi driver for Linux
[ 3.934038] Copyright(c) 2003- 2015 Intel Corporation
[ 3.934265] iwlwifi 0000:01:00.0: enabling device (0000 → 0002)
[ 4.333927] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 4.343506] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.282397] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.282403] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.611048] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.645872] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.645877] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.645880] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.645883] usb 2-1: Manufacturer: Generic
[ 5.649965] hub 2-1:1.0: USB hub found
[ 5.652679] hub 2-1:1.0: 4 ports detected
[ 5.809933] usb 2-1: usb_suspend_both: status 0
[ 5.810048] usb usb2: usb_suspend_both: status 0
[ 6.061911] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 6.071218] iwlwifi 0000:01:00.0: Falling back to user helper
[ 6.091443] using random self ethernet address
[ 6.094375] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 6.094378] iwlwifi 0000:01:00.0: Falling back to user helper
[ 6.124027] using random host ethernet address
[ 6.129284] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 6.129287] iwlwifi 0000:01:00.0: Falling back to user helper
[ 6.173715] usbcore: registered new interface driver btusb
[ 6.182442] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 6.183465] Bluetooth: hci0: Device revision is 16
[ 6.183486] Bluetooth: hci0: Secure boot is enabled
[ 6.183489] Bluetooth: hci0: OTP lock is enabled
[ 6.183491] Bluetooth: hci0: API lock is enabled
[ 6.183493] Bluetooth: hci0: Debug lock is disabled
[ 6.183497] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 6.192733] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 6.213507] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 6.327441] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 6.330233] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.331812] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.380683] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.380696] Bluetooth: BNEP socket layer initialized
[ 6.453259] ieee80211 phy0: Selected rate control algorithm ‘iwl-mvm-rs’
[ 6.454243] thermal thermal_zone6: failed to read out thermal zone (-5)
[ 6.454247] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
[ 7.809067] Bluetooth: hci0: Waiting for firmware download to complete
[ 7.809388] Bluetooth: hci0: Firmware loaded in 1597524 usecs
[ 7.809531] Bluetooth: hci0: Waiting for device to boot
[ 7.821413] Bluetooth: hci0: Device booted in 11636 usecs
[ 8.149656] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 8.152415] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 8.527204] Mass Storage Function, version: 2009/09/11
[ 8.527210] LUN: removable file: (no medium)
[ 8.531632] using random self ethernet address
[ 8.536148] using random host ethernet address
[ 8.682047] rndis0: HOST MAC ee:ad:31:bd:5e:f0
[ 8.682367] rndis0: MAC ee:ad:31:bd:5e:f1
[ 8.682875] usb0: HOST MAC ee:ad:31:bd:5e:f2
[ 8.682903] usb0: MAC ee:ad:31:bd:5e:f3
[ 8.682928] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 8.683886] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 8.683904] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.683940] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 8.684171] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 8.684191] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 8.684697] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 8.684718] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 8.684948] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 8.693653] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.694834] eth0: 0xffffff800a43c000, 00:04:4b:e6:01:34, IRQ 406
[ 8.747129] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.747348] l4tbr0: port 1(rndis0) entered blocking state
[ 8.747352] l4tbr0: port 1(rndis0) entered disabled state
[ 8.747511] device rndis0 entered promiscuous mode
[ 8.754393] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 8.760665] l4tbr0: port 2(usb0) entered blocking state
[ 8.760670] l4tbr0: port 2(usb0) entered disabled state
[ 8.760845] device usb0 entered promiscuous mode
[ 8.765267] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.852146] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.854538] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 8.854983] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 8.974028] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 8.974470] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 9.036049] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.704010] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.919605] zram: Added device: zram0
[ 10.921318] zram: Added device: zram1
[ 10.922385] zram: Added device: zram2
[ 10.923023] zram: Added device: zram3
[ 10.950112] zram0: detected capacity change from 0 to 518541312
[ 11.011617] Adding 506384k swap on /dev/zram0. Priority:5 extents:1 across:506384k SS
[ 11.018887] zram1: detected capacity change from 0 to 518541312
[ 11.031048] Adding 506384k swap on /dev/zram1. Priority:5 extents:1 across:506384k SS
[ 11.036016] zram2: detected capacity change from 0 to 518541312
[ 11.064975] Adding 506384k swap on /dev/zram2. Priority:5 extents:1 across:506384k SS
[ 11.072063] zram3: detected capacity change from 0 to 518541312
[ 11.087185] Adding 506384k swap on /dev/zram3. Priority:5 extents:1 across:506384k SS
[ 12.447982] tegradc tegradc.0: blank - powerdown
[ 12.508246] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 12.508273] Extcon AUX1(HDMI) disable
[ 12.527419] tegradc tegradc.0: unblank
[ 12.537924] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 12.538000] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 12.538999] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 12.539006] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 12.577889] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 12.577891] Extcon AUX1(HDMI) enable
[ 12.583864] tegradc tegradc.0: unblank
[ 12.583882] tegradc tegradc.1: blank - powerdown
[ 14.029597] wlan0: authenticate with 8c:59:c3:ab:18:58
[ 14.039423] wlan0: send auth to 8c:59:c3:ab:18:58 (try 1/3)
[ 14.048017] wlan0: authenticated
[ 14.049896] wlan0: associate with 8c:59:c3:ab:18:58 (try 1/3)
[ 14.052614] wlan0: RX AssocResp from 8c:59:c3:ab:18:58 (capab=0x11 status=0 aid=3)
[ 14.056458] wlan0: associated
[ 14.071274] wlan0: Limiting TX power to 23 (23 - 0) dBm as advertised by 8c:59:c3:ab:18:58
[ 14.077630] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 28.147630] tegradc tegradc.0: blank - powerdown
[ 28.206031] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 28.206033] Extcon AUX1(HDMI) disable
[ 28.226551] tegradc tegradc.1: blank - powerdown
[ 28.362222] tegradc tegradc.0: blank - powerdown
[ 28.362243] tegradc tegradc.0: unblank
[ 28.366997] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 28.367092] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 28.368103] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 28.368111] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 28.408331] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 28.408333] Extcon AUX1(HDMI) enable
[ 28.414058] tegradc tegradc.0: unblank
[ 28.414068] tegradc tegradc.1: blank - powerdown
[ 33.161144] fuse init (API version 7.26)
[ 33.288094] tegradc tegradc.0: unblank
[ 33.288322] tegradc tegradc.1: blank - powerdown
[ 197.880790] nvgpu: 57000000.gpu railgate_enable_store:297 [INFO] railgate is disabled.
[ 310.657205] nvgpu: 57000000.gpu railgate_enable_store:297 [INFO] railgate is disabled.
[ 329.288213] nvgpu: 57000000.gpu railgate_enable_store:297 [INFO] railgate is disabled.
[ 519.051735] nvgpu: 57000000.gpu railgate_enable_store:297 [INFO] railgate is disabled.
[ 580.315619] nvgpu: 57000000.gpu railgate_enable_store:297 [INFO] railgate is disabled.
[ 1592.249616] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1592.249627] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 1592.260226] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 1592.268774] pcieport 0000:00:01.0: [ 0] Receiver Error (First)
[ 2139.434900] tegradc tegradc.0: blank - powerdown
[ 2139.496196] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 2139.496199] Extcon AUX1(HDMI) disable
[ 2337.926759] tegradc tegradc.0: unblank
[ 2337.931513] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 2337.931608] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 2337.932621] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 2337.932628] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 2337.968290] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 2337.968293] Extcon AUX1(HDMI) enable
[ 2337.986885] tegradc tegradc.0: unblank
[ 2337.986895] tegradc tegradc.1: blank - powerdown
[ 3071.786576] fence timeout on [ffffffc0ed04b9c0] after 1500ms
[ 3071.786579] fence timeout on [ffffffc0ed04bc00] after 1500ms
[ 3071.786584] name=[nvhost_sync:23], current value=0 waiting value=1
[ 3071.786586] name=[nvhost_sync:22], current value=79586 waiting value=79587
[ 3071.786590] ---- mlocks ----
[ 3071.786591] ---- mlocks ----
[ 3071.786602] ---- syncpts ----
[ 3071.786603] ---- syncpts ----
[ 3071.786610] id 1 (disp0_a) min 21781 max 21781 refs 1 (previous client : )
[ 3071.786614] id 2 (disp0_b) min 4 max 4 refs 1 (previous client : )
[ 3071.786618] id 3 (disp0_c) min 4 max 4 refs 1 (previous client : )
[ 3071.786624] id 8 (gm20b_507) min 496 max 496 refs 1 (previous client : )
[ 3071.786628] id 9 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 3071.786633] id 11 (gm20b_505) min 528 max 528 refs 1 (previous client : gm20b_505)
[ 3071.786636] id 12 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 3071.786640] id 13 (gm20b_503) min 540272 max 540272 refs 1 (previous client : )
[ 3071.786644] id 14 (gm20b_502) min 200 max 200 refs 1 (previous client : )
[ 3071.786647] id 15 (gm20b_501) min 113980 max 113980 refs 1 (previous client : gm20b_501)
[ 3071.786651] id 16 (gm20b_498) min 197880 max 197880 refs 1 (previous client : gm20b_498)
[ 3071.786655] id 17 (gm20b_497) min 52648 max 52648 refs 1 (previous client : gm20b_497)
[ 3071.786659] id 18 (54600000.isp_0) min 1441046 max 1441046 refs 1 (previous client : gm20b_496)
[ 3071.786663] id 19 (54600000.isp_1) min 482272 max 482272 refs 1 (previous client : gm20b_495)
[ 3071.786667] id 20 (54600000.isp_2) min 543212 max 543212 refs 1 (previous client : gm20b_494)
[ 3071.786671] id 21 (54600000.isp_3) min 678074 max 678074 refs 1 (previous client : gm20b_495)
[ 3071.786675] id 22 (54680000.isp_0) min 79586 max 79589 refs 4 (previous client : gm20b_494)
[ 3071.786678] id 23 (54680000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 3071.786682] id 24 (54680000.isp_2) min 7 max 15 refs 10 (previous client : )
[ 3071.786685] id 25 (54680000.isp_3) min 0 max 3 refs 4 (previous client : )
[ 3071.786689] id 26 (vblank0) min 44025 max -8 refs 1 (previous client : )
[ 3071.786693] id 28 (gm20b_496) min 704 max 704 refs 1 (previous client : )
[ 3071.786696] id 29 (gm20b_495) min 14 max 14 refs 1 (previous client : )
[ 3071.786700] id 30 (gm20b_494) min 2 max 2 refs 1 (previous client : )
[ 3071.786703] id 31 (gm20b_500) min 2 max 2 refs 1 (previous client : )
[ 3071.786707] id 32 (gm20b_499) min 6 max 6 refs 1 (previous client : )
[ 3071.786710] id 33 (gm20b_493) min 6 max 6 refs 1 (previous client : )
[ 3071.786714] id 35 (54080000.vi_1) min 0 max 3 refs 4 (previous client : 54080000.vi_1)
[ 3071.786718] id 36 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 3071.786723] id 39 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 3071.786726] id 40 (gm20b_492) min 8 max 8 refs 1 (previous client : )
[ 3071.786729] id 41 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 3071.786733] id 42 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 3071.786736] id 43 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 3071.786739] id 44 (gm20b_488) min 6 max 6 refs 1 (previous client : )
[ 3071.786743] id 45 (gm20b_487) min 6 max 6 refs 1 (previous client : )
[ 3071.786829] ---- channels ----
[ 3071.786831] id 1 (disp0_a) min 21781 max 21781 refs 1 (previous client : )
[ 3071.786835] id 2 (disp0_b) min 4 max 4 refs 1 (previous client : )
[ 3071.786835]
channel 0 - 54340000.vic
[ 3071.786839] id 3 (disp0_c) min 4 max 4 refs 1 (previous client : )
[ 3071.786840] 0-54340000.vic (0):
[ 3071.786843] inactive
[ 3071.786845] id 8 (gm20b_507) min 496 max 496 refs 1 (previous client : )
[ 3071.786847]
channel 1 - 54600000.isp
[ 3071.786848] id 9 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 3071.786852] id 11 (gm20b_505) min 528 max 528 refs 1 (previous client : gm20b_505)
[ 3071.786853] 1-54600000.isp (1):
[ 3071.786855] id 12 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 3071.786856] inactive
[ 3071.786859]
channel 2 - 54680000.isp
[ 3071.786859] id 13 (gm20b_503) min 540272 max 540272 refs 1 (previous client : )
[ 3071.786862] id 14 (gm20b_502) min 200 max 200 refs 1 (previous client : )
[ 3071.786865] 2-54680000.isp (18):
[ 3071.786866] id 15 (gm20b_501) min 113980 max 113980 refs 1 (previous client : gm20b_501)
[ 3071.786869] active class 01, offset 0050, val 00000016
[ 3071.786869] id 16 (gm20b_498) min 197880 max 197880 refs 1 (previous client : gm20b_498)
[ 3071.786872] id 17 (gm20b_497) min 52648 max 52648 refs 1 (previous client : gm20b_497)
[ 3071.786873] DMAPUT 00000198, DMAGET 00000110, DMACTL 00000000
[ 3071.786875] CBREAD 00000016, CBSTAT 00010050
[ 3071.786876] id 18 (54600000.isp_0) min 1441046 max 1441046 refs 1 (previous client : gm20b_496)
[ 3071.786880] id 19 (54600000.isp_1) min 482272 max 482272 refs 1 (previous client : gm20b_495)
[ 3071.786881]
ffffffc02a6b3000: JOB, syncpt_id=22, syncpt_val=79587, first_get=00000090, timeout=10000, num_slots=3, num_handles=1
[ 3071.786884] id 20 (54600000.isp_2) min 543212 max 543212 refs 1 (previous client : gm20b_494)
[ 3071.786888] id 21 (54600000.isp_3) min 678074 max 678074 refs 1 (previous client : gm20b_495)
[ 3071.786890] GATHER at ffc80000+4c48, 8 words
[ 3071.786891] id 22 (54680000.isp_0) min 79586 max 79589 refs 4 (previous client : gm20b_494)
[ 3071.786894] 20000001
[ 3071.786894] id 23 (54680000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 3071.786896] 00000416
[ 3071.786897] id 24 (54680000.isp_2) min 7 max 15 refs 10 (previous client : )
[ 3071.786900] 20000001
[ 3071.786900] id 25 (54680000.isp_3) min 0 max 3 refs 4 (previous client : )
[ 3071.786902] 00000517
[ 3071.786904] id 26 (vblank0) min 44025 max -8 refs 1 (previous client : )
[ 3071.786905] 20000001
[ 3071.786907] 00000619
[ 3071.786908] id 28 (gm20b_496) min 704 max 704 refs 1 (previous client : )
[ 3071.786910] 200c0001
[ 3071.786911] id 29 (gm20b_495) min 14 max 14 refs 1 (previous client : )
[ 3071.786913] 00000005
[ 3071.786915] id 30 (gm20b_494) min 2 max 2 refs 1 (previous client : )
[ 3071.786918] id 31 (gm20b_500) min 2 max 2 refs 1 (previous client : )
[ 3071.786919] GATHER at ffc80000+4c68, 2 words
[ 3071.786921] 20000001
[ 3071.786923] id 32 (gm20b_499) min 6 max 6 refs 1 (previous client : )
[ 3071.786923] 00000018
[ 3071.786927] id 33 (gm20b_493) min 6 max 6 refs 1 (previous client : )
[ 3071.786930] id 35 (54080000.vi_1) min 0 max 3 refs 4 (previous client : 54080000.vi_1)
[ 3071.786931]
channel 3 - 54080000.vi
[ 3071.786934] id 36 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 3071.786936] 3-54080000.vi (13):
[ 3071.786939] active class 01, offset 0050, val 00000023
[ 3071.786939] id 39 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 3071.786942] id 40 (gm20b_492) min 8 max 8 refs 1 (previous client : )
[ 3071.786943] DMAPUT 00000100, DMAGET 00000100, DMACTL 00000000
[ 3071.786945] CBREAD 00000023, CBSTAT 00010050
[ 3071.786946] id 41 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 3071.786949] id 42 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 3071.786950]
ffffffc02a6b1800: JOB, syncpt_id=35, syncpt_val=1, first_get=00000018, timeout=10000, num_slots=7, num_handles=1
[ 3071.786953] id 43 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 3071.786956] GATHER at ffbd8000+0000, 35 words
[ 3071.786957] id 44 (gm20b_488) min 6 max 6 refs 1 (previous client : )
[ 3071.786959] 10620001
[ 3071.786960] id 45 (gm20b_487) min 6 max 6 refs 1 (previous client : )
[ 3071.786961] 0000001f
[ 3071.786963] 10630002
[ 3071.786965] 00000000
[ 3071.786967] 00000000
[ 3071.786969] 103a0001
[ 3071.786971] 10100010
[ 3071.786973] 103c0001
[ 3071.786975] 10101010
[ 3071.786977] 10420001
[ 3071.786979] 00000001
[ 3071.786981] 10430006
[ 3071.786983] 00000000
[ 3071.786985] 001c984c
[ 3071.786987] 00000000
[ 3071.786989] 00000000
[ 3071.786991] 00000000
[ 3071.786992] 00000000
[ 3071.786994] 10590001
[ 3071.786996] 00000003
[ 3071.786998] 120e0006
[ 3071.787000] 007f0015
[ 3071.787002] 080301f0
[ 3071.787004] 00000000
[ 3071.787006] 00140000
[ 3071.787008] 0000f005
[ 3071.787010] 00000000
[ 3071.787012] 12420001
[ 3071.787014] 00000001
[ 3071.787016] 124b0003
[ 3071.787018] 00000000
[ 3071.787019] 00000000
[ 3071.787021] 00000000
[ 3071.787023] 128b0001
[ 3071.787025] 00000000
[ 3071.787030] GATHER at ffbd8000+008c, 3 words
[ 3071.787032] 304e0005
[ 3071.787034] 00000007
[ 3071.787036] 00000018
[ 3071.787041] GATHER at ffbd8000+0098, 17 words
[ 3071.787043] ---- channels ----
[ 3071.787044] 10430006
[ 3071.787045] 00200004
[ 3071.787046] unable to lock channel list
[ 3071.787048] unable to lock channel list
[ 3071.787048] 001c984c
[ 3071.787050] 00000000
[ 3071.787050] unable to lock channel list
[ 3071.787052] unable to lock channel list
[ 3071.787052] 09a00cc0
[ 3071.787054] 00000ff0
[ 3071.787054] unable to lock channel list
[ 3071.787056] unable to lock channel list
[ 3071.787056] 0000002b
[ 3071.787058] 124b0003
[ 3071.787059] unable to lock channel list
[ 3071.787060] unable to lock channel list
[ 3071.787060] 00000000
[ 3071.787062] 00000000
[ 3071.787062] unable to lock channel list
[ 3071.787064]
---- host general irq ----
[ 3071.787064] 00000008
[ 3071.787066] 20000001
[ 3071.787067] sync_hintmask_ext = 0xc0000000
[ 3071.787068] 00001d23
[ 3071.787070] sync_hintmask = 0x80000000
[ 3071.787071] 20000001
[ 3071.787073] sync_intc0mask = 0x00000001
[ 3071.787074] 00000527
[ 3071.787076] sync_intmask = 0x00000011
[ 3071.787078] 20410001
[ 3071.787078]
---- host syncpt irq mask ----
[ 3071.787080] 00000001
[ 3071.787081] syncpt_thresh_int_mask(0) = 0x00000001
[ 3071.787083] syncpt_thresh_int_mask(1) = 0x00055000
[ 3071.787085] syncpt_thresh_int_mask(2) = 0x00004140
[ 3071.787086] GATHER at ffbd8000+00dc, 2 words
[ 3071.787087] 20000001
[ 3071.787089] syncpt_thresh_int_mask(3) = 0x00000000
[ 3071.787090] 00000024
[ 3071.787092] syncpt_thresh_int_mask(4) = 0x00000000
[ 3071.787095] syncpt_thresh_int_mask(5) = 0x00000000
[ 3071.787097]
[ 3071.787098] syncpt_thresh_int_mask(6) = 0x00000000
[ 3071.787100] syncpt_thresh_int_mask(7) = 0x00000000
[ 3071.787100] sync_hintmask_ext = 0xc0000000
[ 3071.787102] sync_hintmask = 0x80000000
[ 3071.787103] syncpt_thresh_int_mask(8) = 0x00000000
[ 3071.787105] syncpt_thresh_int_mask(9) = 0x00000000
[ 3071.787105] sync_intc0mask = 0x00000001
[ 3071.787107] sync_intmask = 0x00000011
[ 3071.787108] syncpt_thresh_int_mask(10) = 0x00000000
[ 3071.787110]
[ 3071.787110] syncpt_thresh_int_mask(11) = 0x00000000
[ 3071.787112]
---- host syncpt irq status ----
[ 3071.787113] syncpt_thresh_int_mask(0) = 0x00000001
[ 3071.787116] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 3071.787116] syncpt_thresh_int_mask(1) = 0x00055000
[ 3071.787119] syncpt_thresh_int_mask(2) = 0x00004140
[ 3071.787119] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 3071.787121] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 3071.787122] syncpt_thresh_int_mask(3) = 0x00000000
[ 3071.787124] syncpt_thresh_int_mask(4) = 0x00000000
[ 3071.787125] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 3071.787127] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 3071.787127] syncpt_thresh_int_mask(5) = 0x00000000
[ 3071.787129] syncpt_thresh_int_mask(6) = 0x00000000
[ 3071.787130] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 3071.787131]
---- host syncpt thresh ----
[ 3071.787132] syncpt_thresh_int_mask(7) = 0x00000000
[ 3071.787134] syncpt_thresh_int_mask(8) = 0x00000000
[ 3071.787135] syncpt_int_thresh_thresh_0(0) = 1
[ 3071.787138] syncpt_thresh_int_mask(9) = 0x00000000
[ 3071.787140] syncpt_thresh_int_mask(10) = 0x00000000
[ 3071.787143] syncpt_thresh_int_mask(11) = 0x00000000
[ 3071.787145]
[ 3071.787148] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 3071.787149] syncpt_int_thresh_thresh_0(22) = 79587
[ 3071.787151] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 3071.787151] syncpt_int_thresh_thresh_0(23) = 1
[ 3071.787154] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 3071.787154] syncpt_int_thresh_thresh_0(24) = 8
[ 3071.787157] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 3071.787157] syncpt_int_thresh_thresh_0(25) = 1
[ 3071.787159] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 3071.787162] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 3071.787164] syncpt_int_thresh_thresh_0(35) = 1
[ 3071.787164]
[ 3071.787167] syncpt_int_thresh_thresh_0(0) = 1
[ 3071.787168] syncpt_int_thresh_thresh_0(36) = 3
[ 3071.787171] syncpt_int_thresh_thresh_0(39) = 1
[ 3071.787180] syncpt_int_thresh_thresh_0(22) = 79587
[ 3071.787183] syncpt_int_thresh_thresh_0(23) = 1
[ 3071.787186] syncpt_int_thresh_thresh_0(24) = 8
[ 3071.787189] syncpt_int_thresh_thresh_0(25) = 1
[ 3071.787196] syncpt_int_thresh_thresh_0(35) = 1
[ 3071.787199] syncpt_int_thresh_thresh_0(36) = 3
[ 3071.787203] syncpt_int_thresh_thresh_0(39) = 1
[ 3071.850561] fence timeout on [ffffffc0adc4af00] after 1500ms
[ 3071.850569] name=[nvhost_sync:39], current value=0 waiting value=1
[ 3071.850574] ---- mlocks ----
[ 3071.850586] ---- syncpts ----
[ 3071.850594] id 1 (disp0_a) min 21781 max 21781 refs 1 (previous client : )
[ 3071.850598] id 2 (disp0_b) min 4 max 4 refs 1 (previous client : )
[ 3071.850601] id 3 (disp0_c) min 4 max 4 refs 1 (previous client : )
[ 3071.850608] id 8 (gm20b_507) min 496 max 496 refs 1 (previous client : )
[ 3071.850612] id 9 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 3071.850617] id 11 (gm20b_505) min 528 max 528 refs 1 (previous client : gm20b_505)
[ 3071.850620] id 12 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 3071.850624] id 13 (gm20b_503) min 540272 max 540272 refs 1 (previous client : )
[ 3071.850627] id 14 (gm20b_502) min 200 max 200 refs 1 (previous client : )
[ 3071.850631] id 15 (gm20b_501) min 113980 max 113980 refs 1 (previous client : gm20b_501)
[ 3071.850635] id 16 (gm20b_498) min 197880 max 197880 refs 1 (previous client : gm20b_498)
[ 3071.850639] id 17 (gm20b_497) min 52648 max 52648 refs 1 (previous client : gm20b_497)
[ 3071.850643] id 18 (54600000.isp_0) min 1441046 max 1441046 refs 1 (previous client : gm20b_496)
[ 3071.850647] id 19 (54600000.isp_1) min 482272 max 482272 refs 1 (previous client : gm20b_495)
[ 3071.850650] id 20 (54600000.isp_2) min 543212 max 543212 refs 1 (previous client : gm20b_494)
[ 3071.850654] id 21 (54600000.isp_3) min 678074 max 678074 refs 1 (previous client : gm20b_495)
[ 3071.850658] id 22 (54680000.isp_0) min 79586 max 79589 refs 4 (previous client : gm20b_494)
[ 3071.850661] id 23 (54680000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 3071.850665] id 24 (54680000.isp_2) min 7 max 15 refs 10 (previous client : )
[ 3071.850668] id 25 (54680000.isp_3) min 0 max 3 refs 4 (previous client : )
[ 3071.850672] id 26 (vblank0) min 44029 max -8 refs 1 (previous client : )
[ 3071.850676] id 28 (gm20b_496) min 704 max 704 refs 1 (previous client : )
[ 3071.850679] id 29 (gm20b_495) min 14 max 14 refs 1 (previous client : )
[ 3071.850682] id 30 (gm20b_494) min 2 max 2 refs 1 (previous client : )
[ 3071.850686] id 31 (gm20b_500) min 2 max 2 refs 1 (previous client : )
[ 3071.850689] id 32 (gm20b_499) min 6 max 6 refs 1 (previous client : )
[ 3071.850693] id 33 (gm20b_493) min 6 max 6 refs 1 (previous client : )
[ 3071.850697] id 35 (54080000.vi_1) min 0 max 3 refs 4 (previous client : 54080000.vi_1)
[ 3071.850701] id 36 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 3071.850705] id 39 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 3071.850709] id 40 (gm20b_492) min 8 max 8 refs 1 (previous client : )
[ 3071.850712] id 41 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 3071.850715] id 42 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 3071.850718] id 43 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 3071.850722] id 44 (gm20b_488) min 6 max 6 refs 1 (previous client : )
[ 3071.850725] id 45 (gm20b_487) min 6 max 6 refs 1 (previous client : )
[ 3071.850812] ---- channels ----
[ 3071.850818]
[ 3071.850824] 0-54340000.vic (0):
[ 3071.850826] inactive
[ 3071.850831]
[ 3071.850836] 1-54600000.isp (1):
[ 3071.850838] inactive
[ 3071.850841]
[ 3071.850846] 2-54680000.isp (18):
[ 3071.850850] active class 01, offset 0050, val 00000016
[ 3071.850853] DMAPUT 00000198, DMAGET 00000110, DMACTL 00000000
[ 3071.850855] CBREAD 00000016, CBSTAT 00010050
[ 3071.850860]
[ 3071.850866] GATHER at ffc80000+4c48, 8 words
[ 3071.850868] 20000001
[ 3071.850871] 00000416
[ 3071.850873] 20000001
[ 3071.850875] 00000517
[ 3071.850877] 20000001
[ 3071.850879] 00000619
[ 3071.850881] 200c0001
[ 3071.850883] 00000005
[ 3071.850889] GATHER at ffc80000+4c68, 2 words
[ 3071.850891] 20000001
[ 3071.850893] 00000018
[ 3071.850900]
[ 3071.850905] 3-54080000.vi (13):
[ 3071.850909] active class 01, offset 0050, val 00000023
[ 3071.850911] DMAPUT 00000100, DMAGET 00000100, DMACTL 00000000
[ 3071.850913] CBREAD 00000023, CBSTAT 00010050
[ 3071.850919]
[ 3071.850922] GATHER at ffbd8000+0000, 35 words
[ 3071.850924] 10620001
[ 3071.850926] 0000001f
[ 3071.850928] 10630002
[ 3071.850930] 00000000
[ 3071.850932] 00000000
[ 3071.850934] 103a0001
[ 3071.850936] 10100010
[ 3071.850937] 103c0001
[ 3071.850939] 10101010
[ 3071.850941] 10420001
[ 3071.850943] 00000001
[ 3071.850945] 10430006
[ 3071.850947] 00000000
[ 3071.850949] 001c984c
[ 3071.850951] 00000000
[ 3071.850953] 00000000
[ 3071.850955] 00000000
[ 3071.850957] 00000000
[ 3071.850959] 10590001
[ 3071.850960] 00000003
[ 3071.850963] 120e0006
[ 3071.850965] 007f0015
[ 3071.850967] 080301f0
[ 3071.850968] 00000000
[ 3071.850970] 00140000
[ 3071.850972] 0000f005
[ 3071.850974] 00000000
[ 3071.850976] 12420001
[ 3071.850978] 00000001
[ 3071.850980] 124b0003
[ 3071.850982] 00000000
[ 3071.850984] 00000000
[ 3071.850986] 00000000
[ 3071.850988] 128b0001
[ 3071.850989] 00000000
[ 3071.850995] GATHER at ffbd8000+008c, 3 words
[ 3071.850997] 304e0005
[ 3071.850999] 00000007
[ 3071.851001] 00000018
[ 3071.851006] GATHER at ffbd8000+0098, 17 words
[ 3071.851007] 10430006
[ 3071.851009] 00200004
[ 3071.851011] 001c984c
[ 3071.851013] 00000000
[ 3071.851015] 09a00cc0
[ 3071.851017] 00000ff0
[ 3071.851019] 0000002b
[ 3071.851021] 124b0003
[ 3071.851023] 00000000
[ 3071.851025] 00000000
[ 3071.851027] 00000008
[ 3071.851029] 20000001
[ 3071.851030] 00001d23
[ 3071.851032] 20000001
[ 3071.851034] 00000527
[ 3071.851036] 20410001
[ 3071.851038] 00000001
[ 3071.851043] GATHER at ffbd8000+00dc, 2 words
[ 3071.851044] 20000001
[ 3071.851047] 00000024
[ 3071.851053]
[ 3071.851055] sync_hintmask_ext = 0xc0000000
[ 3071.851058] sync_hintmask = 0x80000000
[ 3071.851060] sync_intc0mask = 0x00000001
[ 3071.851063] sync_intmask = 0x00000011
[ 3071.851064]
[ 3071.851068] syncpt_thresh_int_mask(0) = 0x00000001
[ 3071.851070] syncpt_thresh_int_mask(1) = 0x00055000
[ 3071.851073] syncpt_thresh_int_mask(2) = 0x00004140
[ 3071.851076] syncpt_thresh_int_mask(3) = 0x00000000
[ 3071.851078] syncpt_thresh_int_mask(4) = 0x00000000
[ 3071.851081] syncpt_thresh_int_mask(5) = 0x00000000
[ 3071.851083] syncpt_thresh_int_mask(6) = 0x00000000
[ 3071.851086] syncpt_thresh_int_mask(7) = 0x00000000
[ 3071.851088] syncpt_thresh_int_mask(8) = 0x00000000
[ 3071.851091] syncpt_thresh_int_mask(9) = 0x00000000
[ 3071.851093] syncpt_thresh_int_mask(10) = 0x00000000
[ 3071.851096] syncpt_thresh_int_mask(11) = 0x00000000
[ 3071.851098]
[ 3071.851101] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 3071.851103] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 3071.851106] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 3071.851108] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 3071.851111] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 3071.851113] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 3071.851115]
[ 3071.851118] syncpt_int_thresh_thresh_0(0) = 1
[ 3071.851131] syncpt_int_thresh_thresh_0(22) = 79587
[ 3071.851134] syncpt_int_thresh_thresh_0(23) = 1
[ 3071.851137] syncpt_int_thresh_thresh_0(24) = 8
[ 3071.851140] syncpt_int_thresh_thresh_0(25) = 1
[ 3071.851147] syncpt_int_thresh_thresh_0(35) = 1
[ 3071.851150] syncpt_int_thresh_thresh_0(36) = 3
[ 3071.851154] syncpt_int_thresh_thresh_0(39) = 1
[ 3073.290561] fence timeout on [ffffffc0adc4aa80] after 1500ms
[ 3073.290569] name=[nvhost_sync:23], current value=0 waiting value=2
[ 3073.290574] ---- mlocks ----
[ 3073.290586] ---- syncpts ----
[ 3073.290593] id 1 (disp0_a) min 21782 max 21782 refs 1 (previous client : )
[ 3073.290597] id 2 (disp0_b) min 4 max 4 refs 1 (previous client : )
[ 3073.290601] id 3 (disp0_c) min 4 max 4 refs 1 (previous client : )
[ 3073.290607] id 8 (gm20b_507) min 496 max 496 refs 1 (previous client : )
[ 3073.290611] id 9 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 3073.290615] id 11 (gm20b_505) min 528 max 528 refs 1 (previous client : gm20b_505)
[ 3073.290619] id 12 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 3073.290622] id 13 (gm20b_503) min 540276 max 540276 refs 1 (previous client : )
[ 3073.290626] id 14 (gm20b_502) min 200 max 200 refs 1 (previous client : )
[ 3073.290630] id 15 (gm20b_501) min 113984 max 113984 refs 1 (previous client : gm20b_501)
[ 3073.290634] id 16 (gm20b_498) min 197880 max 197880 refs 1 (previous client : gm20b_498)
[ 3073.290638] id 17 (gm20b_497) min 52648 max 52648 refs 1 (previous client : gm20b_497)
[ 3073.290642] id 18 (54600000.isp_0) min 1441046 max 1441046 refs 1 (previous client : gm20b_496)
[ 3073.290646] id 19 (54600000.isp_1) min 482272 max 482272 refs 1 (previous client : gm20b_495)
[ 3073.290650] id 20 (54600000.isp_2) min 543212 max 543212 refs 1 (previous client : gm20b_494)
[ 3073.290654] id 21 (54600000.isp_3) min 678074 max 678074 refs 1 (previous client : gm20b_495)
[ 3073.290657] id 22 (54680000.isp_0) min 79586 max 79590 refs 5 (previous client : gm20b_494)
[ 3073.290661] id 23 (54680000.isp_1) min 0 max 4 refs 5 (previous client : )
[ 3073.290664] id 24 (54680000.isp_2) min 7 max 18 refs 13 (previous client : )
[ 3073.290668] id 25 (54680000.isp_3) min 0 max 4 refs 5 (previous client : )
[ 3073.290672] id 26 (vblank0) min 44115 max -8 refs 1 (previous client : )
[ 3073.290676] id 28 (gm20b_496) min 704 max 704 refs 1 (previous client : )
[ 3073.290679] id 29 (gm20b_495) min 14 max 14 refs 1 (previous client : )
[ 3073.290683] id 30 (gm20b_494) min 2 max 2 refs 1 (previous client : )
[ 3073.290686] id 31 (gm20b_500) min 2 max 2 refs 1 (previous client : )
[ 3073.290690] id 32 (gm20b_499) min 6 max 6 refs 1 (previous client : )
[ 3073.290693] id 33 (gm20b_493) min 6 max 6 refs 1 (previous client : )
[ 3073.290697] id 35 (54080000.vi_1) min 0 max 4 refs 5 (previous client : 54080000.vi_1)
[ 3073.290701] id 36 (54080000.vi_2) min 2 max 9 refs 9 (previous client : 54080000.vi_2)
[ 3073.290706] id 39 (54080000.vi_4) min 0 max 4 refs 5 (previous client : 54080000.vi_4)
[ 3073.290709] id 40 (gm20b_492) min 8 max 8 refs 1 (previous client : )
[ 3073.290713] id 41 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 3073.290716] id 42 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 3073.290719] id 43 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 3073.290723] id 44 (gm20b_488) min 6 max 6 refs 1 (previous client : )
[ 3073.290726] id 45 (gm20b_487) min 6 max 6 refs 1 (previous client : )
[ 3073.290813] ---- channels ----
[ 3073.290818]
[ 3073.290824] 0-54340000.vic (0):
[ 3073.290826] inactive
[ 3073.290830]
[ 3073.290835] 1-54600000.isp (1):
[ 3073.290837] inactive
[ 3073.290840]
[ 3073.290845] 2-54680000.isp (24):
[ 3073.290848] active class 01, offset 0050, val 00000016
[ 3073.290851] DMAPUT 000001f0, DMAGET 00000110, DMACTL 00000000
[ 3073.290854] CBREAD 00000016, CBSTAT 00010050
[ 3073.290859]
[ 3073.290864] GATHER at ffc80000+4c48, 8 words
[ 3073.290867] 20000001
[ 3073.290869] 00000416
[ 3073.290871] 20000001
[ 3073.290873] 00000517
[ 3073.290875] 20000001
[ 3073.290878] 00000619
[ 3073.290880] 200c0001
[ 3073.290882] 00000005
[ 3073.290887] GATHER at ffc80000+4c68, 2 words
[ 3073.290889] 20000001
[ 3073.290891] 00000018
[ 3073.290898]
[ 3073.290903] 3-54080000.vi (17):
[ 3073.290906] active class 01, offset 0050, val 00000023
[ 3073.290909] DMAPUT 00000148, DMAGET 00000120, DMACTL 00000000
[ 3073.290912] CBREAD 00000023, CBSTAT 00010050
[ 3073.290916]
[ 3073.290920] GATHER at ffbd8000+0000, 35 words
[ 3073.290923] 10620001
[ 3073.290925] 0000001f
[ 3073.290927] 10630002
[ 3073.290929] 00000000
[ 3073.290930] 00000000
[ 3073.290933] 103a0001
[ 3073.290934] 10100010
[ 3073.290936] 103c0001
[ 3073.290938] 10101010
[ 3073.290940] 10420001
[ 3073.290942] 00000001
[ 3073.290944] 10430006
[ 3073.290946] 00000000
[ 3073.290948] 001c984c
[ 3073.290950] 00000000
[ 3073.290952] 00000000
[ 3073.290954] 00000000
[ 3073.290956] 00000000
[ 3073.290957] 10590001
[ 3073.290960] 00000003
[ 3073.290962] 120e0006
[ 3073.290964] 007f0015
[ 3073.290966] 080301f0
[ 3073.290968] 00000000
[ 3073.290970] 00140000
[ 3073.290972] 0000f005
[ 3073.290973] 00000000
[ 3073.290976] 12420001
[ 3073.290978] 00000001
[ 3073.290980] 124b0003
[ 3073.290982] 00000000
[ 3073.290984] 00000000
[ 3073.290986] 00000000
[ 3073.290988] 128b0001
[ 3073.290990] 00000000
[ 3073.290995] GATHER at ffbd8000+008c, 3 words
[ 3073.290997] 304e0005
[ 3073.290999] 00000007
[ 3073.291001] 00000018
[ 3073.291006] GATHER at ffbd8000+0098, 17 words
[ 3073.291008] 10430006
[ 3073.291010] 00200004
[ 3073.291012] 001c984c
[ 3073.291014] 00000000
[ 3073.291015] 09a00cc0
[ 3073.291017] 00000ff0
[ 3073.291019] 0000002b
[ 3073.291021] 124b0003
[ 3073.291023] 00000000
[ 3073.291025] 00000000
[ 3073.291027] 00000008
[ 3073.291029] 20000001
[ 3073.291031] 00001d23
[ 3073.291032] 20000001
[ 3073.291034] 00000527
[ 3073.291036] 20410001
[ 3073.291038] 00000001
[ 3073.291042] GATHER at ffbd8000+00dc, 2 words
[ 3073.291044] 20000001
[ 3073.291046] 00000024
[ 3073.291052]
[ 3073.291055] sync_hintmask_ext = 0xc0000000
[ 3073.291057] sync_hintmask = 0x80000000
[ 3073.291059] sync_intc0mask = 0x00000001
[ 3073.291062] sync_intmask = 0x00000011
[ 3073.291064]
[ 3073.291066] syncpt_thresh_int_mask(0) = 0x00000001
[ 3073.291069] syncpt_thresh_int_mask(1) = 0x00055000
[ 3073.291072] syncpt_thresh_int_mask(2) = 0x00004140
[ 3073.291074] syncpt_thresh_int_mask(3) = 0x00000000
[ 3073.291077] syncpt_thresh_int_mask(4) = 0x00000000
[ 3073.291079] syncpt_thresh_int_mask(5) = 0x00000000
[ 3073.291082] syncpt_thresh_int_mask(6) = 0x00000000
[ 3073.291084] syncpt_thresh_int_mask(7) = 0x00000000
[ 3073.291087] syncpt_thresh_int_mask(8) = 0x00000000
[ 3073.291089] syncpt_thresh_int_mask(9) = 0x00000000
[ 3073.291092] syncpt_thresh_int_mask(10) = 0x00000000
[ 3073.291094] syncpt_thresh_int_mask(11) = 0x00000000
[ 3073.291096]
[ 3073.291099] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 3073.291101] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 3073.291104] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 3073.291107] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 3073.291109] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 3073.291112] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 3073.291113]
[ 3073.291117] syncpt_int_thresh_thresh_0(0) = 1
[ 3073.291130] syncpt_int_thresh_thresh_0(22) = 79587
[ 3073.291133] syncpt_int_thresh_thresh_0(23) = 1
[ 3073.291136] syncpt_int_thresh_thresh_0(24) = 8
[ 3073.291139] syncpt_int_thresh_thresh_0(25) = 1
[ 3073.291146] syncpt_int_thresh_thresh_0(35) = 1
[ 3073.291149] syncpt_int_thresh_thresh_0(36) = 3
[ 3073.291153] syncpt_int_thresh_thresh_0(39) = 1
[ 3073.386550] fence timeout on [ffffffc026871e40] after 1500ms
[ 3073.386556] name=[nvhost_sync:39], current value=0 waiting value=4
[ 3073.386561] ---- mlocks ----
[ 3073.386573] ---- syncpts ----
[ 3073.386580] id 1 (disp0_a) min 21782 max 21782 refs 1 (previous client : )
[ 3073.386584] id 2 (disp0_b) min 4 max 4 refs 1 (previous client : )
[ 3073.386587] id 3 (disp0_c) min 4 max 4 refs 1 (previous client : )
[ 3073.386594] id 8 (gm20b_507) min 496 max 496 refs 1 (previous client : )
[ 3073.386597] id 9 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 3073.386602] id 11 (gm20b_505) min 528 max 528 refs 1 (previous client : gm20b_505)
[ 3073.386605] id 12 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 3073.386609] id 13 (gm20b_503) min 540276 max 540276 refs 1 (previous client : )
[ 3073.386612] id 14 (gm20b_502) min 200 max 200 refs 1 (previous client : )
[ 3073.386616] id 15 (gm20b_501) min 113984 max 113984 refs 1 (previous client : gm20b_501)
[ 3073.386620] id 16 (gm20b_498) min 197880 max 197880 refs 1 (previous client : gm20b_498)
[ 3073.386624] id 17 (gm20b_497) min 52648 max 52648 refs 1 (previous client : gm20b_497)
[ 3073.386628] id 18 (54600000.isp_0) min 1441046 max 1441046 refs 1 (previous client : gm20b_496)
[ 3073.386631] id 19 (54600000.isp_1) min 482272 max 482272 refs 1 (previous client : gm20b_495)
[ 3073.386635] id 20 (54600000.isp_2) min 543212 max 543212 refs 1 (previous client : gm20b_494)
[ 3073.386639] id 21 (54600000.isp_3) min 678074 max 678074 refs 1 (previous client : gm20b_495)
[ 3073.386642] id 22 (54680000.isp_0) min 79586 max 79590 refs 5 (previous client : gm20b_494)
[ 3073.386646] id 23 (54680000.isp_1) min 0 max 4 refs 5 (previous client : )
[ 3073.386650] id 24 (54680000.isp_2) min 7 max 18 refs 13 (previous client : )
[ 3073.386653] id 25 (54680000.isp_3) min 0 max 4 refs 5 (previous client : )
[ 3073.386657] id 26 (vblank0) min 44121 max -8 refs 1 (previous client : )
[ 3073.386661] id 28 (gm20b_496) min 704 max 704 refs 1 (previous client : )
[ 3073.386664] id 29 (gm20b_495) min 14 max 14 refs 1 (previous client : )
[ 3073.386668] id 30 (gm20b_494) min 2 max 2 refs 1 (previous client : )
[ 3073.386671] id 31 (gm20b_500) min 2 max 2 refs 1 (previous client : )
[ 3073.386675] id 32 (gm20b_499) min 6 max 6 refs 1 (previous client : )
[ 3073.386678] id 33 (gm20b_493) min 6 max 6 refs 1 (previous client : )
[ 3073.386682] id 35 (54080000.vi_1) min 0 max 4 refs 5 (previous client : 54080000.vi_1)
[ 3073.386685] id 36 (54080000.vi_2) min 2 max 9 refs 9 (previous client : 54080000.vi_2)
[ 3073.386690] id 39 (54080000.vi_4) min 0 max 4 refs 5 (previous client : 54080000.vi_4)
[ 3073.386694] id 40 (gm20b_492) min 8 max 8 refs 1 (previous client : )
[ 3073.386697] id 41 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 3073.386700] id 42 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 3073.386704] id 43 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 3073.386707] id 44 (gm20b_488) min 6 max 6 refs 1 (previous client : )
[ 3073.386710] id 45 (gm20b_487) min 6 max 6 refs 1 (previous client : )
[ 3073.386797] ---- channels ----
[ 3073.386803]
[ 3073.386809] 0-54340000.vic (0):
[ 3073.386811] inactive
[ 3073.386814]
[ 3073.386820] 1-54600000.isp (1):
[ 3073.386822] inactive
[ 3073.386825]
[ 3073.386830] 2-54680000.isp (24):
[ 3073.386834] active class 01, offset 0050, val 00000016
[ 3073.386837] DMAPUT 000001f0, DMAGET 00000110, DMACTL 00000000
[ 3073.386839] CBREAD 00000016, CBSTAT 00010050
[ 3073.386844]
[ 3073.386850] GATHER at ffc80000+4c48, 8 words
[ 3073.386852] 20000001
[ 3073.386854] 00000416
[ 3073.386856] 20000001
[ 3073.386859] 00000517
[ 3073.386860] 20000001
[ 3073.386863] 00000619
[ 3073.386864] 200c0001
[ 3073.386866] 00000005
[ 3073.386872] GATHER at ffc80000+4c68, 2 words
[ 3073.386874] 20000001
[ 3073.386876] 00000018
[ 3073.386883]
[ 3073.386888] 3-54080000.vi (17):
[ 3073.386891] active class 01, offset 0050, val 00000023
[ 3073.386893] DMAPUT 00000148, DMAGET 00000120, DMACTL 00000000
[ 3073.386896] CBREAD 00000023, CBSTAT 00010050
[ 3073.386900]
[ 3073.386904] GATHER at ffbd8000+0000, 35 words
[ 3073.386906] 10620001
[ 3073.386908] 0000001f
[ 3073.386910] 10630002
[ 3073.386912] 00000000
[ 3073.386914] 00000000
[ 3073.386916] 103a0001
[ 3073.386917] 10100010
[ 3073.386919] 103c0001
[ 3073.386921] 10101010
[ 3073.386923] 10420001
[ 3073.386925] 00000001
[ 3073.386927] 10430006
[ 3073.386929] 00000000
[ 3073.386931] 001c984c
[ 3073.386932] 00000000
[ 3073.386934] 00000000
[ 3073.386936] 00000000
[ 3073.386938] 00000000
[ 3073.386940] 10590001
[ 3073.386942] 00000003
[ 3073.386943] 120e0006
[ 3073.386945] 007f0015
[ 3073.386947] 080301f0
[ 3073.386949] 00000000
[ 3073.386951] 00140000
[ 3073.386953] 0000f005
[ 3073.386955] 00000000
[ 3073.386957] 12420001
[ 3073.386959] 00000001
[ 3073.386961] 124b0003
[ 3073.386963] 00000000
[ 3073.386965] 00000000
[ 3073.386966] 00000000
[ 3073.386968] 128b0001
[ 3073.386970] 00000000
[ 3073.386975] GATHER at ffbd8000+008c, 3 words
[ 3073.386977] 304e0005
[ 3073.386979] 00000007
[ 3073.386981] 00000018
[ 3073.386986] GATHER at ffbd8000+0098, 17 words
[ 3073.386988] 10430006
[ 3073.386990] 00200004
[ 3073.386992] 001c984c
[ 3073.386994] 00000000
[ 3073.386996] 09a00cc0
[ 3073.386998] 00000ff0
[ 3073.387000] 0000002b
[ 3073.387002] 124b0003
[ 3073.387003] 00000000
[ 3073.387005] 00000000
[ 3073.387007] 00000008
[ 3073.387009] 20000001
[ 3073.387011] 00001d23
[ 3073.387013] 20000001
[ 3073.387015] 00000527
[ 3073.387017] 20410001
[ 3073.387019] 00000001
[ 3073.387023] GATHER at ffbd8000+00dc, 2 words
[ 3073.387025] 20000001
[ 3073.387028] 00000024
[ 3073.387034]
[ 3073.387036] sync_hintmask_ext = 0xc0000000
[ 3073.387039] sync_hintmask = 0x80000000
[ 3073.387041] sync_intc0mask = 0x00000001
[ 3073.387044] sync_intmask = 0x00000011
[ 3073.387046]
[ 3073.387049] syncpt_thresh_int_mask(0) = 0x00000001
[ 3073.387052] syncpt_thresh_int_mask(1) = 0x00055000
[ 3073.387054] syncpt_thresh_int_mask(2) = 0x00004140
[ 3073.387057] syncpt_thresh_int_mask(3) = 0x00000000
[ 3073.387059] syncpt_thresh_int_mask(4) = 0x00000000
[ 3073.387062] syncpt_thresh_int_mask(5) = 0x00000000
[ 3073.387065] syncpt_thresh_int_mask(6) = 0x00000000
[ 3073.387067] syncpt_thresh_int_mask(7) = 0x00000000
[ 3073.387069] syncpt_thresh_int_mask(8) = 0x00000000
[ 3073.387072] syncpt_thresh_int_mask(9) = 0x00000000
[ 3073.387075] syncpt_thresh_int_mask(10) = 0x00000000
[ 3073.387077] syncpt_thresh_int_mask(11) = 0x00000000
[ 3073.387079]
[ 3073.387082] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 3073.387084] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 3073.387087] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 3073.387089] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 3073.387092] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 3073.387094] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 3073.387096]
[ 3073.387100] syncpt_int_thresh_thresh_0(0) = 1
[ 3073.387112] syncpt_int_thresh_thresh_0(22) = 79587
[ 3073.387115] syncpt_int_thresh_thresh_0(23) = 1
[ 3073.387118] syncpt_int_thresh_thresh_0(24) = 8
[ 3073.387121] syncpt_int_thresh_thresh_0(25) = 1
[ 3073.387128] syncpt_int_thresh_thresh_0(35) = 1
[ 3073.387131] syncpt_int_thresh_thresh_0(36) = 3
[ 3073.387135] syncpt_int_thresh_thresh_0(39) = 1
[ 3074.794584] fence timeout on [ffffffc0adc4ac00] after 1500ms
[ 3074.794592] name=[nvhost_sync:23], current value=0 waiting value=3
[ 3074.794598] ---- mlocks ----
[ 3074.794611] ---- syncpts ----
[ 3074.794618] id 1 (disp0_a) min 21782 max 21782 refs 1 (previous client : )
[ 3074.794622] id 2 (disp0_b) min 4 max 4 refs 1 (previous client : )
[ 3074.794626] id 3 (disp0_c) min 4 max 4 refs 1 (previous client : )
[ 3074.794633] id 8 (gm20b_507) min 496 max 496 refs 1 (previous client : )
[ 3074.794636] id 9 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 3074.794641] id 11 (gm20b_505) min 528 max 528 refs 1 (previous client : gm20b_505)
[ 3074.794644] id 12 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 3074.794648] id 13 (gm20b_503) min 540276 max 540276 refs 1 (previous client : )
[ 3074.794652] id 14 (gm20b_502) min 200 max 200 refs 1 (previous client : )
[ 3074.794655] id 15 (gm20b_501) min 113984 max 113984 refs 1 (previous client : gm20b_501)
[ 3074.794660] id 16 (gm20b_498) min 197880 max 197880 refs 1 (previous client : gm20b_498)
[ 3074.794664] id 17 (gm20b_497) min 52648 max 52648 refs 1 (previous client : gm20b_497)
[ 3074.794667] id 18 (54600000.isp_0) min 1441046 max 1441046 refs 1 (previous client : gm20b_496)
[ 3074.794671] id 19 (54600000.isp_1) min 482272 max 482272 refs 1 (previous client : gm20b_495)
[ 3074.794675] id 20 (54600000.isp_2) min 543212 max 543212 refs 1 (previous client : gm20b_494)
[ 3074.794678] id 21 (54600000.isp_3) min 678074 max 678074 refs 1 (previous client : gm20b_495)
[ 3074.794682] id 22 (54680000.isp_0) min 79586 max 79590 refs 5 (previous client : gm20b_494)
[ 3074.794685] id 23 (54680000.isp_1) min 0 max 4 refs 5 (previous client : )
[ 3074.794689] id 24 (54680000.isp_2) min 7 max 18 refs 13 (previous client : )
[ 3074.794693] id 25 (54680000.isp_3) min 0 max 4 refs 5 (previous client : )
[ 3074.794696] id 26 (vblank0) min 44205 max -8 refs 1 (previous client : )
[ 3074.794700] id 28 (gm20b_496) min 704 max 704 refs 1 (previous client : )
[ 3074.794703] id 29 (gm20b_495) min 14 max 14 refs 1 (previous client : )
[ 3074.794706] id 30 (gm20b_494) min 2 max 2 refs 1 (previous client : )
[ 3074.794710] id 31 (gm20b_500) min 2 max 2 refs 1 (previous client : )
[ 3074.794713] id 32 (gm20b_499) min 6 max 6 refs 1 (previous client : )
[ 3074.794716] id 33 (gm20b_493) min 6 max 6 refs 1 (previous client : )
[ 3074.794720] id 35 (54080000.vi_1) min 0 max 4 refs 5 (previous client : 54080000.vi_1)
[ 3074.794724] id 36 (54080000.vi_2) min 2 max 9 refs 9 (previous client : 54080000.vi_2)
[ 3074.794728] id 39 (54080000.vi_4) min 0 max 4 refs 5 (previous client : 54080000.vi_4)
[ 3074.794732] id 40 (gm20b_492) min 8 max 8 refs 1 (previous client : )
[ 3074.794735] id 41 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 3074.794738] id 42 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 3074.794741] id 43 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 3074.794744] id 44 (gm20b_488) min 6 max 6 refs 1 (previous client : )
[ 3074.794748] id 45 (gm20b_487) min 6 max 6 refs 1 (previous client : )
[ 3074.794836] ---- channels ----
[ 3074.794842]
[ 3074.794848] 0-54340000.vic (0):
[ 3074.794850] inactive
[ 3074.794867]
[ 3074.794872] 1-54600000.isp (1):
[ 3074.794874] inactive
[ 3074.794878]
[ 3074.794883] 2-54680000.isp (24):
[ 3074.794887] active class 01, offset 0050, val 00000016
[ 3074.794890] DMAPUT 000001f0, DMAGET 00000110, DMACTL 00000000
[ 3074.794892] CBREAD 00000016, CBSTAT 00010050
[ 3074.794897]
[ 3074.794903] GATHER at ffc80000+4c48, 8 words
[ 3074.794906] 20000001
[ 3074.794909] 00000416
[ 3074.794911] 20000001
[ 3074.794913] 00000517
[ 3074.794915] 20000001
[ 3074.794917] 00000619
[ 3074.794919] 200c0001
[ 3074.794921] 00000005
[ 3074.794927] GATHER at ffc80000+4c68, 2 words
[ 3074.794929] 20000001
[ 3074.794931] 00000018
[ 3074.794937]
[ 3074.794943] 3-54080000.vi (17):
[ 3074.794946] active class 01, offset 0050, val 00000023
[ 3074.794948] DMAPUT 00000148, DMAGET 00000120, DMACTL 00000000
[ 3074.794951] CBREAD 00000023, CBSTAT 00010050
[ 3074.794956]
[ 3074.794960] GATHER at ffbd8000+0000, 35 words
[ 3074.794963] 10620001
[ 3074.794965] 0000001f
[ 3074.794966] 10630002
[ 3074.794969] 00000000
[ 3074.794970] 00000000
[ 3074.794972] 103a0001
[ 3074.794974] 10100010
[ 3074.794976] 103c0001
[ 3074.794978] 10101010
[ 3074.794980] 10420001
[ 3074.794982] 00000001
[ 3074.794984] 10430006
[ 3074.794986] 00000000
[ 3074.794988] 001c984c
[ 3074.794990] 00000000
[ 3074.794992] 00000000
[ 3074.794993] 00000000
[ 3074.794995] 00000000
[ 3074.794997] 10590001
[ 3074.794999] 00000003
[ 3074.795001] 120e0006
[ 3074.795003] 007f0015
[ 3074.795005] 080301f0
[ 3074.795007] 00000000
[ 3074.795009] 00140000
[ 3074.795011] 0000f005
[ 3074.795012] 00000000
[ 3074.795014] 12420001
[ 3074.795016] 00000001
[ 3074.795018] 124b0003
[ 3074.795020] 00000000
[ 3074.795022] 00000000
[ 3074.795024] 00000000
[ 3074.795026] 128b0001
[ 3074.795028] 00000000
[ 3074.795033] GATHER at ffbd8000+008c, 3 words
[ 3074.795035] 304e0005
[ 3074.795037] 00000007
[ 3074.795039] 00000018
[ 3074.795044] GATHER at ffbd8000+0098, 17 words
[ 3074.795045] 10430006
[ 3074.795048] 00200004
[ 3074.795049] 001c984c
[ 3074.795051] 00000000
[ 3074.795053] 09a00cc0
[ 3074.795055] 00000ff0
[ 3074.795057] 0000002b
[ 3074.795059] 124b0003
[ 3074.795061] 00000000
[ 3074.795063] 00000000
[ 3074.795065] 00000008
[ 3074.795067] 20000001
[ 3074.795069] 00001d23
[ 3074.795071] 20000001
[ 3074.795073] 00000527
[ 3074.795075] 20410001
[ 3074.795077] 00000001
[ 3074.795081] GATHER at ffbd8000+00dc, 2 words
[ 3074.795083] 20000001
[ 3074.795085] 00000024
[ 3074.795091]
[ 3074.795094] sync_hintmask_ext = 0xc0000000
[ 3074.795096] sync_hintmask = 0x80000000
[ 3074.795099] sync_intc0mask = 0x00000001
[ 3074.795101] sync_intmask = 0x00000011
[ 3074.795103]
[ 3074.795106] syncpt_thresh_int_mask(0) = 0x00000001
[ 3074.795109] syncpt_thresh_int_mask(1) = 0x00055000
[ 3074.795111] syncpt_thresh_int_mask(2) = 0x00004140
[ 3074.795114] syncpt_thresh_int_mask(3) = 0x00000000
[ 3074.795116] syncpt_thresh_int_mask(4) = 0x00000000
[ 3074.795119] syncpt_thresh_int_mask(5) = 0x00000000
[ 3074.795121] syncpt_thresh_int_mask(6) = 0x00000000
[ 3074.795124] syncpt_thresh_int_mask(7) = 0x00000000
[ 3074.795126] syncpt_thresh_int_mask(8) = 0x00000000
[ 3074.795129] syncpt_thresh_int_mask(9) = 0x00000000
[ 3074.795131] syncpt_thresh_int_mask(10) = 0x00000000
[ 3074.795134] syncpt_thresh_int_mask(11) = 0x00000000
[ 3074.795135]
[ 3074.795138] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 3074.795141] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 3074.795143] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 3074.795146] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 3074.795148] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 3074.795151] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 3074.795152]
[ 3074.795156] syncpt_int_thresh_thresh_0(0) = 1
[ 3074.795169] syncpt_int_thresh_thresh_0(22) = 79587
[ 3074.795172] syncpt_int_thresh_thresh_0(23) = 1
[ 3074.795175] syncpt_int_thresh_thresh_0(24) = 8
[ 3074.795177] syncpt_int_thresh_thresh_0(25) = 1
[ 3074.795184] syncpt_int_thresh_thresh_0(35) = 1
[ 3074.795187] syncpt_int_thresh_thresh_0(36) = 3
[ 3074.795191] syncpt_int_thresh_thresh_0(39) = 1
[ 3076.938495] fence timeout on [ffffffc026871540] after 1500ms
[ 3076.938503] name=[nvhost_sync:23], current value=0 waiting value=4
[ 3076.938509] ---- mlocks ----
[ 3076.938522] ---- syncpts ----
[ 3076.938529] id 1 (disp0_a) min 21782 max 21782 refs 1 (previous client : )
[ 3076.938533] id 2 (disp0_b) min 4 max 4 refs 1 (previous client : )
[ 3076.938537] id 3 (disp0_c) min 4 max 4 refs 1 (previous client : )
[ 3076.938543] id 8 (gm20b_507) min 496 max 496 refs 1 (previous client : )
[ 3076.938547] id 9 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 3076.938552] id 11 (gm20b_505) min 528 max 528 refs 1 (previous client : gm20b_505)
[ 3076.938556] id 12 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 3076.938560] id 13 (gm20b_503) min 540276 max 540276 refs 1 (previous client : )
[ 3076.938564] id 14 (gm20b_502) min 200 max 200 refs 1 (previous client : )
[ 3076.938567] id 15 (gm20b_501) min 113984 max 113984 refs 1 (previous client : gm20b_501)
[ 3076.938572] id 16 (gm20b_498) min 197880 max 197880 refs 1 (previous client : gm20b_498)
[ 3076.938576] id 17 (gm20b_497) min 52648 max 52648 refs 1 (previous client : gm20b_497)
[ 3076.938580] id 18 (54600000.isp_0) min 1441046 max 1441046 refs 1 (previous client : gm20b_496)
[ 3076.938584] id 19 (54600000.isp_1) min 482272 max 482272 refs 1 (previous client : gm20b_495)
[ 3076.938588] id 20 (54600000.isp_2) min 543212 max 543212 refs 1 (previous client : gm20b_494)
[ 3076.938591] id 21 (54600000.isp_3) min 678074 max 678074 refs 1 (previous client : gm20b_495)
[ 3076.938595] id 22 (54680000.isp_0) min 79586 max 79590 refs 5 (previous client : gm20b_494)
[ 3076.938598] id 23 (54680000.isp_1) min 0 max 4 refs 5 (previous client : )
[ 3076.938602] id 24 (54680000.isp_2) min 7 max 18 refs 13 (previous client : )
[ 3076.938606] id 25 (54680000.isp_3) min 0 max 4 refs 5 (previous client : )
[ 3076.938609] id 26 (vblank0) min 44334 max -8 refs 1 (previous client : )
[ 3076.938614] id 28 (gm20b_496) min 704 max 704 refs 1 (previous client : )
[ 3076.938617] id 29 (gm20b_495) min 14 max 14 refs 1 (previous client : )
[ 3076.938621] id 30 (gm20b_494) min 2 max 2 refs 1 (previous client : )
[ 3076.938624] id 31 (gm20b_500) min 2 max 2 refs 1 (previous client : )
[ 3076.938628] id 32 (gm20b_499) min 6 max 6 refs 1 (previous client : )
[ 3076.938631] id 33 (gm20b_493) min 6 max 6 refs 1 (previous client : )
[ 3076.938635] id 35 (54080000.vi_1) min 0 max 4 refs 5 (previous client : 54080000.vi_1)
[ 3076.938639] id 36 (54080000.vi_2) min 2 max 9 refs 9 (previous client : 54080000.vi_2)
[ 3076.938643] id 39 (54080000.vi_4) min 0 max 4 refs 5 (previous client : 54080000.vi_4)
[ 3076.938647] id 40 (gm20b_492) min 8 max 8 refs 1 (previous client : )
[ 3076.938650] id 41 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 3076.938653] id 42 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 3076.938657] id 43 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 3076.938660] id 44 (gm20b_488) min 6 max 6 refs 1 (previous client : )
[ 3076.938663] id 45 (gm20b_487) min 6 max 6 refs 1 (previous client : )
[ 3076.938751] ---- channels ----
[ 3076.938756]
[ 3076.938762] 0-54340000.vic (0):
[ 3076.938764] inactive
[ 3076.938768]
[ 3076.938773] 1-54600000.isp (1):
[ 3076.938775] inactive
[ 3076.938778]
[ 3076.938783] 2-54680000.isp (24):
[ 3076.938787] active class 01, offset 0050, val 00000016
[ 3076.938790] DMAPUT 000001f0, DMAGET 00000110, DMACTL 00000000
[ 3076.938793] CBREAD 00000016, CBSTAT 00010050
[ 3076.938799]
[ 3076.938804] GATHER at ffc80000+4c48, 8 words
[ 3076.938806] 20000001
[ 3076.938809] 00000416
[ 3076.938811] 20000001
[ 3076.938813] 00000517
[ 3076.938815] 20000001
[ 3076.938817] 00000619
[ 3076.938819] 200c0001
[ 3076.938821] 00000005
[ 3076.938826] GATHER at ffc80000+4c68, 2 words
[ 3076.938828] 20000001
[ 3076.938831] 00000018
[ 3076.938837]
[ 3076.938842] 3-54080000.vi (17):
[ 3076.938846] active class 01, offset 0050, val 00000023
[ 3076.938848] DMAPUT 00000148, DMAGET 00000120, DMACTL 00000000
[ 3076.938851] CBREAD 00000023, CBSTAT 00010050
[ 3076.938856]
[ 3076.938861] GATHER at ffbd8000+0000, 35 words
[ 3076.938863] 10620001
[ 3076.938865] 0000001f
[ 3076.938867] 10630002
[ 3076.938869] 00000000
[ 3076.938871] 00000000
[ 3076.938873] 103a0001
[ 3076.938875] 10100010
[ 3076.938877] 103c0001
[ 3076.938878] 10101010
[ 3076.938880] 10420001
[ 3076.938882] 00000001
[ 3076.938884] 10430006
[ 3076.938886] 00000000
[ 3076.938888] 001c984c
[ 3076.938890] 00000000
[ 3076.938892] 00000000
[ 3076.938894] 00000000
[ 3076.938896] 00000000
[ 3076.938898] 10590001
[ 3076.938900] 00000003
[ 3076.938902] 120e0006
[ 3076.938904] 007f0015
[ 3076.938906] 080301f0
[ 3076.938908] 00000000
[ 3076.938909] 00140000
[ 3076.938911] 0000f005
[ 3076.938913] 00000000
[ 3076.938915] 12420001
[ 3076.938917] 00000001
[ 3076.938919] 124b0003
[ 3076.938921] 00000000
[ 3076.938923] 00000000
[ 3076.938925] 00000000
[ 3076.938927] 128b0001
[ 3076.938929] 00000000
[ 3076.938934] GATHER at ffbd8000+008c, 3 words
[ 3076.938936] 304e0005
[ 3076.938938] 00000007
[ 3076.938940] 00000018
[ 3076.938944] GATHER at ffbd8000+0098, 17 words
[ 3076.938946] 10430006
[ 3076.938948] 00200004
[ 3076.938950] 001c984c
[ 3076.938952] 00000000
[ 3076.938954] 09a00cc0
[ 3076.938956] 00000ff0
[ 3076.938958] 0000002b
[ 3076.938960] 124b0003
[ 3076.938962] 00000000
[ 3076.938964] 00000000
[ 3076.938965] 00000008
[ 3076.938967] 20000001
[ 3076.938969] 00001d23
[ 3076.938971] 20000001
[ 3076.938973] 00000527
[ 3076.938975] 20410001
[ 3076.938977] 00000001
[ 3076.938981] GATHER at ffbd8000+00dc, 2 words
[ 3076.938983] 20000001
[ 3076.938985] 00000024
[ 3076.938991]
[ 3076.938993] sync_hintmask_ext = 0xc0000000
[ 3076.938996] sync_hintmask = 0x80000000
[ 3076.938998] sync_intc0mask = 0x00000001
[ 3076.939001] sync_intmask = 0x00000011
[ 3076.939003]
[ 3076.939006] syncpt_thresh_int_mask(0) = 0x00000001
[ 3076.939008] syncpt_thresh_int_mask(1) = 0x00055000
[ 3076.939011] syncpt_thresh_int_mask(2) = 0x00004140
[ 3076.939013] syncpt_thresh_int_mask(3) = 0x00000000
[ 3076.939016] syncpt_thresh_int_mask(4) = 0x00000000
[ 3076.939018] syncpt_thresh_int_mask(5) = 0x00000000
[ 3076.939021] syncpt_thresh_int_mask(6) = 0x00000000
[ 3076.939023] syncpt_thresh_int_mask(7) = 0x00000000
[ 3076.939025] syncpt_thresh_int_mask(8) = 0x00000000
[ 3076.939028] syncpt_thresh_int_mask(9) = 0x00000000
[ 3076.939030] syncpt_thresh_int_mask(10) = 0x00000000
[ 3076.939033] syncpt_thresh_int_mask(11) = 0x00000000
[ 3076.939035]
[ 3076.939038] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 3076.939040] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 3076.939043] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 3076.939045] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 3076.939048] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 3076.939050] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 3076.939052]
[ 3076.939056] syncpt_int_thresh_thresh_0(0) = 1
[ 3076.939069] syncpt_int_thresh_thresh_0(22) = 79587
[ 3076.939072] syncpt_int_thresh_thresh_0(23) = 1
[ 3076.939074] syncpt_int_thresh_thresh_0(24) = 8
[ 3076.939077] syncpt_int_thresh_thresh_0(25) = 1
[ 3076.939084] syncpt_int_thresh_thresh_0(35) = 1
[ 3076.939087] syncpt_int_thresh_thresh_0(36) = 3
[ 3076.939091] syncpt_int_thresh_thresh_0(39) = 1
[ 3080.522451] host1x 50000000.host1x: cdma_handle_timeout: timeout: 35 (54080000.vi_1) client 12, HW thresh 0, done 1
[ 3080.532977] host1x 50000000.host1x: cdma_handle_timeout: timeout: 39 (54080000.vi_4) client 12, HW thresh 0, done 1
[ 3080.543430] host1x 50000000.host1x: cdma_handle_timeout: timeout: 36 (54080000.vi_2) client 12, HW thresh 2, done 2
[ 3080.554017] ---- mlocks ----
[ 3080.554030] ---- syncpts ----
[ 3080.554038] id 1 (disp0_a) min 21784 max 21784 refs 1 (previous client : )
[ 3080.554042] id 2 (disp0_b) min 4 max 4 refs 1 (previous client : )
[ 3080.554047] id 3 (disp0_c) min 4 max 4 refs 1 (previous client : )
[ 3080.554053] id 8 (gm20b_507) min 496 max 496 refs 1 (previous client : )
[ 3080.554057] id 9 (gm20b_506) min 22 max 22 refs 1 (previous client : )
[ 3080.554062] id 11 (gm20b_505) min 528 max 528 refs 1 (previous client : gm20b_505)
[ 3080.554065] id 12 (gm20b_504) min 6 max 6 refs 1 (previous client : )
[ 3080.554069] id 13 (gm20b_503) min 540284 max 540284 refs 1 (previous client : )
[ 3080.554072] id 14 (gm20b_502) min 200 max 200 refs 1 (previous client : )
[ 3080.554076] id 15 (gm20b_501) min 113994 max 113994 refs 1 (previous client : gm20b_501)
[ 3080.554081] id 16 (gm20b_498) min 197880 max 197880 refs 1 (previous client : gm20b_498)
[ 3080.554085] id 17 (gm20b_497) min 52648 max 52648 refs 1 (previous client : gm20b_497)
[ 3080.554089] id 18 (54600000.isp_0) min 1441046 max 1441046 refs 1 (previous client : gm20b_496)
[ 3080.554093] id 19 (54600000.isp_1) min 482272 max 482272 refs 1 (previous client : gm20b_495)
[ 3080.554096] id 20 (54600000.isp_2) min 543212 max 543212 refs 1 (previous client : gm20b_494)
[ 3080.554100] id 21 (54600000.isp_3) min 678074 max 678074 refs 1 (previous client : gm20b_495)
[ 3080.554104] id 22 (54680000.isp_0) min 79586 max 79590 refs 5 (previous client : gm20b_494)
[ 3080.554107] id 23 (54680000.isp_1) min 0 max 4 refs 5 (previous client : )
[ 3080.554111] id 24 (54680000.isp_2) min 7 max 18 refs 13 (previous client : )
[ 3080.554114] id 25 (54680000.isp_3) min 0 max 4 refs 5 (previous client : )
[ 3080.554118] id 26 (vblank0) min 44551 max -8 refs 1 (previous client : )
[ 3080.554122] id 28 (gm20b_496) min 704 max 704 refs 1 (previous client : )
[ 3080.554126] id 29 (gm20b_495) min 14 max 14 refs 1 (previous client : )
[ 3080.554129] id 30 (gm20b_494) min 2 max 2 refs 1 (previous client : )
[ 3080.554132] id 31 (gm20b_500) min 2 max 2 refs 1 (previous client : )
[ 3080.554136] id 32 (gm20b_499) min 6 max 6 refs 1 (previous client : )
[ 3080.554139] id 33 (gm20b_493) min 6 max 6 refs 1 (previous client : )
[ 3080.554143] id 35 (54080000.vi_1) min 0 max 4 refs 5 (previous client : 54080000.vi_1)
[ 3080.554147] id 36 (54080000.vi_2) min 2 max 9 refs 9 (previous client : 54080000.vi_2)
[ 3080.554151] id 39 (54080000.vi_4) min 0 max 4 refs 5 (previous client : 54080000.vi_4)
[ 3080.554155] id 40 (gm20b_492) min 8 max 8 refs 1 (previous client : )
[ 3080.554158] id 41 (gm20b_491) min 6 max 6 refs 1 (previous client : )
[ 3080.554161] id 42 (gm20b_490) min 6 max 6 refs 1 (previous client : )
[ 3080.554164] id 43 (gm20b_489) min 6 max 6 refs 1 (previous client : )
[ 3080.554168] id 44 (gm20b_488) min 6 max 6 refs 1 (previous client : )
[ 3080.554171] id 45 (gm20b_487) min 6 max 6 refs 1 (previous client : )
[ 3080.554258] ---- channels ----
[ 3080.554264]
[ 3080.554270] 0-54340000.vic (0):
[ 3080.554273] inactive
[ 3080.554277]
[ 3080.554282] 1-54600000.isp (1):
[ 3080.554284] inactive
[ 3080.554288]
[ 3080.554293] 2-54680000.isp (24):
[ 3080.554296] active class 01, offset 0050, val 00000016
[ 3080.554299] DMAPUT 000001f0, DMAGET 00000110, DMACTL 00000000
[ 3080.554302] CBREAD 00000016, CBSTAT 00010050
[ 3080.554307]
[ 3080.554313] GATHER at ffc80000+4c48, 8 words
[ 3080.554315] 20000001
[ 3080.554317] 00000416
[ 3080.554319] 20000001
[ 3080.554322] 00000517
[ 3080.554324] 20000001
[ 3080.554326] 00000619
[ 3080.554328] 200c0001
[ 3080.554330] 00000005
[ 3080.554335] GATHER at ffc80000+4c68, 2 words
[ 3080.554337] 20000001
[ 3080.554339] 00000018
[ 3080.554346]
[ 3080.554351] 3-54080000.vi (17):
[ 3080.554354] active class 01, offset 0050, val 00000023
[ 3080.554357] DMAPUT 00000148, DMAGET 00000120, DMACTL 00000000
[ 3080.554360] CBREAD 00000023, CBSTAT 00010050
[ 3080.554364]
[ 3080.554369] GATHER at ffbd8000+0000, 35 words
[ 3080.554371] 10620001
[ 3080.554373] 0000001f
[ 3080.554375] 10630002
[ 3080.554377] 00000000
[ 3080.554379] 00000000
[ 3080.554381] 103a0001
[ 3080.554383] 10100010
[ 3080.554385] 103c0001
[ 3080.554387] 10101010
[ 3080.554388] 10420001
[ 3080.554390] 00000001
[ 3080.554392] 10430006
[ 3080.554394] 00000000
[ 3080.554396] 001c984c
[ 3080.554398] 00000000
[ 3080.554400] 00000000
[ 3080.554402] 00000000
[ 3080.554404] 00000000
[ 3080.554406] 10590001
[ 3080.554408] 00000003
[ 3080.554431] 120e0006
[ 3080.554433] 007f0015
[ 3080.554435] 080301f0
[ 3080.554438] 00000000
[ 3080.554439] 00140000
[ 3080.554442] 0000f005
[ 3080.554443] 00000000
[ 3080.554445] 12420001
[ 3080.554447] 00000001
[ 3080.554449] 124b0003
[ 3080.554451] 00000000
[ 3080.554453] 00000000
[ 3080.554455] 00000000
[ 3080.554457] 128b0001
[ 3080.554458] 00000000
[ 3080.554464] GATHER at ffbd8000+008c, 3 words
[ 3080.554466] 304e0005
[ 3080.554468] 00000007
[ 3080.554470] 00000018
[ 3080.554475] GATHER at ffbd8000+0098, 17 words
[ 3080.554477] 10430006
[ 3080.554479] 00200004
[ 3080.554480] 001c984c
[ 3080.554482] 00000000
[ 3080.554484] 09a00cc0
[ 3080.554486] 00000ff0
[ 3080.554488] 0000002b
[ 3080.554490] 124b0003
[ 3080.554492] 00000000
[ 3080.554493] 00000000
[ 3080.554495] 00000008
[ 3080.554497] 20000001
[ 3080.554499] 00001d23
[ 3080.554501] 20000001
[ 3080.554503] 00000527
[ 3080.554505] 20410001
[ 3080.554507] 00000001
[ 3080.554514] GATHER at ffbd8000+00dc, 2 words
[ 3080.554516] 20000001
[ 3080.554518] 00000024
[ 3080.554525]
[ 3080.554527] sync_hintmask_ext = 0xc0000000
[ 3080.554530] sync_hintmask = 0x80000000
[ 3080.554532] sync_intc0mask = 0x00000001
[ 3080.554535] sync_intmask = 0x00000011
[ 3080.554537]
[ 3080.554540] syncpt_thresh_int_mask(0) = 0x00000001
[ 3080.554542] syncpt_thresh_int_mask(1) = 0x00055000
[ 3080.554545] syncpt_thresh_int_mask(2) = 0x00004140
[ 3080.554548] syncpt_thresh_int_mask(3) = 0x00000000
[ 3080.554550] syncpt_thresh_int_mask(4) = 0x00000000
[ 3080.554553] syncpt_thresh_int_mask(5) = 0x00000000
[ 3080.554555] syncpt_thresh_int_mask(6) = 0x00000000
[ 3080.554558] syncpt_thresh_int_mask(7) = 0x00000000
[ 3080.554560] syncpt_thresh_int_mask(8) = 0x00000000
[ 3080.554563] syncpt_thresh_int_mask(9) = 0x00000000
[ 3080.554565] syncpt_thresh_int_mask(10) = 0x00000000
[ 3080.554568] syncpt_thresh_int_mask(11) = 0x00000000
[ 3080.554570]
[ 3080.554573] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 3080.554576] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 3080.554579] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 3080.554581] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 3080.702297] isp 54680000.isp: TIMEOUT 10000
[ 3080.702300] isp 54680000.isp: NUM_SLOTS 5
[ 3080.702303] isp 54680000.isp: NUM_HANDLES 1
[ 3080.702307] isp 54680000.isp: SYNCPT_ID 24
[ 3080.702315] isp 54680000.isp: SYNCPT_VAL 16
[ 3080.702318] isp 54680000.isp: FIRST_GET 0x198
[ 3080.702320] isp 54680000.isp: TIMEOUT 10000
[ 3080.702323] isp 54680000.isp: NUM_SLOTS 3
[ 3080.702325] isp 54680000.isp: NUM_HANDLES 3
[ 3080.702333] isp 54680000.isp: SYNCPT_ID 22
[ 3080.702336] isp 54680000.isp: SYNCPT_VAL 79590
[ 3080.702338] isp 54680000.isp: FIRST_GET 0x1b0
[ 3080.702341] isp 54680000.isp: TIMEOUT 10000
[ 3080.702343] isp 54680000.isp: NUM_SLOTS 3
[ 3080.702346] isp 54680000.isp: NUM_HANDLES 1
[ 3080.702356] isp 54680000.isp: SYNCPT_ID 24
[ 3080.702359] isp 54680000.isp: SYNCPT_VAL 18
[ 3080.702362] isp 54680000.isp: FIRST_GET 0x1c8
[ 3080.702364] isp 54680000.isp: TIMEOUT 10000
[ 3080.702367] isp 54680000.isp: NUM_SLOTS 5
[ 3080.702369] isp 54680000.isp: NUM_HANDLES 1
[ 3129.006208] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3129.012853] regmap_util_write_table_8:regmap_util_write_table:-121
[ 3129.070014] imx219 6-0010: Error turning off streaming
[ 3214.688031] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 3214.688042] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 3214.701185] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 3214.709931] pcieport 0000:00:01.0: [ 0] Receiver Error (First)
[ 4005.126408] tegradc tegradc.0: blank - powerdown
[ 4005.178516] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 4005.178519] Extcon AUX1(HDMI) disable
[ 4026.254766] tegradc tegradc.0: unblank
[ 4026.259494] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 4026.259586] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 4026.260626] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 4026.260634] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 4026.298807] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4026.298810] Extcon AUX1(HDMI) enable
[ 4026.313413] tegradc tegradc.0: unblank
[ 4026.313423] tegradc tegradc.1: blank - powerdown
[ 4943.195352] tegradc tegradc.0: blank - powerdown
[ 4943.258535] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 4943.258537] Extcon AUX1(HDMI) disable
[ 5162.724799] tegradc tegradc.0: unblank
[ 5162.729550] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 5162.729644] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 5162.730678] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 5162.730686] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5162.765419] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5162.765422] Extcon AUX1(HDMI) enable
[ 5162.783547] tegradc tegradc.0: unblank
[ 5162.783557] tegradc tegradc.1: blank - powerdown
[ 5473.140531] tegradc tegradc.0: blank - powerdown
[ 5473.196832] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 5473.196834] Extcon AUX1(HDMI) disable
[ 5823.942781] tegradc tegradc.0: unblank
[ 5823.947540] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 5823.947635] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 5823.948667] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 5823.948675] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5823.984973] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5823.984975] Extcon AUX1(HDMI) enable
[ 5823.992857] tegradc tegradc.0: unblank
[ 5823.993150] tegradc tegradc.1: blank - powerdown
