Jetson nano not starting after deleting files in ~/.cache folder
I deleted all the files in ~./cache folder to make space in Jetson nano. After deleting those files the device is not starting, it only flashes Nvidia symbol once and then flashes black screen again and again.
I can ssh into my device and also use remote desktop.
Any solution?
Could you dump the dmesg? Need to check if any error in kernel.
How can I get the dmesg? @WayneWWW
ssh to your device and type command dmesg. Copy the result and attach it here.
my output @WayneWWW
user:~$ dmesg
[ 1.262652] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.262672] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.262675] parse_throttle_dt_data: clk=emc type=3
[ 1.263043] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.263166] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.263304] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.263932] FAN dev name: pwm-fan
[ 1.263974] FAN:gpio request success.
[ 1.264029] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.264252] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.264364] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.264369] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.264444] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.264448] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.264452] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.264456] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.264460] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.264464] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.264468] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.264471] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.264475] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.264479] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.265089] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.265355] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.266184] device-mapper: uevent: version 1.0.3
[ 1.266849] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.272430] tegra210-cpufreq cpufreq: probe()…completed
[ 1.273199] sdhci: Secure Digital Host Controller Interface driver
[ 1.273200] sdhci: Copyright(c) Pierre Ossman
[ 1.273202] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.273677] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.274044] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.274170] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.279078] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.279678] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.280679] tegradc tegradc.0: unblank
[ 1.280817] usbcore: registered new interface driver usbhid
[ 1.280819] usbhid: USB HID core driver
[ 1.283088] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.283259] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.285300] nvpmodel: initialized successfully
[ 1.286383] usbcore: registered new interface driver snd-usb-audio
[ 1.286438] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.286442] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.286458] iommu: Adding device snd-soc-dummy to group 36
[ 1.294303] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.310546] OPE platform probe
[ 1.310633] OPE platform probe successful
[ 1.310885] OPE platform probe
[ 1.310965] OPE platform probe successful
[ 1.318055] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.320918] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 1.320974] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 1.321984] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.321990] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.334163] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.334298] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.334424] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.334547] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.334676] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.334802] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.334928] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.335052] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.335184] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.335308] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.347110] u32 classifier
[ 1.347112] Actions configured
[ 1.347188] Initializing XFRM netlink socket
[ 1.347869] NET: Registered protocol family 10
[ 1.348547] NET: Registered protocol family 17
[ 1.348557] NET: Registered protocol family 15
[ 1.348629] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.348678] Bluetooth: RFCOMM socket layer initialized
[ 1.348687] Bluetooth: RFCOMM ver 1.11
[ 1.348691] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.348696] Bluetooth: HIDP socket layer initialized
[ 1.348714] 9pnet: Installing 9P2000 support
[ 1.348747] Key type dns_resolver registered
[ 1.349135] Registered cp15_barrier emulation handler
[ 1.349141] Registered setend emulation handler
[ 1.350213] registered taskstats version 1
[ 1.350732] Adding domain ve2-pd to PM domain host1x-pd
[ 1.350982] Adding domain ve-pd to PM domain host1x-pd
[ 1.353024] isp 54600000.isp: initialized
[ 1.354013] isp 54680000.isp: initialized
[ 1.356973] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.356975] Extcon AUX1(HDMI) enable
[ 1.364242] last reset is due to power on reset
[ 1.364245] KERNEL: PMC reset status reg: 0x0
[ 1.364323] BL: PMC reset status reg: 0x0
[ 1.364325] BL: PMIC poweroff Event Recorder: 0x40
[ 1.365773] clk_cbus_recalc_rate: no gbus parent
[ 1.365777] clk_cbus_round_rate: no gbus parent
[ 1.365779] clk_cbus_round_rate: no gbus parent
[ 1.365785] clk_cbus_recalc_rate: no gbus parent
[ 1.365906] clk_cbus_recalc_rate: no gbus parent
[ 1.365909] clk_cbus_round_rate: no gbus parent
[ 1.365910] clk_cbus_round_rate: no gbus parent
[ 1.365913] clk_cbus_recalc_rate: no gbus parent
[ 1.366578] tegra_dvfs: GPU-cap: registered
[ 1.366631] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.366633] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.366634] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.368169] tegra_dvfs: vdd-gpu-vts: registered
[ 1.368935] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ā€˜floor cooling device’ registered
[ 1.369575] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ā€˜cap cooling device’ registered
[ 1.370145] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.372317] tegradc tegradc.0: sync windows ret = 246
[ 1.407264] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:16 UTC (946688416)
[ 1.408368] vi 54080000.vi: vi_probe: ++
[ 1.411117] vi 54080000.vi: initialized
[ 1.413149] vi 54080000.vi: subdev nvcsi–2 bound
[ 1.413262] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.414008] Disable partitions left on by BL
[ 1.414010] disb
[ 1.414041] bwmgr: missing cdev-type property
[ 1.414121] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.414126] DRAM derating cdev registered.
[ 1.415209] vdd-fan: disabling
[ 1.415211] vdd-usb-vbus: disabling
[ 1.415213] vdd-usb-vbus2: disabling
[ 1.415223] vddio-sdmmc3-ap: disabling
[ 1.415301] avdd-io-edp-1v05: disabling
[ 1.415303] vdd-usb-hub-en: disabling
[ 1.415382] ALSA device list:
[ 1.415384] #0: tegra-hda at 0x70038000 irq 83
[ 1.415386] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.419965] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.419968] Extcon HDMI: HPD enabled
[ 1.420022] tegradc tegradc.0: hdmi: plugged
[ 1.423113] Freeing unused kernel memory: 8576K
[ 1.423663] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.433889] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.447205] Root device found: mmcblk0p1
[ 1.462813] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.462819] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.462822] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.462826] usb 1-2: Manufacturer: Generic
[ 1.463781] hub 1-2:1.0: USB hub found
[ 1.464371] hub 1-2:1.0: 4 ports detected
[ 1.517733] mmc0: Applying tuning correction
[ 1.517748] mmc0: Tap value after applying correction 60
[ 1.517766] mmc0: hw tuning done …
[ 1.517800] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 1.518172] mmcblk0: mmc0:aaaa SN64G 59.5 GiB
[ 1.523090] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.589878] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 1.609928] usb 1-2: usb_suspend_both: status 0
[ 1.609986] usb usb1: usb_suspend_both: status 0
[ 1.651820] Found dev node: /dev/mmcblk0p1
[ 1.829406] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.936698] EXT4-fs (mmcblk0p1): recovery complete
[ 1.937729] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.938527] Rootfs mounted over mmcblk0p1
[ 1.959432] Switching from initrd to actual rootfs
[ 2.033882] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[ 2.098399] tegra_cec 70015000.tegra_cec: Sent res: -113.
[ 2.098404] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.159802] systemd[1]: System time before build time, advancing clock.
[ 2.196508] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.208863] cgroup: cgroup2: unknown option ā€œnsdelegateā€
[ 2.231471] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.232008] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.232195] systemd[1]: Detected architecture arm64.
[ 2.233882] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.260076] systemd[1]: Set hostname to .
[ 2.339200] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.339206] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.339209] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.339213] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.339216] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.339236] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.339295] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.339435] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.339534] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.339557] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.339586] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.339606] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.339742] pci 0000:01:00.0: supports D1 D2
[ 2.339745] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.350008] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.350080] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.350085] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.350091] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.350109] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.350125] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.350133] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.350137] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.350142] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.350483] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.350487] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.350493] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.350575] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.350748] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 2.350915] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.365742] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.365826] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e7:0a:57 from device tree
[ 2.366360] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.366375] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 2.407414] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.407424] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.614959] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.614989] systemd[1]: Reached target User and Group Name Lookups.
[ 2.615180] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.616966] systemd[1]: Created slice System Slice.
[ 2.617025] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.617192] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.617363] systemd[1]: Listening on udev Control Socket.
[ 2.618251] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.712066] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.820413] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.826195] systemd-journald[1924]: Received request to flush runtime journal from PID 1
[ 3.259591] Adding 6291452k swap on /mnt/swapfile. Priority:-1 extents:13 across:7225340k SS
[ 3.743578] using random self ethernet address
[ 3.748363] using random host ethernet address
[ 4.166445] random: crng init done
[ 4.169878] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.201309] zram: Added device: zram0
[ 5.202407] zram: Added device: zram1
[ 5.204379] zram: Added device: zram2
[ 5.209303] zram: Added device: zram3
[ 5.264251] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.264258] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.554026] zram0: detected capacity change from 0 to 1038274560
[ 5.594268] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.623221] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.623229] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.623233] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.623237] usb 2-1: Manufacturer: Generic
[ 5.626851] hub 2-1:1.0: USB hub found
[ 5.627654] hub 2-1:1.0: 4 ports detected
[ 5.781893] usb 2-1: usb_suspend_both: status 0
[ 5.782029] usb usb2: usb_suspend_both: status 0
[ 5.864704] Adding 1013936k swap on /dev/zram0. Priority:5 extents:1 across:1013936k SS
[ 5.868304] zram1: detected capacity change from 0 to 1038274560
[ 5.882697] Adding 1013936k swap on /dev/zram1. Priority:5 extents:1 across:1013936k SS
[ 5.892693] zram2: detected capacity change from 0 to 1038274560
[ 5.904700] Adding 1013936k swap on /dev/zram2. Priority:5 extents:1 across:1013936k SS
[ 5.913914] zram3: detected capacity change from 0 to 1038274560
[ 5.931569] Adding 1013936k swap on /dev/zram3. Priority:5 extents:1 across:1013936k SS
[ 6.617368] Mass Storage Function, version: 2009/09/11
[ 6.617375] LUN: removable file: (no medium)
[ 6.631360] using random self ethernet address
[ 6.645910] using random host ethernet address
[ 7.279543] zram: Cannot change disksize for initialized device
[ 7.286681] rndis0: HOST MAC 46:be:73:66:5b:68
[ 7.290050] rndis0: MAC 46:be:73:66:5b:69
[ 7.294407] usb0: HOST MAC 46:be:73:66:5b:6a
[ 7.294442] usb0: MAC 46:be:73:66:5b:6b
[ 7.294464] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 7.299520] zram: Cannot change disksize for initialized device
[ 7.309840] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 7.309861] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 7.312206] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 7.312450] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 7.312464] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 7.312841] zram: Cannot change disksize for initialized device
[ 7.315255] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 7.315280] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 7.315532] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 7.322313] l4tbr0: port 1(rndis0) entered blocking state
[ 7.322319] l4tbr0: port 1(rndis0) entered disabled state
[ 7.322493] device rndis0 entered promiscuous mode
[ 7.330618] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 7.333126] zram: Cannot change disksize for initialized device
[ 7.342887] l4tbr0: port 2(usb0) entered blocking state
[ 7.342892] l4tbr0: port 2(usb0) entered disabled state
[ 7.343074] device usb0 entered promiscuous mode
[ 7.354247] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.049937] tegra-xusb 70090000.xusb: entering ELPG
[ 8.051103] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[ 8.051307] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 8.052976] tegra-xusb 70090000.xusb: entering ELPG done
[ 8.083664] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.084746] eth0: 0xffffff800ab67000, 00:04:4b:e7:0a:57, IRQ 407
[ 8.148140] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.124798] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 11.124874] tegradc tegradc.0: blank - normal
[ 11.218357] r8168: eth0: link up
[ 11.218396] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.449231] tegradc tegradc.0: unblank
[ 12.460742] tegradc tegradc.0: sync windows ret = 247
[ 15.799705] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.799717] Bluetooth: BNEP socket layer initialized
[ 16.232162] fuse init (API version 7.26)
[ 18.511569] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 18.515571] tegradc tegradc.0: blank - powerdown
[ 18.556061] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 18.556064] Extcon AUX1(HDMI) disable
[ 18.577197] tegradc tegradc.0: unblank
[ 18.613536] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 18.615102] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 18.617400] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 18.617408] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 18.652346] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 18.652349] Extcon AUX1(HDMI) enable
[ 18.667689] tegradc tegradc.0: sync windows ret = 246
[ 19.268939] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 19.269011] tegradc tegradc.0: blank - normal
[ 19.500365] tegradc tegradc.0: unblank
[ 19.502695] tegradc tegradc.0: sync windows ret = 249
[ 25.054202] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 25.058772] tegradc tegradc.0: blank - powerdown
[ 25.097356] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 25.097360] Extcon AUX1(HDMI) disable
[ 25.117678] tegradc tegradc.0: unblank
[ 25.153707] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 25.153785] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 25.154809] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 25.154815] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 25.190834] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 25.190844] Extcon AUX1(HDMI) enable
[ 25.205152] tegradc tegradc.0: sync windows ret = 247
[ 25.539174] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 25.539225] tegradc tegradc.0: blank - normal
[ 25.769280] tegradc tegradc.0: unblank
[ 25.772993] tegradc tegradc.0: sync windows ret = 249
[ 31.155782] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 31.159974] tegradc tegradc.0: blank - powerdown
[ 31.200396] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 31.200398] Extcon AUX1(HDMI) disable
[ 31.220722] tegradc tegradc.0: unblank
[ 31.256735] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 31.256843] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 31.258334] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 31.258341] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 31.296939] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 31.296941] Extcon AUX1(HDMI) enable
[ 31.308703] tegradc tegradc.0: sync windows ret = 247
[ 31.642770] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 31.642839] tegradc tegradc.0: blank - normal
[ 31.877378] tegradc tegradc.0: unblank
[ 31.893162] tegradc tegradc.0: sync windows ret = 246
[ 37.329545] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 37.338362] tegradc tegradc.0: blank - powerdown
[ 37.387473] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 37.387480] Extcon AUX1(HDMI) disable
[ 37.407802] tegradc tegradc.0: unblank
[ 37.444054] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 37.444135] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 37.445166] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 37.445173] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 37.480477] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 37.480480] Extcon AUX1(HDMI) enable
[ 37.495595] tegradc tegradc.0: sync windows ret = 246
[ 37.829529] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 37.829602] tegradc tegradc.0: blank - normal
[ 38.057090] tegradc tegradc.0: unblank
[ 38.063319] tegradc tegradc.0: sync windows ret = 248
[ 43.481427] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 43.485263] tegradc tegradc.0: blank - powerdown
[ 43.524205] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 43.524210] Extcon AUX1(HDMI) disable
[ 43.544541] tegradc tegradc.0: unblank
[ 43.580451] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 43.580529] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 43.581539] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 43.581545] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 43.620450] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 43.620453] Extcon AUX1(HDMI) enable
[ 43.631903] tegradc tegradc.0: sync windows ret = 247
[ 43.949169] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 43.949215] tegradc tegradc.0: blank - normal
[ 44.177884] tegradc tegradc.0: unblank
[ 44.182995] tegradc tegradc.0: sync windows ret = 249
[ 49.582859] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 49.587024] tegradc tegradc.0: blank - powerdown
[ 49.627246] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 49.627249] Extcon AUX1(HDMI) disable
[ 49.647479] tegradc tegradc.0: unblank
[ 49.683430] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 49.683510] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 49.684518] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 49.684524] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 49.722001] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 49.722004] Extcon AUX1(HDMI) enable
[ 49.734921] tegradc tegradc.0: sync windows ret = 247
[ 50.068933] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 50.068994] tegradc tegradc.0: blank - normal
[ 50.299184] tegradc tegradc.0: unblank
[ 50.302696] tegradc tegradc.0: sync windows ret = 249
[ 55.720109] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 55.724400] tegradc tegradc.0: blank - powerdown
[ 55.763478] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 55.763485] Extcon AUX1(HDMI) disable
[ 55.783899] tegradc tegradc.0: unblank
[ 55.820107] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 55.820181] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 55.821193] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 55.821200] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 55.857096] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 55.857101] Extcon AUX1(HDMI) enable
[ 55.873036] tegradc tegradc.0: sync windows ret = 247
[ 56.188820] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 56.188891] tegradc tegradc.0: blank - normal
[ 56.414979] tegradc tegradc.0: unblank
[ 56.422648] tegradc tegradc.0: sync windows ret = 248
[ 61.840968] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 61.847911] tegradc tegradc.0: blank - powerdown
[ 61.883504] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 61.883512] Extcon AUX1(HDMI) disable
[ 61.903896] tegradc tegradc.0: unblank
[ 61.940208] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 61.940280] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 61.941291] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 61.941298] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 61.978629] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 61.978635] Extcon AUX1(HDMI) enable
[ 61.991663] tegradc tegradc.0: sync windows ret = 247
[ 62.325705] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 62.325758] tegradc tegradc.0: blank - normal
[ 62.554842] tegradc tegradc.0: unblank
[ 62.559431] tegradc tegradc.0: sync windows ret = 249
[ 67.960078] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 67.966218] tegradc tegradc.0: blank - powerdown
[ 68.003603] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 68.003611] Extcon AUX1(HDMI) disable
[ 68.023958] tegradc tegradc.0: unblank
[ 68.059778] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 68.059850] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 68.060868] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 68.060875] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 68.099136] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 68.099139] Extcon AUX1(HDMI) enable
[ 68.111230] tegradc tegradc.0: sync windows ret = 247
[ 68.445235] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 68.445285] tegradc tegradc.0: blank - normal
[ 68.672446] tegradc tegradc.0: unblank
[ 68.678970] tegradc tegradc.0: sync windows ret = 248
[ 74.096831] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 74.101075] tegradc tegradc.0: blank - powerdown
[ 74.139885] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 74.139890] Extcon AUX1(HDMI) disable
[ 74.160261] tegradc tegradc.0: unblank
[ 74.196217] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 74.196291] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 74.197301] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 74.197307] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 74.237459] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 74.237462] Extcon AUX1(HDMI) enable
[ 74.247670] tegradc tegradc.0: sync windows ret = 247
[ 74.564931] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 74.564979] tegradc tegradc.0: blank - normal
[ 74.794405] tegradc tegradc.0: unblank
[ 74.798738] tegradc tegradc.0: sync windows ret = 249
[ 80.216831] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 80.222789] tegradc tegradc.0: blank - powerdown
[ 80.260076] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 80.260078] Extcon AUX1(HDMI) disable
[ 80.280025] tegradc tegradc.0: unblank
[ 80.316063] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 80.316137] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 80.317148] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 80.317154] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 80.354566] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 80.354576] Extcon AUX1(HDMI) enable
[ 80.367518] tegradc tegradc.0: sync windows ret = 247
[ 80.684771] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 80.684844] tegradc tegradc.0: blank - normal
[ 80.912572] tegradc tegradc.0: unblank
[ 80.918593] tegradc tegradc.0: sync windows ret = 248
[ 86.318693] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 86.323177] tegradc tegradc.0: blank - powerdown
[ 86.362772] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 86.362777] Extcon AUX1(HDMI) disable
[ 86.383027] tegradc tegradc.0: unblank
[ 86.418892] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 86.418966] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 86.419979] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 86.419985] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 86.456198] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 86.456201] Extcon AUX1(HDMI) enable
[ 86.470426] tegradc tegradc.0: sync windows ret = 246
[ 86.804367] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 86.804420] tegradc tegradc.0: blank - normal
[ 87.031996] tegradc tegradc.0: unblank
[ 87.038087] tegradc tegradc.0: sync windows ret = 248
[ 92.456843] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 92.463892] tegradc tegradc.0: blank - powerdown
[ 92.499054] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 92.499062] Extcon AUX1(HDMI) disable
[ 92.519358] tegradc tegradc.0: unblank
[ 92.555274] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 92.555352] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 92.556374] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 92.556381] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 92.597967] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 92.597969] Extcon AUX1(HDMI) enable
[ 92.606695] tegradc tegradc.0: sync windows ret = 248
[ 92.940703] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 92.940757] tegradc tegradc.0: blank - normal
[ 93.170289] tegradc tegradc.0: unblank
[ 93.174493] tegradc tegradc.0: sync windows ret = 249
[ 98.593201] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 98.598023] tegradc tegradc.0: blank - powerdown
[ 98.635346] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 98.635350] Extcon AUX1(HDMI) disable
[ 98.655921] tegradc tegradc.0: unblank
[ 98.691782] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 98.691854] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 98.692866] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 98.692872] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 98.731269] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 98.731271] Extcon AUX1(HDMI) enable
[ 98.743226] tegradc tegradc.0: sync windows ret = 247
[ 99.077233] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 99.077283] tegradc tegradc.0: blank - normal
[ 99.305346] tegradc tegradc.0: unblank
[ 99.311349] tegradc tegradc.0: sync windows ret = 248
[ 104.729382] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 104.735999] tegradc tegradc.0: blank - powerdown
[ 104.771885] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 104.771887] Extcon AUX1(HDMI) disable
[ 104.792212] tegradc tegradc.0: unblank
[ 104.828052] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 104.828127] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 104.829136] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 104.829142] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 104.865944] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 104.865946] Extcon AUX1(HDMI) enable
[ 104.879547] tegradc tegradc.0: sync windows ret = 247
[ 105.213465] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 105.213516] tegradc tegradc.0: blank - normal
[ 105.442095] tegradc tegradc.0: unblank
[ 105.447267] tegradc tegradc.0: sync windows ret = 249
[ 110.865337] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 110.871598] tegradc tegradc.0: blank - powerdown
[ 110.908411] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 110.908413] Extcon AUX1(HDMI) disable
[ 110.928480] tegradc tegradc.0: unblank
[ 110.965144] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 110.965215] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 110.966227] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 110.966233] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 111.002855] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 111.002857] Extcon AUX1(HDMI) enable
[ 111.016648] tegradc tegradc.0: sync windows ret = 247
[ 111.350595] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 111.350646] tegradc tegradc.0: blank - normal
[ 111.578224] tegradc tegradc.0: unblank
[ 111.584364] tegradc tegradc.0: sync windows ret = 249
[ 117.001933] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 117.009310] tegradc tegradc.0: blank - powerdown
[ 117.045443] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 117.045450] Extcon AUX1(HDMI) disable
[ 117.065506] tegradc tegradc.0: unblank
[ 117.101340] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 117.101412] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 117.102428] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 117.102434] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 117.141248] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 117.141252] Extcon AUX1(HDMI) enable
[ 117.152793] tegradc tegradc.0: sync windows ret = 247
[ 117.470055] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 117.470139] tegradc tegradc.0: blank - normal
[ 117.696002] tegradc tegradc.0: unblank
[ 117.703866] tegradc tegradc.0: sync windows ret = 248
[ 123.120394] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 123.125247] tegradc tegradc.0: blank - powerdown
[ 123.164816] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 123.164818] Extcon AUX1(HDMI) disable
[ 123.185118] tegradc tegradc.0: unblank
[ 123.221060] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 123.221132] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 123.222189] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 123.222196] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 123.259339] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 123.259344] Extcon AUX1(HDMI) enable
[ 123.272554] tegradc tegradc.0: sync windows ret = 248
[ 123.606557] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 123.606610] tegradc tegradc.0: blank - normal
[ 123.835602] tegradc tegradc.0: unblank
[ 123.840321] tegradc tegradc.0: sync windows ret = 249
[ 129.259372] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 129.266597] tegradc tegradc.0: blank - powerdown
[ 129.301096] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 129.301098] Extcon AUX1(HDMI) disable
[ 129.321698] tegradc tegradc.0: unblank
[ 129.357589] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 129.357663] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 129.358670] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 129.358676] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 129.398011] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 129.398013] Extcon AUX1(HDMI) enable
[ 129.409015] tegradc tegradc.0: sync windows ret = 248
[ 129.743037] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 129.743108] tegradc tegradc.0: blank - normal
[ 129.973524] tegradc tegradc.0: unblank
[ 129.976785] tegradc tegradc.0: sync windows ret = 249
[ 135.378772] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 135.385547] tegradc tegradc.0: blank - powerdown
[ 135.420935] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 135.420939] Extcon AUX1(HDMI) disable
[ 135.441498] tegradc tegradc.0: unblank
[ 135.477571] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 135.477644] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 135.478652] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 135.478658] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 135.515247] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 135.515250] Extcon AUX1(HDMI) enable
[ 135.529012] tegradc tegradc.0: sync windows ret = 247
[ 135.863094] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 135.863148] tegradc tegradc.0: blank - normal
[ 136.091773] tegradc tegradc.0: unblank
[ 136.096793] tegradc tegradc.0: sync windows ret = 249
[ 141.515429] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 141.522134] tegradc tegradc.0: blank - powerdown
[ 141.557844] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 141.557846] Extcon AUX1(HDMI) disable
[ 141.578340] tegradc tegradc.0: unblank
[ 141.614230] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 141.614308] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 141.615323] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 141.615329] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 141.653806] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 141.653808] Extcon AUX1(HDMI) enable
[ 141.665714] tegradc tegradc.0: sync windows ret = 248
[ 141.999644] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 141.999695] tegradc tegradc.0: blank - normal
[ 142.228607] tegradc tegradc.0: unblank
[ 142.233458] tegradc tegradc.0: sync windows ret = 249
[ 147.652554] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 147.660170] tegradc tegradc.0: blank - powerdown
[ 147.694240] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 147.694242] Extcon AUX1(HDMI) disable
[ 147.714807] tegradc tegradc.0: unblank
[ 147.750695] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 147.750771] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 147.751784] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 147.751790] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 147.789983] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 147.789985] Extcon AUX1(HDMI) enable
[ 147.802134] tegradc tegradc.0: sync windows ret = 247
[ 148.136117] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 148.136169] tegradc tegradc.0: blank - normal
[ 148.365672] tegradc tegradc.0: unblank
[ 148.369935] tegradc tegradc.0: sync windows ret = 248
[ 153.770273] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 153.786106] tegradc tegradc.0: blank - powerdown
[ 153.831137] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 153.831149] Extcon AUX1(HDMI) disable
[ 153.851171] tegradc tegradc.0: unblank
[ 153.887086] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 153.887162] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 153.888173] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 153.888180] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 153.925955] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 153.925961] Extcon AUX1(HDMI) enable
[ 153.940925] tegradc tegradc.0: sync windows ret = 247
[ 154.272543] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 154.272594] tegradc tegradc.0: blank - normal
[ 154.500804] tegradc tegradc.0: unblank
[ 154.506308] tegradc tegradc.0: sync windows ret = 248
[ 159.906523] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 159.910580] tegradc tegradc.0: blank - powerdown
[ 159.950771] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 159.950780] Extcon AUX1(HDMI) disable
[ 159.970789] tegradc tegradc.0: unblank
[ 160.006661] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 160.006734] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 160.007742] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 160.007749] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 160.050013] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 160.050015] Extcon AUX1(HDMI) enable
[ 160.058067] tegradc tegradc.0: sync windows ret = 248
[ 160.392113] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 160.392176] tegradc tegradc.0: blank - normal
[ 160.619205] tegradc tegradc.0: unblank
[ 160.625882] tegradc tegradc.0: sync windows ret = 248
[ 166.043785] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 166.048442] tegradc tegradc.0: blank - powerdown
[ 166.086820] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 166.086828] Extcon AUX1(HDMI) disable
[ 166.107193] tegradc tegradc.0: unblank
[ 166.143079] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 166.143153] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 166.144167] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 166.144173] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 166.184909] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 166.184914] Extcon AUX1(HDMI) enable
[ 166.194540] tegradc tegradc.0: sync windows ret = 247
[ 166.528532] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 166.528578] tegradc tegradc.0: blank - normal
[ 166.753939] tegradc tegradc.0: unblank
[ 166.762300] tegradc tegradc.0: sync windows ret = 248
[ 172.180797] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 172.184789] tegradc tegradc.0: blank - powerdown
[ 172.223395] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 172.223403] Extcon AUX1(HDMI) disable
[ 172.243465] tegradc tegradc.0: unblank
[ 172.279286] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 172.279357] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 172.280367] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 172.280374] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 172.318031] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 172.318034] Extcon AUX1(HDMI) enable
[ 172.330732] tegradc tegradc.0: sync windows ret = 247
[ 172.664740] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 172.664788] tegradc tegradc.0: blank - normal
[ 172.891787] tegradc tegradc.0: unblank
[ 172.898491] tegradc tegradc.0: sync windows ret = 248
[ 178.315917] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 178.322458] tegradc tegradc.0: blank - powerdown
[ 178.359910] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 178.359913] Extcon AUX1(HDMI) disable
[ 178.379819] tegradc tegradc.0: unblank
[ 178.415686] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 178.415760] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 178.416768] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 178.416775] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 178.454026] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 178.454029] Extcon AUX1(HDMI) enable
[ 178.467177] tegradc tegradc.0: sync windows ret = 247
[ 178.801177] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 178.801233] tegradc tegradc.0: blank - normal
[ 179.027977] tegradc tegradc.0: unblank
[ 179.034941] tegradc tegradc.0: sync windows ret = 248
[ 184.435513] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 184.441339] tegradc tegradc.0: blank - powerdown
[ 184.479055] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 184.479058] Extcon AUX1(HDMI) disable
[ 184.499671] tegradc tegradc.0: unblank
[ 184.535567] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 184.535642] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 184.536652] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 184.536659] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 184.574130] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 184.574132] Extcon AUX1(HDMI) enable
[ 184.587054] tegradc tegradc.0: sync windows ret = 247
[ 184.904324] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 184.904374] tegradc tegradc.0: blank - normal
[ 185.128407] tegradc tegradc.0: unblank
[ 185.138107] tegradc tegradc.0: sync windows ret = 247
[ 190.555299] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 190.560266] tegradc tegradc.0: blank - powerdown
[ 190.598870] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 190.598871] Extcon AUX1(HDMI) disable
[ 190.619547] tegradc tegradc.0: unblank
[ 190.655509] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 190.655586] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 190.656595] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 190.656601] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 190.693990] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 190.693992] Extcon AUX1(HDMI) enable
[ 190.706987] tegradc tegradc.0: sync windows ret = 247
[ 191.041001] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 191.041073] tegradc tegradc.0: blank - normal
[ 191.268120] tegradc tegradc.0: unblank
[ 191.274778] tegradc tegradc.0: sync windows ret = 248
[ 196.674401] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 196.678440] tegradc tegradc.0: blank - powerdown
[ 196.718880] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 196.718883] Extcon AUX1(HDMI) disable
[ 196.739261] tegradc tegradc.0: unblank
[ 196.775145] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 196.775218] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 196.776233] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 196.776239] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 196.816954] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 196.816964] Extcon AUX1(HDMI) enable
[ 196.826638] tegradc tegradc.0: sync windows ret = 247
[ 197.143869] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 197.160651] tegradc tegradc.0: blank - normal
[ 197.387936] tegradc tegradc.0: unblank
[ 197.394559] tegradc tegradc.0: sync windows ret = 248
[ 202.812218] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 202.818228] tegradc tegradc.0: blank - powerdown
[ 202.855238] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 202.855240] Extcon AUX1(HDMI) disable
[ 202.875671] tegradc tegradc.0: unblank
[ 202.911540] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 202.911619] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 202.912635] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 202.912642] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 202.951486] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 202.951492] Extcon AUX1(HDMI) enable
[ 202.963037] tegradc tegradc.0: sync windows ret = 247
[ 203.296998] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 203.297051] tegradc tegradc.0: blank - normal
[ 203.525238] tegradc tegradc.0: unblank
[ 203.530823] tegradc tegradc.0: sync windows ret = 248
[ 208.947856] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 208.953161] tegradc tegradc.0: blank - powerdown
[ 208.992226] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 208.992228] Extcon AUX1(HDMI) disable
[ 209.011961] tegradc tegradc.0: unblank
[ 209.047847] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 209.047917] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 209.048925] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 209.048931] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 209.087692] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 209.087701] Extcon AUX1(HDMI) enable
[ 209.099317] tegradc tegradc.0: sync windows ret = 247
[ 209.433338] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 209.433388] tegradc tegradc.0: blank - normal
[ 209.661156] tegradc tegradc.0: unblank
[ 209.667281] tegradc tegradc.0: sync windows ret = 248
[ 215.066931] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 215.071382] tegradc tegradc.0: blank - powerdown
[ 215.111270] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 215.111273] Extcon AUX1(HDMI) disable
[ 215.131658] tegradc tegradc.0: unblank
[ 215.167614] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 215.167687] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 215.168689] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 215.168696] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 215.205997] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 215.205999] Extcon AUX1(HDMI) enable
[ 215.219089] tegradc tegradc.0: sync windows ret = 247
[ 215.553053] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 215.553103] tegradc tegradc.0: blank - normal
[ 215.787905] tegradc tegradc.0: unblank
[ 215.803623] tegradc tegradc.0: sync windows ret = 246
[ 221.222218] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 221.229646] tegradc tegradc.0: blank - powerdown
[ 221.264270] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 221.264272] Extcon AUX1(HDMI) disable
[ 221.284787] tegradc tegradc.0: unblank
[ 221.320643] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 221.320716] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 221.321723] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 221.321729] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 221.360945] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 221.360948] Extcon AUX1(HDMI) enable
[ 221.372089] tegradc tegradc.0: sync windows ret = 248
[ 221.689354] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 221.689401] tegradc tegradc.0: blank - normal
[ 221.920779] tegradc tegradc.0: unblank
[ 221.923314] tegradc tegradc.0: sync windows ret = 249
[ 227.340546] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 227.344551] tegradc tegradc.0: blank - powerdown
[ 227.384106] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 227.384114] Extcon AUX1(HDMI) disable
[ 227.404382] tegradc tegradc.0: unblank
[ 227.440332] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 227.440404] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 227.441403] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 227.441410] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 227.490055] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 227.490057] Extcon AUX1(HDMI) enable
[ 227.491734] tegradc tegradc.0: sync windows ret = 250
[ 227.825772] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 227.825827] tegradc tegradc.0: blank - normal
[ 228.055157] tegradc tegradc.0: unblank
[ 228.059521] tegradc tegradc.0: sync windows ret = 249
[ 233.482061] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 233.489678] tegradc tegradc.0: blank - powerdown
[ 233.536981] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 233.536982] Extcon AUX1(HDMI) disable
[ 233.557468] tegradc tegradc.0: unblank
[ 233.593311] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 233.593383] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 233.594396] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 233.594403] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 233.630935] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 233.630937] Extcon AUX1(HDMI) enable
[ 233.644720] tegradc tegradc.0: sync windows ret = 247
[ 233.962093] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 233.962189] tegradc tegradc.0: blank - normal
[ 234.193146] tegradc tegradc.0: unblank
[ 234.195834] tegradc tegradc.0: sync windows ret = 249
[ 239.613345] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 239.620238] tegradc tegradc.0: blank - powerdown
[ 239.656770] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 239.656778] Extcon AUX1(HDMI) disable
[ 239.677196] tegradc tegradc.0: unblank
[ 239.713042] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 239.713116] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 239.714128] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 239.714134] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 239.749960] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 239.749962] Extcon AUX1(HDMI) enable
[ 239.764498] tegradc tegradc.0: sync windows ret = 247
[ 240.098479] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 240.098632] tegradc tegradc.0: blank - normal
[ 240.324209] tegradc tegradc.0: unblank
[ 240.332218] tegradc tegradc.0: sync windows ret = 248
[ 245.750205] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 245.754580] tegradc tegradc.0: blank - powerdown
[ 245.793322] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 245.793330] Extcon AUX1(HDMI) disable
[ 245.813474] tegradc tegradc.0: unblank
[ 245.849380] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 245.849454] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 245.850477] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 245.850484] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 245.894039] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 245.894041] Extcon AUX1(HDMI) enable
[ 245.900810] tegradc tegradc.0: sync windows ret = 249
[ 246.234805] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 246.234881] tegradc tegradc.0: blank - normal
[ 246.466361] tegradc tegradc.0: unblank
[ 246.468598] tegradc tegradc.0: sync windows ret = 250
[ 251.887615] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 251.891782] tegradc tegradc.0: blank - powerdown
[ 251.929604] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 251.929613] Extcon AUX1(HDMI) disable
[ 251.949897] tegradc tegradc.0: unblank
[ 251.985753] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 251.985826] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 251.986852] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 251.986858] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 252.026024] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 252.026027] Extcon AUX1(HDMI) enable
[ 252.037227] tegradc tegradc.0: sync windows ret = 248
[ 252.371238] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 252.371289] tegradc tegradc.0: blank - normal
[ 252.598843] tegradc tegradc.0: unblank
[ 252.605027] tegradc tegradc.0: sync windows ret = 249
[ 258.005728] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 258.009590] tegradc tegradc.0: blank - powerdown
[ 258.049067] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 258.049072] Extcon AUX1(HDMI) disable
[ 258.069617] tegradc tegradc.0: unblank
[ 258.105659] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 258.105733] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 258.106744] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 258.106751] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 258.144697] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 258.144700] Extcon AUX1(HDMI) enable
[ 258.157155] tegradc tegradc.0: sync windows ret = 247
[ 258.491110] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 258.491163] tegradc tegradc.0: blank - normal
[ 258.720108] tegradc tegradc.0: unblank
[ 258.724921] tegradc tegradc.0: sync windows ret = 249
[ 264.142974] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 264.147414] tegradc tegradc.0: blank - powerdown
[ 264.186567] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 264.186581] Extcon AUX1(HDMI) disable
[ 264.206183] tegradc tegradc.0: unblank
[ 264.242072] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 264.242146] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 264.243146] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 264.243152] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 264.281694] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 264.281696] Extcon AUX1(HDMI) enable
[ 264.293507] tegradc tegradc.0: sync windows ret = 248
[ 264.627510] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 264.627561] tegradc tegradc.0: blank - normal
[ 264.856322] tegradc tegradc.0: unblank
[ 264.861282] tegradc tegradc.0: sync windows ret = 249
[ 270.279680] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 270.284369] tegradc tegradc.0: blank - powerdown
[ 270.322045] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 270.322047] Extcon AUX1(HDMI) disable
[ 270.342561] tegradc tegradc.0: unblank
[ 270.378454] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 270.378529] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 270.379541] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 270.379547] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 270.418383] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 270.418392] Extcon AUX1(HDMI) enable
[ 270.429918] tegradc tegradc.0: sync windows ret = 247
[ 270.763907] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 270.763958] tegradc tegradc.0: blank - normal
[ 270.991599] tegradc tegradc.0: unblank
[ 270.997833] tegradc tegradc.0: sync windows ret = 249
[ 276.414423] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 276.418370] tegradc tegradc.0: blank - powerdown
[ 276.458430] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 276.458432] Extcon AUX1(HDMI) disable
[ 276.478916] tegradc tegradc.0: unblank
[ 276.514834] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 276.514908] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 276.515921] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 276.515927] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 276.554163] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 276.554165] Extcon AUX1(HDMI) enable
[ 276.566304] tegradc tegradc.0: sync windows ret = 247
[ 276.883551] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 276.883593] tegradc tegradc.0: blank - normal
[ 277.111621] tegradc tegradc.0: unblank
[ 277.117358] tegradc tegradc.0: sync windows ret = 249
[ 282.535338] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 282.540701] tegradc tegradc.0: blank - powerdown
[ 282.578077] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 282.578079] Extcon AUX1(HDMI) disable
[ 282.598501] tegradc tegradc.0: unblank
[ 282.634406] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 282.634481] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 282.635492] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 282.635499] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 282.677469] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 282.677472] Extcon AUX1(HDMI) enable
[ 282.685820] tegradc tegradc.0: sync windows ret = 248
[ 283.019856] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 283.019907] tegradc tegradc.0: blank - normal
[ 283.245745] tegradc tegradc.0: unblank
[ 283.253613] tegradc tegradc.0: sync windows ret = 249
[ 288.671701] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 288.675959] tegradc tegradc.0: blank - powerdown
[ 288.715353] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 288.715365] Extcon AUX1(HDMI) disable
[ 288.734859] tegradc tegradc.0: unblank
[ 288.770766] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 288.770844] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 288.771854] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 288.771860] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 288.813136] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 288.813142] Extcon AUX1(HDMI) enable
[ 288.822254] tegradc tegradc.0: sync windows ret = 248
[ 289.139480] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 289.139553] tegradc tegradc.0: blank - normal
[ 289.366350] tegradc tegradc.0: unblank
[ 289.373314] tegradc tegradc.0: sync windows ret = 249
[ 294.790755] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 294.795008] tegradc tegradc.0: blank - powerdown
[ 294.834173] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 294.834181] Extcon AUX1(HDMI) disable
[ 294.854416] tegradc tegradc.0: unblank
[ 294.890291] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 294.890366] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 294.891375] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 294.891381] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 294.931899] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 294.931906] Extcon AUX1(HDMI) enable
[ 294.941745] tegradc tegradc.0: sync windows ret = 248
[ 295.275784] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 295.275835] tegradc tegradc.0: blank - normal
[ 295.503597] tegradc tegradc.0: unblank
[ 295.509549] tegradc tegradc.0: sync windows ret = 249
[ 300.929371] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 300.937798] tegradc tegradc.0: blank - powerdown
[ 300.987314] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 300.987316] Extcon AUX1(HDMI) disable
[ 301.007609] tegradc tegradc.0: unblank
[ 301.044288] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 301.044366] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 301.045379] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 301.045385] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 301.087698] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 301.087703] Extcon AUX1(HDMI) enable
[ 301.095758] tegradc tegradc.0: sync windows ret = 248
[ 301.429784] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 301.429833] tegradc tegradc.0: blank - normal
[ 301.661500] tegradc tegradc.0: unblank
[ 301.663551] tegradc tegradc.0: sync windows ret = 249
[ 307.082002] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 307.086120] tegradc tegradc.0: blank - powerdown
[ 307.124768] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 307.124777] Extcon AUX1(HDMI) disable
[ 307.144923] tegradc tegradc.0: unblank
[ 307.181166] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 307.181238] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 307.182252] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 307.182258] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 307.223790] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 307.223792] Extcon AUX1(HDMI) enable
[ 307.232619] tegradc tegradc.0: sync windows ret = 248
[ 307.566621] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 307.566670] tegradc tegradc.0: blank - normal
[ 307.795862] tegradc tegradc.0: unblank
[ 307.800431] tegradc tegradc.0: sync windows ret = 249
[ 313.221183] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 313.230566] tegradc tegradc.0: blank - powerdown
[ 313.277906] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 313.277907] Extcon AUX1(HDMI) disable
[ 313.298441] tegradc tegradc.0: unblank
[ 313.334278] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 313.334353] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 313.335365] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 313.335372] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 313.373994] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 313.373996] Extcon AUX1(HDMI) enable
[ 313.385768] tegradc tegradc.0: sync windows ret = 248
[ 313.719769] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 313.719819] tegradc tegradc.0: blank - normal
[ 313.950663] tegradc tegradc.0: unblank
[ 313.953539] tegradc tegradc.0: sync windows ret = 250
[ 319.373470] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 319.378074] tegradc tegradc.0: blank - powerdown
[ 319.415255] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 319.415262] Extcon AUX1(HDMI) disable
[ 319.434784] tegradc tegradc.0: unblank
[ 319.470930] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 319.471005] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 319.472017] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 319.472024] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 319.513350] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 319.513355] Extcon AUX1(HDMI) enable
[ 319.522384] tegradc tegradc.0: sync windows ret = 247
[ 319.856423] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 319.856473] tegradc tegradc.0: blank - normal
[ 320.084328] tegradc tegradc.0: unblank
[ 320.090307] tegradc tegradc.0: sync windows ret = 248
[ 325.490694] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 325.494839] tegradc tegradc.0: blank - powerdown
[ 325.534569] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 325.534571] Extcon AUX1(HDMI) disable
[ 325.554729] tegradc tegradc.0: unblank
[ 325.591965] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 325.592039] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 325.593048] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 325.593054] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 325.633988] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 325.633990] Extcon AUX1(HDMI) enable
[ 325.643443] tegradc tegradc.0: sync windows ret = 248
[ 325.977464] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 325.977527] tegradc tegradc.0: blank - normal
[ 326.204061] tegradc tegradc.0: unblank
[ 326.211184] tegradc tegradc.0: sync windows ret = 248
[ 331.631124] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 331.640519] tegradc tegradc.0: blank - powerdown
[ 331.688660] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 331.688661] Extcon AUX1(HDMI) disable
[ 331.709085] tegradc tegradc.0: unblank
[ 331.744953] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 331.745026] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 331.746035] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 331.746042] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 331.785102] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 331.785103] Extcon AUX1(HDMI) enable
[ 331.796409] tegradc tegradc.0: sync windows ret = 247
[ 332.113667] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 332.113714] tegradc tegradc.0: blank - normal
[ 332.340667] tegradc tegradc.0: unblank
[ 332.347510] tegradc tegradc.0: sync windows ret = 248
[ 337.765568] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 337.769788] tegradc tegradc.0: blank - powerdown
[ 337.809015] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 337.809020] Extcon AUX1(HDMI) disable
[ 337.828710] tegradc tegradc.0: unblank
[ 337.864637] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 337.864711] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 337.865733] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 337.865739] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 337.903846] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 337.903848] Extcon AUX1(HDMI) enable
[ 337.916137] tegradc tegradc.0: sync windows ret = 247
[ 338.233772] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 338.250106] tegradc tegradc.0: blank - normal
[ 338.482537] tegradc tegradc.0: unblank
[ 338.483891] tegradc tegradc.0: sync windows ret = 250
[ 343.886041] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 343.890597] tegradc tegradc.0: blank - powerdown
[ 343.928425] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 343.928434] Extcon AUX1(HDMI) disable
[ 343.948332] tegradc tegradc.0: unblank
[ 343.984175] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 343.984252] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 343.985263] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 343.985270] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 344.028194] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 344.028196] Extcon AUX1(HDMI) enable
[ 344.035589] tegradc tegradc.0: sync windows ret = 248
[ 344.369635] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 344.369685] tegradc tegradc.0: blank - normal
[ 344.601463] tegradc tegradc.0: unblank
[ 344.603428] tegradc tegradc.0: sync windows ret = 249
[ 350.020807] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 350.026147] tegradc tegradc.0: blank - powerdown
[ 350.064392] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 350.064394] Extcon AUX1(HDMI) disable
[ 350.084578] tegradc tegradc.0: unblank
[ 350.120459] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 350.120534] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 350.121543] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 350.121550] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 350.158447] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 350.158449] Extcon AUX1(HDMI) enable
[ 350.171902] tegradc tegradc.0: sync windows ret = 247
[ 350.505947] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 350.505999] tegradc tegradc.0: blank - normal
[ 350.736402] tegradc tegradc.0: unblank
[ 350.739641] tegradc tegradc.0: sync windows ret = 249
[ 356.156600] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 356.162738] tegradc tegradc.0: blank - powerdown
[ 356.201274] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 356.201286] Extcon AUX1(HDMI) disable
[ 356.221015] tegradc tegradc.0: unblank
[ 356.256939] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 356.257013] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 356.258023] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 356.258029] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 356.301981] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 356.301982] Extcon AUX1(HDMI) enable
[ 356.308346] tegradc tegradc.0: sync windows ret = 249
[ 356.642385] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 356.642438] tegradc tegradc.0: blank - normal
[ 356.870467] tegradc tegradc.0: unblank
[ 356.876161] tegradc tegradc.0: sync windows ret = 249
[ 362.276962] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 362.282931] tegradc tegradc.0: blank - powerdown
[ 362.320297] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 362.320303] Extcon AUX1(HDMI) disable
[ 362.340658] tegradc tegradc.0: unblank
[ 362.376536] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 362.376608] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 362.377622] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 362.377628] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 362.416026] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 362.416029] Extcon AUX1(HDMI) enable
[ 362.427986] tegradc tegradc.0: sync windows ret = 248
[ 362.762001] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 362.762056] tegradc tegradc.0: blank - normal
[ 362.993259] tegradc tegradc.0: unblank
[ 362.995736] tegradc tegradc.0: sync windows ret = 249
[ 368.413751] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 368.418264] tegradc tegradc.0: blank - powerdown
[ 368.457248] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 368.457255] Extcon AUX1(HDMI) disable
[ 368.476997] tegradc tegradc.0: unblank
[ 368.512833] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 368.512906] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 368.513958] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 368.513964] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 368.553970] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 368.553972] Extcon AUX1(HDMI) enable
[ 368.564301] tegradc tegradc.0: sync windows ret = 248
[ 368.898371] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 368.898433] tegradc tegradc.0: blank - normal
[ 369.130054] tegradc tegradc.0: unblank
[ 369.132055] tegradc tegradc.0: sync windows ret = 250
[ 374.550469] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 374.554593] tegradc tegradc.0: blank - powerdown
[ 374.592910] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 374.592917] Extcon AUX1(HDMI) disable
[ 374.613417] tegradc tegradc.0: unblank
[ 374.649327] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 374.649402] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 374.650417] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 374.650424] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 374.690579] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 374.690581] Extcon AUX1(HDMI) enable
[ 374.700747] tegradc tegradc.0: sync windows ret = 248
[ 375.034783] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 375.034835] tegradc tegradc.0: blank - normal
[ 375.265035] tegradc tegradc.0: unblank
[ 375.268579] tegradc tegradc.0: sync windows ret = 249
[ 380.687347] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 380.691879] tegradc tegradc.0: blank - powerdown
[ 380.729394] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 380.729398] Extcon AUX1(HDMI) disable
[ 380.750087] tegradc tegradc.0: unblank
[ 380.785976] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 380.786046] tegradc tegradc.0: hdmi: tmds rate:119000K prod-setting:prod_c_hdmi_75m_150m
[ 380.787057] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 380.787063] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 380.826767] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 380.826774] Extcon AUX1(HDMI) enable
[ 380.837421] tegradc tegradc.0: sync windows ret = 248
[ 381.171409] tegradc tegradc.0: nominal-pclk:119000000 parent:118998632 div:1.0 pclk:118998632 117810000~129710000
[ 381.171498] tegradc tegradc.0: blank - normal
[ 381.398421] tegradc tegradc.0: unblank
[ 381.405133] tegradc tegradc.0: sync windows ret = 249
Shall I post it in a .txt file or is this fine? @WayneWWW
when i attach an HDMI cable it makes some small sounds as well
It looks like the driver keeps trying to waking up the display but it cannot.
Could you also share me the syslog too (/var/log/syslog) too and point me out your boot up timestamp?
Please attach it as a txt file this time because syslog records more than dmesg …
Thank you for your support @WayneWWW . below I’ve attached syslog file in sysloggg.txt filesysloggg.txt (519.2 KB)
this file only consists of record of my previous boot since the system was starting at a default date of 28th Jan and 09:45:45 time stamp so it was little ambiguous so i made a different syslog file for your reference
thanks
Are you using xrdp related process there? I see xrdp in your log.
Also, along with gdm3 failure.
Jan 28 21:28:51 rnd-nano at-spi-bus-launcher[7583]: dbus-daemon[7589]: Successfully activated service ā€˜org.a11y.atspi.Registry’
Jan 28 21:28:51 rnd-nano at-spi-bus-launcher[7583]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 28 21:28:51 rnd-nano gnome-session[7580]: libGL error: MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
Jan 28 21:28:51 rnd-nano gnome-session[7580]: libGL error: failed to load driver: swrast
Jan 28 21:28:51 rnd-nano gnome-session[7580]: X Error of failed request: GLXBadContext
Jan 28 21:28:51 rnd-nano gnome-session[7580]: Major opcode of failed request: 154 (GLX)
Jan 28 21:28:51 rnd-nano gnome-session[7580]: Minor opcode of failed request: 6 (X_GLXIsDirect)
Jan 28 21:28:51 rnd-nano gnome-session[7580]: Serial number of failed request: 35
Jan 28 21:28:51 rnd-nano gnome-session[7580]: Current serial number in output stream: 34
Jan 28 21:28:51 rnd-nano gnome-session[7580]: gnome-session-check-accelerated: GL Helper exited with code 256
Jan 28 21:28:52 rnd-nano dbus-daemon[7358]: [session uid=1000 pid=7358] Successfully activated service ā€˜org.freedesktop.thumbnails.Thumbnailer1’
Jan 28 21:28:52 rnd-nano gnome-session-c[7598]: eglGetDisplay() failed
Jan 28 21:28:52 rnd-nano gnome-session[7580]: gnome-session-check-accelerated: GLES Helper exited with code 256
Jan 28 21:28:52 rnd-nano dbus-daemon[7358]: [session uid=1000 pid=7358] Activating via systemd: service name=ā€˜org.gtk.vfs.Metadata’ unit=ā€˜gvfs-metadata.service’ requested by ā€˜:1.6’ (uid=1000 pid=7381 comm="xfdesktop ")
Jan 28 21:28:52 rnd-nano systemd[7088]: Starting Virtual filesystem metadata service…
Jan 28 21:28:52 rnd-nano dbus-daemon[7358]: [session uid=1000 pid=7358] Successfully activated service ā€˜org.gtk.vfs.Metadata’
Jan 28 21:28:52 rnd-nano systemd[7088]: Started Virtual filesystem metadata service.
Jan 28 21:28:54 rnd-nano dhclient[6085]: XMT: Info-Request on eth0, interval 28550ms.
Jan 28 21:28:57 rnd-nano gnome-session[7580]: libGL error: MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
Jan 28 21:28:57 rnd-nano gnome-session[7580]: libGL error: failed to load driver: swrast
Jan 28 21:28:57 rnd-nano gnome-session[7580]: X Error of failed request: GLXBadContext
Jan 28 21:28:57 rnd-nano gnome-session[7580]: Major opcode of failed request: 154 (GLX)
Jan 28 21:28:57 rnd-nano gnome-session[7580]: Minor opcode of failed request: 6 (X_GLXIsDirect)
Jan 28 21:28:57 rnd-nano gnome-session[7580]: Serial number of failed request: 24
Jan 28 21:28:57 rnd-nano gnome-session[7580]: Current serial number in output stream: 23
Jan 28 21:28:57 rnd-nano gnome-session[7580]: gnome-session-check-accelerated: GL Helper exited with code 256
Jan 28 21:28:57 rnd-nano gnome-session-c[7626]: eglGetDisplay() failed
Jan 28 21:28:57 rnd-nano gnome-session[7580]: gnome-session-check-accelerated: GLES Helper exited with code 256
Jan 28 21:28:57 rnd-nano gnome-session[7580]: gnome-session-binary[7580]: WARNING: software acceleration check failed: Child process exited with code 1
Jan 28 21:28:57 rnd-nano gnome-session[7580]: gnome-session-binary[7580]: CRITICAL: We failed, but the fail whale is dead. Sorry…
Jan 28 21:28:57 rnd-nano gnome-session-binary[7580]: WARNING: software acceleration check failed: Child process exited with code 1
Jan 28 21:28:57 rnd-nano gnome-session-binary[7580]: CRITICAL: We failed, but the fail whale is dead. Sorry…
Are you sure this issue is caused by deleting cache…?
I started using xrdp beacuse nothing was coming up on the display, plus till yesterday everything was running fine before i deleted all the files inside the cache folder @WayneWWW
Could you disable this xrdp process and share me the dmesg and syslog again?
how can i disable and renable again?
I don’t know. You can check if there is a xrdp service there. If there is, disable it and reboot and see if it is really disabled.
sir, if I disable it and if we ain’t able to make it work again I might lose its accessibility thorough xrdp so shall I proceed? plus what is gdm3 and how can we repair its failure
If it is just a systemd service then disable it does not harm at all. Just enable it again should bring it back.
GDM3 is gnome display manager. You need that to enable ubuntu desktop. Thus your issue is not ā€œsystem not startingā€, your issue is ā€œdesktop fails to startā€. And the solution is unknown. Honestly speaking, I’ve seen lots of reason that could make gdm3 fail to run. Thus, we need to clarify if xrdp is the cause first. If it is not, then we check the next. If you have valuable data on jetson, please backup it first. Unless we have no solution in the end but to reflash it.
http://manpages.ubuntu.com/manpages/bionic/man8/gdm3.8.html
I’ve disabled xrdp and the new dmesg log in the filedmesg.txt (63.1 KB)
@WayneWWW
And new syslog please. Thanks.
syslog2.txt (787.5 KB)
Hi, this is the new syslog @WayneWWW
Jan 28 21:28:33 rnd-nano at-spi-bus-launcher[6827]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 28 21:28:33 rnd-nano gnome-session[6825]: libGL error: MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
Jan 28 21:28:33 rnd-nano gnome-session[6825]: libGL error: failed to load driver: swrast
Jan 28 21:28:33 rnd-nano gnome-session[6825]: X Error of failed request: GLXBadContext
This is still here.
Could you try my trick here to see if it can bypass the error?
To create
/usr/lib/aarch64-linux-gnu/libdrm.so.2 → /usr/lib/aarch64-linux-gnu/libdrm.so.2.4.0.
You can use command
sudo ln -sf /usr/lib/aarch64-linux-gnu/libdrm.so.2.4.0 /usr/lib/aarch64-linux-gnu/libdrm.so.2
After this step, reboot the device.
I ran sudo ln -sf /usr/lib/aarch64-linux-gnu/libdrm.so.2.4.0 /usr/lib/aarch64-linux-gnu/libdrm.so.2
and did a reboot. below ive attached new dmesg and syslognewsyslog.txt (189.0 KB) newdmesg.txt (53.7 KB)
