Done. ifconfig shows the same results from before. Here is dmesg output:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2713) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Dec 9 22:47:42 PST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb0000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb1000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb0000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29392(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562224K/4159488K available (15230K kernel code, 2926K rwdata, 6620K rodata, 8576K init, 609K bss, 122128K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a11b808 ( 2927 KB)
[ 0.000000] .bss : 0xffffff800a11b808 - 0xffffff800a1b3dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001829] Console: colour dummy device 80x25
[ 0.001849] console [tty0] enabled
[ 0.001867] kmemleak: Kernel memory leak detector disabled
[ 0.001888] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001902] pid_max: default: 32768 minimum: 301
[ 0.002360] Security Framework initialized
[ 0.002586] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002594] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003759] ftrace: allocating 47001 entries in 184 pages
[ 0.176939] sched-energy: CPU device node has no sched-energy-costs
[ 0.176976] ASID allocator initialised with 65536 entries
[ 0.216182] tegra-id: chipid=22117.
[ 0.216196] tegra-id: opt_subrevision=0.
[ 0.216215] Tegra Speedo/IDDQ fuse revision 4
[ 0.216256] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.216260] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.216266] Tegra: CPU Speedo Value 2043, SoC Speedo Value 1966, GPU Speedo Value 2059
[ 0.216270] Tegra: CPU IDDQ Value 1840, SoC IDDQ Value 2156, GPU IDDQ Value 2530
[ 0.216289] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.216305] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.216312] DTB Build time: Dec 9 2019 22:51:54
[ 0.265081] CPU1: Booted secondary processor [411fd071]
[ 0.297024] CPU2: Booted secondary processor [411fd071]
[ 0.328978] CPU3: Booted secondary processor [411fd071]
[ 0.329071] Brought up 4 CPUs
[ 0.329078] SMP: Total of 4 processors activated.
[ 0.329085] CPU features: detected feature: 32-bit EL0 Support
[ 0.329359] CPU: All CPU(s) started at EL2
[ 0.329378] alternatives: patching kernel code
[ 0.337727] devtmpfs: initialized
[ 0.375329] Initilizing CustomIPI irq domain
[ 0.375708] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.375731] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.387229] pinctrl core: initialized pinctrl subsystem
[ 0.387918] OS set in device tree is not L4T.
[ 0.388357] regulator-dummy: no parameters
[ 0.388660] Initializing plugin-manager
[ 0.388780] Plugin module not found
[ 0.389016] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.389612] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.390472] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.390899] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.391320] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.391749] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.396650] NET: Registered protocol family 16
[ 0.398023] pstore: using zlib compression
[ 0.398067] console [pstore-1] enabled
[ 0.398072] pstore: Registered ramoops as persistent store backend
[ 0.398077] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.417102] cpuidle: using governor menu
[ 0.421517] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.423120] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.423145] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.425570] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.428137] tegra_powergate_init: DONE
[ 0.428152] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.428160] DTB Build time: Dec 9 2019 22:51:54
[ 0.429961] Tegra reboot handler registered.
[ 0.434584] iommu: Adding device tegra-carveouts to group 0
[ 0.434733] platform tegra-carveouts: domain=ffffffc0f9bc2318 allocates as[0]=ffffffc0f9bd40a8
[ 0.435096] iommu: Adding device smmu_test to group 1
[ 0.435147] platform smmu_test: domain=ffffffc0f9bc2558 allocates as[0]=ffffffc0f9bd4110
[ 0.435962] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.436027] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.436079] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.436088] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.436111] mc-err: mcerr ops are set to t21x
[ 0.446057] iommu: Adding device 70090000.xusb to group 2
[ 0.446338] iommu: Adding device 70006000.serial to group 3
[ 0.446423] platform 70006000.serial: domain=ffffffc0f94bc618 allocates as[0]=ffffffc0f9bd4178
[ 0.446852] iommu: Adding device 70006040.serial to group 4
[ 0.447114] iommu: Adding device 70006200.serial to group 5
[ 0.447334] iommu: Adding device sound to group 6
[ 0.447385] platform sound: domain=ffffffc0f94bcb58 allocates as[0]=ffffffc0f9bd41e0
[ 0.447948] iommu: Adding device 7000d400.spi to group 7
[ 0.448201] iommu: Adding device 7000d600.spi to group 8
[ 0.448495] iommu: Adding device 70410000.spi to group 9
[ 0.448802] iommu: Adding device 50000000.host1x to group 10
[ 0.449127] iommu: Adding device 54080000.vi to group 11
[ 0.449527] iommu: Adding device 54600000.isp to group 12
[ 0.449788] iommu: Adding device 54680000.isp to group 13
[ 0.450096] iommu: Adding device tegradc.0 to group 14
[ 0.450157] platform tegradc.0: domain=ffffffc0f94c9a98 allocates as[0]=ffffffc0f9bd4248
[ 0.454352] platform tegradc.0: IOVA linear map 0x0000000092cb0000(800000)
[ 0.454745] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.455088] iommu: Adding device tegradc.1 to group 15
[ 0.455134] platform tegradc.1: domain=ffffffc0f94c9cd8 allocates as[0]=ffffffc0f9bd42b0
[ 0.459312] platform tegradc.1: IOVA linear map 0x0000000092cb0000(800000)
[ 0.459700] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.459961] iommu: Adding device 54340000.vic to group 16
[ 0.460169] iommu: Adding device 544c0000.nvenc to group 17
[ 0.460369] iommu: Adding device 54500000.tsec to group 18
[ 0.460585] iommu: Adding device 54100000.tsecb to group 19
[ 0.460778] iommu: Adding device 54480000.nvdec to group 20
[ 0.460990] iommu: Adding device 54380000.nvjpg to group 21
[ 0.462069] iommu: Adding device 546c0000.i2c to group 22
[ 0.462402] iommu: Adding device 57000000.gpu to group 23
[ 0.462454] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[0]=ffffffc0f9bd4318
[ 0.462494] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[1]=ffffffc0f9bd4380
[ 0.462531] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[2]=ffffffc0f9bd43e8
[ 0.462566] platform 57000000.gpu: domain=ffffffc0f94d8cd8 allocates as[3]=ffffffc0f9bd4450
[ 0.463489] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.463500] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.463512] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.463516] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.463520] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.513197] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.513206] tegra-pmc: Clear bootloader IO dpd settings
[ 0.513224] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.513291] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.513588] iommu: Adding device 70012000.se to group 24
[ 0.514349] iommu: Adding device 7000c000.i2c to group 25
[ 0.514590] iommu: Adding device 7000c400.i2c to group 26
[ 0.514842] iommu: Adding device 7000c500.i2c to group 27
[ 0.515091] iommu: Adding device 7000c700.i2c to group 28
[ 0.515372] iommu: Adding device 7000d000.i2c to group 29
[ 0.515619] iommu: Adding device 7000d100.i2c to group 30
[ 0.515914] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.515970] platform sdhci-tegra.0: domain=ffffffc0f9568e58 allocates as[0]=ffffffc0f9bd44b8
[ 0.516806] iommu: Adding device 700d0000.xudc to group 32
[ 0.520209] vdd-ac-bat: 5000 mV
[ 0.520576] vdd-5v0-sys: 5000 mV
[ 0.521546] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.521617] vdd-5v0-hdmi: 5000 mV
[ 0.522018] vdd-1v8-sys: 1800 mV
[ 0.522405] vdd-fan: supplied by vdd-5v0-sys
[ 0.522443] vdd-fan: 5000 mV
[ 0.522836] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.522889] vdd-usb-vbus: 5000 mV
[ 0.523418] vdd-usb-vbus2: 5000 mV
[ 0.554072] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.556563] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.557697] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.557718] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.558065] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.566114] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.566470] SCSI subsystem initialized
[ 0.566707] libata version 3.00 loaded.
[ 0.566994] usbcore: registered new interface driver usbfs
[ 0.567045] usbcore: registered new interface driver hub
[ 0.567124] usbcore: registered new device driver usb
[ 0.571148] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.576360] random: fast init done
[ 0.576378] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.577427] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.580375] vdd-ddr-1v1: 1150 mV
[ 0.584997] vdd-pre-reg-1v35: 1350 mV
[ 0.589004] vdd-1v8: 1800 mV
[ 0.593008] avdd-sys-1v2: 1200 mV
[ 0.596999] vdd-pex-1v0: 1050 mV
[ 0.597630] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.598174] max77620-ldo3: at 3100 mV
[ 0.600999] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.601551] max77620-ldo5: at 3100 mV
[ 0.602098] max77620-ldo6: at 2800 mV
[ 0.605000] avdd-1v05-pll: 1050 mV
[ 0.608995] avdd-io-hdmi-dp: 1050 mV
[ 0.611669] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.611950] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.612236] max77620 4-003c: max77620 probe successful
[ 0.615104] media: Linux media interface: v0.10
[ 0.615171] Linux video capture interface: v2.00
[ 0.616098] pps_core: LinuxPPS API ver. 1 registered
[ 0.616104] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.616125] PTP clock support registered
[ 0.619887] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.626265] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.627085] Advanced Linux Sound Architecture Driver Initialized.
[ 0.627765] Bluetooth: Core ver 2.22
[ 0.627811] NET: Registered protocol family 31
[ 0.627816] Bluetooth: HCI device and connection manager initialized
[ 0.627830] Bluetooth: HCI socket layer initialized
[ 0.627839] Bluetooth: L2CAP socket layer initialized
[ 0.627863] Bluetooth: SCO socket layer initialized
[ 0.629662] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.629680] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.629728] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.629743] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.633092] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.634277] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.634343] vdd-3v3-sys: 3300 mV
[ 0.634610] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.637069] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.637534] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.637577] vdd-3v3-sd: 3300 mV
[ 0.638618] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.638656] avdd-io-edp-1v05: 1050 mV
[ 0.639160] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.639203] vdd-usb-hub-en: 5000 mV
[ 0.640704] camchar: rtcpu character device driver loaded
[ 0.641411] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.642818] clocksource: Switched to clocksource arch_sys_counter
[ 0.683191] VFS: Disk quotas dquot_6.6.0
[ 0.683326] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.683827] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.684272] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.684293] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.684502] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.684507] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.684519] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.684550] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.684557] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.684570] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.684578] nvmap_page_pool_init: Total RAM pages: 1009340
[ 0.684584] nvmap_page_pool_init: nvmap page pool size: 126167 pages (492 MB)
[ 0.684670] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.685154] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.686190] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.694722] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.695168] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.695426] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.695630] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.695803] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.696082] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.696086] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.696535] NET: Registered protocol family 2
[ 0.697593] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.697802] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.698344] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.698495] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.698575] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.699054] NET: Registered protocol family 1
[ 0.699789] RPC: Registered named UNIX socket transport module.
[ 0.699795] RPC: Registered udp transport module.
[ 0.699799] RPC: Registered tcp transport module.
[ 0.699803] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.699815] PCI: CLS 0 bytes, default 64
[ 0.700054] Trying to unpack rootfs image as initramfs…
[ 0.933896] Freeing initrd memory: 5356K
[ 0.944394] host1x 50000000.host1x: initialized
[ 0.946321] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.949566] audit: initializing netlink subsys (disabled)
[ 0.949661] audit: type=2000 audit(0.795:1): initialized
[ 0.950422] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.960586] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.962126] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.963002] 9p: Installing v9fs 9p2000 file system support
[ 0.966350] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.966496] io scheduler noop registered
[ 0.966780] io scheduler cfq registered (default)
[ 0.969557] gic 702f9000.agic: GIC IRQ controller registered
[ 0.972570] iommu: Adding device 702ef000.adsp to group 33
[ 0.982126] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.982280] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.982928] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8a2a40f
[ 0.982938] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.984590] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.984694] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.984798] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.985002] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.985095] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.985191] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.985282] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.985373] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.985460] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.985548] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.991769] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.993503] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.995458] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.996740] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.997099] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.998292] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.998524] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.998783] Adding domain tsec-pd to PM domain host1x-pd
[ 1.001175] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.002229] tsec 54500000.tsec: initialized
[ 1.003793] tsec 54100000.tsecb: initialized
[ 1.004525] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.008100] nvdec 54480000.nvdec: initialized
[ 1.009141] Adding domain vic03-pd to PM domain host1x-pd
[ 1.009315] Adding domain msenc-pd to PM domain host1x-pd
[ 1.009480] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.013654] falcon 54340000.vic: initialized
[ 1.014861] falcon 544c0000.nvenc: initialized
[ 1.016168] falcon 54380000.nvjpg: initialized
[ 1.020415] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.020489] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.020520] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.020687] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.020822] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.020828] tegra_cec 70015000.tegra_cec: probed
[ 1.020831] display board info: id 0x0, fab 0x0
[ 1.020901] generic_infoframe_type: 0x87
[ 1.021051] tegradc tegradc.0: DT parsed successfully
[ 1.021107] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 1.021617] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.029038] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.030166] tegradc tegradc.0: probed
[ 1.035766] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.037308] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.037809] kfuse 7000fc00.kfuse: initialized
[ 1.039552] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.040571] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.042190] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.042217] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.042726] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.044451] vdd-gpu: applied init 1000000uV constraint
[ 1.044458] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.044933] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.049978] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.050142] No Device Node present for smmu client: serial8250 !!
[ 1.050155] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.050215] iommu: Adding device serial8250 to group 35
[ 1.054035] console [ttyS0] disabled
[ 1.054171] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.054346] console [ttyS0] enabled
[ 1.055586] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.056063] serial-tegra 70006200.serial: RX in PIO mode
[ 1.056163] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.057269] [drm] Initialized
[ 1.063642] Console: switching to colour frame buffer device 240x67
[ 1.063835] tegradc tegradc.0: fb registered
[ 1.069086] brd: module loaded
[ 1.071541] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.071597] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.072141] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.072154] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.075265] loop: module loaded
[ 1.075377] tegra_profiler: version: 1.139, samples/io: 47/27
[ 1.075499] tegra_profiler: auth: init
[ 1.076897] THERMAL EST: found 2 subdevs
[ 1.076908] THERMAL EST num_resources: 0
[ 1.076915] [THERMAL EST subdev 0]
[ 1.076924] [THERMAL EST subdev 1]
[ 1.077398] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.077402] THERMAL EST: thz register success.
[ 1.077582] THERMAL EST: end of probe, return err: 0
[ 1.078877] hisi_sas: driver version v1.6
[ 1.083385] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.084750] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.084762] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.087879] libphy: Fixed MDIO Bus: probed
[ 1.088640] tun: Universal TUN/TAP device driver, 1.6
[ 1.088644] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.089635] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.089643] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.089693] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.089698] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.089745] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.089749] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.089801] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.089806] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.091001] PPP generic driver version 2.4.2
[ 1.091217] PPP BSD Compression module registered
[ 1.091223] PPP Deflate Compression module registered
[ 1.091268] PPP MPPE Compression module registered
[ 1.091275] NET: Registered protocol family 24
[ 1.091351] usbcore: registered new interface driver r8152
[ 1.091399] usbcore: registered new interface driver asix
[ 1.091456] usbcore: registered new interface driver ax88179_178a
[ 1.091504] usbcore: registered new interface driver cdc_ether
[ 1.091541] usbcore: registered new interface driver net1080
[ 1.091592] usbcore: registered new interface driver cdc_subset
[ 1.091635] usbcore: registered new interface driver zaurus
[ 1.091692] usbcore: registered new interface driver cdc_ncm
[ 1.091866] VFIO - User Level meta-driver version: 0.3
[ 1.093330] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.093358] ehci-pci: EHCI PCI platform driver
[ 1.093419] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.093432] ohci-pci: OHCI PCI platform driver
[ 1.093476] ohci-platform: OHCI generic platform driver
[ 1.096318] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.096930] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.098106] tegra-xusb 70090000.xusb: extcon 0: ffffffc0fa5d3800 id
[ 1.098569] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.098578] Extcon AUX1(HDMI) enable
[ 1.100324] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.100445] tegradc tegradc.1: No lt-data, using default setting
[ 1.100493] tegradc tegradc.1: No hpd-gpio in DT
[ 1.100550] tegradc tegradc.1: DT parsed successfully
[ 1.100600] tegradc tegradc.1: Display dc.ffffff800d4c0000 registered with id=1
[ 1.100762] usbcore: registered new interface driver uas
[ 1.100875] usbcore: registered new interface driver usb-storage
[ 1.101026] usbcore: registered new interface driver usbserial
[ 1.101235] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.101345] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.101382] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.102216] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.102264] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.102286] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.102587] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.102592] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.102596] usb usb1: Product: xHCI Host Controller
[ 1.102600] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.102604] usb usb1: SerialNumber: 70090000.xusb
[ 1.103867] hub 1-0:1.0: USB hub found
[ 1.103995] hub 1-0:1.0: 5 ports detected
[ 1.104602] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.104616] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.104719] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.104830] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.104836] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.104840] usb usb2: Product: xHCI Host Controller
[ 1.104844] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.104848] usb usb2: SerialNumber: 70090000.xusb
[ 1.105220] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.105351] hub 2-0:1.0: USB hub found
[ 1.105389] hub 2-0:1.0: 4 ports detected
[ 1.106595] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.106609] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.106625] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.106638] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.106660] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.107728] mousedev: PS/2 mouse device common for all mice
[ 1.107845] usbcore: registered new interface driver xpad
[ 1.113112] tegradc tegradc.1: probed
[ 1.113434] tegradc tegradc.1: fb registered
[ 1.116650] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.116658] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.116667] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.116683] tegradc tegradc.1: blank - powerdown
[ 1.116704] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.116709] Extcon DP: HPD disabled
[ 1.116713] hpd: hpd_switch 0
[ 1.116718] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.116728] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.116734] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.138714] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.206880] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.230289] tegradc tegradc.0: blank - powerdown
[ 1.235703] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.237862] rtc rtc1: alarm rtc device
[ 1.237875] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.237901] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.238247] i2c /dev entries driver
[ 1.239858] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.263145] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.263220] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.263248] imx219 6-0010: board setup failed
[ 1.263311] imx219: probe of 6-0010 failed with error -121
[ 1.264041] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.266300] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.266304] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.266612] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.266625] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.266632] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.266752] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.266760] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.266766] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.266931] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.266939] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.266944] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.267125] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.267653] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.267697] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.267718] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.267734] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.267742] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.268539] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.268553] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.268735] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.268758] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.269140] parse_throttle_dt_data: Num cap clks = 6
[ 1.269143] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.269150] parse_throttle_dt_data: clk=gpu type=4
[ 1.269168] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.269184] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.269202] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.269205] parse_throttle_dt_data: clk=emc type=3
[ 1.269535] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.269625] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.269762] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.270338] FAN dev name: pwm-fan
[ 1.270381] FAN:gpio request success.
[ 1.270436] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.270656] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.270768] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.270774] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.270870] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.270874] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.270878] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.270882] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.270886] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.270889] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.270893] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.270897] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.270900] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.270904] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.271355] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.271630] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.272440] device-mapper: uevent: version 1.0.3
[ 1.272903] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.275554] tegra210-cpufreq cpufreq: probe()…completed
[ 1.275866] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.275868] Extcon AUX1(HDMI) disable
[ 1.295285] sdhci: Secure Digital Host Controller Interface driver
[ 1.295287] sdhci: Copyright(c) Pierre Ossman
[ 1.295288] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.295766] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.296121] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.296242] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.301045] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.301532] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.302605] usbcore: registered new interface driver usbhid
[ 1.302607] usbhid: USB HID core driver
[ 1.303963] tegradc tegradc.0: unblank
[ 1.304916] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.305096] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.307026] nvpmodel: initialized successfully
[ 1.308207] usbcore: registered new interface driver snd-usb-audio
[ 1.308265] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.308269] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.308285] iommu: Adding device snd-soc-dummy to group 36
[ 1.323561] OPE platform probe
[ 1.323648] OPE platform probe successful
[ 1.323673] OPE platform probe
[ 1.323757] OPE platform probe successful
[ 1.343218] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.347547] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.347631] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.348636] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.348704] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.348711] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.356508] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.356642] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.356769] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.356897] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.357020] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.357145] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.357270] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.357399] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.357522] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.357654] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.369443] u32 classifier
[ 1.369445] Actions configured
[ 1.369514] Initializing XFRM netlink socket
[ 1.370215] NET: Registered protocol family 10
[ 1.370958] NET: Registered protocol family 17
[ 1.370968] NET: Registered protocol family 15
[ 1.371045] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.371091] Bluetooth: RFCOMM socket layer initialized
[ 1.371100] Bluetooth: RFCOMM ver 1.11
[ 1.371104] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.371108] Bluetooth: HIDP socket layer initialized
[ 1.371126] 9pnet: Installing 9P2000 support
[ 1.371160] Key type dns_resolver registered
[ 1.371548] Registered cp15_barrier emulation handler
[ 1.371556] Registered setend emulation handler
[ 1.372560] registered taskstats version 1
[ 1.373063] Adding domain ve2-pd to PM domain host1x-pd
[ 1.373321] Adding domain ve-pd to PM domain host1x-pd
[ 1.375400] isp 54600000.isp: initialized
[ 1.376343] isp 54680000.isp: initialized
[ 1.383604] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.383607] Extcon AUX1(HDMI) enable
[ 1.383990] tegradc tegradc.0: sync windows ret = 250
[ 1.386514] last reset is due to power on reset
[ 1.386516] KERNEL: PMC reset status reg: 0x0
[ 1.386595] BL: PMC reset status reg: 0x0
[ 1.386596] BL: PMIC poweroff Event Recorder: 0x40
[ 1.388084] clk_cbus_recalc_rate: no gbus parent
[ 1.388090] clk_cbus_round_rate: no gbus parent
[ 1.388091] clk_cbus_round_rate: no gbus parent
[ 1.388098] clk_cbus_recalc_rate: no gbus parent
[ 1.388188] clk_cbus_recalc_rate: no gbus parent
[ 1.388190] clk_cbus_round_rate: no gbus parent
[ 1.388192] clk_cbus_round_rate: no gbus parent
[ 1.388195] clk_cbus_recalc_rate: no gbus parent
[ 1.388867] tegra_dvfs: GPU-cap: registered
[ 1.388921] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.388924] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.388925] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.390391] tegra_dvfs: vdd-gpu-vts: registered
[ 1.391119] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.391735] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.392303] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.404002] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.404005] Extcon HDMI: HPD enabled
[ 1.404023] tegradc tegradc.0: hdmi: plugged
[ 1.424838] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:13 UTC (946688413)
[ 1.425889] vi 54080000.vi: vi_probe: ++
[ 1.430880] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.442233] vi 54080000.vi: initialized
[ 1.444881] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.448647] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.450079] Disable partitions left on by BL
[ 1.450083] disb
[ 1.450135] bwmgr: missing cdev-type property
[ 1.450229] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.450235] DRAM derating cdev registered.
[ 1.451274] vdd-fan: disabling
[ 1.451277] vdd-usb-vbus: disabling
[ 1.451279] vdd-usb-vbus2: disabling
[ 1.451289] avdd-io-edp-1v05: disabling
[ 1.451444] ALSA device list:
[ 1.451448] #0: tegra-hda at 0x70038000 irq 83
[ 1.451450] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.454552] Freeing unused kernel memory: 8576K
[ 1.475642] Root device found: mmcblk0p1
[ 1.475922] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.475927] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.475931] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.475934] usb 1-2: Manufacturer: Generic
[ 1.478114] hub 1-2:1.0: USB hub found
[ 1.480192] hub 1-2:1.0: 4 ports detected
[ 1.542301] mmc0: hw tuning done …
[ 1.542337] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.542742] mmcblk0: mmc0:aaaa SP32G 29.7 GiB
[ 1.544219] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.680339] Found dev node: /dev/mmcblk0p1
[ 1.774886] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ 1.796035] usb 1-2.1: New USB device found, idVendor=7392, idProduct=a611
[ 1.796039] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.796042] usb 1-2.1: Product: Edimax Wi-Fi N150 Bluetooth4.0 USB Adapter
[ 1.796045] usb 1-2.1: Manufacturer: Realtek
[ 1.796048] usb 1-2.1: SerialNumber: 00e04c000001
[ 1.850940] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.878869] usb 1-2.3: new full-speed USB device number 4 using tegra-xusb
[ 1.902725] usb 1-2.3: New USB device found, idVendor=046d, idProduct=c52f
[ 1.902730] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.902733] usb 1-2.3: Product: USB Receiver
[ 1.902735] usb 1-2.3: Manufacturer: Logitech
[ 1.905937] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:046D:C52F.0001/input/input2
[ 1.906304] hid-generic 0003:046D:C52F.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-70090000.xusb-2.3/input0
[ 1.908607] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.1/0003:046D:C52F.0002/input/input3
[ 1.967049] hid-generic 0003:046D:C52F.0002: input,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-70090000.xusb-2.3/input1
[ 2.032600] EXT4-fs (mmcblk0p1): 24 orphan inodes deleted
[ 2.032603] EXT4-fs (mmcblk0p1): recovery complete
[ 2.038833] tegra_cec 70015000.tegra_cec: physical address: 30:00.
[ 2.046881] usb 1-2.4: new low-speed USB device number 5 using tegra-xusb
[ 2.051240] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.052027] Rootfs mounted over mmcblk0p1
[ 2.066274] Switching from initrd to actual rootfs
[ 2.075567] usb 1-2.4: New USB device found, idVendor=04ca, idProduct=0027
[ 2.075572] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.075575] usb 1-2.4: Product: USB Multimedia Keyboard
[ 2.075578] usb 1-2.4: Manufacturer: Lite-On Technology Corp.
[ 2.080170] input: Lite-On Technology Corp. USB Multimedia Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:04CA:0027.0003/input/input4
[ 2.102650] tegra_cec 70015000.tegra_cec: Sent res: -70.
[ 2.102655] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.139225] hid-generic 0003:04CA:0027.0003: input,hidraw2: USB HID v1.10 Keyboard [Lite-On Technology Corp. USB Multimedia Keyboard] on usb-70090000.xusb-2.4/input0
[ 2.146773] input: Lite-On Technology Corp. USB Multimedia Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.1/0003:04CA:0027.0004/input/input5
[ 2.203116] hid-generic 0003:04CA:0027.0004: input,hidraw3: USB HID v1.10 Device [Lite-On Technology Corp. USB Multimedia Keyboard] on usb-70090000.xusb-2.4/input1
[ 2.219692] systemd[1]: System time before build time, advancing clock.
[ 2.247864] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.252828] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.254820] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.259600] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.286547] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.287317] systemd[1]: Detected architecture arm64.
[ 2.315830] systemd[1]: Set hostname to .
[ 2.360283] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.360290] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.360294] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.360297] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.360301] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.360322] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.360383] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.360584] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.360754] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.360778] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.360808] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.360828] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.360963] pci 0000:01:00.0: supports D1 D2
[ 2.360966] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.361272] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.361299] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.361303] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.361310] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.361328] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.361344] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.361352] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.361356] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.361361] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.361674] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.361678] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.361683] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.361768] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.361949] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 2.361965] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.376191] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.376281] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e6:41:00 from device tree
[ 2.376718] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.376734] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 2.405360] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.405370] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.523373] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.525059] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.525173] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.525194] systemd[1]: Reached target User and Group Name Lookups.
[ 2.525220] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.525239] systemd[1]: Reached target Swap.
[ 2.526764] systemd[1]: Created slice User and Session Slice.
[ 2.526949] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.581089] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.667785] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.918611] systemd-journald[2045]: Received request to flush runtime journal from PID 1
[ 3.934334] random: crng init done
[ 3.937769] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.974888] using random self ethernet address
[ 3.984148] using random host ethernet address
[ 5.273184] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.273190] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.527833] usbcore: registered new interface driver btusb
[ 5.534886] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 5.534890] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_config.bin
[ 5.536499] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 5.536502] bluetooth hci0: Falling back to user helper
[ 5.600935] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.637041] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.637048] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.637052] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.637056] usb 2-1: Manufacturer: Generic
[ 5.641958] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 5.647199] hub 2-1:1.0: USB hub found
[ 5.648618] hub 2-1:1.0: 4 ports detected
[ 5.648639] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
[ 5.652815] Bluetooth: hci0: rom_version status=0 version=1
[ 5.652834] Bluetooth: cfg_sz 0, total size 22496
[ 5.806831] usb 2-1: usb_suspend_both: status 0
[ 5.807006] usb usb2: usb_suspend_both: status 0
[ 7.933468] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.933480] Bluetooth: BNEP socket layer initialized
[ 8.073729] zram: Added device: zram0
[ 8.085291] zram: Added device: zram1
[ 8.093201] zram: Added device: zram2
[ 8.096661] zram: Added device: zram3
[ 8.143687] zram0: detected capacity change from 0 to 518565888
[ 8.237456] Adding 506408k swap on /dev/zram0. Priority:5 extents:1 across:506408k SS
[ 8.242252] zram1: detected capacity change from 0 to 518565888
[ 8.269507] Adding 506408k swap on /dev/zram1. Priority:5 extents:1 across:506408k SS
[ 8.273327] zram2: detected capacity change from 0 to 518565888
[ 8.285163] Adding 506408k swap on /dev/zram2. Priority:5 extents:1 across:506408k SS
[ 8.289296] zram3: detected capacity change from 0 to 518565888
[ 8.300662] Adding 506408k swap on /dev/zram3. Priority:5 extents:1 across:506408k SS
[ 9.078003] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.081321] eth0: 0xffffff800d5b2000, 00:04:4b:e6:41:00, IRQ 407
[ 9.154928] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.129173] tegradc tegradc.0: blank - powerdown
[ 13.182514] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 13.182516] Extcon AUX1(HDMI) disable
[ 13.202885] tegradc tegradc.0: unblank
[ 13.213408] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 13.213486] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 13.214489] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 13.214495] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 13.249342] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 13.249345] Extcon AUX1(HDMI) enable
[ 13.255408] tegradc tegradc.0: unblank
[ 13.255417] tegradc tegradc.1: blank - powerdown
[ 16.556582] fuse init (API version 7.26)
[ 18.065984] tegradc tegradc.0: unblank
[ 18.066193] tegradc tegradc.1: blank - powerdown
[ 859.085666] tegradc tegradc.0: blank - powerdown
[ 859.146245] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 859.146249] Extcon AUX1(HDMI) disable
[ 1279.072957] usb 1-2.1: USB disconnect, device number 3
[ 1296.636524] tegradc tegradc.0: unblank
[ 1296.654648] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1296.656001] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1296.657007] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1296.657015] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1296.695505] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1296.695514] Extcon AUX1(HDMI) enable
[ 1296.707498] tegradc tegradc.0: unblank
[ 1296.707794] tegradc tegradc.1: blank - powerdown
[ 1743.932361] tegradc tegradc.0: blank - powerdown
[ 1743.989658] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1743.989660] Extcon AUX1(HDMI) disable
[ 2449.082641] tegradc tegradc.0: unblank
[ 2449.100336] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 2449.100497] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 2449.101653] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 2449.101660] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 2449.145009] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 2449.145015] Extcon AUX1(HDMI) enable
[ 2449.172764] tegradc tegradc.0: unblank
[ 2449.172776] tegradc tegradc.1: blank - powerdown
[ 3228.508341] usb 1-2.4: USB disconnect, device number 5
[ 3327.205178] tegradc tegradc.0: blank - powerdown
[ 3327.266399] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 3327.266400] Extcon AUX1(HDMI) disable
[ 3402.047515] usb 1-2.1: new high-speed USB device number 6 using tegra-xusb
[ 3402.071868] usb 1-2.1: New USB device found, idVendor=058f, idProduct=6387
[ 3402.071874] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3402.071877] usb 1-2.1: Product: Mass Storage
[ 3402.071880] usb 1-2.1: Manufacturer: Generic
[ 3402.071883] usb 1-2.1: SerialNumber: A6729E37
[ 3402.072829] usb-storage 1-2.1:1.0: USB Mass Storage device detected
[ 3402.074624] scsi host0: usb-storage 1-2.1:1.0
[ 3403.102019] scsi 0:0:0:0: Direct-Access digitor MicroDrive 4GB 8.07 PQ: 0 ANSI: 2
[ 3403.115666] sd 0:0:0:0: [sda] 7794688 512-byte logical blocks: (3.99 GB/3.72 GiB)
[ 3403.123414] sd 0:0:0:0: [sda] Write Protect is off
[ 3403.128268] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 3403.128479] sd 0:0:0:0: [sda] No Caching mode page found
[ 3403.133824] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 3403.351155] sda: sda1
[ 3403.352778] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 3421.243512] usb 1-2.4: new low-speed USB device number 7 using tegra-xusb
[ 3421.276382] usb 1-2.4: New USB device found, idVendor=04ca, idProduct=0027
[ 3421.276444] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3421.276490] usb 1-2.4: Product: USB Multimedia Keyboard
[ 3421.276531] usb 1-2.4: Manufacturer: Lite-On Technology Corp.
[ 3421.291766] input: Lite-On Technology Corp. USB Multimedia Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:04CA:0027.0005/input/input6
[ 3421.352911] hid-generic 0003:04CA:0027.0005: input,hidraw2: USB HID v1.10 Keyboard [Lite-On Technology Corp. USB Multimedia Keyboard] on usb-70090000.xusb-2.4/input0
[ 3421.360721] input: Lite-On Technology Corp. USB Multimedia Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.1/0003:04CA:0027.0006/input/input7
[ 3421.420654] hid-generic 0003:04CA:0027.0006: input,hidraw3: USB HID v1.10 Device [Lite-On Technology Corp. USB Multimedia Keyboard] on usb-70090000.xusb-2.4/input1
[ 3423.370073] tegradc tegradc.0: unblank
[ 3423.385699] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 3423.386883] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 3423.387892] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 3423.387899] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 3423.425199] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 3423.425208] Extcon AUX1(HDMI) enable
[ 3423.428125] tegradc tegradc.0: unblank
[ 3423.428136] tegradc tegradc.1: blank - powerdown
[ 3528.284653] usb 1-2.1: USB disconnect, device number 6
[ 3528.351285] FAT-fs (sda1): unable to read boot sector to mark fs as dirty
[ 3533.883393] usb 1-2.1: new high-speed USB device number 8 using tegra-xusb
[ 3533.910622] usb 1-2.1: New USB device found, idVendor=7392, idProduct=a611
[ 3533.910691] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3533.910740] usb 1-2.1: Product: Edimax Wi-Fi N150 Bluetooth4.0 USB Adapter
[ 3533.910782] usb 1-2.1: Manufacturer: Realtek
[ 3533.911256] usb 1-2.1: SerialNumber: 00e04c000001
[ 3533.926786] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 3533.926793] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_config.bin
[ 3533.926881] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 3533.936050] bluetooth hci0: Falling back to user helper
[ 3533.980694] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 3533.987295] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
[ 3533.988819] Bluetooth: hci0: rom_version status=0 version=1
[ 3533.988838] Bluetooth: cfg_sz 0, total size 22496
[ 3636.062541] usb 1-2.1: USB disconnect, device number 8
[ 3647.295409] usb 1-2.1: new high-speed USB device number 9 using tegra-xusb
[ 3647.321461] usb 1-2.1: New USB device found, idVendor=058f, idProduct=6387
[ 3647.321524] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3647.321569] usb 1-2.1: Product: Mass Storage
[ 3647.321726] usb 1-2.1: Manufacturer: Generic
[ 3647.321769] usb 1-2.1: SerialNumber: A6729E37
[ 3647.326347] usb-storage 1-2.1:1.0: USB Mass Storage device detected
[ 3647.330698] scsi host0: usb-storage 1-2.1:1.0
[ 3648.347314] scsi 0:0:0:0: Direct-Access digitor MicroDrive 4GB 8.07 PQ: 0 ANSI: 2
[ 3648.359144] sd 0:0:0:0: [sda] 7794688 512-byte logical blocks: (3.99 GB/3.72 GiB)
[ 3648.366907] sd 0:0:0:0: [sda] Write Protect is off
[ 3648.371972] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 3648.373824] sd 0:0:0:0: [sda] No Caching mode page found
[ 3648.379273] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 3648.964455] sda: sda1
[ 3648.965882] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 3649.689131] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 3710.812604] usb 1-2.1: USB disconnect, device number 9
[ 3716.155403] usb 1-2.1: new high-speed USB device number 10 using tegra-xusb
[ 3716.178991] usb 1-2.1: New USB device found, idVendor=7392, idProduct=a611
[ 3716.179053] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3716.179100] usb 1-2.1: Product: Edimax Wi-Fi N150 Bluetooth4.0 USB Adapter
[ 3716.179142] usb 1-2.1: Manufacturer: Realtek
[ 3716.179183] usb 1-2.1: SerialNumber: 00e04c000001
[ 3716.190841] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 3716.190847] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_config.bin
[ 3716.190887] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 3716.200186] bluetooth hci0: Falling back to user helper
[ 3716.244270] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 3716.250914] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
[ 3716.251804] Bluetooth: hci0: rom_version status=0 version=1
[ 3716.251825] Bluetooth: cfg_sz 0, total size 22496
[ 3888.479659] usb 1-2.1: USB disconnect, device number 10
[ 3894.079451] usb 1-2.1: new high-speed USB device number 11 using tegra-xusb
[ 3894.107186] usb 1-2.1: New USB device found, idVendor=058f, idProduct=6387
[ 3894.107247] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3894.107293] usb 1-2.1: Product: Mass Storage
[ 3894.107335] usb 1-2.1: Manufacturer: Generic
[ 3894.107375] usb 1-2.1: SerialNumber: A6729E37
[ 3894.120020] usb-storage 1-2.1:1.0: USB Mass Storage device detected
[ 3894.122332] scsi host0: usb-storage 1-2.1:1.0
[ 3895.130863] scsi 0:0:0:0: Direct-Access digitor MicroDrive 4GB 8.07 PQ: 0 ANSI: 2
[ 3895.140302] sd 0:0:0:0: [sda] 7794688 512-byte logical blocks: (3.99 GB/3.72 GiB)
[ 3895.148081] sd 0:0:0:0: [sda] Write Protect is off
[ 3895.152950] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 3895.153209] sd 0:0:0:0: [sda] No Caching mode page found
[ 3895.158734] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 3896.417018] sda: sda1
[ 3896.418517] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 3908.700346] usb 1-2.1: USB disconnect, device number 11
[ 3908.767713] FAT-fs (sda1): unable to read boot sector to mark fs as dirty
[ 3992.123395] usb 1-2.1: new high-speed USB device number 12 using tegra-xusb
[ 3992.150327] usb 1-2.1: New USB device found, idVendor=058f, idProduct=6387
[ 3992.150388] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3992.150436] usb 1-2.1: Product: Mass Storage
[ 3992.150476] usb 1-2.1: Manufacturer: Generic
[ 3992.150518] usb 1-2.1: SerialNumber: A6729E37
[ 3992.160077] usb-storage 1-2.1:1.0: USB Mass Storage device detected
[ 3992.164765] scsi host0: usb-storage 1-2.1:1.0
[ 3993.178523] scsi 0:0:0:0: Direct-Access digitor MicroDrive 4GB 8.07 PQ: 0 ANSI: 2
[ 3993.188641] sd 0:0:0:0: [sda] 7794688 512-byte logical blocks: (3.99 GB/3.72 GiB)
[ 3993.196414] sd 0:0:0:0: [sda] Write Protect is off
[ 3993.201265] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 3993.201511] sd 0:0:0:0: [sda] No Caching mode page found
[ 3993.206878] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 3993.789654] sda: sda1
[ 3993.791443] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 4062.044508] usb 1-2.1: USB disconnect, device number 12
[ 4371.775390] usb 1-2.1: new high-speed USB device number 13 using tegra-xusb
[ 4371.799029] usb 1-2.1: New USB device found, idVendor=7392, idProduct=a611
[ 4371.799091] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4371.799139] usb 1-2.1: Product: Edimax Wi-Fi N150 Bluetooth4.0 USB Adapter
[ 4371.799182] usb 1-2.1: Manufacturer: Realtek
[ 4371.799224] usb 1-2.1: SerialNumber: 00e04c000001
[ 4371.816795] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 4371.816802] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_config.bin
[ 4371.816833] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 4371.826861] bluetooth hci0: Falling back to user helper
[ 4371.867583] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 4371.874186] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
[ 4371.875859] Bluetooth: hci0: rom_version status=0 version=1
[ 4371.875878] Bluetooth: cfg_sz 0, total size 22496
[ 4525.571432] FAT-fs (sda1): unable to read boot sector to mark fs as dirty
[ 4532.574183] usb 1-2.1: USB disconnect, device number 13
[ 4539.707424] usb 1-2.1: new high-speed USB device number 14 using tegra-xusb
[ 4539.732227] usb 1-2.1: New USB device found, idVendor=058f, idProduct=6387
[ 4539.732271] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4539.732303] usb 1-2.1: Product: Mass Storage
[ 4539.732333] usb 1-2.1: Manufacturer: Generic
[ 4539.732361] usb 1-2.1: SerialNumber: A6729E37
[ 4539.739380] usb-storage 1-2.1:1.0: USB Mass Storage device detected
[ 4539.739902] scsi host0: usb-storage 1-2.1:1.0
[ 4540.759743] scsi 0:0:0:0: Direct-Access digitor MicroDrive 4GB 8.07 PQ: 0 ANSI: 2
[ 4540.771234] sd 0:0:0:0: [sda] 7794688 512-byte logical blocks: (3.99 GB/3.72 GiB)
[ 4540.780497] sd 0:0:0:0: [sda] Write Protect is off
[ 4540.785489] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 4540.785715] sd 0:0:0:0: [sda] No Caching mode page found
[ 4540.791110] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 4541.368104] sda: sda1
[ 4541.371234] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 4560.220843] usb 1-2.1: USB disconnect, device number 14
[ 4619.839405] usb 1-2.1: new high-speed USB device number 15 using tegra-xusb
[ 4619.863665] usb 1-2.1: New USB device found, idVendor=7392, idProduct=a611
[ 4619.863733] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4619.863786] usb 1-2.1: Product: Edimax Wi-Fi N150 Bluetooth4.0 USB Adapter
[ 4619.863830] usb 1-2.1: Manufacturer: Realtek
[ 4619.863875] usb 1-2.1: SerialNumber: 00e04c000001
[ 4619.879877] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 4619.879884] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_config.bin
[ 4619.879915] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 4619.889126] bluetooth hci0: Falling back to user helper
[ 4619.940323] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 4619.946909] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
[ 4619.947811] Bluetooth: hci0: rom_version status=0 version=1
[ 4619.947829] Bluetooth: cfg_sz 0, total size 22496
[ 4960.405907] tegradc tegradc.0: blank - powerdown
[ 4960.467602] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 4960.467604] Extcon AUX1(HDMI) disable
[ 5002.812316] tegradc tegradc.0: unblank
[ 5002.828020] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 5002.828165] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 5002.829321] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 5002.829333] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5002.867544] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5002.867555] Extcon AUX1(HDMI) enable
[ 5002.876171] tegradc tegradc.0: unblank
[ 5002.876181] tegradc tegradc.1: blank - powerdown
[ 5466.750408] tegradc tegradc.0: blank - powerdown
[ 5466.812039] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 5466.812043] Extcon AUX1(HDMI) disable
[ 5574.944499] tegradc tegradc.0: unblank
[ 5574.960555] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 5574.960719] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 5574.961939] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 5574.961947] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5574.999377] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5574.999387] Extcon AUX1(HDMI) enable
[ 5575.006560] tegradc tegradc.0: unblank
[ 5575.006570] tegradc tegradc.1: blank - powerdown
