Package: nvidia-jetpack
Version: 4.6.4-b39
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0), nvidia-cuda (= 4.6.4-b39), nvidia-tensorrt (= 4.6.4-b39), nvidia-nsight-sys (= 4.6.4-b39), nvidia-cudnn8 (= 4.6.4-b39), nvidia-opencv (= 4.6.4-b39), nvidia-container (= 4.6.4-b39), nvidia-visionworks (= 4.6.4-b39), nvidia-vpi (= 4.6.4-b39)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.4-b39_arm64.deb
SHA256: adf7a6660f73cdc4f95bc15c48d8588688e3afa5ee18bfd5b3a3caa3a458aa02
SHA1: 5abbe0df74f71579c1a0ee30ab7c2c236e1bcdbb
MD5sum: ec293a56d17f2b2793448d621811330d
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Version: 4.6.3-b17
Architecture: arm64
Installed-Size: 194
Depends: nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0), nvidia-cuda (= 4.6.3-b17), nvidia-tensorrt (= 4.6.3-b17), nvidia-nsight-sys (= 4.6.3-b17), nvidia-cudnn8 (= 4.6.3-b17), nvidia-opencv (= 4.6.3-b17), nvidia-container (= 4.6.3-b17), nvidia-vpi (= 4.6.3-b17)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.3-b17_arm64.deb
SHA256: 694254a8667ebbf13852548bdd13a5b8ae61481ac059845b706398eefdcb9e01
SHA1: 67140fc8463ec61fd69352b225244b639c799edd
MD5sum: afa1382b6caded6b736d494fc481bab4
Version: 4.6.2-b5
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.6.2-b5), nvidia-opencv (= 4.6.2-b5), nvidia-cudnn8 (= 4.6.2-b5), nvidia-tensorrt (= 4.6.2-b5), nvidia-visionworks (= 4.6.2-b5), nvidia-container (= 4.6.2-b5), nvidia-vpi (= 4.6.2-b5), nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.2-b5_arm64.deb
SHA256: 925f4abff97e6024d86cff3b9e132e7c7554d05fb83590487381b7e925d5b2bb
SHA1: e3ef727e87df5c331aece34508c110d57d744fe9
MD5sum: 7cb2e387af41bc8143ac7b6525af7794
Version: 4.6.1-b110
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.6.1-b110), nvidia-opencv (= 4.6.1-b110), nvidia-cudnn8 (= 4.6.1-b110), nvidia-tensorrt (= 4.6.1-b110), nvidia-visionworks (= 4.6.1-b110), nvidia-container (= 4.6.1-b110), nvidia-vpi (= 4.6.1-b110), nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.1-b110_arm64.deb
SHA256: acfd9e75af780eab165361d61de4b4fe4974890864fe191060b402ac4c2f54d5
SHA1: a016568ac53705acc145a9f7e60505707bea259f
MD5sum: 79be976b184a8c885bd9169ea5b7fb7b
#DMESG
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5434-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 8 21:19:14 PDT 2023
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57816 r8192 d32296 u98304
[ 0.000000] pcpu-alloc: s57816 r8192 d32296 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: enabling workaround for Spectre-BHB
[ 0.000000] CPU features: enabling workaround for ARM erratum 1742098
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29616(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3560060K/4159488K available (15486K kernel code, 2982K rwdata, 6716K rodata, 8640K init, 614K bss, 124292K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0x (ptrval) - 0x (ptrval) ( 15488 KB)
[ 0.000000] .rodata : 0x (ptrval) - 0x (ptrval) ( 6784 KB)
[ 0.000000] .init : 0x (ptrval) - 0x (ptrval) ( 8640 KB)
[ 0.000000] .data : 0x (ptrval) - 0x (ptrval) ( 2983 KB)
[ 0.000000] .bss : 0x (ptrval) - 0x (ptrval) ( 615 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001709] Console: colour dummy device 80x25
[ 0.001719] console [tty0] enabled
[ 0.001725] bootconsole [uart8250] disabled
[ 0.001746] kmemleak: Kernel memory leak detector disabled
[ 0.001767] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001778] pid_max: default: 32768 minimum: 301
[ 0.002258] Security Framework initialized
[ 0.002504] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002510] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003674] ftrace: allocating 47296 entries in 185 pages
[ 0.182408] sched-energy: CPU device node has no sched-energy-costs
[ 0.192270] ASID allocator initialised with 65536 entries
[ 0.220066] tegra-id: chipid=22117.
[ 0.220078] tegra-id: opt_subrevision=0.
[ 0.220097] Tegra Speedo/IDDQ fuse revision 4
[ 0.220102] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.220107] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.220113] Tegra: CPU Speedo Value 2108, SoC Speedo Value 2002, GPU Speedo Value 2110
[ 0.220117] Tegra: CPU IDDQ Value 2200, SoC IDDQ Value 2320, GPU IDDQ Value 3050
[ 0.220132] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.220147] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.220156] DTB Build time: Jun 8 2023 21:21:40
[ 0.269126] CPU1: Booted secondary processor [411fd071]
[ 0.301012] CPU2: Booted secondary processor [411fd071]
[ 0.332985] CPU3: Booted secondary processor [411fd071]
[ 0.333084] Brought up 4 CPUs
[ 0.333089] SMP: Total of 4 processors activated.
[ 0.333097] CPU features: detected feature: 32-bit EL0 Support
[ 0.333341] CPU: All CPU(s) started at EL2
[ 0.333361] alternatives: patching kernel code
[ 0.341782] devtmpfs: initialized
[ 0.380286] Initilizing CustomIPI irq domain
[ 0.380606] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.380625] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.393514] pinctrl core: initialized pinctrl subsystem
[ 0.394128] OS set in device tree is not L4T.
[ 0.394598] regulator-dummy: no parameters
[ 0.394875] Initializing plugin-manager
[ 0.395043] Plugin module not found
[ 0.395231] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.395750] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.396713] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.396926] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.397599] node /plugin-manager/fragement@13 match with board >=3448-0000-300
[ 0.401348] NET: Registered protocol family 16
[ 0.402691] pstore: using zlib compression
[ 0.402730] console [pstore-1] enabled
[ 0.402735] pstore: Registered ramoops as persistent store backend
[ 0.402740] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.417143] cpuidle: using governor menu
[ 0.421276] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.423037] vdso: 2 pages (1 code @ (ptrval), 1 data @ (ptrval))
[ 0.423063] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.425715] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.428048] Serial: AMBA PL011 UART driver
[ 0.428557] tegra_powergate_init: DONE
[ 0.428572] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.428580] DTB Build time: Jun 8 2023 21:21:40
[ 0.430518] Tegra reboot handler registered.
[ 0.435129] iommu: Adding device tegra-carveouts to group 0
[ 0.435269] platform tegra-carveouts: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.435629] iommu: Adding device smmu_test to group 1
[ 0.435679] platform smmu_test: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.436521] mc: mapped MMIO address: 0x (ptrval) -> 0x70019000
[ 0.436575] mc: mapped MMIO address: 0x (ptrval) -> 0x7001c000
[ 0.436625] mc: mapped MMIO address: 0x (ptrval) -> 0x7001d000
[ 0.436636] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.436658] mc-err: mcerr ops are set to t21x
[ 0.447576] iommu: Adding device 70090000.xusb to group 2
[ 0.447866] iommu: Adding device 70006000.serial to group 3
[ 0.447952] platform 70006000.serial: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.448377] iommu: Adding device 70006040.serial to group 4
[ 0.448645] iommu: Adding device 70006200.serial to group 5
[ 0.448875] iommu: Adding device sound to group 6
[ 0.448920] platform sound: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.449568] iommu: Adding device 7000d400.spi to group 7
[ 0.449825] iommu: Adding device 7000d600.spi to group 8
[ 0.450102] iommu: Adding device 70410000.spi to group 9
[ 0.450407] iommu: Adding device 50000000.host1x to group 10
[ 0.450684] iommu: Adding device 54080000.vi to group 11
[ 0.451080] iommu: Adding device 54600000.isp to group 12
[ 0.451376] iommu: Adding device 54680000.isp to group 13
[ 0.451653] iommu: Adding device tegradc.0 to group 14
[ 0.451704] platform tegradc.0: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.455888] platform tegradc.0: IOVA linear map 0x0000000092ca9000(800000)
[ 0.456280] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.456620] iommu: Adding device tegradc.1 to group 15
[ 0.456667] platform tegradc.1: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.460848] platform tegradc.1: IOVA linear map 0x0000000092ca9000(800000)
[ 0.461261] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.461516] iommu: Adding device 54340000.vic to group 16
[ 0.461726] iommu: Adding device 544c0000.nvenc to group 17
[ 0.461931] iommu: Adding device 54500000.tsec to group 18
[ 0.462132] iommu: Adding device 54100000.tsecb to group 19
[ 0.462359] iommu: Adding device 54480000.nvdec to group 20
[ 0.462557] iommu: Adding device 54380000.nvjpg to group 21
[ 0.463609] iommu: Adding device 546c0000.i2c to group 22
[ 0.463938] iommu: Adding device 57000000.gpu to group 23
[ 0.463988] platform 57000000.gpu: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.464027] platform 57000000.gpu: domain= (ptrval) allocates as[1]= (ptrval)
[ 0.464067] platform 57000000.gpu: domain= (ptrval) allocates as[2]= (ptrval)
[ 0.464123] platform 57000000.gpu: domain= (ptrval) allocates as[3]= (ptrval)
[ 0.464997] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.465048] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.465062] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.465066] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.465070] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.517189] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.517199] tegra-pmc: Clear bootloader IO dpd settings
[ 0.517219] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.517286] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.517584] iommu: Adding device 70012000.se to group 24
[ 0.518168] iommu: Adding device 1003000.pcie to group 25
[ 0.518226] platform 1003000.pcie: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.518696] iommu: Adding device 7000c000.i2c to group 26
[ 0.518951] iommu: Adding device 7000c400.i2c to group 27
[ 0.519213] iommu: Adding device 7000c500.i2c to group 28
[ 0.519460] iommu: Adding device 7000c700.i2c to group 29
[ 0.519707] iommu: Adding device 7000d000.i2c to group 30
[ 0.519951] iommu: Adding device 7000d100.i2c to group 31
[ 0.520237] iommu: Adding device sdhci-tegra.0 to group 32
[ 0.520292] platform sdhci-tegra.0: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.521183] iommu: Adding device 700d0000.xudc to group 33
[ 0.524465] vdd-ac-bat: 5000 mV
[ 0.524834] vdd-5v0-sys: 5000 mV
[ 0.525518] vdd-5v0-hdmi: 5000 mV
[ 0.525940] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.526191] vdd-1v8-sys: 1800 mV
[ 0.526635] vdd-fan: 5000 mV
[ 0.526859] vdd-fan: supplied by vdd-5v0-sys
[ 0.527072] vdd-usb-vbus: 5000 mV
[ 0.527279] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.527622] vdd-usb-vbus2: 5000 mV
[ 0.558110] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.560471] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.561602] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.561629] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.561648] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.562050] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.570097] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.570471] SCSI subsystem initialized
[ 0.570668] libata version 3.00 loaded.
[ 0.570974] usbcore: registered new interface driver usbfs
[ 0.571027] usbcore: registered new interface driver hub
[ 0.571070] usbcore: registered new device driver usb
[ 0.575369] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.581254] vdd-core: 600 <--> 1162 mV at 1075 mV
[ 0.582318] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.584249] vdd-ddr-1v1: 1150 mV
[ 0.588243] vdd-pre-reg-1v35: 1350 mV
[ 0.592246] vdd-1v8: 1800 mV
[ 0.596241] avdd-sys-1v2: 1200 mV
[ 0.600244] vdd-pex-1v0: 1050 mV
[ 0.600866] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.601395] max77620-ldo3: at 3100 mV
[ 0.604244] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.604778] max77620-ldo5: at 3100 mV
[ 0.608245] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[ 0.612238] avdd-1v05-pll: 1050 mV
[ 0.616243] avdd-io-hdmi-dp: 1050 mV
[ 0.618945] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.619242] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.619531] max77620 4-003c: max77620 probe successful
[ 0.622331] media: Linux media interface: v0.10
[ 0.622392] Linux video capture interface: v2.00
[ 0.623309] pps_core: LinuxPPS API ver. 1 registered
[ 0.623315] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.623335] PTP clock support registered
[ 0.626483] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.627373] Advanced Linux Sound Architecture Driver Initialized.
[ 0.628003] Bluetooth: Core ver 2.22
[ 0.628051] NET: Registered protocol family 31
[ 0.628054] Bluetooth: HCI device and connection manager initialized
[ 0.628069] Bluetooth: HCI socket layer initialized
[ 0.628077] Bluetooth: L2CAP socket layer initialized
[ 0.628104] Bluetooth: SCO socket layer initialized
[ 0.629840] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.629859] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.629909] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.629925] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.633427] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.634554] vdd-3v3-sys: 3300 mV
[ 0.634909] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.634980] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.636323] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.636738] vdd-3v3-sd: 3300 mV
[ 0.637117] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.637871] avdd-io-edp-1v05: 1050 mV
[ 0.638248] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.638388] vdd-usb-hub-en: 5000 mV
[ 0.638725] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.639911] camchar: rtcpu character device driver loaded
[ 0.640653] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.642125] clocksource: Switched to clocksource arch_sys_counter
[ 0.683259] VFS: Disk quotas dquot_6.6.0
[ 0.683396] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.683935] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.684449] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.684467] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.684674] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.684679] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.684691] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.684720] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.684726] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.684750] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.684757] nvmap_page_pool_init: Total RAM pages: 1008799
[ 0.684762] nvmap_page_pool_init: nvmap page pool size: 126099 pages (492 MB)
[ 0.684848] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.685361] misc nvmap: created heap iram base 0x (ptrval) size (252KiB)
[ 0.686403] misc nvmap: created heap vpr base 0x (ptrval) size (409600KiB)
[ 0.694793] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.695234] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.695593] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.695863] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.696041] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.696321] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.696325] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.696786] NET: Registered protocol family 2
[ 0.696938] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.714417] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.714630] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.715169] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.715335] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.715417] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.715848] NET: Registered protocol family 1
[ 0.716577] RPC: Registered named UNIX socket transport module.
[ 0.716582] RPC: Registered udp transport module.
[ 0.716586] RPC: Registered tcp transport module.
[ 0.716590] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.716604] PCI: CLS 0 bytes, default 64
[ 0.716854] Trying to unpack rootfs image as initramfs...
[ 1.026426] Freeing initrd memory: 6988K
[ 1.036254] host1x 50000000.host1x: initialized
[ 1.038266] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.041521] audit: initializing netlink subsys (disabled)
[ 1.041617] audit: type=2000 audit(0.879:1): initialized
[ 1.042402] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.052269] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.053761] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.054630] 9p: Installing v9fs 9p2000 file system support
[ 1.057881] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.058005] io scheduler noop registered
[ 1.058354] io scheduler cfq registered (default)
[ 1.061176] gic 702f9000.agic: GIC IRQ controller registered
[ 1.064676] iommu: Adding device 702ef000.adsp to group 34
[ 1.073635] iommu: Adding device aconnect@702c0000:adsp_audio to group 35
[ 1.073783] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.074493] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x79a840c
[ 1.074501] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.076142] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.076245] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.076346] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.076533] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.076622] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.076716] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.076801] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.076896] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.076987] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.077079] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.083277] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.084944] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.086890] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.088166] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.088522] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.089820] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.090049] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.090297] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.090514] Adding domain tsec-pd to PM domain host1x-pd
[ 1.093820] tsec 54500000.tsec: initialized
[ 1.095201] tsec 54100000.tsecb: initialized
[ 1.095918] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.099294] nvdec 54480000.nvdec: initialized
[ 1.100338] Adding domain vic03-pd to PM domain host1x-pd
[ 1.100507] Adding domain msenc-pd to PM domain host1x-pd
[ 1.100667] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.104741] falcon 54340000.vic: initialized
[ 1.106008] falcon 544c0000.nvenc: initialized
[ 1.107362] falcon 54380000.nvjpg: initialized
[ 1.111828] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.111871] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.111908] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.112016] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.112112] display board info: id 0x0, fab 0x0
[ 1.112167] generic_infoframe_type: 0x87
[ 1.112293] tegradc tegradc.0: DT parsed successfully
[ 1.112339] tegradc tegradc.0: Display dc. (ptrval) registered with id=0
[ 1.112832] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.114082] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.114092] tegra_cec 70015000.tegra_cec: probed
[ 1.116248] tegradc tegradc.0: probed
[ 1.125082] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.131351] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 1.131374] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.131380] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 1.131388] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 1.131397] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.131465] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 1.131664] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.132030] iommu: Adding device 0000:00:01.0 to group 36
[ 1.132230] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 1.132339] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.132717] iommu: Adding device 0000:00:02.0 to group 37
[ 1.132842] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.132861] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.133132] pci 0000:01:00.0: [8086:24fd] type 00 class 0x028000
[ 1.133209] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 1.133577] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 1.134019] iommu: Adding device 0000:01:00.0 to group 38
[ 1.134829] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.136396] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.136404] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.136864] kfuse 7000fc00.kfuse: initialized
[ 1.138594] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.139528] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.141026] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.141044] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.141607] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.142946] vdd-gpu: applied init 1000000uV constraint
[ 1.142952] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.143313] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.146330] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.146571] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 1.146609] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 1.146649] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 1.146675] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 1.146918] pci 0000:02:00.0: supports D1 D2
[ 1.146922] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.147218] iommu: Adding device 0000:02:00.0 to group 39
[ 1.148125] Console: switching to colour frame buffer device 240x67
[ 1.148250] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.148252] tegradc tegradc.0: fb registered
[ 1.148415] No Device Node present for smmu client: serial8250 !!
[ 1.148424] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.148456] iommu: Adding device serial8250 to group 40
[ 1.151243] console [ttyS0] disabled
[ 1.151319] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.151421] console [ttyS0] enabled
[ 1.152401] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.152689] serial-tegra 70006200.serial: RX in PIO mode
[ 1.152785] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.153827] [drm] Initialized
[ 1.155566] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.155610] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.156128] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.156142] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.158312] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 1.158403] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 1.158411] pci 0000:00:02.0: BAR 14: assigned [mem 0x13100000-0x131fffff]
[ 1.158417] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.158429] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13001fff 64bit]
[ 1.158460] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 1.158470] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 1.158484] pci 0000:02:00.0: BAR 4: assigned [mem 0x13100000-0x13103fff 64bit]
[ 1.158506] pci 0000:02:00.0: BAR 2: assigned [mem 0x13104000-0x13104fff 64bit]
[ 1.158528] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.158538] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 1.158543] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 1.158551] pci 0000:00:02.0: bridge window [mem 0x13100000-0x131fffff]
[ 1.159181] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 1.159188] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.159197] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 1.159334] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 1.159580] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 1.159586] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 1.159593] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 1.159703] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 1.167063] brd: module loaded
[ 1.172594] loop: module loaded
[ 1.172687] tegra_profiler: version: 1.145, samples/io: 49/28
[ 1.172800] tegra_profiler: auth: init
[ 1.174322] THERMAL EST: found 2 subdevs
[ 1.174331] THERMAL EST num_resources: 0
[ 1.174339] [THERMAL EST subdev 0]
[ 1.174349] [THERMAL EST subdev 1]
[ 1.174803] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.174808] THERMAL EST: thz register success.
[ 1.174977] THERMAL EST: end of probe, return err: 0
[ 1.176242] sd: No Scsi addr parsed to reserve index
[ 1.176281] hisi_sas: driver version v1.6
[ 1.181371] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.182547] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.182553] Extcon AUX1(HDMI) enable
[ 1.183496] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.183571] tegradc tegradc.1: No lt-data, using default setting
[ 1.183599] tegradc tegradc.1: No hpd-gpio in DT
[ 1.183631] tegradc tegradc.1: DT parsed successfully
[ 1.183681] tegradc tegradc.1: Display dc. (ptrval) registered with id=1
[ 1.185112] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.185275] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.185282] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.192264] tun: Universal TUN/TAP device driver, 1.6
[ 1.192270] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.193409] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.193415] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.193475] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.193479] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.193527] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.193532] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.193584] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 1.193587] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 1.195103] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[ 1.195142] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 1.195508] tegradc tegradc.1: probed
[ 1.195859] tegradc tegradc.1: fb registered
[ 1.199077] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.199084] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.199093] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.199110] tegradc tegradc.1: blank - powerdown
[ 1.199133] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.199137] Extcon DP: HPD disabled
[ 1.199142] hpd: hpd_switch 0
[ 1.199146] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.199155] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.199162] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.209738] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 1.209880] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:5c:39:aa from device tree
[ 1.211105] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.211169] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 1.211795] PPP generic driver version 2.4.2
[ 1.212008] PPP BSD Compression module registered
[ 1.212014] PPP Deflate Compression module registered
[ 1.212067] PPP MPPE Compression module registered
[ 1.212076] NET: Registered protocol family 24
[ 1.212164] usbcore: registered new interface driver r8152
[ 1.212222] usbcore: registered new interface driver asix
[ 1.212318] usbcore: registered new interface driver ax88179_178a
[ 1.212368] usbcore: registered new interface driver cdc_ether
[ 1.212415] usbcore: registered new interface driver net1080
[ 1.212466] usbcore: registered new interface driver cdc_subset
[ 1.212511] usbcore: registered new interface driver zaurus
[ 1.212605] usbcore: registered new interface driver cdc_ncm
[ 1.212830] VFIO - User Level meta-driver version: 0.3
[ 1.214317] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.214374] ehci-pci: EHCI PCI platform driver
[ 1.214428] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.214439] ohci-pci: OHCI PCI platform driver
[ 1.214481] ohci-platform: OHCI generic platform driver
[ 1.217264] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.217895] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.219172] tegra-xusb 70090000.xusb: extcon 0: (ptrval) id
[ 1.221597] usbcore: registered new interface driver uas
[ 1.221658] usbcore: registered new interface driver usb-storage
[ 1.221759] usbcore: registered new interface driver usbserial
[ 1.222078] tegra-xusb 70090000.xusb: Firmware timestamp: 2023-04-25 07:35:59 UTC, Version: 50.29 release
[ 1.222170] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.222200] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.222964] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.223027] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.223236] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.223243] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.223248] usb usb1: Product: xHCI Host Controller
[ 1.223253] usb usb1: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[ 1.223258] usb usb1: SerialNumber: 70090000.xusb
[ 1.223922] hub 1-0:1.0: USB hub found
[ 1.223966] hub 1-0:1.0: 5 ports detected
[ 1.224569] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.224581] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.224659] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.224821] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.224826] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.224832] usb usb2: Product: xHCI Host Controller
[ 1.224837] usb usb2: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[ 1.224841] usb usb2: SerialNumber: 70090000.xusb
[ 1.225271] hub 2-0:1.0: USB hub found
[ 1.225300] hub 2-0:1.0: 4 ports detected
[ 1.230087] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.230145] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.230320] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.230325] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.231099] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.231109] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.231119] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.231127] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.231148] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.231680] mousedev: PS/2 mouse device common for all mice
[ 1.231751] usbcore: registered new interface driver xpad
[ 1.246225] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.246272] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 1.317670] tegradc tegradc.0: blank - powerdown
[ 1.354137] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.356265] rtc rtc1: alarm rtc device
[ 1.356278] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.356294] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.356655] i2c /dev entries driver
[ 1.358354] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.358690] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.358695] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.359264] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.360069] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.360072] Extcon AUX1(HDMI) disable
[ 1.382539] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.382607] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.382672] imx219 7-0010: board setup failed
[ 1.382724] imx219: probe of 7-0010 failed with error -121
[ 1.383150] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.395247] tegradc tegradc.0: unblank
[ 1.406422] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.406496] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.406597] imx219 8-0010: board setup failed
[ 1.406668] imx219: probe of 8-0010 failed with error -121
[ 1.408286] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.408344] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.408429] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.409768] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.411244] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.411250] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.411719] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.411736] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.411745] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.411875] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.411885] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.411891] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.412040] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.412051] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.412056] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.412228] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.413170] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.413227] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.413253] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.413270] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.413279] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.414265] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.414284] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.414487] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.414521] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.414935] parse_throttle_dt_data: Num cap clks = 6
[ 1.414941] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.414956] parse_throttle_dt_data: clk=gpu type=4
[ 1.414982] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.415005] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.415028] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.415031] parse_throttle_dt_data: clk=emc type=3
[ 1.415405] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.415528] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.415664] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.416463] FAN dev name: pwm-fan
[ 1.416539] FAN:gpio request success.
[ 1.416600] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.416898] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.417082] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.417091] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.417196] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.417201] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.417205] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.417209] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.417213] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.417217] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.417221] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.417225] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.417229] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.417233] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.420169] device-mapper: uevent: version 1.0.3
[ 1.420642] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.425353] tegra210-cpufreq cpufreq: probe()...completed
[ 1.426066] sdhci: Secure Digital Host Controller Interface driver
[ 1.426068] sdhci: Copyright(c) Pierre Ossman
[ 1.426069] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.426572] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.426928] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.427049] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.431864] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.432355] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.433433] usbcore: registered new interface driver usbhid
[ 1.433435] usbhid: USB HID core driver
[ 1.435597] ashmem: initialized
[ 1.436521] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.436687] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.438935] nvpmodel: initialized successfully
[ 1.439894] usbcore: registered new interface driver snd-usb-audio
[ 1.439945] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.439950] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.439970] iommu: Adding device snd-soc-dummy to group 41
[ 1.444774] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.444777] Extcon AUX1(HDMI) enable
[ 1.455200] OPE platform probe
[ 1.455284] OPE platform probe successful
[ 1.455574] OPE platform probe
[ 1.455660] OPE platform probe successful
[ 1.459473] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.460011] tegradc tegradc.0: sync windows ret = 246
[ 1.470231] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.478255] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.478773] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.478900] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.479018] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.479145] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.479265] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.479403] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.479523] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.479644] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.479762] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.479881] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.497894] u32 classifier
[ 1.497895] Actions configured
[ 1.497964] Initializing XFRM netlink socket
[ 1.498710] NET: Registered protocol family 10
[ 1.503624] NET: Registered protocol family 17
[ 1.503634] NET: Registered protocol family 15
[ 1.503717] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.503860] Bluetooth: RFCOMM socket layer initialized
[ 1.503868] Bluetooth: RFCOMM ver 1.11
[ 1.503872] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.503877] Bluetooth: HIDP socket layer initialized
[ 1.503894] 9pnet: Installing 9P2000 support
[ 1.503948] Key type dns_resolver registered
[ 1.504334] Registered cp15_barrier emulation handler
[ 1.504340] Registered setend emulation handler
[ 1.506569] registered taskstats version 1
[ 1.507225] Adding domain ve2-pd to PM domain host1x-pd
[ 1.507461] Adding domain ve-pd to PM domain host1x-pd
[ 1.508864] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.508867] Extcon HDMI: HPD enabled
[ 1.508886] tegradc tegradc.0: hdmi: plugged
[ 1.509430] isp 54600000.isp: initialized
[ 1.510439] isp 54680000.isp: initialized
[ 1.515768] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.515773] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.515776] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.515779] usb 1-2: Manufacturer: Generic
[ 1.516759] hub 1-2:1.0: USB hub found
[ 1.517339] hub 1-2:1.0: 4 ports detected
[ 1.520966] last reset is due to power on reset
[ 1.520970] KERNEL: PMC reset status reg: 0x0
[ 1.521032] BL: PMC reset status reg: 0x0
[ 1.521034] BL: PMIC poweroff Event Recorder: 0x40
[ 1.522565] clk_cbus_recalc_rate: no gbus parent
[ 1.522570] clk_cbus_round_rate: no gbus parent
[ 1.522573] clk_cbus_round_rate: no gbus parent
[ 1.522580] clk_cbus_recalc_rate: no gbus parent
[ 1.522677] clk_cbus_recalc_rate: no gbus parent
[ 1.522681] clk_cbus_round_rate: no gbus parent
[ 1.522683] clk_cbus_round_rate: no gbus parent
[ 1.522686] clk_cbus_recalc_rate: no gbus parent
[ 1.523347] tegra_dvfs: GPU-cap: registered
[ 1.523412] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.523415] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.523417] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.524709] tegra_dvfs: vdd-gpu-vts: registered
[ 1.525377] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 1.525925] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 1.526702] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.561202] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:13 UTC (946688413)
[ 1.562229] vi 54080000.vi: vi_probe: ++
[ 1.565263] vi 54080000.vi: initialized
[ 1.568071] vi 54080000.vi: subdev nvcsi--2 bound
[ 1.568178] vi 54080000.vi: subdev nvcsi--1 bound
[ 1.569592] Disable partitions left on by BL
[ 1.569596] disb
[ 1.569640] bwmgr: missing cdev-type property
[ 1.569730] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.569737] DRAM derating cdev registered.
[ 1.570559] ALSA device list:
[ 1.570563] #0: tegra-hda at 0x70038000 irq 83
[ 1.570565] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.573883] Freeing unused kernel memory: 8640K
[ 1.598597] Root device found: mmcblk0p1
[ 1.638527] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 1.666859] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 1.666863] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.666866] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 1.666869] usb 2-1: Manufacturer: Generic
[ 1.670085] hub 2-1:1.0: USB hub found
[ 1.670860] hub 2-1:1.0: 4 ports detected
[ 1.698779] mmc0: hw tuning done ...
[ 1.698821] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 1.699147] mmcblk0: mmc0:aaaa SN128 119 GiB
[ 1.703644] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.782138] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 1.803694] Found dev node: /dev/mmcblk0p1
[ 1.803940] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 1.803944] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.826158] usb 2-1: usb_suspend_both: status 0
[ 1.826297] usb usb2: usb_suspend_both: status 0
[ 1.882143] usb 1-2.4: new high-speed USB device number 4 using tegra-xusb
[ 1.910899] usb 1-2.4: New USB device found, idVendor=0c45, idProduct=64ab
[ 1.910903] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.910906] usb 1-2.4: Product: DSJ-2062-309
[ 1.910908] usb 1-2.4: Manufacturer: 191029-
[ 2.142143] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[ 2.206676] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -113.
[ 2.206682] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 3.554400] EXT4-fs (mmcblk0p1): 2 orphan inodes deleted
[ 3.554403] EXT4-fs (mmcblk0p1): recovery complete
[ 3.563648] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.565530] Rootfs mounted over mmcblk0p1
[ 3.578991] Switching from initrd to actual rootfs
[ 3.776461] systemd[1]: System time before build time, advancing clock.
[ 3.812789] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.825673] cgroup: cgroup2: unknown option "nsdelegate"
[ 3.841081] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.841872] systemd[1]: Detected architecture arm64.
[ 3.864107] systemd[1]: Set hostname to <nvidia-desktop>.
[ 4.007327] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.007336] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.110463] systemd[1]: Configuration file /etc/systemd/system/connect.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.173765] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.175448] systemd[1]: Created slice System Slice.
[ 4.175588] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.175753] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 4.175785] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.175944] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.176103] systemd[1]: Listening on udev Control Socket.
[ 4.250802] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.364029] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 4.555906] systemd-journald[1967]: Received request to flush runtime journal from PID 1
[ 5.286107] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[ 5.395909] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.406364] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.490045] random: crng init done
[ 5.493513] random: 167 urandom warning(s) missed due to ratelimiting
[ 5.505461] Intel(R) Wireless WiFi driver for Linux
[ 5.505464] Copyright(c) 2003- 2015 Intel Corporation
[ 5.505670] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 5.603872] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.603894] cpu-throttle-alert cooling device registered.
[ 5.604189] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.604205] gpu-throttle-alert cooling device registered.
[ 5.604415] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.604429] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.604445] hot-surface-alert cooling device registered.
[ 5.612353] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 5.621696] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.736179] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 5.745974] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.752745] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 5.762764] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.769457] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 5.778885] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.825233] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 6.036561] using random self ethernet address
[ 6.036564] using random host ethernet address
[ 6.053392] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 6.055537] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.056209] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 6.078631] usbcore: registered new interface driver btusb
[ 6.079586] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 6.081594] Bluetooth: hci0: Device revision is 16
[ 6.081597] Bluetooth: hci0: Secure boot is enabled
[ 6.081599] Bluetooth: hci0: OTP lock is enabled
[ 6.081600] Bluetooth: hci0: API lock is enabled
[ 6.081602] Bluetooth: hci0: Debug lock is disabled
[ 6.081604] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 6.104772] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 6.175952] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 6.177443] thermal thermal_zone6: failed to read out thermal zone (-5)
[ 6.184284] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi_1
[ 7.386010] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.386021] Bluetooth: BNEP socket layer initialized
[ 7.578251] Bluetooth: hci0: Waiting for firmware download to complete
[ 7.578586] Bluetooth: hci0: Firmware loaded in 1464923 usecs
[ 7.578929] Bluetooth: hci0: Waiting for device to boot
[ 7.591577] Bluetooth: hci0: Device booted in 12415 usecs
[ 7.596429] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 7.599588] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 7.813394] Mass Storage Function, version: 2009/09/11
[ 7.813401] LUN: removable file: (no medium)
[ 7.817474] uvcvideo: Found UVC 1.00 device DSJ-2062-309 (0c45:64ab)
[ 7.824485] using random self ethernet address
[ 7.827117] uvcvideo 1-2.4:1.0: Entity type for entity Extension 4 was not initialized!
[ 7.827123] uvcvideo 1-2.4:1.0: Entity type for entity Extension 3 was not initialized!
[ 7.827127] uvcvideo 1-2.4:1.0: Entity type for entity Processing 2 was not initialized!
[ 7.827131] uvcvideo 1-2.4:1.0: Entity type for entity Camera 1 was not initialized!
[ 7.827475] input: DSJ-2062-309 as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/input/input2
[ 7.827648] usbcore: registered new interface driver uvcvideo
[ 7.827649] USB Video Class driver (1.1.1)
[ 7.873965] using random host ethernet address
[ 8.246097] rndis0: HOST MAC 1e:03:92:00:ed:ac
[ 8.247605] rndis0: MAC 1e:03:92:00:ed:ad
[ 8.248119] usb0: HOST MAC 1e:03:92:00:ed:ae
[ 8.248153] usb0: MAC 1e:03:92:00:ed:af
[ 8.248184] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.254902] l4tbr0: port 1(rndis0) entered blocking state
[ 8.254906] l4tbr0: port 1(rndis0) entered disabled state
[ 8.255499] device rndis0 entered promiscuous mode
[ 8.261898] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 8.267080] l4tbr0: port 2(usb0) entered blocking state
[ 8.267085] l4tbr0: port 2(usb0) entered disabled state
[ 8.267663] device usb0 entered promiscuous mode
[ 8.283050] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.309057] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.354957] eth0: 0xffffff800a41c000, 48:b0:2d:5c:39:aa, IRQ 406
[ 8.405859] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.418047] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.419616] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 8.419929] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 8.539449] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 8.539762] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 8.599694] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.757382] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.778675] zram: Added device: zram0
[ 8.779111] zram: Added device: zram1
[ 8.781471] zram: Added device: zram2
[ 8.785037] zram: Added device: zram3
[ 8.820228] zram0: detected capacity change from 0 to 518508544
[ 9.011638] Adding 506352k swap on /dev/zram0. Priority:5 extents:1 across:506352k SS
[ 9.016863] zram1: detected capacity change from 0 to 518508544
[ 9.027213] Adding 506352k swap on /dev/zram1. Priority:5 extents:1 across:506352k SS
[ 9.031172] zram2: detected capacity change from 0 to 518508544
[ 9.041772] Adding 506352k swap on /dev/zram2. Priority:5 extents:1 across:506352k SS
[ 9.045424] zram3: detected capacity change from 0 to 518508544
[ 9.055641] Adding 506352k swap on /dev/zram3. Priority:5 extents:1 across:506352k SS
[ 10.138189] usb 1-2.4: usb_suspend_both: status 0
[ 10.158196] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 10.178204] usb 1-2: usb_suspend_both: status 0
[ 11.961428] Bridge firewalling registered
[ 11.988110] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 12.119882] Netfilter messages via NETLINK v0.30.
[ 12.123012] ctnetlink v0.93: registering with nfnetlink.
[ 12.223354] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 12.356842] wlan0: authenticate with b2:8b:a9:d5:8c:f3
[ 12.356857] wlan0: capabilities/regulatory prevented using AP HT/VHT configuration, downgraded
[ 12.366311] wlan0: send auth to b2:8b:a9:d5:8c:f3 (try 1/3)
[ 12.379558] wlan0: authenticated
[ 12.382166] wlan0: associate with b2:8b:a9:d5:8c:f3 (try 1/3)
[ 12.388144] wlan0: RX AssocResp from b2:8b:a9:d5:8c:f3 (capab=0x1111 status=0 aid=10)
[ 12.391374] wlan0: associated
[ 12.408500] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 12.479055] wlan0: Limiting TX power to 23 (23 - 0) dBm as advertised by b2:8b:a9:d5:8c:f3
[ 13.068520] fuse init (API version 7.26)
[ 31.872637] vdd-usb-vbus: disabling
[ 31.872680] vdd-usb-vbus2: disabling
[ 31.872777] vddio-sdmmc3-ap: disabling
[ 31.873734] avdd-io-edp-1v05: disabling
[ 31.873774] vdd-usb-hub-en: disabling
[ 756.096071] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 759.185360] usb 1-2.4: usb_suspend_both: status 0
[ 759.205374] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 759.225404] usb 1-2: usb_suspend_both: status 0
[ 831.464896] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1702.083134] usb 1-2.4: usb_suspend_both: status 0
[ 1702.103100] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 1702.123100] usb 1-2: usb_suspend_both: status 0
# full device tree
aconnect@702c0000
actmon@6000c800
#address-cells
adma@702e2000
adsp_audio
agic-controller
ahb@6000c000
ahub
aliases
apbmisc@70000800
arm-pmu
bpmp
bthrot_cdev
bwmgr
camera-pcl
cam_i2cmux
chosen
clock
clock@70110000
compatible
core_dvfs_cdev_cap
cpu_edp
cpufreq
cpuidle
cpus
cpu-throttle-alert
dfll-cdev-cap
dfll-cdev-floor
dfll-max77621@70110000
dma@60020000
dma_test
dtv@7000c300
dummy-cool-dev
dvfs
dvfs_rails
eeprom-manager
efuse@7000f800
extcon
external-memory-controller@7001b000
flow-controller@60007000
gpio@6000d000
gpio-keys
gpio-timed-keys
gps_wake
gpu
gpu-dvfs-rework
gpu_edp
gpu-throttle-alert
hda@70030000
host1x
hot-surface-alert
i2c@7000c000
i2c@7000c400
i2c@7000c500
i2c@7000c700
i2c@7000d000
i2c@7000d100
interrupt-parent
iommu
kfuse@7000fc00
leds
lens_imx219@RBPCV2
mailbox@70098000
max16984-cdp
mc
memory@80000000
memory-controller@70019000
mipical
model
modem
mods-simple-bus
mselect
name
nvdumper
nvidia,boardids
nvidia,dtbbuildtime
nvidia,dtsfilename
nvidia,fastboot-usb-pid
nvidia,pmu-boardid
nvidia,proc-boardid
nvpmodel
pcie@1003000
pfsd
pinctrl@7009f000
pinmux@700008d4
plugin-manager
pmc@7000e400
pmc-iopower
power-domain
psci
psy_extcon_xudc
ptm
pwm@7000a000
pwm@70110000
pwm-fan
pwm_regulators
r8168
regulators
reserved-memory
rollback-protection
rtc
sata@70020000
sdhci@700b0000
sdhci@700b0200
sdhci@700b0400
sdhci@700b0600
se@70012000
serial@70006000
serial@70006040
serial@70006200
serial@70006300
serial-number
#size-cells
smmu_test
smp-custom-ipi
soctherm@0x700E2000
soft_watchdog
sound
sound_ref
spdif-dit.0@0
spdif-dit.1@1
spdif-dit.2@2
spdif-dit.3@3
spdif-dit.4@4
spdif-dit.5@5
spdif-dit.6@6
spdif-dit.7@7
spi@7000d400
spi@7000d600
spi@7000d800
spi@7000da00
spi@70410000
__symbols__
tegra-aotag
tegra-carveouts
tegra_cec
tegra_fiq_debugger
tegra-pmc-blink-pwm
tegra-supply-tests
tegra_udrm
tfesd
thermal-fan-est
thermal-zones
timer
timer@60005000
tlk
trusty
usb_cd
watchdog@60005100
xotg
xudc@700d0000
xusb@70090000
xusb_padctl@7009f000
