THS0 UART is not receiving any data
I have a problem with UART on my device (I’m using ttyTHS0) - after the restart, it’s stopped receiving any data (sending is still working). I tried different programs to receive (which worked previously) to make sure it’s not my program’s fault. I changed senders (Arduino, STM, PC) but I have no idea what’s going on, any ideas on how to fix that?
I was working on pretty high speeds, is there a chance that it could break something?
hello vtg,
may I know what’s your target baudrate?
the default uart is using 115200/8n1. did you have done modifications to update the settings?
Yup, I used 6.250.000 baudrate (I asked about this here), and it was working correctly, but after some time and restart it’s stopped receiving anything.
I also connected the converter (115200 BR) and it also started working only one way, it seems like any tty now cannot receive anything.
hello vtg,
could you please have a try to execute getty running at background to ensure data transferred properly,
for example, $ sudo /sbin/getty -a ubuntu -L 115200 ttyTHS<port> &
I tried but nothing changed.
hello vtg,
is there any failures reported from the kernel side? i.e. $ dmesg --follow
can this workaround by reboot the system?
Rebooting doesn’t help.
I’m not sure what to look at in output to
so here’s what I get:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5285-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:42:04 PST 2021
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44800000
[    0.000000] OF: fdt: - 100000000 ,  180000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[    0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[    0.000000] On node 0 totalpages: 2033152
[    0.000000]   DMA zone: 7192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 460288 pages, LIFO batch:31
[    0.000000]   Normal zone: 24576 pages used for memmap
[    0.000000]   Normal zone: 1572864 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[    0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 2001384
[    0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix=_b boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1    quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29080(88%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Memory: 7190816K/8132608K available (15294K kernel code, 2942K rwdata, 6664K rodata, 8576K init, 609K bss, 188128K reserved, 753664K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f70000   ( 15296 KB)
[    0.000000]     .rodata : 0xffffff8008f70000 - 0xffffff8009600000   (  6720 KB)
[    0.000000]       .init : 0xffffff8009600000 - 0xffffff8009e60000   (  8576 KB)
[    0.000000]       .data : 0xffffff8009e60000 - 0xffffff800a13f808   (  2943 KB)
[    0.000000]        .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc   (   610 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf08000000   (   128 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc200000000   (  8192 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000639] Console: colour dummy device 80x25
[    0.000650] console [tty0] enabled
[    0.000658] bootconsole [tegra_comb_uart0] disabled
[    0.000671] kmemleak: Kernel memory leak detector disabled
[    0.000689] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000704] pid_max: default: 32768 minimum: 301
[    0.001819] Security Framework initialized
[    0.002423] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.002433] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.004095] ftrace: allocating 47208 entries in 185 pages
[    0.405134] sched-energy: Sched-energy-costs installed from DT
[    0.405155] ASID allocator initialised with 65536 entries
[    0.440874] tegra-id: chipid=21917.
[    0.440886] tegra-id: opt_subrevision=1.
[    0.440912] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[    0.440925] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[    0.440935] DTB Build time: Feb 19 2021 08:44:25
[    0.488284] CPU1: Booted secondary processor [4e0f0040]
[    0.520374] CPU2: Booted secondary processor [4e0f0040]
[    0.552493] CPU3: Booted secondary processor [4e0f0040]
[    0.584684] CPU4: Booted secondary processor [4e0f0040]
[    0.616745] CPU5: Booted secondary processor [4e0f0040]
[    0.616939] Brought up 6 CPUs
[    0.616987] SMP: Total of 6 processors activated.
[    0.617003] CPU features: detected feature: Privileged Access Never
[    0.617010] CPU features: detected feature: LSE atomic instructions
[    0.617016] CPU features: detected feature: User Access Override
[    0.617022] CPU features: detected feature: 32-bit EL0 Support
[    0.618504] CPU: All CPU(s) started at EL2
[    0.618558] alternatives: patching kernel code
[    0.625019] devtmpfs: initialized
[    0.663723] Initilizing CustomIPI irq domain
[    0.663963] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.664002] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.674536] pinctrl core: initialized pinctrl subsystem
[    0.674763] OS set in device tree is not L4T.
[    0.675038] regulator-dummy: no parameters
[    0.675304] Initializing plugin-manager
[    0.675359] Plugin module not found
[    0.675399] Plugin-manager status disabled
[    0.676444] NET: Registered protocol family 16
[    0.677623] pstore: using zlib compression
[    0.677642] console [pstore-1] enabled
[    0.677647] pstore: Registered ramoops as persistent store backend
[    0.677654] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[    0.691340] cpuidle: using governor menu
[    0.692410] bpmp: waiting for handshake
[    0.692419] bpmp: handshake completed
[    0.692433] bpmp: synchronizing channels
[    0.692442] bpmp: channels synchronized
[    0.692448] bpmp: mail init ok
[    0.694649] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[    0.694811] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[    0.694818] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[    0.694824] t19x-arm-smmu 12000000.iommu:    stage 1 translation
[    0.694830] t19x-arm-smmu 12000000.iommu:    stage 2 translation
[    0.694836] t19x-arm-smmu 12000000.iommu:    nested translation
[    0.694845] t19x-arm-smmu 12000000.iommu:    stream matching with 128 register groups, mask 0x7f80
[    0.694853] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.694859] t19x-arm-smmu 12000000.iommu:    64 context banks (0 stage-2 only)
[    0.694867] t19x-arm-smmu 12000000.iommu:    Stage-1: 39-bit VA -> 48-bit IPA
[    0.694873] t19x-arm-smmu 12000000.iommu:    Stage-2: 39-bit IPA -> 48-bit PA
[    0.697582] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[    0.697606] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.700109] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.701056] tegra_aon_clk_init: ok
[    0.701064] Registering BPMP clocks...
[    0.701154] tegra_bpmp_clk_init: clock init ok (400 clks)
[    0.701730] Serial: AMBA PL011 UART driver
[    0.701883] tegra_powergate_init: DONE
[    0.702985] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[    0.703021] DTB Build time: Feb 19 2021 08:44:25
[    0.705444] Tegra reboot handler registered.
[    0.712464] iommu: Adding device 14160000.pcie to group 0
[    0.713054] iommu: Adding device 141a0000.pcie to group 1
[    0.714236] iommu: Adding device 2490000.ether_qos to group 2
[    0.714699] iommu: Adding device 3100000.serial to group 3
[    0.715130] iommu: Adding device 3110000.serial to group 4
[    0.715519] iommu: Adding device 3140000.serial to group 5
[    0.716105] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.716420] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.716438] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[    0.716443] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[    0.716448] tegra-pmc: ### PMC reset status reg: 0x0
[    0.716494] tegra-pmc: PMC Prod config success
[    0.716753] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.716768] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.717051] iommu: Adding device 3400000.sdhci to group 6
[    0.717518] iommu: Adding device 3210000.spi to group 7
[    0.717937] iommu: Adding device 3230000.spi to group 8
[    0.718299] iommu: Adding device 3270000.spi to group 9
[    0.719366] iommu: Adding device 3160000.i2c to group 10
[    0.719764] iommu: Adding device c240000.i2c to group 11
[    0.720109] iommu: Adding device 3180000.i2c to group 12
[    0.720512] iommu: Adding device 3190000.i2c to group 13
[    0.721088] iommu: Adding device 31b0000.i2c to group 14
[    0.721433] iommu: Adding device 31c0000.i2c to group 15
[    0.721816] iommu: Adding device c250000.i2c to group 16
[    0.722210] iommu: Adding device 31e0000.i2c to group 17
[    0.722800] iommu: Adding device sound to group 18
[    0.723277] iommu: Adding device 3510000.hda to group 19
[    0.723826] iommu: Adding device bc00000.rtcpu to group 20
[    0.725538] iommu: Adding device 13e10000.host1x to group 21
[    0.725918] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[    0.726304] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[    0.726632] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[    0.727029] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[    0.727399] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[    0.727784] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[    0.728170] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[    0.728502] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[    0.728991] iommu: Adding device 15340000.vic to group 30
[    0.729382] iommu: Adding device 15380000.nvjpg to group 31
[    0.729632] iommu: Adding device 15500000.tsec to group 32
[    0.729880] iommu: Adding device 15100000.tsecb to group 33
[    0.730143] iommu: Adding device 15480000.nvdec to group 34
[    0.730417] iommu: Adding device 15140000.nvdec1 to group 35
[    0.730668] iommu: Adding device 154c0000.nvenc to group 36
[    0.730925] iommu: Adding device 15a80000.nvenc1 to group 37
[    0.731304] iommu: Adding device 15880000.nvdla0 to group 38
[    0.731724] iommu: Adding device 158c0000.nvdla1 to group 39
[    0.732225] iommu: Adding device 15200000.nvdisplay to group 40
[    0.736289] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[    0.736370] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[    0.737062] iommu: Adding device 15210000.nvdisplay to group 41
[    0.737105] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[    0.739045] iommu: Adding device 15c10000.vi to group 42
[    0.739244] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[    0.739636] iommu: Adding device 14800000.isp to group 43
[    0.740548] iommu: Adding device 16000000.pva0 to group 44
[    0.741059] iommu: Adding device 16800000.pva1 to group 45
[    0.741407] iommu: Adding device 15810000.se to group 46
[    0.741775] iommu: Adding device 15820000.se to group 47
[    0.742040] iommu: Adding device 15830000.se to group 48
[    0.742318] iommu: Adding device 15840000.se to group 49
[    0.742648] iommu: Adding device c1a0000.aon to group 50
[    0.744172] iommu: Adding device d000000.bpmp to group 51
[    0.744490] bpmp: ping status is 0
[    0.744635] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[    0.747785] bpmp d000000.bpmp: probe ok
[    0.749611] tegra-reset 0.bpmp_reset: registered 190 resets.
[    0.750009] iommu: Adding device smmu_test to group 52
[    0.750964] mc: mapped MMIO address: 0xffffff800a590000 -> 0x2c10000
[    0.750987] mc: mapped MMIO address: 0xffffff800a5b0000 -> 0x2c20000
[    0.751008] mc: mapped MMIO address: 0xffffff800a5d0000 -> 0x2c30000
[    0.751027] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[    0.751046] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[    0.751068] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2b80000
[    0.751086] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2b90000
[    0.751106] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2ba0000
[    0.751124] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2bb0000
[    0.751141] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1700000
[    0.751159] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1710000
[    0.751176] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1720000
[    0.751194] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1730000
[    0.751213] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1740000
[    0.751231] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1750000
[    0.751248] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1760000
[    0.751278] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1770000
[    0.751350] mc-err: mcerr ops are set to t19x
[    0.756705] iommu: Adding device 2600000.dma to group 53
[    0.762205] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[    0.763455] GPIO line 339 (wifi-enable) hogged as output/high
[    0.763502] GPIO line 412 (camera-control-output-low) hogged as output/low
[    0.763566] GPIO line 413 (camera-control-output-low) hogged as output/low
[    0.763894] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[    0.770501] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[    0.770571] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[    0.770617] GPIO line 266 (w-disable1) hogged as output/high
[    0.770653] GPIO line 264 (w-disable2) hogged as output/high
[    0.770688] GPIO line 265 (suspend-led-gpio) hogged as output/high
[    0.770950] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[    0.773239] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[    0.773250] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.773260] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    0.774137] iommu: Adding device 3550000.xudc to group 54
[    0.774793] iommu: Adding device 3610000.xhci to group 55
[    0.776920] arm64_ras arm64_ras: probed
[    0.777273] ras_fhi_enable: FHI 469 enabled on CPU0
[    0.777329] ras_fhi_enable: FHI 470 enabled on CPU1
[    0.777414] ras_fhi_enable: FHI 471 enabled on CPU2
[    0.777498] ras_fhi_enable: FHI 472 enabled on CPU3
[    0.777587] ras_fhi_enable: FHI 473 enabled on CPU4
[    0.777685] ras_fhi_enable: FHI 474 enabled on CPU5
[    0.777873] carmel_ras_enable: RAS enabled on cpu0
[    0.778048] carmel_ras_enable: RAS enabled on cpu1
[    0.778284] carmel_ras_enable: RAS enabled on cpu2
[    0.778476] carmel_ras_enable: RAS enabled on cpu3
[    0.778691] carmel_ras_enable: RAS enabled on cpu4
[    0.778922] carmel_ras_enable: RAS enabled on cpu5
[    0.778985] carmel_ras carmel_ras: probed
[    0.779980] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 478, noc_nonsecure_irq = 477>
[    0.780510] tegra-cbb c600000.aon-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[    0.781281] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[    0.782002] tegra-cbb be00000.rce-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[    0.782780] tegra-cbb b600000.sce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[    0.783107] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[    0.784338] vdd-ac-bat: 5000 mV
[    0.784750] vdd-sdmmc1-sw: 3300 mV
[    0.785190] vdd-1v8-sd: 1800 mV
[    0.785489] vdd-3v3-cvb: 3300 mV
[    0.785781] vdd-1v8-cvb: 1800 mV
[    0.786088] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    0.786124] vdd-epb-1v0: 1000 mV
[    0.786465] avdd-cam-2v8: 2800 mV
[    0.786754] vdd-fan: 5000 mV
[    0.787008] vdd-hdmi-5v0: 5000 mV
[    0.787261] vdd_sys_en: 1200 mV
[    0.821803] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.826555] eventlib_kernel: keventlib is initialized, test id: 0
[    0.826871] SCSI subsystem initialized
[    0.827100] libata version 3.00 loaded.
[    0.827328] usbcore: registered new interface driver usbfs
[    0.827380] usbcore: registered new interface driver hub
[    0.827516] usbcore: registered new device driver usb
[    0.838781] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[    0.841760] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    0.849291] vdd-1v0: at 1000 mV
[    0.853344] vdd-1v8-hs: at 1800 mV
[    0.857363] vdd-1v8-ls: at 1800 mV
[    0.861372] vdd-1v8-ao: at 1800 mV
[    0.865415] vddio-ddr-1v1: at 1100 mV
[    0.869159] vdd-rtc: at 800 mV
[    0.870284] spmic-ldo1: at 2375 mV
[    0.877204] vdd-ao-3v3: at 3300 mV
[    0.885258] vddio-emmc-3v3: at 3300 mV
[    0.886696] spmic-ldo4: at 1587 mV
[    0.893264] vdd-usb-3v3: at 3300 mV
[    0.901310] vddio-sdmmc1-3v3: at 3300 mV
[    0.905324] vdd-csi-1v2: at 1200 mV
[    0.906768] spmic-ldo8: at 1800 mV
[    0.911502] GPIO line 246 (gpio_default) hogged as output/high
[    0.912873] GPIO line 247 (gpio_default) hogged as output/high
[    0.913230] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[    0.913561] max77620 4-003c: max77620 probe successful
[    0.914217] media: Linux media interface: v0.10
[    0.914316] Linux video capture interface: v2.00
[    0.915756] pps_core: LinuxPPS API ver. 1 registered
[    0.915768] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.915885] PTP clock support registered
[    0.916267] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.916599] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.916654] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.919227] trusty trusty: trusty version: Built: 08:40:57 Feb 19 2021
[    0.919285] trusty trusty: selected api version: 3 (requested 3)
[    0.920530] Advanced Linux Sound Architecture Driver Initialized.
[    0.921025] Bluetooth: Core ver 2.22
[    0.921095] NET: Registered protocol family 31
[    0.921120] Bluetooth: HCI device and connection manager initialized
[    0.921136] Bluetooth: HCI socket layer initialized
[    0.921146] Bluetooth: L2CAP socket layer initialized
[    0.921175] Bluetooth: SCO socket layer initialized
[    0.924361] camchar: rtcpu character device driver loaded
[    0.924856] gpio tegra-gpio wake61 for gpio=201(Z:1)
[    0.924941] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[    0.925944] clocksource: Switched to clocksource arch_sys_counter
[    0.967740] VFS: Disk quotas dquot_6.6.0
[    0.967831] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.968157] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.969509] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[    0.969555] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[    0.969785] cma: enabled page replacement for spfn=c6000, epfn=f0000
[    0.969792] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.969804] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[    0.969812] nvmap_page_pool_init: Total RAM pages: 1986120
[    0.969818] nvmap_page_pool_init: nvmap page pool size: 248265 pages (969 MB)
[    0.969975] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.970416] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[    0.972260] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    0.983797] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[    0.983978] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[    0.984192] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[    0.984339] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[    0.984484] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.985659] la/ptsa driver initialized.
[    0.986025] NET: Registered protocol family 2
[    0.986900] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.987232] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.987834] TCP: Hash tables configured (established 65536 bind 65536)
[    0.987877] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.987993] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.988461] NET: Registered protocol family 1
[    0.988984] RPC: Registered named UNIX socket transport module.
[    0.988989] RPC: Registered udp transport module.
[    0.988994] RPC: Registered tcp transport module.
[    0.988998] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.989009] PCI: CLS 0 bytes, default 64
[    0.989181] Trying to unpack rootfs image as initramfs...
[    1.219957] Freeing initrd memory: 7064K
[    1.234455] random: fast init done
[    1.238660] host1x 13e10000.host1x: initialized
[    1.240254] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.244737] audit: initializing netlink subsys (disabled)
[    1.244796] audit: type=2000 audit(0.864:1): initialized
[    1.245571] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    1.253886] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.255093] ntfs: driver 2.1.32 [Flags: R/W].
[    1.255693] 9p: Installing v9fs 9p2000 file system support
[    1.261130] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.261310] io scheduler noop registered
[    1.261520] io scheduler cfq registered (default)
[    1.265120] gic 2a41000.agic-controller: GIC IRQ controller registered
[    1.300724] iommu: Adding device 2993000.adsp to group 56
[    1.412320] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[    1.413371] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    1.426770] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    1.427225] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    1.427899] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    1.428332] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    1.428738] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    1.432126] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.432313] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    1.435076] tsec 15500000.tsec: initialized
[    1.436823] tsec 15100000.tsecb: initialized
[    1.440656] nvdec 15480000.nvdec: initialized
[    1.443171] nvdec 15140000.nvdec1: initialized
[    1.449172] falcon 15340000.vic: initialized
[    1.451189] falcon 15380000.nvjpg: initialized
[    1.452991] falcon 154c0000.nvenc: initialized
[    1.455070] falcon 15a80000.nvenc1: initialized
[    1.458587] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    1.460181] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    1.461858] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    1.463443] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    1.465008] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    1.466612] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    1.468167] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    1.469845] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    1.473354] t194-nvcsi 15a00000.nvcsi: initialized
[    1.478428] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    1.478793] scare-pigeon 14b00000.isp-thi: initialized
[    1.484154] pva 16000000.pva0: initialized
[    1.489940] pva 16800000.pva1: initialized
[    1.495070] nvdla 15880000.nvdla0: initialized
[    1.499604] nvdla 158c0000.nvdla1: initialized
[    1.501027] tegradccommon 15200000.dc_common: host1x channel mapped
[    1.501039] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    1.501112] tegradccommon 15200000.dc_common: dma mapping done
[    1.501263] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[    1.501273] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[    1.501592] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    1.501622] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    1.501894] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    1.501903] tegra_cec 3960000.tegra_cec: probed
[    1.502569] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[    1.502627] generic_infoframe_type: 0x87
[    1.502734] tegradc 15200000.nvdisplay: DT parsed successfully
[    1.502795] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[    1.507477] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[    1.507485] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[    1.507490] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    1.507720] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[    1.507729] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[    1.510921] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[    1.510930] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    1.513423] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[    1.514196] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[    1.514204] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    1.514530] kfuse 3830000.kfuse: initialized
[    1.515143] tegradc 15200000.nvdisplay: probed
[    1.515796] Console: switching to colour frame buffer device 80x30
[    1.515824] tegradc 15200000.nvdisplay: fb registered
[    1.516120] gpio tegra-gpio wake63 for gpio=97(M:1)
[    1.516660] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[    1.516687] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[    1.516783] tegradc 15210000.nvdisplay: DT parsed successfully
[    1.516815] tegradc 15210000.nvdisplay: Display dc.ffffff800be90000 registered with id=1
[    1.517012] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[    1.517028] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[    1.524448] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.527253] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[    1.527388] tegradc 15210000.nvdisplay: probed
[    1.527687] tegradc 15210000.nvdisplay: fb registered
[    1.528478] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[    1.530916] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[    1.531364] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    1.531372] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    1.531385] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    1.531396] tegradc 15210000.nvdisplay: blank - powerdown
[    1.531410] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    1.531415] Extcon DP: HPD disabled
[    1.531420] hpd: hpd_switch 0
[    1.531425] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    1.531435] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    1.531444] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    1.532208] console [ttyTCU0] enabled
[    1.532541] [drm] Initialized
[    1.544618] brd: module loaded
[    1.550234] loop: module loaded
[    1.550323] tegra_profiler: version: 1.143, samples/io: 48/28
[    1.550461] tegra_profiler: auth: init
[    1.551169] THERMAL EST: found 3 subdevs
[    1.551176] THERMAL EST num_resources: 0
[    1.551183] [THERMAL EST subdev 0]
[    1.551190] [THERMAL EST subdev 1]
[    1.551195] [THERMAL EST subdev 2]
[    1.551205] THERMAL EST: Found 2 profiles, default profile is quiet
[    1.551489] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    1.551494] THERMAL EST: thz register success.
[    1.551640] THERMAL EST: end of probe, return err: 0
[    1.552710] sd: No Scsi addr parsed to reserve index
[    1.552741] hisi_sas: driver version v1.6
[    1.562380] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[    1.562389] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[    1.562399] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[    1.562643] 1 ofpart partitions found on MTD device spi6.0
[    1.562648] Creating 1 MTD partitions on "spi6.0":
[    1.562657] 0x000000000000-0x000002000000 : "Whole_flash0"
[    1.565086] libphy: Fixed MDIO Bus: probed
[    1.566100] tun: Universal TUN/TAP device driver, 1.6
[    1.566106] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.566952] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.566958] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.567009] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    1.567019] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.567061] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.567065] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.567099] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[    1.567103] Copyright(c) 1999 - 2017 Intel Corporation.
[    1.812901] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[    1.813499] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 2f 79 2c
[    1.813757] libphy: dwc_phy: probed
[    1.816395] PPP generic driver version 2.4.2
[    1.816786] PPP BSD Compression module registered
[    1.816793] PPP Deflate Compression module registered
[    1.816817] PPP MPPE Compression module registered
[    1.816824] NET: Registered protocol family 24
[    1.816882] usbcore: registered new interface driver r8152
[    1.816929] usbcore: registered new interface driver asix
[    1.816985] usbcore: registered new interface driver ax88179_178a
[    1.817012] usbcore: registered new interface driver cdc_ether
[    1.817072] usbcore: registered new interface driver net1080
[    1.817100] usbcore: registered new interface driver cdc_subset
[    1.817138] usbcore: registered new interface driver zaurus
[    1.817174] usbcore: registered new interface driver cdc_ncm
[    1.817360] VFIO - User Level meta-driver version: 0.3
[    1.818684] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.818707] ehci-pci: EHCI PCI platform driver
[    1.818738] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.818748] ohci-pci: OHCI PCI platform driver
[    1.818778] ohci-platform: OHCI generic platform driver
[    1.823809] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[    1.825776] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f5bbe400 id
[    1.826081] usbcore: registered new interface driver uas
[    1.826130] usbcore: registered new interface driver usb-storage
[    1.826199] usbcore: registered new interface driver usbserial
[    1.829256] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[    1.829340] tegra-xudc-new 3550000.xudc: device count: 1
[    1.830315] tegra-xudc-new 3550000.xudc: vbus state: 0
[    1.830326] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[    1.830445] tegra-xudc-new 3550000.xudc: entering ELPG
[    1.830648] tegra-xudc-new 3550000.xudc: entering ELPG done
[    1.831131] mousedev: PS/2 mouse device common for all mice
[    1.831232] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[    1.831235] usbcore: registered new interface driver xpad
[    1.831272] tegra-xusb 3610000.xhci: xHCI Host Controller
[    1.831293] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    1.832017] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[    1.832082] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[    1.832342] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.832349] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.832356] usb usb1: Product: xHCI Host Controller
[    1.832362] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[    1.832368] usb usb1: SerialNumber: 3610000.xhci
[    1.832908] hub 1-0:1.0: USB hub found
[    1.832957] hub 1-0:1.0: 4 ports detected
[    1.833486] tegra-xusb 3610000.xhci: xHCI Host Controller
[    1.833521] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    1.833532] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    1.833820] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.833828] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.833834] usb usb2: Product: xHCI Host Controller
[    1.833840] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[    1.833846] usb usb2: SerialNumber: 3610000.xhci
[    1.834319] hub 2-0:1.0: USB hub found
[    1.834362] hub 2-0:1.0: 4 ports detected
[    1.835403] Wake76 for irq=199
[    1.835409] Wake77 for irq=199
[    1.835413] Wake78 for irq=199
[    1.835418] Wake79 for irq=199
[    1.835423] Wake80 for irq=199
[    1.835427] Wake81 for irq=199
[    1.835431] Wake82 for irq=199
[    1.835473] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[    1.835480] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[    1.938285] usb usb2: usb_suspend_both: status 0
[    1.965176] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.966783] Wake73 for irq=42
[    1.968166] rtc rtc1: alarm rtc device
[    1.968182] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    1.968217] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    1.968376] i2c /dev entries driver
[    1.970739] i2c i2c-2: Added multiplexed i2c bus 9
[    1.971246] i2c i2c-2: Added multiplexed i2c bus 10
[    1.971255] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    1.971809] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[    1.995313] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    1.995364] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.995625] imx219 9-0010: board setup failed
[    1.995817] imx219: probe of 9-0010 failed with error -121
[    1.996202] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[    2.019439] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    2.019487] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[    2.019734] imx219 10-0010: board setup failed
[    2.019892] imx219: probe of 10-0010 failed with error -121
[    2.020955] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[    2.028817] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[    2.029243] FAN dev name: pwm-fan
[    2.029311] FAN:gpio request success.
[    2.029321] FAN: can't find tach_gpio
[    2.029331] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[    2.029367] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[    2.029626] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    2.029633] pwm_fan_driver pwm-fan: tach period: 1000
[    2.030264] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    2.030272] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[    2.030278] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[    2.030284] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[    2.030290] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    2.030296] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    2.030302] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    2.030307] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    2.030335] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    2.030341] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    2.031216] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[    2.032311] device-mapper: uevent: version 1.0.3
[    2.032837] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    2.036391] tegra194_cpufreq_probe: platform driver Initialization: pass
[    2.037460] cpuidle: Initializing cpuidle driver
[    2.038511] sdhci: Secure Digital Host Controller Interface driver
[    2.038516] sdhci: Copyright(c) Pierre Ossman
[    2.038519] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.038823] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    2.040007] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[    2.041853] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 246
[    2.046454] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    2.047468] tegra-se-nvhost 15810000.se: initialized
[    2.048503] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    2.049572] tegra-se-nvhost 15820000.se: initialized
[    2.050912] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    2.051936] tegra-se-nvhost 15830000.se: initialized
[    2.052657] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    2.053780] tegra-se-nvhost 15840000.se: initialized
[    2.054841] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    2.055174] hidraw: raw HID events driver (C) Jiri Kosina
[    2.056385] usbcore: registered new interface driver usbhid
[    2.056389] usbhid: USB HID core driver
[    2.060665] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[    2.061759] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    2.062263] tegra186-aondbg aondbg: aondbg driver probe() OK
[    2.063068] denver_knobs_init:MTS_VERSION:51035886
[    2.063225] tegra19x_actmon d230000.actmon: in actmon_register()...
[    2.064070] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[    2.064467] t19x_cache tegra-cache: probed
[    2.067930] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[    2.067938] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[    2.068452] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[    2.069122] PLL_AON clock registered
[    2.070559] Clocks initialized successfully
[    2.072229] nvpmodel: initialized successfully
[    2.073631] trusty-virtio trusty:virtio: initializing
[    2.073851] trusty_ipc virtio0: vring0: va(pa)  ffffffc1f2740000(0) qsz 32 notifyid 1
[    2.073859] trusty_ipc virtio0: vring1: va(pa)  ffffffc1f2742000(0) qsz 32 notifyid 2
[    2.074068] trusty-virtio trusty:virtio: initializing done
[    2.074388] trusty_ipc virtio0: is online
[    2.075094] tegra-hda 3510000.hda: Override SDO lines to 4
[    2.075438] usbcore: registered new interface driver snd-usb-audio
[    2.086047] gpio tegra-gpio wake8 for gpio=55(G:7)
[    2.086106] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[    2.088644] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    2.088837] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    2.089046] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[    2.089244] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[    2.157961] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    2.180335] OPE platform probe
[    2.180452] OPE platform probe successful
[    2.198421] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[    2.198427] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.198432] usb 1-2: Product: 4-Port USB 2.0 Hub
[    2.198436] usb 1-2: Manufacturer: Generic
[    2.199725] hub 1-2:1.0: USB hub found
[    2.201080] hub 1-2:1.0: 4 ports detected
[    2.246979] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.260130] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    2.260248] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    2.260366] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    2.260454] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    2.260563] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    2.260695] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    2.260819] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    2.260908] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    2.261017] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    2.261112] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    2.261200] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    2.261284] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    2.261371] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    2.261453] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    2.261535] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    2.261651] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    2.261776] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    2.261863] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    2.261965] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    2.262053] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    2.294582] u32 classifier
[    2.294588]     Actions configured
[    2.294677] Initializing XFRM netlink socket
[    2.295282] NET: Registered protocol family 10
[    2.296068] NET: Registered protocol family 17
[    2.296081] NET: Registered protocol family 15
[    2.296146] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.296264] Bluetooth: RFCOMM socket layer initialized
[    2.296283] Bluetooth: RFCOMM ver 1.11
[    2.296289] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.296295] Bluetooth: HIDP socket layer initialized
[    2.296313] 9pnet: Installing 9P2000 support
[    2.296353] Key type dns_resolver registered
[    2.297156] Registered cp15_barrier emulation handler
[    2.297190] Registered setend emulation handler
[    2.299064] registered taskstats version 1
[    2.299532] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[    2.300587] OF: PCI: host bridge /pcie@14160000 ranges:
[    2.300605] OF: PCI:    IO 0x36100000..0x361fffff -> 0x36100000
[    2.300616] OF: PCI:   MEM 0x1740000000..0x17ffffffff -> 0x40000000
[    2.300622] OF: PCI:   MEM 0x1400000000..0x173fffffff -> 0x1400000000
[    2.306852] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[    2.343741] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[    2.343748] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.343752] usb 2-3: Product: 4-Port USB 3.0 Hub
[    2.343756] usb 2-3: Manufacturer: Generic
[    2.353646] hub 2-3:1.0: USB hub found
[    2.355439] hub 2-3:1.0: 4 ports detected
[    2.389131] mmc0: hw tuning done ...
[    2.389166] mmc0: new ultra high speed SDR104 SDXC card at address e624
[    2.389591] mmcblk0: mmc0:e624 SC64G 59.5 GiB
[    2.395329]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[    2.409949] tegra-pcie-dw 14160000.pcie: link is up
[    2.410169] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[    2.410178] pci_bus 0004:00: root bus resource [bus 00-ff]
[    2.410186] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[    2.410192] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[    2.410196] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[    2.410243] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[    2.410418] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[    2.410638] iommu: Adding device 0004:00:00.0 to group 58
[    2.410934] pci 0004:01:00.0: [10ec:c822] type 00 class 0x028000
[    2.411070] pci 0004:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    2.411074] pci 0004:01:00.0: reg 0x10: [io  size 0x0100]
[    2.411233] pci 0004:01:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit]
[    2.411948] pci 0004:01:00.0: supports D1 D2
[    2.411952] pci 0004:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.412262] iommu: Adding device 0004:01:00.0 to group 59
[    2.423015] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[    2.423023] pci 0004:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    2.423030] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[    2.423113] pci 0004:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.423141] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    2.423146] pci 0004:00:00.0:   bridge window [io  0x1000-0x1fff]
[    2.423154] pci 0004:00:00.0:   bridge window [mem 0x1740000000-0x17400fffff]
[    2.423174] pci 0004:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    2.423251] pci 0004:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    2.423587] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[    2.423592] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[    2.423598] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[    2.423694] aer 0004:00:00.0:pcie002: service driver aer loaded
[    2.424360] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[    2.425577] OF: PCI: host bridge /pcie@141a0000 ranges:
[    2.425595] OF: PCI:    IO 0x3a100000..0x3a1fffff -> 0x3a100000
[    2.425603] OF: PCI:   MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[    2.425608] OF: PCI:   MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    2.517948] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[    2.517954] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    2.533948] tegra-pcie-dw 141a0000.pcie: link is up
[    2.534203] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[    2.534211] pci_bus 0005:00: root bus resource [bus 00-ff]
[    2.534218] pci_bus 0005:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[    2.534224] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    2.534228] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    2.534253] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[    2.534416] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[    2.534645] iommu: Adding device 0005:00:00.0 to group 60
[    2.535009] pci 0005:01:00.0: [144d:a808] type 00 class 0x010802
[    2.535121] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    2.536056] iommu: Adding device 0005:01:00.0 to group 61
[    2.546813] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[    2.546843] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[    2.546902] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    2.546909] pci 0005:00:00.0:   bridge window [mem 0x1f40000000-0x1f400fffff]
[    2.546926] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    2.546968] pci 0005:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    2.547169] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[    2.547173] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[    2.547179] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[    2.547264] aer 0005:00:00.0:pcie002: service driver aer loaded
[    2.547721] nvme nvme0: pci function 0005:01:00.0
[    2.547811] nvme 0005:01:00.0: enabling device (0000 -> 0002)
[    2.558414] tegra-cbb 14040000.cv-noc: noc_secure_irq = 90, noc_nonsecure_irq = 89>
[    2.563396] tegra194-isp5 14800000.isp: initialized
[    2.570257] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[    2.573088] tegra194-vi5 15c10000.vi: initialized
[    2.574031] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    2.577789] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[    2.577867] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[    2.578174] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[    2.582574] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[    2.582590] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[    2.582595] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[    2.582678] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[    2.582713] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[    2.582718] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[    2.587010] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[    2.587058] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[    2.587063] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[    2.587402] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[    2.587437] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[    2.587442] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[    2.587828] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[    2.587872] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[    2.587877] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[    2.588218] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[    2.589024] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    2.595099] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549
[    2.595104] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.595109] usb 1-3: Product: Bluetooth Radio
[    2.595113] usb 1-3: Manufacturer: Realtek
[    2.595116] usb 1-3: SerialNumber: 00e04c000001
[    2.667942]  nvme0n1: p1
[    2.671337] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[    2.671730] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    2.671909] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[    2.672079] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[    2.672472] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[    2.672536] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[    2.672754] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[    2.672758] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    2.673791] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[    2.674299] Wake83 for irq=211
[    2.674383] gpio tegra-gpio wake67 for gpio=48(G:0)
[    2.674457] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[    2.674605] input: gpio-keys as /devices/gpio-keys/input/input4
[    2.706968] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:16 UTC (946688416)
[    2.707457] mmcblk mmc0:e624: Card claimed for testing.
[    2.745001] bpmp: mounted debugfs mirror
[    2.751556] ALSA device list:
[    2.751564]   #0: tegra-hda-xnx at 0x3518000 irq 64
[    2.751568]   #1: jetson-xaviernx-ape
[    2.753226] Freeing unused kernel memory: 8576K
[    2.792447] Root device found: mmcblk0p1
[    2.794280] Found dev node: /dev/mmcblk0p1
[    2.897954] usb 1-2.1: new full-speed USB device number 4 using tegra-xusb
[    2.920109] usb 1-2.1: New USB device found, idVendor=0483, idProduct=374b
[    2.920115] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.920120] usb 1-2.1: Product: STM32 STLink
[    2.920173] usb 1-2.1: Manufacturer: STMicroelectronics
[    2.920177] usb 1-2.1: SerialNumber: 066EFF525750877267164129
[    2.929943] usb 2-3: usb_suspend_both: status 0
[    2.930250] usb usb2: usb_suspend_both: status 0
[    2.976182] usb-storage 1-2.1:1.1: USB Mass Storage device detected
[    2.976495] scsi host0: usb-storage 1-2.1:1.1
[    3.990767] scsi 0:0:0:0: Direct-Access     MBED     microcontroller  1.0  PQ: 0 ANSI: 2
[    3.991901] sd 0:0:0:0: [sda] 840 512-byte logical blocks: (430 kB/420 KiB)
[    3.992185] sd 0:0:0:0: [sda] Write Protect is off
[    3.992194] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[    3.992411] sd 0:0:0:0: [sda] No Caching mode page found
[    3.992551] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    4.006026] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    5.102930] EXT4-fs (mmcblk0p1): 25 orphan inodes deleted
[    5.102936] EXT4-fs (mmcblk0p1): recovery complete
[    5.893985] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    5.897051] Rootfs mounted over mmcblk0p1
[    5.917543] Switching from initrd to actual rootfs
[    6.100361] systemd[1]: System time before build time, advancing clock.
[    6.129690] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.134761] cgroup: cgroup2: unknown option "nsdelegate"
[    6.154255] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    6.154897] systemd[1]: Detected architecture arm64.
[    6.161234] systemd[1]: Set hostname to <v5.local>.
[    6.302439] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    6.302452] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    6.495594] random: systemd: uninitialized urandom read (16 bytes read)
[    6.495632] systemd[1]: Reached target User and Group Name Lookups.
[    6.495855] random: systemd: uninitialized urandom read (16 bytes read)
[    6.498476] systemd[1]: Created slice User and Session Slice.
[    6.498770] random: systemd: uninitialized urandom read (16 bytes read)
[    6.499164] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.500382] systemd[1]: Created slice System Slice.
[    6.500909] systemd[1]: Listening on Journal Audit Socket.
[    6.554951] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    6.662376] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:291  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[    6.685385] cpu-throttle-alert cooling device registered.
[    6.685665] gpu-throttle-alert cooling device registered.
[    6.687353] aux-throttle-alert cooling device registered.
[    6.886974] Adding 4194300k swap on /swfile.  Priority:-1 extents:4 across:4587516k SS
[    7.099219] systemd-journald[2268]: Received request to flush runtime journal from PID 1
[    7.721060] using random self ethernet address
[    7.721185] using random host ethernet address
[    8.174971] rtl88x2ce 0004:01:00.0: enabling device (0000 -> 0003)
[    8.256682] random: crng init done
[    8.256787] random: 7 urandom warning(s) missed due to ratelimiting
[    8.605464] usbcore: registered new interface driver btusb
[    8.627847] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[    8.627855] rtk_btcoex: rtk_btcoex_init: version: 1.2
[    8.627858] rtk_btcoex: create workqueue
[    8.629894] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[    8.630309] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[    8.630317] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[    8.630321] rtk_btusb: patch_add
[    8.630326] rtk_btusb: auto suspend is disabled
[    8.630330] rtk_btusb: pid = 0x3549
[    8.630336] rtk_btusb: patch_add: Reset gEVersion to 0xff
[    8.630347] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[    8.633281] rtk_btusb: btusb_open start
[    8.633287] rtk_btusb: btusb_open hdev->promisc ==0
[    8.633291] rtk_btusb: download_patch start
[    8.633299] rtk_btusb: chip type value: 0x73
[    8.633303] rtk_btusb: HCI reset.
[    8.633333] rtk_btusb: btusb_probe: done
[    8.633495] usbcore: registered new interface driver rtk_btusb
[    8.644660] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[    8.644672] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[    8.644677] rtk_btusb: patch_entry->lmp_sub = 0x8822
[    8.644682] rtk_btusb: load_firmware start
[    8.644687] rtk_btusb: lmp_version = 0x8822
[    8.644691] rtk_btusb: config filename rtl8822cu_config
[    8.762223] rtk_btusb: no bdaddr file /opt/bdaddr
[    8.762238] rtk_btusb: 55 ab 23 87 00 00
[    8.762263] rtk_btusb: Config file length 6, new length 6
[    8.762272] rtk_btusb: fw name is  rtl8822cu_fw
[    8.770007] rtk_btusb: This is not 8723a, use new patch style!
[    8.770018] rtk_btusb: rtk_get_eversion: gEVersion 255
[    8.770638] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[    8.770644] rtk_btusb: load_firmware: New gEVersion 3
[    8.770648] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[    8.770653] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[    8.770656] rtk_btusb: fw_version = 0x98a42f7
[    8.770659] rtk_btusb: number_of_total_patch = 3
[    8.770662] rtk_btusb: chipID 4
[    8.770667] rtk_btusb: patch_length 0x55f0
[    8.770670] rtk_btusb: start_offset 0x00005d00
[    8.770674] rtk_btusb: Svn version:    21761
[    8.770678] rtk_btusb: Coexistence: BTCOEX_20190509-0d0d
[    8.770681] rtk_btusb: buf_len = 0x55f6
[    8.770705] rtk_btusb: fw: exists, config file: exists
[    8.770708] rtk_btusb: load_firmware done
[    8.770735] rtk_btusb: download_data start
[    8.822880] cdc_acm 1-2.1:1.2: ttyACM0: USB ACM device
[    8.823562] usbcore: registered new interface driver cdc_acm
[    8.823568] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    8.824297] Mass Storage Function, version: 2009/09/11
[    8.824305] LUN: removable file: (no medium)
[    8.830308] using random self ethernet address
[    8.830434] using random host ethernet address
[    8.884669] rtk_btusb: download_data done
[    8.884677] rtk_btusb: HCI reset.
[    8.895642] rtk_btusb: read_ver_rsp->lmp_subver = 0x42f7
[    8.895650] rtk_btusb: read_ver_rsp->hci_rev = 0x98a
[    8.895654] rtk_btusb: patch_entry->lmp_sub = 0x8822
[    8.895665] rtk_btusb: Rtk patch end 0
[    8.895670] rtk_btusb: btusb_open set HCI_RUNNING
[    8.895695] rtk_btcoex: Open BTCOEX
[    8.895699] rtk_btusb: btusb_open end
[    8.897661] rtk_btcoex: BTCOEX hci_rev 0x098a
[    8.897667] rtk_btcoex: BTCOEX lmp_subver 0x42f7
[    8.917655] rtk_btusb: btusb_notify: hci0 evt 3
[    9.100494] rndis0: HOST MAC d6:2c:3f:13:ab:00
[    9.100647] rndis0: MAC d6:2c:3f:13:ab:01
[    9.101870] usb0: HOST MAC d6:2c:3f:13:ab:02
[    9.102142] usb0: MAC d6:2c:3f:13:ab:03
[    9.102164] tegra-xudc-new 3550000.xudc: exiting ELPG
[    9.110475] tegra-xudc-new 3550000.xudc: exiting ELPG done
[    9.110501] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[    9.110538] tegra-xudc-new 3550000.xudc: entering ELPG
[    9.110765] tegra-xudc-new 3550000.xudc: entering ELPG done
[    9.110780] tegra-xudc-new 3550000.xudc: exiting ELPG
[    9.111213] tegra-xudc-new 3550000.xudc: exiting ELPG done
[    9.111225] tegra-xudc-new 3550000.xudc: entering ELPG
[    9.111409] tegra-xudc-new 3550000.xudc: entering ELPG done
[    9.115437] l4tbr0: port 1(rndis0) entered blocking state
[    9.115445] l4tbr0: port 1(rndis0) entered disabled state
[    9.116059] device rndis0 entered promiscuous mode
[    9.121905] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[    9.126376] l4tbr0: port 2(usb0) entered blocking state
[    9.126384] l4tbr0: port 2(usb0) entered disabled state
[    9.127002] device usb0 entered promiscuous mode
[    9.133350] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[    9.248422] rtk_btusb: btusb_flush add delay
[    9.258446] rtk_btusb: btusb_close
[    9.270198] rtk_btcoex: Close BTCOEX
[    9.270206] rtk_btcoex: -x
[    9.332377] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    9.332394] Bluetooth: BNEP socket layer initialized
[   10.238664] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.550814] gpio tegra-gpio wake20 for gpio=52(G:4)
[   10.557882] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.622076] nvgpu: 17000000.gv11b                 tpc_pg_mask_store:843  [INFO]  no value change, same mask already set
[   10.633102] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   10.939000] zram: Added device: zram0
[   10.940383] zram: Added device: zram1
[   10.941188] zram: Added device: zram2
[   10.949082] zram: Added device: zram3
[   10.949565] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   10.949791] zram: Added device: zram4
[   10.952387] zram: Added device: zram5
[   10.984178] zram0: detected capacity change from 0 to 679264256
[   11.024389] Adding 663340k swap on /dev/zram0.  Priority:5 extents:1 across:663340k SS
[   11.028139] zram1: detected capacity change from 0 to 679264256
[   11.063996] Adding 663340k swap on /dev/zram1.  Priority:5 extents:1 across:663340k SS
[   11.068934] zram2: detected capacity change from 0 to 679264256
[   11.113557] Adding 663340k swap on /dev/zram2.  Priority:5 extents:1 across:663340k SS
[   11.196516] zram3: detected capacity change from 0 to 679264256
[   11.228049] Adding 663340k swap on /dev/zram3.  Priority:5 extents:1 across:663340k SS
[   11.232440] zram4: detected capacity change from 0 to 679264256
[   11.251947] Adding 663340k swap on /dev/zram4.  Priority:5 extents:1 across:663340k SS
[   11.256726] zram5: detected capacity change from 0 to 679264256
[   11.276982] Adding 663340k swap on /dev/zram5.  Priority:5 extents:1 across:663340k SS
[   11.299506] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   13.149986] tegradc 15200000.nvdisplay: blank - powerdown
[   13.150000] tegradc 15210000.nvdisplay: blank - powerdown
[   15.440751] ------------[ cut here ]------------
[   15.440984] WARNING: CPU: 2 PID: 6164 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/net/wireless/nl80211.c:14141 cfg80211_ch_switch_notify+0x150/0x170 [cfg80211]
[   15.441242] Modules linked in: zram overlay bnep cdc_acm rtk_btusb btusb btrtl btbcm btintel rtl8822ce spidev cfg80211 userspace_alert nvgpu bluedroid_pm ip_tables x_tables
[   15.441319] CPU: 2 PID: 6164 Comm: RTW_CMD_THREAD Not tainted 4.9.201-tegra #1
[   15.441324] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[   15.441329] task: ffffffc1ea9baa00 task.stack: ffffffc1d4fec000
[   15.441413] PC is at cfg80211_ch_switch_notify+0x150/0x170 [cfg80211]
[   15.442002] LR is at rtw_cfg80211_ch_switch_notify+0x94/0x98 [rtl8822ce]
[   15.442008] pc : [<ffffff800119e080>] lr : [<ffffff8001304ac8>] pstate: 60c00045
[   15.442012] sp : ffffffc1d4fefc20
[   15.442017] x29: ffffffc1d4fefc20 x28: ffffff8001295760
[   15.442028] x27: ffffff800d0821bc x26: ffffff800145a578
[   15.442039] x25: ffffff80014de13c x24: ffffffc1f5b09000
[   15.442057] x23: ffffffc1e1de8000 x22: ffffffc1e1dad800
[   15.442068] x21: 0000000000000002 x20: ffffffc1d4fefca8
[   15.442078] x19: ffffffc1e9a9bc00 x18: 0000000000000400
[   15.442088] x17: 0000007fac50bd40 x16: 0000000000000000
[   15.442099] x15: 0000000000000140 x14: 0000000000000008
[   15.442109] x13: 7f1201c7fffc002a x12: 0105c00363fffa03
[   15.442119] x11: 0000000000000004 x10: 0000000000000002
[   15.442130] x9 : 0000000000000004 x8 : ffffffc1d4fefd3a
[   15.442141] x7 : 0000000000000000 x6 : 0000000000000001
[   15.442151] x5 : 0000000000000040 x4 : 0000000000001478
[   15.442161] x3 : 0000145a00000003 x2 : ffffffc1e1daf108
[   15.442171] x1 : 0000145a00000003 x0 : 0000000000000000
[   15.442185] ---[ end trace 918e20f40cba6a71 ]---
[   15.442280] Call trace:
[   15.442366] [<ffffff800119e080>] cfg80211_ch_switch_notify+0x150/0x170 [cfg80211]
[   15.442958] [<ffffff8001304ac8>] rtw_cfg80211_ch_switch_notify+0x94/0x98 [rtl8822ce]
[   15.443521] [<ffffff80012956c4>] rtw_chk_start_clnt_join+0x43c/0x4d8 [rtl8822ce]
[   15.444089] [<ffffff8001295998>] join_cmd_hdl+0x238/0x330 [rtl8822ce]
[   15.444646] [<ffffff8001252420>] rtw_cmd_thread+0x308/0x608 [rtl8822ce]
[   15.444658] [<ffffff80080db074>] kthread+0xec/0xf0
[   15.444666] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
[   15.897188] fuse init (API version 7.26)
[   16.587172] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   34.134178] vdd-1v8-sd: disabling
[   34.134188] vdd-1v8-cvb: disabling
[   34.134194] vdd-epb-1v0: disabling
[   34.134199] avdd-cam-2v8: disabling
[   34.134205] vdd_sys_en: disabling
[ 1742.548898] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control off
[ 1742.549742] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 1747.663070] eqos 2490000.ether_qos eth0: Link is Down
[ 1749.316100] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control off
[ 2320.537413] eqos 2490000.ether_qos eth0: Link is Down
[ 2330.677191] usb 1-2.1: USB disconnect, device number 4
[ 2330.731120] FAT-fs (sda): unable to read boot sector to mark fs as dirty
[ 2330.881920] usb 1-2: usb_suspend_both: status 0
hello vtg,
did you have any device tree updates?
those kernel messages indicate you’re using the device tree blob with native JetPack release version.
I don’t think so, I run an upgrade once and it bricked my device so I now try to avoid any system changes. I use a development board so I thought there was no need to look into it more.
I have a plain SDcard image installed, some handy packages, and OpenCV. I do everything from the c++ code now.
hello vtg,
don’t you change the settings? how you configure baudrate only with user-space changes?
what’s the stop bits, are you keep it as 1? is there CTS/RTS?
 fd = open(Device, O_RDWR | O_NOCTTY | O_NDELAY);
  fcntl(fd, F_SETFL, FNDELAY);
  ioctl(fd, TCSETS2, &options);
  // Clear all the options
  bzero(&options, sizeof(options));
  options.c_cflag &= ~CBAUD;
  options.c_cflag |= BOTHER;
  options.c_cflag |= CLOCAL;
  options.c_cflag |= CSTOPB;
  options.c_ispeed = Bauds;
  options.c_ospeed = Bauds;
  // Timer unused
  options.c_cc[VTIME] = 0;
  options.c_cc[VMIN] = 0;
Here’s part of my code that set settings for serial, but as I said other applications for that also have that problem so I don’t think it caused that.
I’m going to suggest a test before using the C code interface (and keep in mind the C interface options depend on the driver, and the “/dev/ttyS#” uses a legacy driver, while the “/dev/ttyTHS#” uses an NVIDIA-based DMA-capable driver). On the Jetson, disconnect anything on the serial UART terminals. Wire TX to RX, and see if a serial console program can echo text. Also try with CTS and RTS wired together, see if anything differs. Then use the serial console program itself to set for whatever rate/spec you are using in C, and see if the terminal can echo text with those specific settings. This will narrow down what you are looking for.
