Hi, I have purchased Xavier NX and downloaded SD card image from Download Center.
However, when flashed with Etcher, the image is not booting.
On display, there is a flashing cursor with blank screen.
On serial console, we get the following:
[ 1.576046] tegra-cbb be00000.rce-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 1.583754] tegra-cbb b600000.sce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 1.591080] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.598753] vdd-ac-bat: 5000 mV
[ 1.600926] vdd-sdmmc1-sw: 3300 mV
[ 1.604684] vdd-1v8-sd: 1800 mV
[ 1.608072] vdd-3v3-cvb: 3300 mV
[ 1.611255] vdd-1v8-cvb: 1800 mV
[ 1.614535] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.618821] vdd-epb-1v0: 1000 mV
[ 1.622548] avdd-cam-2v8: 2800 mV
[ 1.625934] vdd-fan: 5000 mV
[ 1.629042] vdd-hdmi-5v0: 5000 mV
[ 1.632249] vdd_sys_en: 1200 mV
[ 1.660751] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.665282] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.665666] SCSI subsystem initialized
[ 1.666123] usbcore: registered new interface driver usbfs
[ 1.666293] usbcore: registered new interface driver hub
[ 1.666497] usbcore: registered new device driver usb
[ 1.678765] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.681754] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.692368] vdd-1v0: at 1000 mV
[ 1.696371] vdd-1v8-hs: at 1800 mV
[ 1.700415] vdd-1v8-ls: at 1800 mV
[ 1.704412] vdd-1v8-ao: at 1800 mV
[ 1.708090] vddio-ddr-1v1: at 1100 mV
[ 1.712225] vdd-rtc: at 800 mV
[ 1.713443] spmic-ldo1: at 2375 mV
[ 1.720278] vdd-ao-3v3: at 3300 mV
[ 1.728280] vddio-emmc-3v3: at 3300 mV
[ 1.729642] spmic-ldo4: at 1587 mV
[ 1.735939] vdd-usb-3v3: at 3300 mV
[ 1.743979] vddio-sdmmc1-3v3: at 3300 mV
[ 1.747996] vdd-csi-1v2: at 1200 mV
[ 1.749536] spmic-ldo8: at 1800 mV
[ 1.754399] GPIO line 246 (gpio_default) hogged as output/high
[ 1.755976] GPIO line 247 (gpio_default) hogged as output/high
[ 1.756415] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.756887] max77620 4-003c: max77620 probe successful
[ 1.760406] media: Linux media interface: v0.10
[ 1.764605] Linux video capture interface: v2.00
[ 1.770351] pps_core: LinuxPPS API ver. 1 registered
[ 1.773933] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.782881] PTP clock support registered
[ 1.786616] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 1.793494] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.800352] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.808931] trusty trusty: trusty version: Built: 10:27:05 Apr 2 2020
[ 1.813396] trusty trusty: selected api version: 3 (requested 3)
[ 1.820265] Advanced Linux Sound Architecture Driver Initialized.
[ 1.825654] Bluetooth: Core ver 2.22
[ 1.829154] NET: Registered protocol family 31
[ 1.833427] Bluetooth: HCI device and connection manager initialized
[ 1.839902] Bluetooth: HCI socket layer initialized
[ 1.844887] Bluetooth: L2CAP socket layer initialized
[ 1.850158] Bluetooth: SCO socket layer initialized
[ 1.857529] camchar: rtcpu character device driver loaded
[ 1.860630] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 1.865531] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 1.873881] clocksource: Switched to clocksource arch_sys_counter
[ 1.915006] VFS: Disk quotas dquot_6.6.0
[ 1.915192] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.915683] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.916990] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.917208] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.917835] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.918696] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.926573] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.926705] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.926830] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.926948] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.927068] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.928206] la/ptsa driver initialized.
[ 1.928507] NET: Registered protocol family 2
[ 1.929293] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.929625] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.930269] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.930311] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.930433] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.930860] NET: Registered protocol family 1
[ 1.935512] RPC: Registered named UNIX socket transport module.
[ 1.935517] RPC: Registered udp transport module.
[ 1.935520] RPC: Registered tcp transport module.
[ 1.935523] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.935748] Trying to unpack rootfs image as initramfs...
[ 2.044402] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful[ 2.053154] nvmap: nvmap_select_cache_ops() nvmap cache ops setf
[ 2.059702] nvmap_page_pool_init: Total RAM pages: 1986014
[ 2.065135] nvmap_page_pool_init: nvmap page pool size: 248251 pages (969 MB)
[ 2.072744] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.073126] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 2.113464] Freeing initrd memory: 5432K
[ 2.124977] random: fast init done
[ 2.129300] host1x 13e10000.host1x: initialized
[ 2.131047] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.135309] audit: initializing netlink subsys (disabled)
[ 2.135477] audit: type=2000 audit(1.440:1): initialized
[ 2.136262] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 2.142508] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.143584] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.144178] 9p: Installing v9fs 9p2000 file system support
[ 2.149170] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.149507] io scheduler noop registered
[ 2.151148] io scheduler cfq registered (default)
[ 2.158800] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 2.196173] iommu: Adding device 2993000.adsp to group 56
[ 2.312126] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 2.313387] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 2.326604] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.327126] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 2.327840] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.328360] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 2.328975] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.331792] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 2.332143] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 2.335472] tsec 15500000.tsec: initialized
[ 2.337228] tsec 15100000.tsecb: initialized
[ 2.340976] nvdec 15480000.nvdec: initialized
[ 2.343604] nvdec 15140000.nvdec1: initialized
[ 2.349067] falcon 15340000.vic: initialized
[ 2.350939] falcon 15380000.nvjpg: initialized
[ 2.352860] falcon 154c0000.nvenc: initialized
[ 2.354776] falcon 15a80000.nvenc1: initialized
[ 2.358163] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 2.359872] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 2.361357] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 2.362892] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 2.364395] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 2.365846] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 2.367380] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 2.371024] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 2.380163] t194-nvcsi 15a00000.nvcsi: initialized
[ 2.387057] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 2.388526] scare-pigeon 14b00000.isp-thi: initialized
[ 2.398551] pva 16000000.pva0: initialized
[ 2.404132] pva 16800000.pva1: initialized
[ 2.409127] nvdla 15880000.nvdla0: initialized
[ 2.413924] nvdla 158c0000.nvdla1: initialized
[ 2.415445] tegradccommon 15200000.dc_common: host1x channel mapped
[ 2.416122] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 2.423377] tegradccommon 15200000.dc_common: dma mapping done
[ 2.429780] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 2.436128] generic_infoframe_type: 0x87
[ 2.440368] tegradc 15200000.nvdisplay: DT parsed successfully
[ 2.446183] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[ 2.457171] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[ 2.461820] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[ 2.470036] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 179200000 Hz
[ 2.478629] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 2.484479] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 2.493515] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 2.498747] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 2.509400] tegradc 15200000.nvdisplay: probed
[ 2.511548] Console: switching to colour frame buffer device 80x30
[ 2.517124] tegradc 15200000.nvdisplay: fb registered
[ 2.522618] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 2.527727] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 2.534730] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 2.542129] tegradc 15210000.nvdisplay: DT parsed successfully
[ 2.548404] tegradc 15210000.nvdisplay: Display dc.ffffff800be10000 registered with id=1
[ 2.556329] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 2.562699] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 2.577843] tegradc 15210000.nvdisplay: probed
[ 2.578223] tegradc 15210000.nvdisplay: fb registered
[ 2.582129] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 2.585975] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 2.586213] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 2.586227] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 2.601315] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 2.601441] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 2.601571] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 2.601575] tegra_cec 3960000.tegra_cec: probed
[ 2.629405] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 2.634920] tegradc 15210000.nvdisplay: blank - powerdown
[ 2.639989] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 2.648206] Extcon DP: HPD disabled
[ 2.651964] hpd: hpd_switch 0
[ 2.654844] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 2.658665] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 2.669472] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 2.675255] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 2.682810] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 2.690397] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 2.698028] kfuse 3830000.kfuse: initialized
[ 2.707392] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.711012] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 2.718607] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 2.726991] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 2.735709] console [ttyTCU0] enabled
[ 2.742002] bootconsole [tegra_comb_uart0] disabled
[ 2.752098] [drm] Initialized
[ 2.764591] brd: module loaded
[ 2.769173] loop: module loaded
[ 2.769334] tegra_profiler: version: 1.141, samples/io: 48/28
[ 2.769622] tegra_profiler: auth: init
[ 2.771118] THERMAL EST: found 3 subdevs
[ 2.774377] THERMAL EST num_resources: 0
[ 2.778307] [THERMAL EST subdev 0]
[ 2.781440] [THERMAL EST subdev 1]
[ 2.785000] [THERMAL EST subdev 2]
[ 2.788114] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.794480] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 2.803519] THERMAL EST: thz register success.
[ 2.808179] THERMAL EST: end of probe, return err: 0
[ 2.813397] sd: No Scsi addr parsed to reserve index
[ 2.817618] hisi_sas: driver version v1.6
[ 2.830759] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 2.830909] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 2.832447] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 2.844191] 1 ofpart partitions found on MTD device spi6.0
[ 2.849357] Creating 1 MTD partitions on "spi6.0":
[ 2.854620] 0x000000000000-0x000002000000 : "Whole_flash0"
[ 2.862049] libphy: Fixed MDIO Bus: probed
[ 2.864767] tun: Universal TUN/TAP device driver, 1.6
[ 2.869565] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.876119] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.881734] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.887535] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 2.894240] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.900139] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 2.907711] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 2.913795] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 2.920836] Copyright(c) 1999 - 2017 Intel Corporation.
��WARNING: at platform/drivers/pg/pg-cv-t194.c:73
��[ 3.169659] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 15 e3 25
[ 3.170020] libphy: dwc_phy: probed
[ 3.172369] PPP generic driver version 2.4.2
[ 3.172749] PPP BSD Compression module registered
[ 3.172863] PPP Deflate Compression module registered
[ 3.172984] PPP MPPE Compression module registered
[ 3.173080] NET: Registered protocol family 24
[ 3.173226] usbcore: registered new interface driver r8152
[ 3.173365] usbcore: registered new interface driver asix
[ 3.173505] usbcore: registered new interface driver ax88179_178a
[ 3.173646] usbcore: registered new interface driver cdc_ether
[ 3.173787] usbcore: registered new interface driver net1080
[ 3.173968] usbcore: registered new interface driver cdc_subset
[ 3.174108] usbcore: registered new interface driver zaurus
[ 3.174311] usbcore: registered new interface driver cdc_ncm
[ 3.174608] VFIO - User Level meta-driver version: 0.3
[ 3.175814] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.175992] ehci-pci: EHCI PCI platform driver
[ 3.176123] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.180409] ohci-pci: OHCI PCI platform driver
[ 3.184895] ohci-platform: OHCI generic platform driver
[ 3.194886] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 3.197628] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4c77c00 id
[ 3.202736] usbcore: registered new interface driver uas
[ 3.207467] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 3.207497] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 3.207518] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 3.208230] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 3.208290] tegra-xusb 3610000.xhci: irq 463, io mem 0x03610000
[ 3.208542] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.208549] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.208553] usb usb1: Product: xHCI Host Controller
[ 3.208558] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.208562] usb usb1: SerialNumber: 3610000.xhci
[ 3.217250] hub 1-0:1.0: USB hub found
[ 3.217306] hub 1-0:1.0: 4 ports detected
[ 3.217655] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 3.217665] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 3.217673] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.217993] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.217999] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.218004] usb usb2: Product: xHCI Host Controller
[ 3.218010] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.218037] usb usb2: SerialNumber: 3610000.xhci
[ 3.222295] hub 2-0:1.0: USB hub found
[ 3.222341] hub 2-0:1.0: 4 ports detected
[ 3.340235] usbcore: registered new interface driver usb-storage
[ 3.346014] usbcore: registered new interface driver usbserial
[ 3.354482] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 3.357566] tegra-xudc-new 3550000.xudc: device count: 1
[ 3.363771] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 3.368531] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 3.374754] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.380620] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.380815] mousedev: PS/2 mouse device common for all mice
[ 3.380891] usbcore: registered new interface driver xpad
[ 3.528990] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.530481] Wake73 for irq=42
[ 3.531787] rtc rtc1: alarm rtc device
[ 3.531926] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.532075] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.532463] i2c /dev entries driver
[ 3.534556] i2c i2c-2: Added multiplexed i2c bus 9
[ 3.535021] i2c i2c-2: Added multiplexed i2c bus 10
[ 3.535128] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 3.535824] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.553935] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 3.559447] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 3.559644] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.559837] imx219 9-0010: board setup failed
[ 3.560037] imx219: probe of 9-0010 failed with error -121
[ 3.560613] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.584014] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 3.584225] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.584412] imx219 10-0010: board setup failed
[ 3.584614] imx219: probe of 10-0010 failed with error -121
[ 3.585824] max77620-power max20024-power: Event recorder REG_NVERC : 0x80
[ 3.592977] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 3.593064] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[ 3.593071] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.593076] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 3.593080] usb 1-2: Manufacturer: Generic
[ 3.594362] hub 1-2:1.0: USB hub found
[ 3.596013] hub 1-2:1.0: 4 ports detected
[ 3.597858] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 3.606014] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 3.609923] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 3.609929] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 3.627135] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 3.636136] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 3.644156] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 3.652767] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 3.661493] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 3.669207] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 3.678058] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 3.687961] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 3.695866] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 3.705711] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 3.715774] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 3.724241] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 3.732927] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 3.742033] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 3.749923] FAN dev name: pwm-fan
[ 3.752893] FAN:gpio request success.
[ 3.756807] FAN: can't find tach_gpio
[ 3.760222] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 3.767508] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 3.773522] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.780165] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.785597] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.792426] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 3.800385] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 3.808079] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 3.815698] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.823660] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.831532] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.839311] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.846930] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.854910] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.863871] device-mapper: uevent: version 1.0.3
[ 3.868112] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.879759] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 3.883987] cpuidle: Initializing cpuidle driver
[ 3.888761] sdhci: Secure Digital Host Controller Interface driver
[ 3.894266] sdhci: Copyright(c) Pierre Ossman
[ 3.898726] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.904534] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.910273] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.918557] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 245
[ 3.927700] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.930967] tegra-se-nvhost 15810000.se: initialized
[ 3.935196] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.941176] tegra-se-nvhost 15820000.se: initialized
[ 3.946575] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.952666] tegra-se-nvhost 15830000.se: initialized
[ 3.957039] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.963333] tegra-se-nvhost 15840000.se: initialized
[ 3.968524] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.973989] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 3.978667] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.978797] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.979823] usbcore: registered new interface driver usbhid
[ 3.979826] usbhid: USB HID core driver
[ 3.983560] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 3.984591] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 3.984931] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.985442] denver_knobs_init:MTS_VERSION:48073932
[ 3.985588] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 3.986145] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.986587] t19x_cache tegra-cache: probed
[ 3.988710] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 3.988717] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 3.989065] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 3.989419] PLL_AON clock registered
[ 3.991089] Clocks initialized successfully
[ 3.992622] nvpmodel: initialized successfully
[ 3.993814] trusty-virtio trusty:virtio: initializing
[ 3.994094] trusty_ipc virtio0: vring0: va(pa) ffffffc1f2020000(0) qsz 32 notifyid 1
[ 3.994103] trusty_ipc virtio0: vring1: va(pa) ffffffc1f2022000(0) qsz 32 notifyid 2
[ 3.994245] trusty-virtio trusty:virtio: initializing done
[ 3.994491] trusty_ipc virtio0: is online
[ 3.995162] tegra-hda 3510000.hda: Override SDO lines to 4
[ 3.995437] usbcore: registered new interface driver snd-usb-audio
[ 4.008251] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.008414] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.008558] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 4.008752] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 4.080316] OPE platform probe
[ 4.080428] OPE platform probe successful
[ 4.153907] usb 1-2: usb_suspend_both: status 0
[ 4.153975] usb usb1: usb_suspend_both: status 0
[ 4.157415] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.157542] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.157657] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.157797] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.157946] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.158068] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.158192] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.158287] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.158382] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.158491] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.158587] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.158698] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.158808] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.158938] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.159044] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.159133] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.159228] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.159318] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.159407] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.159494] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.186463] u32 classifier
[ 4.186467] Actions configured
[ 4.186580] Initializing XFRM netlink socket
[ 4.187199] NET: Registered protocol family 10
[ 4.188031] NET: Registered protocol family 17
[ 4.188049] NET: Registered protocol family 15
[ 4.188106] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.188200] Bluetooth: RFCOMM socket layer initialized
[ 4.188222] Bluetooth: RFCOMM ver 1.11
[ 4.188227] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.188239] Bluetooth: HIDP socket layer initialized
[ 4.188276] 9pnet: Installing 9P2000 support
[ 4.188317] Key type dns_resolver registered
[ 4.192813] Registered cp15_barrier emulation handler
[ 4.192835] Registered setend emulation handler
[ 4.194650] registered taskstats version 1
[ 4.195109] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 4.196168] OF: PCI: host bridge /pcie@14160000 ranges:
[ 4.196190] OF: PCI: IO 0x36100000..0x361fffff -> 0x36100000
[ 4.196198] OF: PCI: MEM 0x1740000000..0x17ffffffff -> 0x40000000
[ 4.196203] OF: PCI: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 4.305922] tegra-pcie-dw 14160000.pcie: link is up
[ 4.306171] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 4.306191] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 4.306197] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 4.306203] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 4.306207] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 4.306555] iommu: Adding device 0004:00:00.0 to group 58
[ 4.307149] pci 0004:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 4.308396] iommu: Adding device 0004:01:00.0 to group 59
[ 4.326984] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 4.326990] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 4.326999] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[ 4.327095] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 4.327122] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 4.327138] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 4.327145] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 4.327162] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 4.327221] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 4.327510] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 4.327513] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 4.328189] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 4.329171] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 4.329190] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 4.329200] OF: PCI: MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[ 4.329223] OF: PCI: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 4.429911] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 4.459028] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549
[ 4.459032] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.459036] usb 1-3: Product: Bluetooth Radio
[ 4.459038] usb 1-3: Manufacturer: Realtek
[ 4.459041] usb 1-3: SerialNumber: 00e04c000001
��WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
fmon_disable: FMON_CAN2: detected fault 0x1
��[ 4.778896] mmc0: host does not support reading read-only switch, assuming write-enable
[ 4.840894] tegra-pcie-dw 141a0000.pcie: link is down
[ 4.841117] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 4.841242] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 4.841360] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 4.841529] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 4.841721] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 4.842255] iommu: Adding device 0005:00:00.0 to group 60
[ 4.842577] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 4.842687] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 4.843042] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 4.843841] iommu: Removing device 0005:00:00.0 from group 60
[ 4.845657] tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
[ 4.855473] tegra-cbb 14040000.cv-noc: noc_secure_irq = 89, noc_nonsecure_irq = 88>
[ 4.860395] tegra194-isp5 14800000.isp: initialized
[ 4.867165] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 4.870067] tegra194-vi5 15c10000.vi: initialized
[ 4.874266] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[ 4.874505] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[ 4.875401] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.923940] mmc0: hw tuning done ...
[ 4.924068] mmc0: new ultra high speed SDR104 SDHC card at address e624
[ 4.924589] mmcblk0: mmc0:e624 SB32G 29.7 GiB
[ 4.928518] Alternate GPT is invalid, using primary GPT.
[ 4.928684] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 4.960543] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 4.961069] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.961477] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 4.961853] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 4.962388] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 4.962663] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 4.966373] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 4.972289] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.981166] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 4.991799] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 4.996396] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 5.001933] input: gpio-keys as /devices/gpio-keys/input/input4
[ 5.039254] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:52 UTC (946688452)
[ 5.039940] mmcblk mmc0:e624: Card claimed for testing.
[ 5.072065] bpmp: mounted debugfs mirror
[ 5.078609] vdd-1v8-sd: disabling
[ 5.078684] vdd-1v8-cvb: disabling
[ 5.078763] vdd-epb-1v0: disabling
[ 5.078844] avdd-cam-2v8: disabling
[ 5.078907] vdd-fan: disabling
[ 5.078963] vdd_sys_en: disabling
[ 5.079034] ALSA device list:
[ 5.079089] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 5.079169] #1: jetson-xaviernx-ape
[ 5.081143] Freeing unused kernel memory: 8576K
[ 5.114532] No root-device: Mount failed
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-4.3# ��WARNING: at platform/drivers/pg/pg-cv-t194.c:73
��[ 7.390419] Wake76 for irq=199
[ 7.390512] Wake77 for irq=199
[ 7.390567] Wake78 for irq=199
[ 7.390620] Wake79 for irq=199 +-----------------------------+
[ 7.390674] Wake80 for irq=199 | |
[ 7.390728] Wake81 for irq=199 | Cannot open /dev/ttyUSB0! |
[ 7.390781] Wake82 for irq=199 | |
[ 7.390883] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0 +-----------------------------+
[ 7.390984] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 7.718744] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[ 7.755290] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[ 7.755430] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.755547] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 7.755647] usb 2-3: Manufacturer: Generic
[ 7.765846] hub 2-3:1.0: USB hub found
[ 7.767891] hub 2-3:1.0: 4 ports detected
[ 8.365900] usb 2-3: usb_suspend_both: status 0
[ 8.366161] usb usb2: usb_suspend_both: status 0
I observed following error:
**bash: cannot set terminal process group (-1): Inappropriate ioctl for device **
Any ideas why this might happen is greately appreciated.
