Hi Jerry,
I dont see the GPIOs listed in my dmesg output (see below) - any input would be appriciated!
[ 0.627365] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.627374] nvmap_page_pool_init: Total RAM pages: 2008804
[ 0.627381] nvmap_page_pool_init: nvmap page pool size: 251100 pages (980 MB)
[ 0.627499] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.631551] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.643314] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.643496] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.643853] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.643958] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.644097] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.644229] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.644395] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.644676] la/ptsa driver initialized.
[ 0.644689] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.644694] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.645863] NET: Registered protocol family 2
[ 0.647847] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.648724] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.649552] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.649606] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.649734] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.650619] NET: Registered protocol family 1
[ 0.651782] RPC: Registered named UNIX socket transport module.
[ 0.651788] RPC: Registered udp transport module.
[ 0.651793] RPC: Registered tcp transport module.
[ 0.651798] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.651808] PCI: CLS 0 bytes, default 64
[ 0.652041] Trying to unpack rootfs image as initramfs…
[ 0.849158] Freeing initrd memory: 5432K
[ 0.869731] host1x 13e10000.host1x: initialized
[ 0.871535] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.876411] audit: initializing netlink subsys (disabled)
[ 0.876463] audit: type=2000 audit(0.764:1): initialized
[ 0.877271] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.890153] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.892931] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.894542] 9p: Installing v9fs 9p2000 file system support
[ 0.901248] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.901409] io scheduler noop registered
[ 0.902032] io scheduler cfq registered (default)
[ 0.906767] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.936509] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[ 0.976096] iommu: Adding device 2993000.adsp to group 54
[ 0.977293] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.980840] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.984898] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.986364] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.987679] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.988973] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.991663] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 0.992766] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.993175] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 0.993504] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.993671] misc tegra_camera_ctrl: tegra_camera_isomgr_register: some fields not in DT.
[ 0.993682] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0, vi_iso_bw=4500000, max_bw=4500000
[ 0.995661] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.997224] tsec 15500000.tsec: initialized
[ 0.998837] tsec 15100000.tsecb: initialized
[ 1.002326] nvdec 15480000.nvdec: initialized
[ 1.007568] falcon 15340000.vic: initialized
[ 1.009076] falcon 154c0000.nvenc: initialized
[ 1.010756] falcon 15380000.nvjpg: initialized
[ 1.014234] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.015992] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.017662] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.019404] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.021076] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.022733] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.024297] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.025923] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.029477] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.029491] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.029548] tegradccommon 15200000.dc_common: dma mapping done
[ 1.030962] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=390
[ 1.031165] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.031206] generic_infoframe_type: 0x87
[ 1.031274] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.031301] tegradc 15210000.nvdisplay: Display dc.ffffff800b650000 registered with id=0
[ 1.031704] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.032758] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.032786] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.033535] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.033542] tegra_cec 3960000.tegra_cec: probed
[ 1.036282] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.036286] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.036288] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.036455] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 1.036459] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 1.043510] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.043519] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.047238] tegradc 15210000.nvdisplay: probed
[ 1.049924] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.050518] Console: switching to colour frame buffer device 240x67
[ 1.050697] tegradc 15210000.nvdisplay: fb registered
[ 1.050715] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.050906] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 1.052023] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.052206] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.052258] kfuse 3830000.kfuse: initialized
[ 1.052318] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.053859] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.059012] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.060040] Parent Clock set for DC plld2
[ 1.062370] console [ttyS0] disabled
[ 1.062441] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.062517] console [ttyS0] enabled
[ 1.064837] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 1.065166] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.066147] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 1.066453] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 1.066460] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.066465] serial-tegra 3130000.serial: RX in PIO mode
[ 1.067538] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 1.068880] [drm] Initialized
[ 1.070399] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.070405] Extcon AUX1(HDMI) enable
[ 1.078750] brd: module loaded
[ 1.083631] loop: module loaded
[ 1.083985] tegra_profiler: version: 1.139, samples/io: 47/27
[ 1.084124] tegra_profiler: auth: init
[ 1.084604] nct1008_nct72 7-004c: starting parse dt
[ 1.084754] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 1.084770] nct1008_nct72 7-004c: success parsing dt
[ 1.084877] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 1.084925] THERMAL EST: found 3 subdevs
[ 1.084959] THERMAL EST num_resources: 0
[ 1.084964] [THERMAL EST subdev 0]
[ 1.085001] [THERMAL EST subdev 1]
[ 1.085006] [THERMAL EST subdev 2]
[ 1.085351] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.085356] THERMAL EST: thz register success.
[ 1.085509] THERMAL EST: end of probe, return err: 0
[ 1.086681] hisi_sas: driver version v1.6
[ 1.090815] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.090829] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.091856] scsi host0: tegra_ahci
[ 1.092903] scsi host1: tegra_ahci
[ 1.093065] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 1.093071] ata2: DUMMY
[ 1.099387] libphy: Fixed MDIO Bus: probed
[ 1.099873] tun: Universal TUN/TAP device driver, 1.6
[ 1.099878] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.100645] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.100651] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.100688] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.100692] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.100723] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.100728] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.100777] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.100781] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.108661] eqos 2490000.ether_qos: can’t get pllrefe_vcoout clk (-2)
[ 1.112334] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c7 77 64
[ 1.112460] libphy: dwc_phy: probed
[ 1.112935] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 1.115230] PPP generic driver version 2.4.2
[ 1.115464] PPP BSD Compression module registered
[ 1.115470] PPP Deflate Compression module registered
[ 1.115517] PPP MPPE Compression module registered
[ 1.115523] NET: Registered protocol family 24
[ 1.115576] usbcore: registered new interface driver r8152
[ 1.115618] usbcore: registered new interface driver asix
[ 1.115649] usbcore: registered new interface driver ax88179_178a
[ 1.115674] usbcore: registered new interface driver cdc_ether
[ 1.115699] usbcore: registered new interface driver net1080
[ 1.115724] usbcore: registered new interface driver cdc_subset
[ 1.115749] usbcore: registered new interface driver zaurus
[ 1.115790] usbcore: registered new interface driver cdc_ncm
[ 1.116053] VFIO - User Level meta-driver version: 0.3
[ 1.116769] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 1.117413] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 1.117805] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.117823] ehci-pci: EHCI PCI platform driver
[ 1.117854] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.117863] ohci-pci: OHCI PCI platform driver
[ 1.117891] ohci-platform: OHCI generic platform driver
[ 1.122706] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 1.124474] tegra-xusb 3530000.xhci: extcon 0: ffffffc1eb442800 id
[ 1.125335] usbcore: registered new interface driver uas
[ 1.125416] usbcore: registered new interface driver usb-storage
[ 1.125487] usbcore: registered new interface driver usbserial
[ 1.126952] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 1.129374] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.130523] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.130556] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.131453] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.131905] mousedev: PS/2 mouse device common for all mice
[ 1.132000] usbcore: registered new interface driver xpad
[ 1.132385] rotary-encoder jog_wheel: gray
[ 1.133023] gpio tegra-gpio wake63 for gpio=68(I:4)
[ 1.133215] input: jog_wheel as /devices/jog_wheel/input/input0
[ 1.150573] nct1008_nct72 7-004c: initial LOC temp: 34000
[ 1.150914] nct1008_nct72 7-004c: initial EXT temp: 34500
[ 1.151582] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 1.152002] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 1.152222] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.152655] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.152676] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 1.153580] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 1.153627] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[ 1.153888] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.153896] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.153902] usb usb1: Product: xHCI Host Controller
[ 1.153907] usb usb1: Manufacturer: Linux 4.9.140-magellan xhci-hcd
[ 1.153913] usb usb1: SerialNumber: 3530000.xhci
[ 1.154476] hub 1-0:1.0: USB hub found
[ 1.154520] hub 1-0:1.0: 4 ports detected
[ 1.154940] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.154952] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 1.155176] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.155182] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.155188] usb usb2: Product: xHCI Host Controller
[ 1.155193] usb usb2: Manufacturer: Linux 4.9.140-magellan xhci-hcd
[ 1.155198] usb usb2: SerialNumber: 3530000.xhci
[ 1.155632] hub 2-0:1.0: USB hub found
[ 1.155672] hub 2-0:1.0: 3 ports detected
[ 1.172870] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.216709] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.216713] Extcon AUX1(HDMI) disable
[ 1.244336] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 1.244936] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.250315] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.266693] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.289521] Wake73 for irq=42
[ 1.294663] rtc rtc1: alarm rtc device
[ 1.295059] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.295458] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.299781] i2c /dev entries driver
[ 1.333550] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.389109] i2c i2c-4: tegra_bpmp_i2c_req ret -5
[ 1.389141] i2c i2c-4: — message dump for debugging —
[ 1.389175] i2c i2c-4: addr 0x2e flags 0x0 len 0 data:
[ 1.389189] i2c i2c-4:
[ 1.411671] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.419863] tegradc 15210000.nvdisplay: unblank
[ 1.422930] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.433648] i2c i2c-4: tegra_bpmp_i2c_req ret -5
[ 1.433663] i2c i2c-4: — message dump for debugging —
[ 1.433677] i2c i2c-4: addr 0x2f flags 0x0 len 0 data:
[ 1.433687] i2c i2c-4:
[ 1.478100] i2c i2c-4: tegra_bpmp_i2c_req ret -5
[ 1.478102] i2c i2c-4: — message dump for debugging —
[ 1.478109] i2c i2c-4: addr 0x2c flags 0x0 len 0 data:
[ 1.478111] i2c i2c-4:
[ 1.484797] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 1.514772] usb 1-3: New USB device found, idVendor=046d, idProduct=c52b
[ 1.514792] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.514805] usb 1-3: Product: USB Receiver
[ 1.514813] usb 1-3: Manufacturer: Logitech
[ 1.522794] i2c i2c-4: tegra_bpmp_i2c_req ret -5
[ 1.522802] i2c i2c-4: — message dump for debugging —
[ 1.522805] i2c i2c-4: addr 0x2d flags 0x0 len 0 data:
[ 1.522807] i2c i2c-4:
[ 1.568113] i2c i2c-4: tegra_bpmp_i2c_req ret -5
[ 1.568148] i2c i2c-4: — message dump for debugging —
[ 1.568162] i2c i2c-4: addr 0x4c flags 0x0 len 0 data:
[ 1.568171] i2c i2c-4:
[ 1.612375] i2c i2c-4: tegra_bpmp_i2c_req ret -5
[ 1.612383] i2c i2c-4: — message dump for debugging —
[ 1.612396] i2c i2c-4: addr 0x4d flags 0x0 len 0 data:
[ 1.612403] i2c i2c-4:
[ 1.614323] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.615261] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.615885] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.629838] Parent Clock set for DC plld2
[ 1.633792] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.635350] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 1.635361] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.636941] parse_throttle_dt_data: Num cap clks = 4
[ 1.636947] parse_throttle_dt_data: clk=mcpu type=1
[ 1.636951] parse_throttle_dt_data: clk=bcpu type=2
[ 1.636959] parse_throttle_dt_data: clk=gpu type=4
[ 1.636963] parse_throttle_dt_data: clk=emc type=3
[ 1.637873] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.638661] FAN dev name: pwm-fan
[ 1.638715] FAN:gpio request success.
[ 1.638723] FAN: can’t find tach_gpio
[ 1.638745] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.638979] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 1.638984] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.639752] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.639756] Extcon AUX1(HDMI) enable
[ 1.640057] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.640063] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.640068] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.640072] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.640076] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.640080] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.640084] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.640088] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.640093] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.640098] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.641856] device-mapper: uevent: version 1.0.3
[ 1.642694] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.643043] CPU EMC frequency mapping table: default setting
[ 1.647597] cpufreq: platform driver Initialization: pass
[ 1.648190] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 1.648302] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 1.649156] sdhci: Secure Digital Host Controller Interface driver
[ 1.649159] sdhci: Copyright(c) Pierre Ossman
[ 1.649161] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.650735] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.652693] CMDQ: cmdq_platfm_init successful
[ 1.653876] CQE: CMD_TIMING bit set for R1B DCMD
[ 1.653956] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 1.656822] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.656870] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 1.657583] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.661945] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 1.666503] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.667677] tegra-se-nvhost 15810000.se: initialized
[ 1.668813] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.669675] tegra-se-nvhost 15820000.se: initialized
[ 1.670758] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.671426] tegra-se-nvhost 15830000.se: initialized
[ 1.672241] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.672824] tegra-se-nvhost 15840000.se: initialized
[ 1.673765] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.673999] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.682326] usbcore: registered new interface driver usbhid
[ 1.682327] usbhid: USB HID core driver
[ 1.686326] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 1.688841] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 1.689257] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 1.689438] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 1.689834] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 1.691140] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 1.691254] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 1.691343] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 1.691466] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 1.691642] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 1.692149] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 1.692152] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 1.693164] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 1.694799] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.695348] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.695718] register_ari_mca_banks: Registered MCA ROC:IOB
[ 1.695790] register_ari_mca_banks: Registered MCA ROC:CCE
[ 1.696170] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696174] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 1.696177] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 1.696233] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696236] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 1.696238] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 1.696292] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696296] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 1.696299] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 1.696353] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696357] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 1.696359] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 1.696410] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696413] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 1.696416] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 1.696466] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696473] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 1.696475] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 1.696561] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696566] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 1.696569] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 1.696601] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.696632] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696638] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 1.696640] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 1.696710] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696736] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 1.696738] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 1.696791] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696795] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 1.696797] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 1.696849] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696855] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 1.696857] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 1.696909] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696915] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 1.696917] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 1.696968] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.696974] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 1.696976] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 1.697030] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.697037] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 1.697039] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 1.697094] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.697099] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 1.697101] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 1.697171] tegra18_a57_serr_init: on CPU 2 a Denver Core
[ 1.697243] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 1.697903] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.698334] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 1.698433] denver_knobs_init:MTS_VERSION:47926945
[ 1.700064] nvpmodel: initialized successfully
[ 1.700614] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.701844] trusty-virtio trusty:virtio: initializing
[ 1.701965] trusty_ipc virtio0: vring0: va¶ ffffffc1e5432000(0) qsz 32 notifyid 1
[ 1.701970] trusty_ipc virtio0: vring1: va¶ ffffffc1e5434000(0) qsz 32 notifyid 2
[ 1.702220] trusty-virtio trusty:virtio: initializing done
[ 1.702320] trusty_ipc virtio0: is online
[ 1.703586] usbcore: registered new interface driver snd-usb-audio
[ 1.709001] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 1.709062] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.724752] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input1
[ 1.724918] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input2
[ 1.750756] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.766554] mmc0: periodic cache flush enabled
[ 1.766585] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.767073] mmcblk0: mmc0:0001 DG4032 29.1 GiB
[ 1.767339] mmcblk0boot0: mmc0:0001 DG4032 partition 1 4.00 MiB
[ 1.767573] mmcblk0boot1: mmc0:0001 DG4032 partition 2 4.00 MiB
[ 1.767868] mmcblk0rpmb: mmc0:0001 DG4032 partition 3 4.00 MiB
[ 1.770048] OPE platform probe
[ 1.770113] OPE platform probe successful
[ 1.771464] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[ 1.839270] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.839363] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.839451] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.839545] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.839660] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.839750] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.839835] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.839919] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.840005] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.840094] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.840182] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 1.840277] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 1.840363] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 1.840449] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 1.840576] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 1.841258] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 1.841358] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 1.841447] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 1.841533] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 1.841625] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 1.842573] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.877993] u32 classifier
[ 1.877996] Actions configured
[ 1.878076] Initializing XFRM netlink socket
[ 1.879740] NET: Registered protocol family 10
[ 1.881065] NET: Registered protocol family 17
[ 1.881078] NET: Registered protocol family 15
[ 1.881284] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.881359] Bluetooth: RFCOMM socket layer initialized
[ 1.881388] Bluetooth: RFCOMM ver 1.11
[ 1.881394] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.881399] Bluetooth: HIDP socket layer initialized
[ 1.881438] 9pnet: Installing 9P2000 support
[ 1.881479] Key type dns_resolver registered
[ 1.882675] Registered cp15_barrier emulation handler
[ 1.882694] Registered setend emulation handler
[ 1.886402] registered taskstats version 1
[ 1.889845] isp 15600000.isp: initialized
[ 1.894358] nvcsi 150c0000.nvcsi: initialized
[ 1.900131] GPIO line 224 (top_out_high) hogged as output/high
[ 1.900384] GPIO line 225 (top_out_high) hogged as output/high
[ 1.900624] GPIO line 226 (top_out_high) hogged as output/high
[ 1.900751] GPIO line 227 (top_in) hogged as input
[ 1.900875] GPIO line 228 (top_in) hogged as input
[ 1.900997] GPIO line 232 (top_in) hogged as input
[ 1.901007] tegra-vi4 15700000.vi: initialized
[ 1.901128] GPIO line 236 (top_in) hogged as input
[ 1.901272] GPIO line 238 (top_in) hogged as input
[ 1.901398] GPIO line 239 (top_in) hogged as input
[ 1.901643] GPIO line 229 (top_out_low) hogged as output/low
[ 1.901881] GPIO line 230 (top_out_low) hogged as output/low
[ 1.902126] GPIO line 231 (top_out_low) hogged as output/low
[ 1.902369] GPIO line 234 (top_out_low) hogged as output/low
[ 1.902607] GPIO line 235 (top_out_low) hogged as output/low
[ 1.902869] GPIO line 237 (top_out_low) hogged as output/low
[ 1.903114] GPIO line 240 (top_out_low) hogged as output/low
[ 1.903360] GPIO line 241 (top_out_low) hogged as output/low
[ 1.903593] GPIO line 243 (top_out_low) hogged as output/low
[ 1.903825] GPIO line 244 (top_out_low) hogged as output/low
[ 1.904074] GPIO line 245 (top_out_low) hogged as output/low
[ 1.904309] GPIO line 246 (top_out_low) hogged as output/low
[ 1.904581] GPIO line 247 (top_out_low) hogged as output/low
[ 1.904776] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–3 bound
[ 1.904788] gpiochip_setup_dev: registered GPIOs 224 to 247 on device: gpiochip3 (tca6424)
[ 1.904887] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–2 bound
[ 1.904973] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–1 bound
[ 1.906130] magellan-sdi 0-004c: requested gpio 231 adv-reset
[ 1.906378] magellan-sdi 0-004c: requested gpio 233 sdi-enabled
[ 1.906616] magellan-sdi 0-004c: requested gpio 234 sdi-standby
[ 1.906860] magellan-sdi 0-004c: requested gpio 235 sdi-rate-sel
[ 1.907103] magellan-sdi 0-004c: requested gpio 237 sdi-reset
[ 1.907106] magellan-sdi 0-004c: Setting gpios
[ 1.952415] mmc1: hw tuning done …
[ 1.959591] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 2.060596] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.247101] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.249138] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.448820] magellan-sdi 0-004c: Finishing
[ 2.449805] magellan-sdi 0-004c: Done initializing SDI
[ 2.450634] gpio tegra-gpio wake64 for gpio=70(I:6)
[ 2.450705] gpio tegra-gpio wake9 for gpio=16(C:0)
[ 2.450812] gpio tegra-gpio wake8 for gpio=13(B:5)
[ 2.451025] input: gpio-keys-direct as /devices/gpio-keys-direct/input/input3
[ 2.451720] input: gpio-keys-i2c as /devices/gpio-keys-i2c/input/input4
[ 2.485289] tegra_rtc c2a0000.rtc: setting system clock to 2020-11-03 08:23:49 UTC (1604391829)
[ 2.486214] mmcblk mmc0:0001: Card claimed for testing.
[ 2.523243] bpmp: mounted debugfs mirror
[ 2.524869] bwmgr: missing cdev-type property
[ 2.530529] spmic-ldo0: disabling
[ 2.530720] spmic-ldo1: disabling
[ 2.530882] en-vdd-sd: disabling
[ 2.530885] en-vdd-cam: disabling
[ 2.530888] vdd-usb0-5v: disabling
[ 2.530891] vdd-usb1-5v: disabling
[ 2.530917] en-vdd-disp-3v3: disabling
[ 2.530919] en-mdm-pwr-3v7: disabling
[ 2.530921] en-vdd-disp-1v8: disabling
[ 2.530924] en-vdd-cam-hv-2v8: disabling
[ 2.530926] en-vdd-cam-1v2: disabling
[ 2.530929] vdd-fan: disabling
[ 2.530932] en-vdd-vcm-2v8: disabling
[ 2.530934] vdd-usb2-5v: disabling
[ 2.530937] vdd-sys-bl: disabling
[ 2.530939] en-vdd-sys: disabling
[ 2.530942] ALSA device list:
[ 2.530945] #0: tegra-hda at 0x3518000 irq 383
[ 2.530947] #1: tegra-snd-t186ref-mobile-rt565x
[ 2.662543] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.068826] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.474787] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.476827] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 3.695369] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 3.707884] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 3.756795] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 3.756799] Extcon HDMI: HPD enabled
[ 3.756834] tegradc 15210000.nvdisplay: hdmi: plugged
[ 3.759552] Freeing unused kernel memory: 8576K
[ 3.790815] Root device found: mmcblk0p1
[ 3.791588] Found dev node: /dev/mmcblk0p1
[ 3.812448] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.813144] Rootfs mounted over mmcblk0p1
[ 3.837336] Switching from initrd to actual rootfs
[ 3.838891] tegra_edid_read_block: remainder is 250 for the last 5 attempts. Assuming bad sink EDID and ignoring. New checksum is 6
[ 3.838904] tegradc 15210000.nvdisplay: read_edid_into_buffer: extension_blocks = 0, max_ext_blocks = 3
[ 3.838909] tegradc 15210000.nvdisplay: hdmi_recheck_edid: read_edid_into_buffer() returned 128
[ 3.838915] tegradc 15210000.nvdisplay: old edid len = 256
[ 3.838924] tmp :ffffffc1e9bc7b10: ffffff00 00ffffff 00000000 00000000 …
[ 3.838930] tmp :ffffffc1e9bc7b20: 00000000 00000000 00000000 00000000 …
[ 3.838935] tmp :ffffffc1e9bc7b30: 00000000 00000000 00000000 00000000 …
[ 3.838939] tmp :ffffffc1e9bc7b40: 00000000 00000000 00000000 00000000 …
[ 3.838943] tmp :ffffffc1e9bc7b50: 00000000 00000000 00000000 00000000 …
[ 3.838947] tmp :ffffffc1e9bc7b60: 00000000 00000000 00000000 00000000 …
[ 3.838952] tmp :ffffffc1e9bc7b70: 00000000 00000000 00000000 00000000 …
[ 3.838956] tmp :ffffffc1e9bc7b80: 00000000 00000000 00000000 06000000 …
[ 3.838962] data:ffffff800b181088: ffffff00 00ffffff bdc6a409 00000000 …
[ 3.838967] data:ffffff800b181098: 03011634 78000080 a391ee0a 26994c54 4…x…TL.&
[ 3.838972] data:ffffff800b1810a8: 2054500f 01010000 01010101 01010101 .PT …
[ 3.838976] data:ffffff800b1810b8: 01010101 3a020101 38711880 2c58402d …:…q8-@X,
[ 3.838981] data:ffffff800b1810c8: 8ec40045 1e000021 18801d01 20161c71 E…!..q…
[ 3.838986] data:ffffff800b1810d8: 00252c58 00218ec4 00009e00 4200fc00 X,%…!..B
[ 3.838991] data:ffffff800b1810e8: 4820444d 0a494d44 20202020 fd000000 MD HDMI. …
[ 3.838997] data:ffffff800b1810f8: 0f3c1700 0a000f44 20202020 93012020 …<.D… …
[ 3.839002] data:ffffff800b181108: 71280302 221f9052 14052021 15061304 …(qR…"! …
[ 3.839024] data:ffffff800b181118: 03021607 23011211 8307040f 6800000f …#…h
[ 3.839029] data:ffffff800b181128: 10000c03 001e0000 72001d01 201ed051 …rQ…
[ 3.839034] data:ffffff800b181138: 0055286e 00218ec4 0a8c1e00 f05114a0 n(U…!..Q.
[ 3.839039] data:ffffff800b181148: 7c260016 8e130043 98000021 d0801d01 …&|C…!..
[ 3.839043] data:ffffff800b181158: 20161c72 80252c10 00218ec4 1d019e00 r… .,%…!..
[ 3.839048] data:ffffff800b181168: d052bc00 28b8201e 8ec44055 1e000021 …R… .(U@…!..
[ 3.839053] data:ffffff800b181178: 00000000 00000000 00000000 4a000000 …J
[ 3.839057] tegradc 15210000.nvdisplay: hdmi: EDID change after HPD bounce, resetting
[ 3.885585] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 3.885591] Extcon AUX1(HDMI) disable
[ 3.907955] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 3.908047] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 3.908855] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 3.908997] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.909172] extcon-disp-state external-connection:disp-state: cable 51 state 0
[ 3.909176] Extcon HDMI: HPD disabled
[ 3.909196] tegradc 15210000.nvdisplay: hdmi: plugged
[ 3.909335] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.914155] tegradc 15210000.nvdisplay: unblank
[ 3.915101] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 3.915197] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 3.915294] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 3.916834] Parent Clock set for DC plld2
[ 3.920288] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 3.921674] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 3.921696] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 3.925368] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 3.925371] Extcon AUX1(HDMI) enable
[ 4.172580] tegra_cec 3960000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[ 4.172593] tegra_cec 3960000.tegra_cec: Sent res: -62.
[ 4.172598] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 4.273014] Wake76 for irq=199
[ 4.273017] Wake77 for irq=199
[ 4.273018] Wake78 for irq=199
[ 4.273020] Wake79 for irq=199
[ 4.273021] Wake80 for irq=199
[ 4.273023] Wake81 for irq=199
[ 4.273024] Wake82 for irq=199
[ 4.273060] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 4.273064] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 4.376815] usb usb2: usb_suspend_both: status 0
[ 5.945063] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 5.945067] Extcon HDMI: HPD enabled
[ 5.945088] tegradc 15210000.nvdisplay: hdmi: plugged
[ 5.980006] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.024667] cgroup: cgroup2: unknown option “nsdelegate”
[ 6.050787] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 6.053890] systemd[1]: Detected architecture arm64.
[ 6.143422] systemd[1]: Set hostname to .
[ 6.234123] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.234148] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.438554] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.442077] systemd[1]: Created slice User and Session Slice.
[ 6.442379] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.442425] systemd[1]: Reached target User and Group Name Lookups.
[ 6.442507] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.444234] systemd[1]: Created slice System Slice.
[ 6.445099] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.445542] systemd[1]: Listening on udev Control Socket.
[ 6.484496] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 6.545288] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.646290] random: crng init done
[ 6.646294] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.784660] systemd-journald[2339]: Received request to flush runtime journal from PID 1
[ 7.028893] can: controller area network core (rev 20120528 abi 9)
[ 7.029129] NET: Registered protocol family 29
[ 7.511724] using random self ethernet address
[ 7.516901] using random host ethernet address
[ 7.698028] imx185 2-001a: probing v4l2 sensor
[ 7.701128] imx185 2-001a: tegracam sensor driver:imx185_v2.0.6
[ 7.736612] tegra-vi4 15700000.vi: subdev imx185 2-001a bound
[ 7.745426] imx185 2-001a: Detected IMX185 sensor
[ 7.954492] logitech-djreceiver 0003:046D:C52B.0003: hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3530000.xhci-3/input2
[ 7.965346] Mass Storage Function, version: 2009/09/11
[ 7.965352] LUN: removable file: (no medium)
[ 7.974007] using random self ethernet address
[ 7.983252] using random host ethernet address
[ 8.046490] rndis0: HOST MAC 4e:b3:8b:78:c6:c8
[ 8.046814] rndis0: MAC 4e:b3:8b:78:c6:c9
[ 8.049137] usb0: HOST MAC 4e:b3:8b:78:c6:ca
[ 8.049188] usb0: MAC 4e:b3:8b:78:c6:cb
[ 8.049214] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.051887] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.051907] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.051949] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.052754] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.052774] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.053769] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.053790] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.055587] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.070697] l4tbr0: port 1(rndis0) entered blocking state
[ 8.070703] l4tbr0: port 1(rndis0) entered disabled state
[ 8.071005] device rndis0 entered promiscuous mode
[ 8.078252] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 8.085755] l4tbr0: port 2(usb0) entered blocking state
[ 8.085760] l4tbr0: port 2(usb0) entered disabled state
[ 8.085901] device usb0 entered promiscuous mode
[ 8.101835] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.202104] dhd_module_init in
[ 8.202304] found wifi platform device bcmdhd_wlan
[ 8.203476] wifi_platform_get_country_code_map: could not get country_code_map
[ 8.203479] wifi_plat_dev_drv_probe:platform country code map is not available
[ 8.203498] Power-up adapter ‘DHD generic adapter’
[ 8.203506] wifi_platform_set_power = 1
[ 8.417414] wifi_platform_bus_enumerate device present 1
[ 8.442749] wifi_platform_bus_enumerate device present 0
[ 8.443436] F1 signature read @0x18000000=0x17214354
[ 8.470169] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.471039] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.471157] wifi_platform_get_mac_addr
[ 8.485053] ids dhd_log_netlink_init
[ 8.485824] wl_create_event_handler(): thread:wl_event_handler:14ff started
[ 8.485826] wl_event_handler :
[ 8.485829] tsk Enter, tsk = 0xffffffc1e0a01a90
[ 8.488882] dhd_attach(): thread:dhd_watchdog_thread:1501 started
[ 8.492795] dhd_attach(): thread:dhd_dpc:1505 started
[ 8.497696] dhd_attach(): thread:dhd_rxf:150a started
[ 8.497706] dhd_deferred_work_init: work queue initialized
[ 8.499594]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ 8.499970] Register interface [wlan0] MAC: 00:04:4b:c7:77:62
[ 8.499975] dhd_prot_ioctl : bus is down. we have nothing to do
[ 8.500212] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 57
[ 8.501257] wifi_platform_set_power = 0
[ 8.630239] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.717452] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 8.720061] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.821738] CPU1: shutdown
[ 8.824476] psci: CPU1 killed.
[ 8.917427] CPU2: shutdown
[ 8.920194] psci: CPU2 killed.
[ 9.060952] zram: Added device: zram0
[ 9.062839] zram: Added device: zram1
[ 9.063225] zram: Added device: zram2
[ 9.068684] zram: Added device: zram3
[ 9.093268] zram0: detected capacity change from 0 to 1030303744
[ 9.132154] Adding 1006152k swap on /dev/zram0. Priority:5 extents:1 across:1006152k SS
[ 9.136651] zram1: detected capacity change from 0 to 1030303744
[ 9.153860] Adding 1006152k swap on /dev/zram1. Priority:5 extents:1 across:1006152k SS
[ 9.159452] zram2: detected capacity change from 0 to 1030303744
[ 9.190566] Adding 1006152k swap on /dev/zram2. Priority:5 extents:1 across:1006152k SS
[ 9.199162] zram3: detected capacity change from 0 to 1030303744
[ 9.212942] Adding 1006152k swap on /dev/zram3. Priority:5 extents:1 across:1006152k SS
[ 9.711707] input: Logitech M215 2nd Gen as /devices/3530000.xhci/usb1/1-3/1-3:1.2/0003:046D:C52B.0003/0003:046D:401B.0004/input/input5
[ 9.711955] logitech-hidpp-device 0003:046D:401B.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech M215 2nd Gen] on usb-3530000.xhci-3:1
[ 9.715902] input: Logitech K330 as /devices/3530000.xhci/usb1/1-3/1-3:1.2/0003:046D:C52B.0003/0003:046D:4016.0005/input/input6
[ 9.716733] logitech-hidpp-device 0003:046D:4016.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech K330] on usb-3530000.xhci-3:2
[ 9.721971] input: Logitech M570 as /devices/3530000.xhci/usb1/1-3/1-3:1.2/0003:046D:C52B.0003/0003:046D:1028.0006/input/input7
[ 9.722263] logitech-hidpp-device 0003:046D:1028.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech M570] on usb-3530000.xhci-3:3
[ 9.728018] input: Logitech M570 as /devices/3530000.xhci/usb1/1-3/1-3:1.2/0003:046D:C52B.0003/0003:046D:1028.0007/input/input8
[ 9.728322] logitech-hidpp-device 0003:046D:1028.0007: input,hidraw4: USB HID v1.11 Mouse [Logitech M570] on usb-3530000.xhci-3:4
[ 9.733917] input: Logitech K360 as /devices/3530000.xhci/usb1/1-3/1-3:1.2/0003:046D:C52B.0003/0003:046D:4004.0008/input/input9
[ 9.734513] logitech-hidpp-device 0003:046D:4004.0008: input,hidraw5: USB HID v1.11 Keyboard [Logitech K360] on usb-3530000.xhci-3:5
[ 9.934482] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.934600]
Compiled from
[ 9.934607] wl_android_wifi_on in
[ 9.934611] wifi_platform_set_power = 1
[ 10.145643] vdd-1v8: voltage operation not allowed
[ 10.145653] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 10.164708] vdd-1v8: voltage operation not allowed
[ 10.164716] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 10.185540] vdd-1v8: voltage operation not allowed
[ 10.185547] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 10.187949] vdd-1v8: voltage operation not allowed
[ 10.187956] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 10.289830] vdd-1v8: voltage operation not allowed
[ 10.289850] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 10.290819] vdd-1v8: voltage operation not allowed
[ 10.290833] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 10.292447] vdd-1v8: voltage operation not allowed
[ 10.292460] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 10.292490] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 57
[ 10.293426] F1 signature read @0x18000000=0x17214354
[ 10.299217] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 10.299947] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 10.379939] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 10.442229] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 10.442568] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 10.442638] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 10.442640] Enabling wake69
[ 10.444069] wifi_platform_get_mac_addr
[ 10.445947] Firmware up: op_mode=0x0005, MAC=00:04:4b:c7:77:62
[ 10.450668] clm path from default:/lib/firmware/brcm/bcmdhd.clm_blob
[ 10.450712] Skipping the clm download. len:0 memblk: (null)
[ 10.453121] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 10.458508] Firmware version = wl0: May 17 2019 16:59:40 version 7.35.349.79 (r714996 CY) FWID 01-e527e2ad
[ 10.461096] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 10.551905] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if :
[ 10.551905] P2P interface registered
[ 10.560115] WLC_E_IF: NO_IF set, event Ignored
[ 10.567590] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 12.275166] [11-03 08:23:59.289] wl_cfg80211_connect: Connectting with c4:a8:1d:87:76:f0 channel (4) ssid “MeLaLi”, len (6)
[ 12.346273] [11-03 08:23:59.360] wl_notify_connect_status: wl_bss_connect_done succeeded with c4:a8:1d:87:76:f0
[ 12.347937] [11-03 08:23:59.362] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [RX] : M1 of 4way
[ 12.372858] wl_bss_connect_done :
[ 12.372859] Report connect result - connection succeeded
[ 12.375909] [11-03 08:23:59.390] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [TX] : M2 of 4way
[ 12.381384] [11-03 08:23:59.396] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [RX] : M3 of 4way
[ 12.381996] [11-03 08:23:59.396] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [TX] : M4 of 4way
[ 12.406483] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 12.422694] [11-03 08:23:59.437] wl_notify_connect_status: wl_bss_connect_done succeeded with c4:a8:1d:87:76:f0
[ 12.460114] dhd_ndo_add_ip: ndo ip addr add failed, ret = -23
[ 12.460128] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 12.504884] ifidx:0 DHCP - REQUEST [TX]
[ 12.559378] ifidx:0 DHCP - ACK [RX]
[ 12.903806] tegradc 15210000.nvdisplay: blank - powerdown
[ 12.955237] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 12.955239] Extcon AUX1(HDMI) disable
[ 12.978820] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 12.978897] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 12.979518] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 12.979638] tegradc 15210000.nvdisplay: unblank
[ 12.980431] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 12.980512] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 12.980592] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 12.981872] Parent Clock set for DC plld2
[ 12.984844] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 12.986055] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 12.986061] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 12.990345] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 12.990347] Extcon AUX1(HDMI) enable
[ 12.990402] tegradc 15210000.nvdisplay: unblank
[ 13.887129] fuse init (API version 7.26)
[ 14.177223] dhd_ndo_add_ip: ndo ip addr add failed, ret = -23
[ 14.177235] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 14.178038] dhd_ndo_add_ip: ndo ip addr add failed, ret = -23
[ 14.178047] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 14.261558] CAN device driver interface
[ 14.286136] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x000009c0|
| rxbc_rbsa |0x000009c0|
| txefc_efsa |0x000009c0|
| txbc_tbsa |0x00000a40|
| tmc_tmsa |0x00000ec0|
[ 14.286308] Release 3.2.0 from 19.12.2014
[ 14.286764] net can0: mttcan device registered (regs=ffffff80123aa000, irq=387)
[ 14.289551] Message RAM Configuration
| base addr |0x0c322000|
[ 14.289724] Release 3.2.0 from 19.12.2014
[ 14.294511] net can1: mttcan device registered (regs=ffffff80123b9000, irq=388)
[ 15.923345] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.923357] Bluetooth: BNEP socket layer initialized
[ 18.182451] gpio tegra-gpio wake54 for gpio=160(Y:0)
[ 18.182971] gpio tegra-gpio wake58 for gpio=166(Y:6)
[ 18.183082] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 18.183179] gpio tegra-gpio-aon wake25 for gpio=3(S:3)
[ 18.188784] usb usb2: usb_suspend_both: status 0
[ 18.583442] mttcan c310000.mttcan can0: Bitrate set
[ 18.629473] mttcan_controller_config: ctrlmode 0
[ 18.629496] mttcan c310000.mttcan can0: Bitrate set
[ 18.676091] can: raw protocol (rev 20120528)
[ 28.563910] tegra-i2c 3180000.i2c: no acknowledge from address 0x1a
[ 28.570273] imx185 2-001a: imx185_write_reg: i2c write failed, 0x3003 = 1
