Jetson nano USB malfunction after flashed
1、I plug a P3448-0002 on P3541 board.
2、And use SDK Manager flashed successfully.
3、I can see the login on HDMI and can SSH by lan also.
4、Just all USB doesn’t work.
5、It was good last time when I flashed the P3448 on a P3449 board and move it to P3541.
6、But I nolonger have a P3449 board now.
So, is there any way to make it work (P3448-0002 on P3541)?
something like device tree modify?
some of dmesg:
red words are:
[ 1.125933] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.291842] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.291914] imx219 7-0010: board setup failed
[ 1.315768] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.315825] imx219 8-0010: board setup failed
[ 1.655419] cgroup: cgroup2: unknown option “nsdelegate”
[ 4.210837] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[ 1.121386] usbcore: registered new interface driver r8152
[ 1.121436] usbcore: registered new interface driver asix
[ 1.121479] usbcore: registered new interface driver ax88179_178a
[ 1.121522] usbcore: registered new interface driver cdc_ether
[ 1.121568] usbcore: registered new interface driver net1080
[ 1.121601] usbcore: registered new interface driver cdc_subset
[ 1.121634] usbcore: registered new interface driver zaurus
[ 1.121691] usbcore: registered new interface driver cdc_ncm
[ 1.121877] VFIO - User Level meta-driver version: 0.3
[ 1.122589] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.122594] Extcon AUX1(HDMI) enable
[ 1.123809] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.123836] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.123869] ehci-pci: EHCI PCI platform driver
[ 1.123899] tegradc tegradc.1: No lt-data, using default setting
[ 1.123924] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.123931] tegradc tegradc.1: No hpd-gpio in DT
[ 1.123939] ohci-pci: OHCI PCI platform driver
[ 1.123974] tegradc tegradc.1: DT parsed successfully
[ 1.123994] ohci-platform: OHCI generic platform driver
[ 1.124045] tegradc tegradc.1: Display dc.ffffff800d540000 registered with id=1
[ 1.127154] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.127938] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.129132] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f944bc00 id
[ 1.131577] usbcore: registered new interface driver uas
[ 1.131639] usbcore: registered new interface driver usb-storage
[ 1.131760] usbcore: registered new interface driver usbserial
[ 1.137226] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.138285] tegradc tegradc.1: probed
[ 1.138664] tegradc tegradc.1: fb registered
[ 1.139042] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.139056] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.139594] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.139900] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.141912] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.141919] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.141928] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.141942] tegradc tegradc.1: blank - powerdown
[ 1.141963] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.141967] Extcon DP: HPD disabled
[ 1.141971] hpd: hpd_switch 0
[ 1.141976] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.141984] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.141992] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.142732] mousedev: PS/2 mouse device common for all mice
[ 1.142885] usbcore: registered new interface driver xpad
[ 1.161009] tegradc tegradc.0: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[ 1.161166] tegra-xusb 70090000.xusb: Firmware timestamp: 2020-07-31 09:33:12 UTC, Version: 50.26 release
[ 1.161199] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.161218] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.161965] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.161999] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.164694] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.164701] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.164706] usb usb1: Product: xHCI Host Controller
[ 1.164711] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.164715] usb usb1: SerialNumber: 70090000.xusb
[ 1.170682] hub 1-0:1.0: USB hub found
[ 1.170717] hub 1-0:1.0: 5 ports detected
[ 1.171246] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.171257] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.171352] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.171445] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.171452] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.171456] usb usb2: Product: xHCI Host Controller
[ 1.171461] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.171465] usb usb2: SerialNumber: 70090000.xusb
[ 1.171850] hub 2-0:1.0: USB hub found
[ 1.171882] hub 2-0:1.0: 4 ports detected
[ 1.172503] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.172509] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.254264] tegradc tegradc.0: blank - powerdown
[ 1.263080] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.265254] rtc rtc1: alarm rtc device
[ 1.265266] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.265283] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.265653] i2c /dev entries driver
[ 1.267382] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.267802] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.267807] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.268458] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.274922] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 1.275172] usb usb2: usb_suspend_both: status 0
[ 1.291750] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.291965] imx219: probe of 7-0010 failed with error -121
[ 1.292401] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.298225] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.298227] Extcon AUX1(HDMI) disable
[ 1.315682] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.315871] imx219: probe of 8-0010 failed with error -121
[ 1.316997] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.319193] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.319200] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.319728] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.319746] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.319757] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.319936] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.319947] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.319953] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.320102] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.320114] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.320119] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.320295] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.321496] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.321567] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.321596] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.321613] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.321621] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.322848] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.322870] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.323100] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.323133] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.323694] parse_throttle_dt_data: Num cap clks = 6
[ 1.323699] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.323714] parse_throttle_dt_data: clk=gpu type=4
[ 1.323745] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.323767] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.323792] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.323796] parse_throttle_dt_data: clk=emc type=3
[ 1.324318] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.324478] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.324700] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.325667] FAN dev name: pwm-fan
[ 1.325746] FAN:gpio request success.
[ 1.325821] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.326232] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.326428] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.326438] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.326550] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.326555] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.326559] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.326564] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.326568] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.326572] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.326575] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.326579] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.326583] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.326588] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.329748] device-mapper: uevent: version 1.0.3
[ 1.330330] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.335545] tegra210-cpufreq cpufreq: probe()…completed
[ 1.336353] sdhci: Secure Digital Host Controller Interface driver
[ 1.336354] sdhci: Copyright(c) Pierre Ossman
[ 1.336356] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.336726] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 1.343493] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.343990] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.345172] usbcore: registered new interface driver usbhid
[ 1.345174] usbhid: USB HID core driver
[ 1.347343] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.347674] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.349635] nvpmodel: initialized successfully
[ 1.350592] usbcore: registered new interface driver snd-usb-audio
[ 1.350657] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.350661] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.350677] iommu: Adding device snd-soc-dummy to group 36
[ 1.354324] tegradc tegradc.0: unblank
[ 1.362481] OPE platform probe
[ 1.362565] OPE platform probe successful
[ 1.362590] OPE platform probe
[ 1.362667] OPE platform probe successful
[ 1.367491] tegradc tegradc.0: nominal-pclk:265600000 parent:265600000 div:1.0 pclk:265600000 262944000~289504000
[ 1.367556] tegradc tegradc.0: hdmi: tmds rate:265600K prod-setting:prod_c_hdmi_150m_300m
[ 1.368563] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.368832] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.378812] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 1.389790] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.389920] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.390047] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.390180] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.390307] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.390432] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.390561] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.390685] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.390861] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.390993] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
Your first line already revealed the problem.
There is no support for nano 4gb on nano 2gb carrier board.
Adjusted the gpio66 then the system was fully functional.
