My L4T version is 32.3.1, the current most updated. I am connecting 2 realsense cameras D435 to jetson nano USB 3.0 port. I turned on 1080p 30 fps color stream and 720p 30 fps for depth stream. I checked usb bandwidth with usbtop. Here’s the log.
Bus ID 0 (All USB buses) To device From device
Device ID 1 : 0.00 KiB/s 0.00 KiB/s
Device ID 2 : 0.00 KiB/s 0.00 KiB/s
Device ID 3 : 0.00 KiB/s 0.00 KiB/s
Device ID 4 : 3.30 KiB/s 3.29 KiB/s
Device ID 5 : 3.25 KiB/s 3.27 KiB/s
Bus ID 1 (USB bus number 1) To device From device
Device ID 4 : 0.00 KiB/s 0.00 KiB/s
Bus ID 2 (USB bus number 2) To device From device
Device ID 4 : 3.30 KiB/s 3.30 KiB/s
Device ID 5 : 3.25 KiB/s 3.25 KiB/s
I have checked the cameras with PC, the bandwidth always above 150000KiB/s for each camera.
I have followed this thread and it doesnt worked. I have changed the /sys/module/usbcore/parameters/autosuspend to -1 and /sys/module/usbcore/parameters/usbfs_memory_mb to 1024 successfully, but the bandwidth is still low.
Is there a way to overcome the limit, because this limit makes the camera sometimes lose frame.
I discovered that when I start the nano, there is an error in the kernel log. This is the output of dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2713) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Dec 9 22:47:42 PST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb1000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 console=ttys0,115200n8 usb_port_owner_info=2 usbcore.usbfs_memory_mb=1024 usbcore.autosuspend=-1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29300(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562224K/4159488K available (15230K kernel code, 2926K rwdata, 6620K rodata, 8576K init, 609K bss, 122128K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a11b808 ( 2927 KB)
[ 0.000000] .bss : 0xffffff800a11b808 - 0xffffff800a1b3dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001779] Console: colour dummy device 80x25
[ 0.002639] console [tty0] enabled
[ 0.002668] kmemleak: Kernel memory leak detector disabled
[ 0.002701] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.002731] pid_max: default: 32768 minimum: 301
[ 0.003193] Security Framework initialized
[ 0.003426] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003446] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004704] ftrace: allocating 47001 entries in 184 pages
[ 0.178052] sched-energy: CPU device node has no sched-energy-costs
[ 0.178089] ASID allocator initialised with 65536 entries
[ 0.215979] tegra-id: chipid=22117.
[ 0.216032] tegra-id: opt_subrevision=0.
[ 0.216061] Tegra Speedo/IDDQ fuse revision 4
[ 0.216076] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.216092] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.216107] Tegra: CPU Speedo Value 2057, SoC Speedo Value 1954, GPU Speedo Value 2052
[ 0.216129] Tegra: CPU IDDQ Value 1800, SoC IDDQ Value 1956, GPU IDDQ Value 2385
[ 0.216164] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.216190] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.216263] DTB Build time: Dec 9 2019 22:51:55
[ 0.265069] CPU1: Booted secondary processor [411fd071]
[ 0.297002] CPU2: Booted secondary processor [411fd071]
[ 0.328965] CPU3: Booted secondary processor [411fd071]
[ 0.329059] Brought up 4 CPUs
[ 0.329122] SMP: Total of 4 processors activated.
[ 0.329139] CPU features: detected feature: 32-bit EL0 Support
[ 0.329417] CPU: All CPU(s) started at EL2
[ 0.329451] alternatives: patching kernel code
[ 0.337836] devtmpfs: initialized
[ 0.376210] Initilizing CustomIPI irq domain
[ 0.376650] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.376696] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.388152] pinctrl core: initialized pinctrl subsystem
[ 0.388894] OS set in device tree is not L4T.
[ 0.389388] regulator-dummy: no parameters
[ 0.389689] Initializing plugin-manager
[ 0.389827] Plugin module not found
[ 0.390071] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.390646] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.391528] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.392532] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.397427] NET: Registered protocol family 16
[ 0.398805] pstore: using zlib compression
[ 0.399484] console [pstore-1] enabled
[ 0.399503] pstore: Registered ramoops as persistent store backend
[ 0.399522] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.409094] cpuidle: using governor menu
[ 0.413453] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.415158] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.415203] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.417645] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.420404] tegra_powergate_init: DONE
[ 0.420445] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.420483] DTB Build time: Dec 9 2019 22:51:55
[ 0.422392] Tegra reboot handler registered.
[ 0.426974] iommu: Adding device tegra-carveouts to group 0
[ 0.427152] platform tegra-carveouts: domain=ffffffc0f9b30e58 allocates as[0]=ffffffc0f9bcc0a8
[ 0.427539] iommu: Adding device smmu_test to group 1
[ 0.427600] platform smmu_test: domain=ffffffc0f9b400d8 allocates as[0]=ffffffc0f9bcc110
[ 0.428441] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.428525] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.428595] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.428621] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.428652] mc-err: mcerr ops are set to t21x
[ 0.438403] iommu: Adding device 70090000.xusb to group 2
[ 0.438719] iommu: Adding device 70006000.serial to group 3
[ 0.438794] platform 70006000.serial: domain=ffffffc0f9491798 allocates as[0]=ffffffc0f9bcc178
[ 0.439256] iommu: Adding device 70006040.serial to group 4
[ 0.439538] iommu: Adding device 70006200.serial to group 5
[ 0.439748] iommu: Adding device sound to group 6
[ 0.439813] platform sound: domain=ffffffc0f9491cd8 allocates as[0]=ffffffc0f9bcc1e0
[ 0.440386] iommu: Adding device 7000d400.spi to group 7
[ 0.440682] iommu: Adding device 7000d600.spi to group 8
[ 0.441027] iommu: Adding device 70410000.spi to group 9
[ 0.441368] iommu: Adding device 50000000.host1x to group 10
[ 0.441681] iommu: Adding device 54080000.vi to group 11
[ 0.442088] iommu: Adding device 54600000.isp to group 12
[ 0.442369] iommu: Adding device 54680000.isp to group 13
[ 0.442675] iommu: Adding device tegradc.0 to group 14
[ 0.442747] platform tegradc.0: domain=ffffffc0f949ec18 allocates as[0]=ffffffc0f9bcc248
[ 0.446957] platform tegradc.0: IOVA linear map 0x0000000092cb4000(800000)
[ 0.447370] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.447735] iommu: Adding device tegradc.1 to group 15
[ 0.447802] platform tegradc.1: domain=ffffffc0f949ee58 allocates as[0]=ffffffc0f9bcc2b0
[ 0.451985] platform tegradc.1: IOVA linear map 0x0000000092cb4000(800000)
[ 0.452393] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.452702] iommu: Adding device 54340000.vic to group 16
[ 0.452925] iommu: Adding device 544c0000.nvenc to group 17
[ 0.453156] iommu: Adding device 54500000.tsec to group 18
[ 0.453368] iommu: Adding device 54100000.tsecb to group 19
[ 0.453579] iommu: Adding device 54480000.nvdec to group 20
[ 0.453787] iommu: Adding device 54380000.nvjpg to group 21
[ 0.454848] iommu: Adding device 546c0000.i2c to group 22
[ 0.455199] iommu: Adding device 57000000.gpu to group 23
[ 0.455269] platform 57000000.gpu: domain=ffffffc0f9507e58 allocates as[0]=ffffffc0f9bcc318
[ 0.455349] platform 57000000.gpu: domain=ffffffc0f9507e58 allocates as[1]=ffffffc0f9bcc380
[ 0.455406] platform 57000000.gpu: domain=ffffffc0f9507e58 allocates as[2]=ffffffc0f9bcc3e8
[ 0.455463] platform 57000000.gpu: domain=ffffffc0f9507e58 allocates as[3]=ffffffc0f9bcc450
[ 0.456376] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.456416] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.456443] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.456463] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.456481] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.509206] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.509242] tegra-pmc: Clear bootloader IO dpd settings
[ 0.509278] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.509358] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.509673] iommu: Adding device 70012000.se to group 24
[ 0.510465] iommu: Adding device 7000c000.i2c to group 25
[ 0.510743] iommu: Adding device 7000c400.i2c to group 26
[ 0.511025] iommu: Adding device 7000c500.i2c to group 27
[ 0.511295] iommu: Adding device 7000c700.i2c to group 28
[ 0.511559] iommu: Adding device 7000d000.i2c to group 29
[ 0.511817] iommu: Adding device 7000d100.i2c to group 30
[ 0.512132] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.512213] platform sdhci-tegra.0: domain=ffffffc0f9589018 allocates as[0]=ffffffc0f9bcc4b8
[ 0.513134] iommu: Adding device 700d0000.xudc to group 32
[ 0.516329] vdd-ac-bat: 5000 mV
[ 0.516713] vdd-5v0-sys: 5000 mV
[ 0.517721] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.517788] vdd-5v0-hdmi: 5000 mV
[ 0.518227] vdd-1v8-sys: 1800 mV
[ 0.518705] vdd-fan: supplied by vdd-5v0-sys
[ 0.518756] vdd-fan: 5000 mV
[ 0.519152] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.519202] vdd-usb-vbus: 5000 mV
[ 0.519718] vdd-usb-vbus2: 5000 mV
[ 0.545947] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.548421] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.549600] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.549638] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.550012] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.558896] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.559280] SCSI subsystem initialized
[ 0.559530] libata version 3.00 loaded.
[ 0.559873] usbcore: registered new interface driver usbfs
[ 0.559946] usbcore: registered new interface driver hub
[ 0.560035] usbcore: registered new device driver usb
[ 0.563948] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.569101] vdd-core: 600 ↔ 1162 mV at 1075 mV
[ 0.569780] random: fast init done
[ 0.570129] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.573077] vdd-ddr-1v1: 1150 mV
[ 0.576319] vdd-pre-reg-1v35: 1350 mV
[ 0.580237] vdd-1v8: 1800 mV
[ 0.584236] avdd-sys-1v2: 1200 mV
[ 0.588237] vdd-pex-1v0: 1050 mV
[ 0.588902] vddio-sdmmc-ap: 1800 ↔ 3300 mV at 3300 mV
[ 0.589506] max77620-ldo3: at 3100 mV
[ 0.592238] vdd-rtc: 850 ↔ 1100 mV at 1000 mV
[ 0.592798] max77620-ldo5: at 3100 mV
[ 0.593361] max77620-ldo6: at 2800 mV
[ 0.596239] avdd-1v05-pll: 1050 mV
[ 0.600233] avdd-io-hdmi-dp: 1050 mV
[ 0.602958] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.603309] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.603623] max77620 4-003c: max77620 probe successful
[ 0.606471] media: Linux media interface: v0.10
[ 0.606550] Linux video capture interface: v2.00
[ 0.607480] pps_core: LinuxPPS API ver. 1 registered
[ 0.607506] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.607548] PTP clock support registered
[ 0.611152] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.617633] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.618544] Advanced Linux Sound Architecture Driver Initialized.
[ 0.619237] Bluetooth: Core ver 2.22
[ 0.619312] NET: Registered protocol family 31
[ 0.619331] Bluetooth: HCI device and connection manager initialized
[ 0.619360] Bluetooth: HCI socket layer initialized
[ 0.619382] Bluetooth: L2CAP socket layer initialized
[ 0.619424] Bluetooth: SCO socket layer initialized
[ 0.621249] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.621290] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.621351] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.621380] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.624770] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.626016] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.626133] vdd-3v3-sys: 3300 mV
[ 0.626444] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.629151] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.629635] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.629690] vdd-3v3-sd: 3300 mV
[ 0.630691] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.630751] avdd-io-edp-1v05: 1050 mV
[ 0.631231] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.631285] vdd-usb-hub-en: 5000 mV
[ 0.632764] camchar: rtcpu character device driver loaded
[ 0.633603] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.635039] clocksource: Switched to clocksource arch_sys_counter
[ 0.675484] VFS: Disk quotas dquot_6.6.0
[ 0.675662] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.676189] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.676659] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.676711] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.676930] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.676952] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.676979] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.677030] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.677058] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.677092] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.677115] nvmap_page_pool_init: Total RAM pages: 1009340
[ 0.677133] nvmap_page_pool_init: nvmap page pool size: 126167 pages (492 MB)
[ 0.677285] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.677699] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.678684] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.686973] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.687455] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.687729] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.687974] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.688167] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.688456] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.688476] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.688927] NET: Registered protocol family 2
[ 0.689934] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.690171] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.690719] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.690900] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.690999] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.691504] NET: Registered protocol family 1
[ 0.692322] RPC: Registered named UNIX socket transport module.
[ 0.692352] RPC: Registered udp transport module.
[ 0.692369] RPC: Registered tcp transport module.
[ 0.692387] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.692414] PCI: CLS 0 bytes, default 64
[ 0.692664] Trying to unpack rootfs image as initramfs…
[ 0.926745] Freeing initrd memory: 5356K
[ 0.936874] host1x 50000000.host1x: initialized
[ 0.938888] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.942287] audit: initializing netlink subsys (disabled)
[ 0.942408] audit: type=2000 audit(0.787:1): initialized
[ 0.943244] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.953363] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.954913] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.955800] 9p: Installing v9fs 9p2000 file system support
[ 0.959324] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.959500] io scheduler noop registered
[ 0.959818] io scheduler cfq registered (default)
[ 0.962545] gic 702f9000.agic: GIC IRQ controller registered
[ 0.965560] iommu: Adding device 702ef000.adsp to group 33
[ 0.974753] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.974934] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.975628] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9a08412
[ 0.975663] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.977361] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.977515] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.977633] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.977859] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.977974] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.978086] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.978196] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.978305] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.978430] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.978539] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.984811] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.986582] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.988577] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.989896] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.990265] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.991654] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.991905] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.992190] Adding domain tsec-pd to PM domain host1x-pd
[ 0.994434] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.995421] tsec 54500000.tsec: initialized
[ 0.996969] tsec 54100000.tsecb: initialized
[ 0.997672] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.001287] nvdec 54480000.nvdec: initialized
[ 1.002380] Adding domain vic03-pd to PM domain host1x-pd
[ 1.002577] Adding domain msenc-pd to PM domain host1x-pd
[ 1.002757] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.007043] falcon 54340000.vic: initialized
[ 1.008320] falcon 544c0000.nvenc: initialized
[ 1.009682] falcon 54380000.nvjpg: initialized
[ 1.014066] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.014149] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.014177] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.014222] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.014296] display board info: id 0x0, fab 0x0
[ 1.014371] generic_infoframe_type: 0x87
[ 1.014525] tegradc tegradc.0: DT parsed successfully
[ 1.014549] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.014573] tegra_cec 70015000.tegra_cec: probed
[ 1.014585] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 1.015191] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.018365] tegradc tegradc.0: probed
[ 1.024945] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.031755] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.032862] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.033245] kfuse 7000fc00.kfuse: initialized
[ 1.034853] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.036016] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.037652] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.037698] vdd-cpu: 708 ↔ 1322 mV at 708 mV
[ 1.038211] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.040051] vdd-gpu: applied init 1000000uV constraint
[ 1.040086] vdd-gpu: 708 ↔ 1323 mV at 997 mV
[ 1.040554] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.045387] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.045514] No Device Node present for smmu client: serial8250 !!
[ 1.045541] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.045607] iommu: Adding device serial8250 to group 35
[ 1.048016] console [ttyS0] disabled
[ 1.048116] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.517906] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.922343] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.047061] tegra_cec 70015000.tegra_cec: Can’t find physical addresse.
[ 2.047066] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.326669] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.328686] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.434865] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.434874] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.434879] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.434885] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.434891] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.434933] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.435080] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.435326] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.435484] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.435513] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.435546] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.435569] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.435722] pci 0000:01:00.0: supports D1 D2
[ 2.435726] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.447138] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.447185] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.447190] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.447204] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.447225] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.447243] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.447255] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.447261] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.447268] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.447665] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.447670] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.447677] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.447808] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.483042] console [ttyS0] enabled
[ 3.483648] Console: switching to colour frame buffer device 240x67
[ 3.484398] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.484783] serial-tegra 70006200.serial: RX in PIO mode
[ 3.484880] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.485948] [drm] Initialized
[ 3.509123] brd: module loaded
[ 3.522962] tegradc tegradc.0: fb registered
[ 3.523887] loop: module loaded
[ 3.523987] tegra_profiler: version: 1.139, samples/io: 47/27
[ 3.527126] tegra_profiler: auth: init
[ 3.528523] THERMAL EST: found 2 subdevs
[ 3.528529] THERMAL EST num_resources: 0
[ 3.528533] [THERMAL EST subdev 0]
[ 3.528540] [THERMAL EST subdev 1]
[ 3.529013] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.529016] THERMAL EST: thz register success.
[ 3.529192] THERMAL EST: end of probe, return err: 0
[ 3.530548] hisi_sas: driver version v1.6
[ 3.535070] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.536415] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.536431] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.545224] libphy: Fixed MDIO Bus: probed
[ 3.545824] tun: Universal TUN/TAP device driver, 1.6
[ 3.545826] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.548928] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.548931] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.548977] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.548979] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.549038] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.549040] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.549080] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.549083] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.554102] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 3.554132] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.568310] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 3.568487] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:cc:3e:cf from device tree
[ 3.569096] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.569145] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 3.569709] PPP generic driver version 2.4.2
[ 3.569932] PPP BSD Compression module registered
[ 3.569935] PPP Deflate Compression module registered
[ 3.569978] PPP MPPE Compression module registered
[ 3.569985] NET: Registered protocol family 24
[ 3.570060] usbcore: registered new interface driver r8152
[ 3.570109] usbcore: registered new interface driver asix
[ 3.570162] usbcore: registered new interface driver ax88179_178a
[ 3.570205] usbcore: registered new interface driver cdc_ether
[ 3.570251] usbcore: registered new interface driver net1080
[ 3.570340] usbcore: registered new interface driver cdc_subset
[ 3.570379] usbcore: registered new interface driver zaurus
[ 3.570441] usbcore: registered new interface driver cdc_ncm
[ 3.570621] VFIO - User Level meta-driver version: 0.3
[ 3.572110] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.572131] ehci-pci: EHCI PCI platform driver
[ 3.572180] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.572191] ohci-pci: OHCI PCI platform driver
[ 3.572236] ohci-platform: OHCI generic platform driver
[ 3.574939] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.575760] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.576964] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9bcb400 id
[ 3.579127] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 3.579207] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.579235] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 3.580015] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 3.580082] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 3.580341] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.580347] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.580351] usb usb1: Product: xHCI Host Controller
[ 3.580356] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.580359] usb usb1: SerialNumber: 70090000.xusb
[ 3.581051] hub 1-0:1.0: USB hub found
[ 3.581094] hub 1-0:1.0: 5 ports detected
[ 3.581662] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.581675] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 3.581751] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.581849] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.581854] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.581857] usb usb2: Product: xHCI Host Controller
[ 3.581861] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.581864] usb usb2: SerialNumber: 70090000.xusb
[ 3.582135] usbcore: registered new interface driver uas
[ 3.582236] usbcore: registered new interface driver usb-storage
[ 3.582356] usbcore: registered new interface driver usbserial
[ 3.585690] hub 2-0:1.0: USB hub found
[ 3.585730] hub 2-0:1.0: 4 ports detected
[ 3.586401] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.587737] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.587752] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 3.587780] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.588017] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.588665] mousedev: PS/2 mouse device common for all mice
[ 3.588773] usbcore: registered new interface driver xpad
[ 3.683130] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 3.836240] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.848054] rtc rtc1: alarm rtc device
[ 3.848072] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.848099] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.848743] i2c /dev entries driver
[ 3.850863] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.874446] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.874526] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.874556] imx219 6-0010: board setup failed
[ 3.874664] imx219: probe of 6-0010 failed with error -121
[ 3.879981] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.919056] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 3.928085] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.928089] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.928592] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.928608] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.928618] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.928748] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.928757] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.928763] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.928906] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.928917] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.928921] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.929094] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.929948] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.930004] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.930030] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.930047] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.930056] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.930885] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.930904] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 3.931131] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.931162] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 3.931549] parse_throttle_dt_data: Num cap clks = 6
[ 3.931555] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.931569] parse_throttle_dt_data: clk=gpu type=4
[ 3.931592] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.931611] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.931631] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.931634] parse_throttle_dt_data: clk=emc type=3
[ 3.932197] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.932302] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.932442] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.933305] FAN dev name: pwm-fan
[ 3.933404] FAN:gpio request success.
[ 3.933483] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.933802] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.933975] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.933987] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.934102] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.934107] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.934112] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.934116] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.934120] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.934123] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.934127] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.934131] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.934134] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.934138] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.935431] device-mapper: uevent: version 1.0.3
[ 3.936021] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.941753] tegra210-cpufreq cpufreq: probe()…completed
[ 3.942503] sdhci: Secure Digital Host Controller Interface driver
[ 3.942504] sdhci: Copyright(c) Pierre Ossman
[ 3.942506] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.942977] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.943342] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.943461] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.947925] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.948397] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.949721] usbcore: registered new interface driver usbhid
[ 3.949722] usbhid: USB HID core driver
[ 3.976230] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 3.976488] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.978203] nvpmodel: initialized successfully
[ 3.979234] usbcore: registered new interface driver snd-usb-audio
[ 3.979290] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.979294] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.979311] iommu: Adding device snd-soc-dummy to group 36
[ 3.991201] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.996437] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 3.996443] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.996446] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 3.996448] usb 1-2: Manufacturer: Generic
[ 4.008680] hub 1-2:1.0: USB hub found
[ 4.010388] OPE platform probe
[ 4.010474] OPE platform probe successful
[ 4.010802] OPE platform probe
[ 4.010884] OPE platform probe successful
[ 4.012413] hub 1-2:1.0: 4 ports detected
[ 4.036967] tegra-asoc: sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 4.037097] tegra-asoc: sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 4.037218] tegra-asoc: sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 4.037339] tegra-asoc: sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 4.037460] tegra-asoc: sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 4.037580] tegra-asoc: sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 4.037710] tegra-asoc: sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 4.037832] tegra-asoc: sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 4.037949] tegra-asoc: sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 4.038066] tegra-asoc: sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 4.049756] u32 classifier
[ 4.049758] Actions configured
[ 4.049830] Initializing XFRM netlink socket
[ 4.050550] NET: Registered protocol family 10
[ 4.051278] NET: Registered protocol family 17
[ 4.051289] NET: Registered protocol family 15
[ 4.051363] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.051409] Bluetooth: RFCOMM socket layer initialized
[ 4.051418] Bluetooth: RFCOMM ver 1.11
[ 4.051422] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.051426] Bluetooth: HIDP socket layer initialized
[ 4.051444] 9pnet: Installing 9P2000 support
[ 4.051478] Key type dns_resolver registered
[ 4.056112] Registered cp15_barrier emulation handler
[ 4.056252] Registered setend emulation handler
[ 4.057301] registered taskstats version 1
[ 4.057867] Adding domain ve2-pd to PM domain host1x-pd
[ 4.058106] Adding domain ve-pd to PM domain host1x-pd
[ 4.121475] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 4.797956] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 4.805235] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 4.813657] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 4.820835] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 4.853051] mmc0: hw tuning done …
[ 4.853596] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4.853597] Extcon AUX1(HDMI) enable
[ 4.854007] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 4.854044] tegradc tegradc.1: No lt-data, using default setting
[ 4.854056] tegradc tegradc.1: No hpd-gpio in DT
[ 4.854073] tegradc tegradc.1: DT parsed successfully
[ 4.854092] tegradc tegradc.1: Display dc.ffffff800d4c0000 registered with id=1
[ 4.854714] tegradc tegradc.1: dpd enable lookup fail:-19
[ 4.858777] tegradc tegradc.1: probed
[ 4.891784] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 4.914868] tegradc tegradc.1: fb registered
[ 4.914903] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 4.915253] mmcblk0: mmc0:aaaa SC128 119 GiB
[ 4.922982] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 4.939648] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 4.946789] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 4.947937] isp 54600000.isp: initialized
[ 4.948637] isp 54680000.isp: initialized
[ 4.958741] last reset is due to power on reset
[ 4.958744] KERNEL: PMC reset status reg: 0x0
[ 4.958815] BL: PMC reset status reg: 0x0
[ 4.958817] BL: PMIC poweroff Event Recorder: 0x40
[ 4.963574] clk_cbus_recalc_rate: no gbus parent
[ 4.963579] clk_cbus_round_rate: no gbus parent
[ 4.963580] clk_cbus_round_rate: no gbus parent
[ 4.963587] clk_cbus_recalc_rate: no gbus parent
[ 4.963686] clk_cbus_recalc_rate: no gbus parent
[ 4.963689] clk_cbus_round_rate: no gbus parent
[ 4.963690] clk_cbus_round_rate: no gbus parent
[ 4.963693] clk_cbus_recalc_rate: no gbus parent
[ 4.963706] tegra_dvfs: GPU-cap: registered
[ 4.963767] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.963769] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.963771] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.965125] tegra_dvfs: vdd-gpu-vts: registered
[ 4.965787] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 4.966374] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 4.966843] input: gpio-keys as /devices/gpio-keys/input/input1
[ 5.003661] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:23 UTC (946688423)
[ 5.004670] vi 54080000.vi: vi_probe: ++
[ 5.007973] vi 54080000.vi: initialized
[ 5.010178] vi 54080000.vi: subdev nvcsi–1 bound
[ 5.010430] mmcblk mmc0:aaaa: Card claimed for testing.
[ 5.011700] Disable partitions left on by BL
[ 5.011703] disb
[ 5.011747] bwmgr: missing cdev-type property
[ 5.011882] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.011887] DRAM derating cdev registered.
[ 5.012895] vdd-fan: disabling
[ 5.012897] vdd-usb-vbus: disabling
[ 5.012899] vdd-usb-vbus2: disabling
[ 5.012908] avdd-io-edp-1v05: disabling
[ 5.012993] ALSA device list:
[ 5.012995] #0: tegra-hda at 0x70038000 irq 83
[ 5.012997] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.152764] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 5.152775] tegradc tegradc.0: blank - powerdown
[ 5.199371] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 5.199373] Extcon AUX1(HDMI) disable
[ 5.227256] tegradc tegradc.0: unblank
[ 5.263610] tegradc tegradc.0: nominal-pclk:174500000 parent:174498750 div:1.0 pclk:174498750 172755000~190205000
[ 5.263657] tegradc tegradc.0: hdmi: tmds rate:174500K prod-setting:prod_c_hdmi_150m_300m
[ 5.264650] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 5.264655] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5.299377] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5.299378] Extcon AUX1(HDMI) enable
[ 5.299713] tegradc tegradc.0: sync windows ret = 250
[ 5.402206] tegradc tegradc.1: blank - powerdown
[ 5.408948] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 5.408950] Extcon DP: HPD disabled
[ 5.408952] hpd: hpd_switch 0
[ 5.408954] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 5.408963] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.408967] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.454920] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 5.454921] Extcon HDMI: HPD enabled
[ 5.454933] tegradc tegradc.0: hdmi: plugged
[ 5.478158] Freeing unused kernel memory: 8576K
[ 5.505492] Root device found: mmcblk0p1
[ 5.512552] Found dev node: /dev/mmcblk0p1
[ 5.578099] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.589182] Rootfs mounted over mmcblk0p1
[ 5.628206] Switching from initrd to actual rootfs
[ 5.850239] systemd[1]: System time before build time, advancing clock.
[ 5.892347] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.912064] cgroup: cgroup2: unknown option “nsdelegate”
[ 5.937785] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.964291] systemd[1]: Detected architecture arm64.
[ 6.014451] systemd[1]: Set hostname to .
[ 6.157240] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.176575] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.342293] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.352950] systemd[1]: Created slice System Slice.
[ 6.362895] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.372186] systemd[1]: Listening on Journal Socket.
[ 6.382267] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.391379] systemd[1]: Listening on Journal Audit Socket.
[ 6.403942] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.417225] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.495872] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.594652] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 6.842177] systemd-journald[1959]: Received request to flush runtime journal from PID 1
[ 7.509595] zram: Added device: zram0
[ 7.510333] zram: Added device: zram1
[ 7.510967] zram: Added device: zram2
[ 7.515915] zram: Added device: zram3
[ 7.768911] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 7.768917] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 7.778836] zram0: detected capacity change from 0 to 1037131776
[ 7.828292] using random self ethernet address
[ 7.834416] using random host ethernet address
[ 7.903192] random: crng init done
[ 7.908112] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.040165] Adding 1012820k swap on /dev/zram0. Priority:5 extents:1 across:1012820k SS
[ 8.050982] zram1: detected capacity change from 0 to 1037131776
[ 8.063508] Adding 1012820k swap on /dev/zram1. Priority:5 extents:1 across:1012820k SS
[ 8.069304] zram2: detected capacity change from 0 to 1037131776
[ 8.082215] Adding 1012820k swap on /dev/zram2. Priority:5 extents:1 across:1012820k SS
[ 8.086426] zram3: detected capacity change from 0 to 1037131776
[ 8.099179] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 8.121103] Adding 1012820k swap on /dev/zram3. Priority:5 extents:1 across:1012820k SS
[ 8.134260] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 8.134267] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.134271] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 8.134274] usb 2-1: Manufacturer: Generic
[ 8.141004] hub 2-1:1.0: USB hub found
[ 8.142546] hub 2-1:1.0: 4 ports detected
[ 8.635860] Mass Storage Function, version: 2009/09/11
[ 8.635866] LUN: removable file: (no medium)
[ 8.646102] using random self ethernet address
[ 8.666543] using random host ethernet address
[ 8.801762] rndis0: HOST MAC 8e:e4:ce:62:af:f4
[ 8.801977] rndis0: MAC 8e:e4:ce:62:af:f5
[ 8.808354] usb0: HOST MAC 8e:e4:ce:62:af:f6
[ 8.808388] usb0: MAC 8e:e4:ce:62:af:f7
[ 8.808408] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 8.809266] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 8.809283] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.809315] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 8.809578] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 8.809596] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 8.810142] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 8.810160] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 8.810376] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 8.820877] l4tbr0: port 1(rndis0) entered blocking state
[ 8.820881] l4tbr0: port 1(rndis0) entered disabled state
[ 8.821073] device rndis0 entered promiscuous mode
[ 8.829124] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 8.842999] l4tbr0: port 2(usb0) entered blocking state
[ 8.843002] l4tbr0: port 2(usb0) entered disabled state
[ 8.843733] device usb0 entered promiscuous mode
[ 8.859177] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 9.847387] zram: Cannot change disksize for initialized device
[ 9.864720] zram: Cannot change disksize for initialized device
[ 9.877760] zram: Cannot change disksize for initialized device
[ 9.888939] zram: Cannot change disksize for initialized device
[ 10.194403] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.196160] eth0: 0xffffff800a39e000, 00:04:4b:cc:3e:cf, IRQ 406
[ 10.248506] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.114046] Bridge firewalling registered
[ 12.197239] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 12.583710] tegradc tegradc.0: blank - powerdown
[ 12.627745] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 12.627749] Extcon AUX1(HDMI) disable
[ 12.644801] tegradc tegradc.0: unblank
[ 12.655623] tegradc tegradc.0: nominal-pclk:174500000 parent:174498750 div:1.0 pclk:174498750 172755000~190205000
[ 12.655754] tegradc tegradc.0: hdmi: tmds rate:174500K prod-setting:prod_c_hdmi_150m_300m
[ 12.656832] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 12.656841] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 12.691843] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 12.691846] Extcon AUX1(HDMI) enable
[ 12.697872] tegradc tegradc.0: unblank
[ 12.697882] tegradc tegradc.1: blank - powerdown
[ 12.706965] Netfilter messages via NETLINK v0.30.
[ 12.709567] ctnetlink v0.93: registering with nfnetlink.
[ 12.901951] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 43.751320] usb 1-2.2: new low-speed USB device number 3 using tegra-xusb
[ 43.781986] usb 1-2.2: New USB device found, idVendor=1a2c, idProduct=4b44
[ 43.782037] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 43.782074] usb 1-2.2: Product: USB Keyboard
[ 43.782109] usb 1-2.2: Manufacturer: SEMICO
[ 43.795607] input: SEMICO USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.0/0003:1A2C:4B44.0001/input/input2
[ 43.859363] hid-generic 0003:1A2C:4B44.0001: input,hidraw0: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-70090000.xusb-2.2/input0
[ 43.862972] input: SEMICO USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.1/0003:1A2C:4B44.0002/input/input3
[ 43.920672] hid-generic 0003:1A2C:4B44.0002: input,hidraw1: USB HID v1.10 Device [SEMICO USB Keyboard] on usb-70090000.xusb-2.2/input1
[ 48.103580] usb 1-2.1: new low-speed USB device number 4 using tegra-xusb
[ 48.132342] usb 1-2.1: New USB device found, idVendor=1bcf, idProduct=0880
[ 48.132394] usb 1-2.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 48.132432] usb 1-2.1: Product: USB Optical Mouse
[ 48.147583] input: USB Optical Mouse as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:1BCF:0880.0003/input/input4
[ 48.211042] hid-generic 0003:1BCF:0880.0003: input,hidraw2: USB HID v1.10 Keyboard [USB Optical Mouse ] on usb-70090000.xusb-2.1/input0
[ 56.131397] tegradc tegradc.0: blank - powerdown
[ 56.180438] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 56.180440] Extcon AUX1(HDMI) disable
[ 56.197130] tegradc tegradc.1: blank - powerdown
[ 56.327473] tegradc tegradc.0: blank - powerdown
[ 56.327495] tegradc tegradc.0: unblank
[ 56.332320] tegradc tegradc.0: nominal-pclk:174500000 parent:174498750 div:1.0 pclk:174498750 172755000~190205000
[ 56.332407] tegradc tegradc.0: hdmi: tmds rate:174500K prod-setting:prod_c_hdmi_150m_300m
[ 56.333432] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 56.333439] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 56.368549] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 56.368551] Extcon AUX1(HDMI) enable
[ 56.374899] tegradc tegradc.0: unblank
[ 56.374908] tegradc tegradc.1: blank - powerdown
[ 59.378297] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 59.378309] Bluetooth: BNEP socket layer initialized
[ 59.726928] fuse init (API version 7.26)
[ 59.977214] tegradc tegradc.0: unblank
[ 59.977224] tegradc tegradc.1: blank - powerdown
[ 180.021060] usb 2-1.4: new SuperSpeed USB device number 3 using tegra-xusb
[ 180.048469] usb 2-1.4: New USB device found, idVendor=8086, idProduct=0b07
[ 180.048534] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 180.048582] usb 2-1.4: Product: Intel(R) RealSense™ Depth Camera 435
[ 180.048626] usb 2-1.4: Manufacturer: Intel(R) RealSense™ Depth Camera 435
[ 180.048669] usb 2-1.4: SerialNumber: 816513021771
[ 180.095375] uvcvideo: Unknown video format 00000050-0000-0010-8000-00aa00389b71
[ 180.095403] uvcvideo: Unknown video format 00000032-0000-0010-8000-00aa00389b71
[ 180.095587] uvcvideo: Found UVC 1.50 device Intel(R) RealSense™ Depth Camera 435 (8086:0b07)
[ 180.098780] uvcvideo: Unable to create debugfs 2-3 directory.
[ 180.099171] uvcvideo 2-1.4:1.0: Entity type for entity Intel(R) RealSense™ Depth Ca was not initialized!
[ 180.109044] uvcvideo 2-1.4:1.0: Entity type for entity Processing 2 was not initialized!
[ 180.117206] uvcvideo 2-1.4:1.0: Entity type for entity Camera 1 was not initialized!
[ 180.125249] input: Intel(R) RealSense™ Depth Ca as /devices/70090000.xusb/usb2/2-1/2-1.4/2-1.4:1.0/input/input5
[ 180.125472] uvcvideo: Unknown video format 36315752-1a66-a242-9065-d01814a8ef8a
[ 180.125482] uvcvideo: Found UVC 1.50 device Intel(R) RealSense™ Depth Camera 435 (8086:0b07)
[ 180.126385] uvcvideo: Unable to create debugfs 2-3 directory.
[ 180.126518] uvcvideo 2-1.4:1.3: Entity type for entity Processing 7 was not initialized!
[ 180.134889] uvcvideo 2-1.4:1.3: Entity type for entity Extension 8 was not initialized!
[ 180.142927] uvcvideo 2-1.4:1.3: Entity type for entity Camera 6 was not initialized!
[ 180.150912] usbcore: registered new interface driver uvcvideo
[ 180.150915] USB Video Class driver (1.1.1)
[ 185.764291] usb 2-1.3: new SuperSpeed USB device number 4 using tegra-xusb
[ 185.787408] usb 2-1.3: New USB device found, idVendor=8086, idProduct=0b07
[ 185.787474] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 185.787522] usb 2-1.3: Product: Intel(R) RealSense™ Depth Camera 435
[ 185.787566] usb 2-1.3: Manufacturer: Intel(R) RealSense™ Depth Camera 435
[ 185.787608] usb 2-1.3: SerialNumber: 812113020492
[ 185.792424] uvcvideo: Unknown video format 00000050-0000-0010-8000-00aa00389b71
[ 185.792434] uvcvideo: Unknown video format 00000032-0000-0010-8000-00aa00389b71
[ 185.792557] uvcvideo: Found UVC 1.50 device Intel(R) RealSense™ Depth Camera 435 (8086:0b07)
[ 185.794439] uvcvideo: Unable to create debugfs 2-4 directory.
[ 185.794696] uvcvideo 2-1.3:1.0: Entity type for entity Intel(R) RealSense™ Depth Ca was not initialized!
[ 185.804656] uvcvideo 2-1.3:1.0: Entity type for entity Processing 2 was not initialized!
[ 185.813067] uvcvideo 2-1.3:1.0: Entity type for entity Camera 1 was not initialized!
[ 185.821382] input: Intel(R) RealSense™ Depth Ca as /devices/70090000.xusb/usb2/2-1/2-1.3/2-1.3:1.0/input/input6
[ 185.822344] uvcvideo: Unknown video format 36315752-1a66-a242-9065-d01814a8ef8a
[ 185.822354] uvcvideo: Found UVC 1.50 device Intel(R) RealSense™ Depth Camera 435 (8086:0b07)
[ 185.823287] uvcvideo: Unable to create debugfs 2-4 directory.
[ 185.823467] uvcvideo 2-1.3:1.3: Entity type for entity Processing 7 was not initialized!
[ 185.831654] uvcvideo 2-1.3:1.3: Entity type for entity Extension 8 was not initialized!
[ 185.839978] uvcvideo 2-1.3:1.3: Entity type for entity Camera 6 was not initialized!
