hi sorry to my english level
i tried connect more than two usb camera but program is not running.
i found same issue’s topic
https://devtalk.nvidia.com/default/topic/1058334/deepstream-sdk/deepstream4-jetson-nano-multiple-webcams-issue/post/5390583/#5390583
and followed DaneLLL’s solution but Issue is not cleared.
program operates normally when the two cameras are connected.
my system :
Jetson Nano Dev kit
Deepstream 4.0.1 (deepstream-app) sample app
modified configfile(DaneLLL’s Solution)
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=960
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=0
[source1]
enable=1
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=1
[source2]
enable=1
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=2
[source3]
enable=0
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=3
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=5
sync=0
display-id=0
offset-x=0
offset-y=0
width=0
height=0
overlay-id=1
source-id=0
[osd]
enable=1
border-width=2
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[streammux]
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=640
height=480
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
model-engine-file=../../models/Primary_Detector_Nano/resnet10.caffemodel_b4_fp16.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=4
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
config-file=config_infer_primary_nano.txt
[tests]
file-loop=0
message log :
usb1-2.4 : Not enough bandwidth for new device state.
ERROR from src_elem: Failed to allocate required memory
Buffer pool activation failed
ERROR from src_elem: Internal data stream error.
streaming stopped, reason not-negotiated (-4)
Quitting
App run failed
Please share brand and model ID of your USB cameras, and information of executing ‘$ v4l2-ctl -d /dev/videoX --list-formats-ext’.
We have verified four 640x480p30 v4l2 sources. One possible cause of the failure is that we use different cameras. Let’s see if we can get more clues on this.
here is my Usb Cameras information
-Camera Model
Logitec C525
https://www.amazon.com/Logitech-Webcam-Portable-Calling-Autofocus/dp/B004WO8HQ4/ref=sr_1_1?keywords=c525&qid=1575522782&s=electronics&sr=1-1
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1792x1008
Size: Discrete 1920x1080
Index : 1
Pixel Format: 'MJPG' (compressed)
ELP 1megapixel Day Night Vision USB CAMERA
https://www.amazon.com/ELP-1megapixel-Vandal-proof-Industrial-Security-cctv/dp/B00VFLWOC0
Index : 0
Index : 1
Microsoft HD-5000 USB CAM
https://www.amazon.com/Microsoft-LifeCam-HD-5000-720p-Webcam/dp/B002XN7C6W/ref=sr_1_1?keywords=Microsoft+HD-5000&qid=1575522856&sr=8-1
Index : 0
Index : 1
Custom USB Camera (No brand)
Index : 0
Index : 1
Please execute ‘sudo jetson_clocks’ and check if you can run four previews:
$ gst-launch-1.0 v4l2src device=/dev/videoX ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! nveglglessink
Hi DaneLLL
i’ve worked according to your solution.
-Do-
sudo jetson_clocks
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! nveglglessink
gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! nveglglessink
gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! nveglglessink
gst-launch-1.0 v4l2src device=/dev/video3 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! nveglglessink
It didn’t work in console(CLI) mode.
In GUI mode, camera images were normally played on pop-up windows.
What should I check?
Do you mean you can see four camera previews in running:
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! nveglglessink & \
gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! nveglglessink & \
gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! nveglglessink & \
gst-launch-1.0 v4l2src device=/dev/video3 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! nveglglessink &
Hi DaneLLL
root@yih-nano:/# sudo jetson_clocks
root@yih-nano:/# gst-launch-1.0 v4l2src device= /dev/video0 ! video/x-raw, format=YUY2, width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM), format=NV12' ! nvvidconv ! nveglglessink & \
> gst-launch-1.0 v4l2src device= /dev/video1 ! video/x-raw, format=YUY2, width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM), format=NV12' ! nvvidconv ! nveglglessink & \
> gst-launch-1.0 v4l2src device= /dev/video2 ! video/x-raw, format=YUY2, width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM), format=NV12' ! nvvidconv ! nveglglessink & \
> gst-launch-1.0 v4l2src device= /dev/video3 ! video/x-raw, format=YUY2, width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM), format=NV12' ! nvvidconv ! nveglglessink &
[1] 1355
[2] 1356
[3] 1357
[4] 1358
root@yih-nano:/# Setting pipeline to PAUSED ...
Using winsys: x11
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Using winsys: x11
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Using winsys: x11
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
Additional debug info:
gstv4l2src.c(658): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Execution ended after 0:00:00.332423768
Setting pipeline to READY ...
Setting pipeline to NULL ...
Execution ended after 0:00:00.322664770
Freeing pipeline ...
Two cameras ran normally but other two cameras errors occurred
Please check if cleaning cache helps:
$ rm .cache/gstreamer-1.0/registry.aarch64.bin
For information, do you install all packages( system image+DS4.0.1+CUDA+… ) through sdkmanager?
Hi DaneLLL
i tried
sudo jetson_clocks
The same issue has occurred and has not been cleared
<=For information, do you install all packages( system image+DS4.0.1+CUDA+… ) through sdkmanager?
I installed ‘JetPack’ on Micro SD Card
and Updated the Deepstream SDK version to 4.0 → 4.0.1
DaneLLL
December 9, 2019, 5:50am
10
Do you have other USB cameras for a try? Probably it is specific to certain cameras. Or try lower 320x240
We have four cameras running 640x480p30 and no issue is seen. It is supposed to work fine.
Okay. I’ll try.
Can you recommend cameras?
USB Webcam type
Hi DaneLLL
i did buy the four usb2.0 VGA cams (640x480) for bandwidth limit test
as before,i did test used gst-launch, and result is same even though when i set 640x480 resolution & 10/1 framerate.
the calculated value is under 0.1M bps in my option’s (640x480 four camera, 10/1 framerate)
this value is far short of bandwidth.
i think sdk has another problem in use 2.0 usb webcam (If : locked more than two ???)
error message from deepstream sdk.
Quitting
App run failed
it’s same before
I may use usb3.0, but I asked again because I thought this problem was not just a matter of bandwidth.
DaneLLL
February 20, 2020, 2:11am
14
We have clarified it is an issue in insufficient bandwidth. Even though you run in 640x480 10fps, The driver may still run in 30fps.
Thanks for your quick answer
What you’re saying is camera’s just sending fixed specification data, and gst-launch options are post-processing?
If that is so, I can understand !
dweom
November 26, 2020, 2:11am
16
I have same problem with jchcdev.
I tested 4 usb 3.0 cameras connected to USB 3.0 hub (with external power)
but it failed with same error as follows, (It worked well with 2 usb cameras)
kayccc
November 30, 2020, 8:02am
17
Hi dweom ,
Please help to open a new topic for your issue. Thanks
Hi @dweom :
Did it work? Did you followed this on another thread?
I’m about to buy 3 usb 3.0 cameras and I need them to work with AGX (or even NX).
Thanks a lot!
