And I tried to set to 320x240 of each web cam, but it stuck also…
python3 cam4.py --input-width=320 --input-height=240
import jetson.inference
import jetson.utils
import sys
net = jetson.inference.detectNet("ssd-mobilenet-v2", threshold=0.5)
argv="--input-width=320 --input-height=240"
camera0 = jetson.utils.videoSource("/dev/video0", argv=sys.argv)
camera1 = jetson.utils.videoSource("/dev/video1", argv=sys.argv)
camera2 = jetson.utils.videoSource("/dev/video2", argv=sys.argv)
camera3 = jetson.utils.videoSource("/dev/video3", argv=sys.argv)
display = jetson.utils.videoOutput("display://0") # 'my_video.mp4' for file
i = 0
while display.IsStreaming():
if(i==0):
img = camera0.Capture()
elif(i==1):
img = camera1.Capture()
elif(i==2):
img = camera2.Capture()
elif(i==3):
img = camera3.Capture()
if(i>=3):
i = 0
else:
i=i+1
detections = net.Detect(img)
display.Render(img)
display.SetStatus("Object Detection | Network {:.0f} FPS".format(net.GetNetworkFPS()))
jetson.inference -- detectNet loading build-in network 'ssd-mobilenet-v2'
detectNet -- loading detection network model from:
-- model networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
-- input_blob 'Input'
-- output_blob 'NMS'
-- output_count 'NMS_1'
-- class_labels networks/SSD-Mobilenet-v2/ssd_coco_labels.txt
-- threshold 0.500000
-- batch_size 1
[TRT] TensorRT version 8.0.1
[TRT] loading NVIDIA plugins...
[TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[TRT] Registered plugin creator - ::GridAnchorRect_TRT version 1
[TRT] Registered plugin creator - ::NMS_TRT version 1
[TRT] Registered plugin creator - ::Reorg_TRT version 1
[TRT] Registered plugin creator - ::Region_TRT version 1
[TRT] Registered plugin creator - ::Clip_TRT version 1
[TRT] Registered plugin creator - ::LReLU_TRT version 1
[TRT] Registered plugin creator - ::PriorBox_TRT version 1
[TRT] Registered plugin creator - ::Normalize_TRT version 1
[TRT] Registered plugin creator - ::ScatterND version 1
[TRT] Registered plugin creator - ::RPROI_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
[TRT] Registered plugin creator - ::CropAndResize version 1
[TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT] Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[TRT] Registered plugin creator - ::EfficientNMS_TRT version 1
[TRT] Registered plugin creator - ::Proposal version 1
[TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT] Registered plugin creator - ::Split version 1
[TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT] detected model format - UFF (extension '.uff')
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] [MemUsageChange] Init CUDA: CPU +203, GPU +0, now: CPU 227, GPU 3475 (MiB)
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.8001.GPU.FP16.engine
[TRT] loading network plan from engine cache... /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.8001.GPU.FP16.engine
[TRT] device GPU, loaded /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
[TRT] [MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 261, GPU 3509 (MiB)
[TRT] Loaded engine size: 34 MB
[TRT] [MemUsageSnapshot] deserializeCudaEngine begin: CPU 261 MiB, GPU 3509 MiB
[TRT] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[TRT] Using cublas a tactic source
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +158, GPU +163, now: CPU 437, GPU 3691 (MiB)
[TRT] Using cuDNN as a tactic source
[TRT] [MemUsageChange] Init cuDNN: CPU +241, GPU +184, now: CPU 678, GPU 3875 (MiB)
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU -1, now: CPU 678, GPU 3875 (MiB)
[TRT] Deserialization required 2864618 microseconds.
[TRT] [MemUsageSnapshot] deserializeCudaEngine end: CPU 678 MiB, GPU 3875 MiB
[TRT] [MemUsageSnapshot] ExecutionContext creation begin: CPU 678 MiB, GPU 3875 MiB
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 678, GPU 3875 (MiB)
[TRT] [MemUsageChange] Init cuDNN: CPU +0, GPU +0, now: CPU 678, GPU 3875 (MiB)
[TRT] Total per-runner device memory is 22661632
[TRT] Total per-runner host memory is 124640
[TRT] Allocated activation device memory of size 14270976
[TRT] [MemUsageSnapshot] ExecutionContext creation end: CPU 680 MiB, GPU 3882 MiB
[TRT]
[TRT] CUDA engine context initialized on device GPU:
[TRT] -- layers 119
[TRT] -- maxBatchSize 1
[TRT] -- deviceMemory 14270976
[TRT] -- bindings 3
[TRT] binding 0
-- index 0
-- name 'Input'
-- type FP32
-- in/out INPUT
-- # dims 3
-- dim #0 3
-- dim #1 300
-- dim #2 300
[TRT] binding 1
-- index 1
-- name 'NMS'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 1
-- dim #1 100
-- dim #2 7
[TRT] binding 2
-- index 2
-- name 'NMS_1'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 1
-- dim #1 1
-- dim #2 1
[TRT]
[TRT] binding to input 0 Input binding index: 0
[TRT] binding to input 0 Input dims (b=1 c=3 h=300 w=300) size=1080000
[TRT] binding to output 0 NMS binding index: 1
[TRT] binding to output 0 NMS dims (b=1 c=1 h=100 w=7) size=2800
[TRT] binding to output 1 NMS_1 binding index: 2
[TRT] binding to output 1 NMS_1 dims (b=1 c=1 h=1 w=1) size=4
[TRT]
[TRT] device GPU, /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff initialized.
[TRT] W = 7 H = 100 C = 1
[TRT] detectNet -- maximum bounding boxes: 100
[TRT] detectNet -- loaded 91 class info entries
[TRT] detectNet -- number of object classes: 91
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstCamera -- attempting to create device v4l2:///dev/video0
[gstreamer] gstCamera -- found v4l2 device: USB2.0-Camera
[gstreamer] v4l2-proplist, device.path=(string)/dev/video3, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)USB2.0-Camera, v4l2.device.bus_info=(string)usb-70090000.xusb-2.2.4, v4l2.device.version=(uint)264701, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] gstCamera -- found v4l2 device: SPCA2650 PC Camera
[gstreamer] v4l2-proplist, device.path=(string)/dev/video2, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)"SPCA2650\ PC\ Camera", v4l2.device.bus_info=(string)usb-70090000.xusb-2.2.3, v4l2.device.version=(uint)264701, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] v4l2-proplist, device.path=(string)/dev/video1, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)USB2.0-Camera, v4l2.device.bus_info=(string)usb-70090000.xusb-2.2.2, v4l2.device.version=(uint)264701, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] gstCamera -- found v4l2 device: HD Camera
[gstreamer] v4l2-proplist, device.path=(string)/dev/video0, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)"HD\ Camera", v4l2.device.bus_info=(string)usb-70090000.xusb-2.2.1, v4l2.device.version=(uint)264701, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] gstCamera -- found 12 caps for v4l2 device /dev/video0
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)1024, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)5/1;
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)5/1;
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)5/1;
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 25/1, 20/1, 15/1, 10/1 };
[gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 25/1, 20/1, 15/1, 10/1 };
[gstreamer] [5] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 25/1, 20/1, 15/1, 10/1 };
[gstreamer] [6] image/jpeg, width=(int)1280, height=(int)1024, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1 };
[gstreamer] [7] image/jpeg, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1 };
[gstreamer] [8] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1 };
[gstreamer] [9] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1 };
[gstreamer] [10] image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1 };
[gstreamer] [11] image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1 };
[gstreamer] gstCamera -- selected device profile: codec=mjpeg format=unknown width=320 height=240
[gstreamer] gstCamera pipeline string:
[gstreamer] v4l2src device=/dev/video0 do-timestamp=true ! image/jpeg, width=(int)320, height=(int)240 ! jpegdec ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully created device v4l2:///dev/video0
[video] created gstCamera from v4l2:///dev/video0
gstCamera video options:
-- URI: v4l2:///dev/video0
- protocol: v4l2
-- deviceType: v4l2
-- ioType: input
-- codec: mjpeg
-- width: 320
-- height: 240
-- frameRate: 30.000000
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
[gstreamer] gstCamera -- attempting to create device v4l2:///dev/video1
[gstreamer] gstCamera -- found 8 caps for v4l2 device /dev/video1
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)5/1;
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)712, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)15/1;
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1;
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)472, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1;
[gstreamer] [4] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)15/1;
[gstreamer] [5] image/jpeg, width=(int)1280, height=(int)712, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)15/1;
[gstreamer] [6] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1;
[gstreamer] [7] image/jpeg, width=(int)640, height=(int)472, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1;
[gstreamer] gstCamera -- selected device profile: codec=raw format=yuyv width=640 height=472
[gstreamer] v4l2src device=/dev/video1 do-timestamp=true ! video/x-raw, format=(string)YUY2, width=(int)640, height=(int)472 ! appsink name=mysink
[gstreamer] gstCamera successfully created device v4l2:///dev/video1
[video] created gstCamera from v4l2:///dev/video1
-- URI: v4l2:///dev/video1
- protocol: v4l2
- port: 1
-- deviceType: v4l2
-- ioType: input
-- codec: raw
-- width: 640
-- height: 472
-- frameRate: 20.000000
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
[gstreamer] gstCamera -- attempting to create device v4l2:///dev/video2
[gstreamer] gstCamera -- found 10 caps for v4l2 device /dev/video2
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1;
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)712, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1;
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1;
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)472, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [5] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)15/1;
[gstreamer] [6] image/jpeg, width=(int)1280, height=(int)712, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)15/1;
[gstreamer] [7] image/jpeg, width=(int)1280, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1;
[gstreamer] [8] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [9] image/jpeg, width=(int)640, height=(int)472, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] v4l2src device=/dev/video2 do-timestamp=true ! video/x-raw, format=(string)YUY2, width=(int)640, height=(int)472 ! appsink name=mysink
[gstreamer] gstCamera successfully created device v4l2:///dev/video2
[video] created gstCamera from v4l2:///dev/video2
-- URI: v4l2:///dev/video2
- protocol: v4l2
- port: 2
-- deviceType: v4l2
-- ioType: input
-- codec: raw
-- width: 640
-- height: 472
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
[gstreamer] gstCamera -- attempting to create device v4l2:///dev/video3
[gstreamer] gstCamera -- found 8 caps for v4l2 device /dev/video3
[gstreamer] v4l2src device=/dev/video3 do-timestamp=true ! video/x-raw, format=(string)YUY2, width=(int)640, height=(int)472 ! appsink name=mysink
[gstreamer] gstCamera successfully created device v4l2:///dev/video3
[video] created gstCamera from v4l2:///dev/video3
-- URI: v4l2:///dev/video3
- protocol: v4l2
- port: 3
-- deviceType: v4l2
-- ioType: input
-- codec: raw
-- width: 640
-- height: 472
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
[OpenGL] glDisplay -- X screen 0 resolution: 1920x1080
[OpenGL] glDisplay -- X window resolution: 1920x1080
[OpenGL] glDisplay -- display device initialized (1920x1080)
[video] created glDisplay from display://0
glDisplay video options:
-- URI: display://0
- protocol: display
-- deviceType: display
-- ioType: output
-- codec: raw
-- width: 1920
-- height: 1080
-- frameRate: 0.000000
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> jpegdec0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> jpegdec0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer message stream-start ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> jpegdec0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstCamera -- onPreroll
[gstreamer] gstBufferManager -- map buffer size was less than max size (115200 vs 115207)
[gstreamer] gstBufferManager recieve caps: video/x-raw, format=(string)I420, width=(int)320, height=(int)240, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)jpeg, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
[gstreamer] gstBufferManager -- recieved first frame, codec=mjpeg format=i420 width=320 height=240 size=115207
RingBuffer -- allocated 4 buffers (115207 bytes each, 460828 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
RingBuffer -- allocated 4 buffers (230400 bytes each, 921600 bytes total)
[OpenGL] glDisplay -- set the window size to 320x240
[OpenGL] creating 320x240 texture (GL_RGB8 format, 230400 bytes)
[cuda] registered openGL texture for interop access (320x240, GL_RGB8, 230400 bytes)
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter2
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src1
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline1
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter2
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src1
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline1
[gstreamer] gstreamer message new-clock ==> pipeline1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter2
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src1
[gstreamer] gstreamer message stream-start ==> pipeline1
[gstreamer] gstBufferManager recieve caps: video/x-raw, format=(string)YUY2, width=(int)640, height=(int)472, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
[gstreamer] gstBufferManager -- recieved first frame, codec=raw format=yuyv width=640 height=472 size=604160
RingBuffer -- allocated 4 buffers (604160 bytes each, 2416640 bytes total)
[gstreamer] gstreamer message async-done ==> pipeline1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline1
RingBuffer -- allocated 4 buffers (906240 bytes each, 3624960 bytes total)
[OpenGL] glDisplay -- set the window size to 640x472
[OpenGL] creating 640x472 texture (GL_RGB8 format, 906240 bytes)
[cuda] registered openGL texture for interop access (640x472, GL_RGB8, 906240 bytes)
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter3
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src2
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline2
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter3
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src2
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline2
[gstreamer] gstreamer message new-clock ==> pipeline2
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter3
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src2
[gstreamer] gstreamer message stream-start ==> pipeline2
[gstreamer] gstCamera -- end of stream (EOS)
[gstreamer] gstreamer v4l2src2 ERROR Failed to allocate required memory.
[gstreamer] gstreamer Debugging info: gstv4l2src.c(658): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline2/GstV4l2Src:v4l2src2:
Buffer pool activation failed
[gstreamer] gstreamer v4l2src2 ERROR Internal data stream error.
[gstreamer] gstreamer Debugging info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline2/GstV4l2Src:v4l2src2:
streaming stopped, reason not-negotiated (-4)
