Hi all,
I’m trying how to use a 5.8G UVC USB receiver with Jetson NANO.
In particular I’m interested to redirect the 640x480 video received to the “detectnet-camera.py”.
Using a USB-CAM or a CSI-CAM everything works fine.
While running the detectnet-camera-py when the 5.8G UVC Receiver is connected to the USB here is what happened:
./detectnet-camera.py --camera=/dev/video0
jetson.inference.init.py
jetson.inference – initializing Python 2.7 bindings…
jetson.inference – registering module types…
jetson.inference – done registering module types
jetson.inference – done Python 2.7 binding initialization
jetson.utils.init.py
jetson.utils – initializing Python 2.7 bindings…
jetson.utils – registering module functions…
jetson.utils – done registering module functions
jetson.utils – registering module types…
jetson.utils – done registering module types
jetson.utils – done Python 2.7 binding initialization
jetson.inference – PyTensorNet_New()
jetson.inference – PyDetectNet_Init()
jetson.inference – detectNet loading build-in network ‘pednet’
detectNet – loading detection network model from:
– prototxt networks/ped-100/deploy.prototxt
– model networks/ped-100/snapshot_iter_70800.caffemodel
– input_blob ‘data’
– output_cvg ‘coverage’
– output_bbox ‘bboxes’
– mean_pixel 0.000000
– mean_binary NULL
– class_labels networks/ped-100/class_labels.txt
– threshold 0.500000
– batch_size 1
[TRT] TensorRT version 5.1.6
[TRT] loading NVIDIA plugins…
[TRT] Plugin Creator registration succeeded - GridAnchor_TRT
[TRT] Plugin Creator registration succeeded - NMS_TRT
[TRT] Plugin Creator registration succeeded - Reorg_TRT
[TRT] Plugin Creator registration succeeded - Region_TRT
[TRT] Plugin Creator registration succeeded - Clip_TRT
[TRT] Plugin Creator registration succeeded - LReLU_TRT
[TRT] Plugin Creator registration succeeded - PriorBox_TRT
[TRT] Plugin Creator registration succeeded - Normalize_TRT
[TRT] Plugin Creator registration succeeded - RPROI_TRT
[TRT] Plugin Creator registration succeeded - BatchedNMS_TRT
[TRT] completed loading NVIDIA plugins.
[TRT] detected model format - caffe (extension ‘.caffemodel’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file networks/ped-100/snapshot_iter_70800.caffemodel.1.1.GPU.FP16.engine
[TRT] loading network profile from engine cache… networks/ped-100/snapshot_iter_70800.caffemodel.1.1.GPU.FP16.engine
[TRT] device GPU, networks/ped-100/snapshot_iter_70800.caffemodel loaded
[TRT] device GPU, CUDA engine context initialized with 3 bindings
[TRT] binding – index 0
– name ‘data’
– type FP32
– in/out INPUT
– # dims 3
– dim #0 3 (CHANNEL)
– dim #1 512 (SPATIAL)
– dim #2 1024 (SPATIAL)
[TRT] binding – index 1
– name ‘coverage’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #0 1 (CHANNEL)
– dim #1 32 (SPATIAL)
– dim #2 64 (SPATIAL)
[TRT] binding – index 2
– name ‘bboxes’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #0 4 (CHANNEL)
[TRT] binding to input 0 data binding index: 0
[TRT] binding to input 0 data dims (b=1 c=3 h=512 w=1024) size=6291456
[TRT] binding to output 0 coverage binding index: 1
[TRT] binding to output 0 coverage dims (b=1 c=1 h=32 w=64) size=8192
[TRT] binding to output 1 bboxes binding index: 2
[TRT] binding to output 1 bboxes dims (b=1 c=4 h=32 w=64) size=32768
device GPU, networks/ped-100/snapshot_iter_70800.caffemodel initialized.
detectNet – number object classes: 1
detectNet – maximum bounding boxes: 2048
detectNet – loaded 1 class info entries
detectNet – number of object classes: 1
jetson.utils – PyCamera_New()
jetson.utils – PyCamera_Init()
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVARGUS, camera /dev/video0
[gstreamer] gstCamera pipeline string:
v4l2src device=/dev/video0 ! video/x-raw, width=(int)1280, height=(int)720, format=YUY2 ! videoconvert ! video/x-raw, format=RGB ! videoconvert !appsink name=mysink
[gstreamer] gstCamera successfully initialized with GST_SOURCE_V4L2, camera /dev/video0
jetson.utils – PyDisplay_New()
jetson.utils – PyDisplay_Init()
[OpenGL] glDisplay – X screen 0 resolution: 1920x1080
[OpenGL] glDisplay – display device initialized
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert1
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert1
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer msg new-clock ==> pipeline0
[gstreamer] gstreamer msg stream-start ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstCamera onEOS
[gstreamer] gstreamer v4l2src0 ERROR Internal data stream error.
[gstreamer] gstreamer Debugging info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
Seems that Gstreame does not recognize the stream data format.
Any ideas on how resolve this error?
Thanks to anyone will help
Plauto
