Use the Object Detection on the Jetson Nano and put out the results per Usb
I made an own project based on the object detection in python and would like to run it on the jetson nano but see the outputs/the gui on my Host via usb. Is it possible to show the results on the host without changing the project to jupyterlab?
Thank you,
Steffen
Hi @steffen.epp, you would need to stream the output video to your host with RTP. I’ve been working on adding this in this dev branch: https://github.com/dusty-nv/jetson-inference/tree/dev
I will update the Python detectnet example later today and show you the command to run.
Pperfect, thank you very much. I’m looking forward to it.
OK, so if you clone my dev branch (GitHub - dusty-nv/jetson-inference at dev) and build/install it, you should be able to run this after replacing $HOST_IP with your PC’s IP address on your local network:
$ detectnet-video.py /dev/video0 rtp://$HOST_IP:5000   # from V4L2 webcam
$ detectnet-video.py csi://0 rtp://$HOST_IP:5000       # from MIPI CSI camera
$ detectnet-video.py my_video.mkv rtp://$HOST_IP:5000  # from video file (mkv, avi, mp4, flv)
Then to view it from your PC with GStreamer:
$ gst-launch-1.0 -v udpsrc port=5000 caps = "application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96" ! rtph264depay ! decodebin ! videoconvert ! autovideosink
To view it from your PC with VLC player, create a SDP file on your PC with the following contents:
c=IN IP4 127.0.0.1
m=video 5000 RTP/AVP 96
a=rtpmap:96 H264/90000
If you name the file with .sdp extension, you should be able to double-click it from your PC and open the stream with VLC. In my testing so far, the stream is smoother when viewing it from GStreamer than it is in VLC player.
first, thank you for the explanation.
But it looks like it is over a network connection and not through usb or am I wrong? Is there another opportunity to receive the data over usb?
And is there another documentation where i can receive the information to build an own gui? or just make the outputs on the terminal.
It’s a virtual network connection over MicroUSB. The networking drivers over USB are already built-in. Over MicroUSB, the Jetson will have a static IP of 192.168.55.1. Alternatively, you could use the virtual serial connection over MicroUSB (the serial drivers for USB are also already built-in). Both the network and serial connection are still over MicroUSB, they are just tunneled through USB by the built-in drivers.
If you wanted to use USB directly, you would need to write your own USB drivers for both the host and device that directly uses the USB protocol. It would be much easier to use the virtual networking or serial connection.
The easiest way to get the outputs on the terminal would be to run the application via SSH over the MicroUSB networking connection.
Hello, thank you for your help, but i still have two problems.
  1. When starting the vlc by opening the .sdp, it just loads a few seconds and then stops. I have no error or anything.
  2. Is it possible to start this command: “detectnet-video.py /dev/video0 rtp://$HOST_IP:5000” over the ssh connection?
    I also installed XMing and it works partly. The terminaloutputs are working but there is no window showing the input by the camera. If i check what happens on the nano (not in headless mode), the window with the videostream appears on the nano, but not on my host ( It also doesn’t show it in headless mode).
Thank you for your help.
Hi @steffen.epp, sorry for the delay - are you able to view it with GStreamer? In my experience, it’s good to confirm that GStreamer can receive it before trying VLC (VLC seems trickier with RTP than GStreamer).
If you monitor the rx packet count on your host PC (i.e. with ifconfig), does it consistently go up when the stream is active?
It’s not possible to share the OpenGL window that’s running on the Jetson over SSH. Or if you setup X11 tunneling, it might work with very low framerate, but it isn’t very desirable. Hence using the compressed RTP streaming is often a better fit when you are able to get it working.
No I’m not able to view it via Gstreamer. I checked if the installation works properly and it does. It fidns all the plugins and can display a testvid.
When using your command:
I get the following output, but no videostream:
gst-launch-1.0 -v udpsrc port=5000 caps = “application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96” ! rtph264depay ! decodebin ! videoconvert ! autovideosink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
/GstPipeline:pipeline0/GstUDPSrc:udpsrc0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
Setting pipeline to PLAYING …
New clock: GstSystemClock
When monitoring the rx packet count, before starting the program in headless mode its 13.000 segments received, after starting it, it rises to between 60.000-130.000.
Maybe it helps if i share the output when i start the program including the rtp flag:
Before starting the program, i set the display variable to: “DISPLAY=:0”. Otherwise i get this output:
Summary
Using TensorFlow backend.
np_resource = np.dtype([(“resource”, np.ubyte, 1)])
jetson.inference – imageNet loading build-in network ‘resnet-18’
imageNet – loading classification network model from:
– prototxt networks/ResNet-18/deploy.prototxt
– model networks/ResNet-18/ResNet-18.caffemodel
– class_labels networks/ilsvrc12_synset_words.txt
– input_blob ‘data’
– output_blob ‘prob’
– batch_size 1
[TRT] TensorRT version 5.0.6
[TRT] loading NVIDIA plugins…
[TRT] Plugin Creator registration succeeded - GridAnchor_TRT
[TRT] Plugin Creator registration succeeded - NMS_TRT
[TRT] Plugin Creator registration succeeded - Reorg_TRT
[TRT] Plugin Creator registration succeeded - Region_TRT
[TRT] Plugin Creator registration succeeded - Clip_TRT
[TRT] Plugin Creator registration succeeded - LReLU_TRT
[TRT] Plugin Creator registration succeeded - PriorBox_TRT
[TRT] Plugin Creator registration succeeded - Normalize_TRT
[TRT] Plugin Creator registration succeeded - RPROI_TRT
[TRT] detected model format - caffe (extension ‘.caffemodel’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file /usr/local/bin/networks/ResNet-18/ResNet-18.caffemodel.1.1.5006.GPU.FP16.engine
[TRT] loading network plan from engine cache… /usr/local/bin/networks/ResNet-18/ResNet-18.caffemodel.1.1.5006.GPU.FP16.engine
[TRT] device GPU, loaded /usr/local/bin/networks/ResNet-18/ResNet-18.caffemodel
[TRT] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[TRT] Glob Size is 33434528 bytes.
[TRT] Added linear block of size 1605632
[TRT] Added linear block of size 401408
[TRT] Deserialize required 2908744 microseconds.
[TRT]
[TRT] CUDA engine context initialized on device GPU:
[TRT] – layers 29
[TRT] – maxBatchSize 1
[TRT] – workspace 0
[TRT] – deviceMemory 2408448
[TRT] – bindings 2
[TRT] binding 0
– index 0
– name ‘data’
– type FP32
– in/out INPUT
– # dims 3
– dim #0 3 (CHANNEL)
– dim #1 224 (SPATIAL)
– dim #2 224 (SPATIAL)
[TRT] binding 1
– index 1
– name ‘prob’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #0 1000 (CHANNEL)
– dim #1 1 (SPATIAL)
– dim #2 1 (SPATIAL)
[TRT]
[TRT] binding to input 0 data binding index: 0
[TRT] binding to input 0 data dims (b=1 c=3 h=224 w=224) size=602112
[TRT] binding to output 0 prob binding index: 1
[TRT] binding to output 0 prob dims (b=1 c=1000 h=1 w=1) size=4000
[TRT]
[TRT] device GPU, /usr/local/bin/networks/ResNet-18/ResNet-18.caffemodel initialized.
[TRT] imageNet – loaded 1000 class info entries
[TRT] imageNet – networks/ResNet-18/ResNet-18.caffemodel initialized.
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstCamera – attempting to create device v4l2:///dev/video0
[gstreamer] gstCamera – found v4l2 device: UVC Camera (046d:0825)
[gstreamer] v4l2-proplist, device.path=(string)/dev/video0, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)“UVC\ Camera\ (046d:0825)”, v4l2.device.bus_info=(string)usb-70090000.xusb-2.3, v4l2.device.version=(uint)264588, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] gstCamera – found 38 caps for v4l2 device /dev/video0
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [5] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 5/1 };
[gstreamer] [6] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [7] video/x-raw, format=(string)YUY2, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [8] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [9] video/x-raw, format=(string)YUY2, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [10] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [11] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [12] video/x-raw, format=(string)YUY2, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [13] video/x-raw, format=(string)YUY2, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [14] video/x-raw, format=(string)YUY2, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [15] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [16] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [17] video/x-raw, format=(string)YUY2, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [18] video/x-raw, format=(string)YUY2, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [19] image/jpeg, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [20] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [21] image/jpeg, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [22] image/jpeg, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [23] image/jpeg, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [24] image/jpeg, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [25] image/jpeg, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [26] image/jpeg, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [27] image/jpeg, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [28] image/jpeg, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [29] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [30] image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [31] image/jpeg, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [32] image/jpeg, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [33] image/jpeg, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [34] image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [35] image/jpeg, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [36] image/jpeg, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [37] image/jpeg, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] gstCamera – selected device profile: codec=raw format=yuyv width=640 height=480
[gstreamer] gstCamera pipeline string:
[gstreamer] v4l2src device=/dev/video0 ! video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480 ! appsink name=mysink
[gstreamer] gstCamera successfully created device v4l2:///dev/video0
PuTTY X11 proxy: unable to connect to forwarded X server: Network error: Connection refused
[OpenGL] failed to open X11 server connection.
[OpenGL] failed to create X11 Window.
[OpenGL] failed to create OpenGL window
Process Process-1:
File “/usr/lib/python3.6/multiprocessing/process.py”, line 258, in _bootstrap
self.run()
File “/usr/lib/python3.6/multiprocessing/process.py”, line 93, in run
self._target(*self._args, **self._kwargs)
File “/home/dlinano/…py”, line 19, in xxxx
display = jetson.utils.glDisplay()
Exception: jetson.utils – failed to create glDisplay device
When setting the Display variable:
Summary
– input_blob ‘data’
– batch_size 1
[TRT] requested fasted precision for device GPU without providing valid calib rator, disabling INT8
[TRT] attempting to open engine cache file /usr/local/bin/networks/ResNet-18/ ResNet-18.caffemodel.1.1.5006.GPU.FP16.engine
[TRT] loading network plan from engine cache… /usr/local/bin/networks/ResNe t-18/ResNet-18.caffemodel.1.1.5006.GPU.FP16.engine
[TRT] device GPU, loaded /usr/local/bin/networks/ResNet-18/ResNet-18.caffemod el
[TRT] Using an engine plan file across different models of devices is not rec ommended and is likely to affect performance or even cause errors.
[TRT] Deserialize required 2855627 microseconds.
[TRT]
[TRT] – layers 29
[TRT] – workspace 0
[TRT] – bindings 2
[TRT] binding 0
– index 0
– name ‘data’
– type FP32
– in/out INPUT
– # dims 3
[TRT] binding 1
– index 1
– name ‘prob’
– type FP32
– in/out OUTPUT
– # dims 3
[TRT]
[TRT]
[TRT] device GPU, /usr/local/bin/networks/ResNet-18/ResNet-18.caffemodel init ialized.
[gstreamer] v4l2-proplist, device.path=(string)/dev/video0, udev-probed=(boolean )false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.devic e.card=(string)“UVC\ Camera\ (046d:0825)”, v4l2.device.bus_info=(string)usb-70 090000.xusb-2.3, v4l2.device.version=(uint)264588, v4l2.device.capabilities=(uin t)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)9 60, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)7 20, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)1184, height=(int)6 56, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)72 0, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)1024, height=(int)5 76, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [5] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)54 4, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 5/1 };
[gstreamer] [6] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)60 0, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [7] video/x-raw, format=(string)YUY2, width=(int)864, height=(int)48 0, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [8] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)44 8, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [9] video/x-raw, format=(string)YUY2, width=(int)752, height=(int)41 6, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 25/1, 20/1, 15/1, 10/ 1, 5/1 };
[gstreamer] [10] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)4 80, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15 /1, 10/1, 5/1 };
[gstreamer] [11] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)3 60, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15 /1, 10/1, 5/1 };
[gstreamer] [12] video/x-raw, format=(string)YUY2, width=(int)544, height=(int)2 88, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15 /1, 10/1, 5/1 };
[gstreamer] [13] video/x-raw, format=(string)YUY2, width=(int)432, height=(int)2 40, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15 /1, 10/1, 5/1 };
[gstreamer] [14] video/x-raw, format=(string)YUY2, width=(int)352, height=(int)2 88, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15 /1, 10/1, 5/1 };
[gstreamer] [15] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)2 40, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15 /1, 10/1, 5/1 };
[gstreamer] [16] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)1 76, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15 /1, 10/1, 5/1 };
[gstreamer] [17] video/x-raw, format=(string)YUY2, width=(int)176, height=(int)1 44, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15 /1, 10/1, 5/1 };
[gstreamer] [18] video/x-raw, format=(string)YUY2, width=(int)160, height=(int)1 20, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15 /1, 10/1, 5/1 };
[gstreamer] [19] image/jpeg, width=(int)1280, height=(int)960, pixel-aspect-rati o=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [20] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-rati o=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [21] image/jpeg, width=(int)1184, height=(int)656, pixel-aspect-rati o=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [22] image/jpeg, width=(int)960, height=(int)720, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [23] image/jpeg, width=(int)1024, height=(int)576, pixel-aspect-rati o=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [24] image/jpeg, width=(int)960, height=(int)544, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [25] image/jpeg, width=(int)800, height=(int)600, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [26] image/jpeg, width=(int)864, height=(int)480, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [27] image/jpeg, width=(int)800, height=(int)448, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [28] image/jpeg, width=(int)752, height=(int)416, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [29] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [30] image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [31] image/jpeg, width=(int)544, height=(int)288, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [32] image/jpeg, width=(int)432, height=(int)240, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [33] image/jpeg, width=(int)352, height=(int)288, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [34] image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [35] image/jpeg, width=(int)320, height=(int)176, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [36] image/jpeg, width=(int)176, height=(int)144, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [37] image/jpeg, width=(int)160, height=(int)120, pixel-aspect-ratio =(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] gstCamera – selected device profile: codec=raw format=yuyv width=6 40 height=480
[gstreamer] v4l2src device=/dev/video0 ! video/x-raw, format=(string)YUY2, width =(int)640, height=(int)480 ! appsink name=mysink
[OpenGL] glDisplay – X screen 0 resolution: 640x480
[OpenGL] glDisplay – X window resolution: 640x480
[OpenGL] glDisplay – display device initialized (640x480)
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE _PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstreamer message stream-start ==> pipeline0
[gstreamer] gstCamera – onPreroll
[gstreamer] gstCamera recieve caps: video/x-raw, format=(string)YUY2, width=(in t)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30 /1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
[gstreamer] gstCamera – recieved first frame, codec=raw format=yuyv width=640 h eight=480 size=614400
RingBuffer – allocated 4 buffers (614400 bytes each, 2457600 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
RingBuffer – allocated 4 buffers (4915200 bytes each, 19660800 bytes total)
class 0078 - 0.045410 (tick)
class 0111 - 0.010635 (nematode, nematode worm, roundworm)
class 0301 - 0.022385 (ladybug, ladybeetle, lady beetle, ladybird, ladybird bee tle)
The OpenGL window is not going to be able to be forwarded/tunneled over SSH
It seems like your PC is receiving the RTP packets - sometimes it may take some seconds to sync/display the video. Does it ever show? Do you happen to have a firewall on PC that might be intercepting or blocking the traffic?
Ok i didn’t expect the firewall to be the problem. But it worked with another host, thank you very much.
