10 lines of code example out of date?
Hi there, I successfully followed the Nano setup tutorials and the 10 lines of code example which worked out a couple of months ago: Real-Time Object Detection in 10 Lines of Python on Jetson Nano | NVIDIA Technical Blog
However I’ve just rebuilt my Nano with the latest Jetpack, but now the example code produces no outut at all - it looks like it runs with no errors but then it just returns the command prompt, the video feed doesn’t appear and it doesn’t produce any detection results. My code is exactly as shown in the video tutorial with the exception of using /dev/video0 instead of video1. It seems to initialise the camera ok (it’s a Logitech C270 which worked before).
Output is as below, what do I need to do now to make it work now?
jetson.inference – detectNet loading build-in network ‘ssd-mobilenet-v2’
detectNet – loading detection network model from:
– model networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
– input_blob ‘Input’
– output_blob ‘NMS’
– output_count ‘NMS_1’
– class_labels networks/SSD-Mobilenet-v2/ssd_coco_labels.txt
– threshold 0.500000
– batch_size 1
[TRT] TensorRT version 7.1.3
[TRT] loading NVIDIA plugins…
[TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[TRT] Registered plugin creator - ::NMS_TRT version 1
[TRT] Registered plugin creator - ::Reorg_TRT version 1
[TRT] Registered plugin creator - ::Region_TRT version 1
[TRT] Registered plugin creator - ::Clip_TRT version 1
[TRT] Registered plugin creator - ::LReLU_TRT version 1
[TRT] Registered plugin creator - ::PriorBox_TRT version 1
[TRT] Registered plugin creator - ::Normalize_TRT version 1
[TRT] Registered plugin creator - ::RPROI_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
[TRT] Registered plugin creator - ::CropAndResize version 1
[TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT] Registered plugin creator - ::Proposal version 1
[TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT] Registered plugin creator - ::Split version 1
[TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT] detected model format - UFF (extension ‘.uff’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.7103.GPU.FP16.engine
[TRT] loading network plan from engine cache… /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.7103.GPU.FP16.engine
[TRT] device GPU, loaded /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
[TRT] Deserialize required 6596971 microseconds.
[TRT]
[TRT] CUDA engine context initialized on device GPU:
[TRT] – layers 116
[TRT] – maxBatchSize 1
[TRT] – workspace 0
[TRT] – deviceMemory 35449856
[TRT] – bindings 3
[TRT] binding 0
– index 0
– name ‘Input’
– type FP32
– in/out INPUT
– # dims 3
– dim #0 3 (SPATIAL)
– dim #1 300 (SPATIAL)
– dim #2 300 (SPATIAL)
[TRT] binding 1
– index 1
– name ‘NMS’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #0 1 (SPATIAL)
– dim #1 100 (SPATIAL)
– dim #2 7 (SPATIAL)
[TRT] binding 2
– index 2
– name ‘NMS_1’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #1 1 (SPATIAL)
– dim #2 1 (SPATIAL)
[TRT]
[TRT] binding to input 0 Input binding index: 0
[TRT] binding to input 0 Input dims (b=1 c=3 h=300 w=300) size=1080000
[TRT] binding to output 0 NMS binding index: 1
[TRT] binding to output 0 NMS dims (b=1 c=1 h=100 w=7) size=2800
[TRT] binding to output 1 NMS_1 binding index: 2
[TRT] binding to output 1 NMS_1 dims (b=1 c=1 h=1 w=1) size=4
[TRT]
[TRT] device GPU, /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff initialized.
[TRT] W = 7 H = 100 C = 1
[TRT] detectNet – maximum bounding boxes: 100
[TRT] detectNet – loaded 91 class info entries
[TRT] detectNet – number of object classes: 91
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstCamera – attempting to create device v4l2:///dev/video0
[gstreamer] gstCamera – found v4l2 device: UVC Camera (046d:0825)
[gstreamer] v4l2-proplist, device.path=(string)/dev/video0, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)“UVC\ Camera\ (046d:0825)”, v4l2.device.bus_info=(string)usb-70090000.xusb-2.4, v4l2.device.version=(uint)264588, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] gstCamera – found 38 caps for v4l2 device /dev/video0
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [5] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 5/1 };
[gstreamer] [6] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [7] video/x-raw, format=(string)YUY2, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [8] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [9] video/x-raw, format=(string)YUY2, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [10] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [11] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [12] video/x-raw, format=(string)YUY2, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [13] video/x-raw, format=(string)YUY2, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [14] video/x-raw, format=(string)YUY2, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [15] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [16] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [17] video/x-raw, format=(string)YUY2, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [18] video/x-raw, format=(string)YUY2, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [19] image/jpeg, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [20] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [21] image/jpeg, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [22] image/jpeg, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [23] image/jpeg, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [24] image/jpeg, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [25] image/jpeg, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [26] image/jpeg, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [27] image/jpeg, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [28] image/jpeg, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [29] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [30] image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [31] image/jpeg, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [32] image/jpeg, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [33] image/jpeg, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [34] image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [35] image/jpeg, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [36] image/jpeg, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [37] image/jpeg, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] gstCamera – selected device profile: codec=mjpeg format=unknown width=1280 height=720
[gstreamer] gstCamera pipeline string:
[gstreamer] v4l2src device=/dev/video0 ! image/jpeg, width=(int)1280, height=(int)720 ! nvjpegdec ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully created device v4l2:///dev/video0
[OpenGL] glDisplay – X screen 0 resolution: 1920x1080
[OpenGL] glDisplay – X window resolution: 1920x1080
[OpenGL] glDisplay – display device initialized (1920x1080)
james@james-nano1:~$
Solved: I found the new Python etc examples in /home/jetson-inference/build/arch64/bin in the actual Jetpack image which seem to work ok.
Probably worth the original blog post being updated though.
Hi @xrobots, thanks for letting me know - I recently made a change to the display window opening behavior, where it now opens when the first image is rendered (as opposed to opening right away) - and it turns out this breaks the previous code used from that video tutorial.
So I have checked-in a patch to the repo which restores the original code to be working. You can update/re-build your repo like so:
$ cd jetson-inference/utils
$ git pull origin master
$ cd ../
$ cd build
$ make
$ sudo make install
(or you can re-clone the repo instead, if desired)
You should then be able to run this original code from the video:
import jetson.inference
import jetson.utils
net = jetson.inference.detectNet("ssd-mobilenet-v2", threshold=0.5)
camera = jetson.utils.gstCamera(1280, 720, "/dev/video0")  # using V4L2
display = jetson.utils.glDisplay()
while display.IsOpen():
	img, width, height = camera.CaptureRGBA()
	detections = net.Detect(img, width, height)
	display.RenderOnce(img, width, height)
	display.SetTitle("Object Detection | Network {:.0f} FPS".format(net.GetNetworkFPS()))
Also, I am working on re-shooting that YouTube video with the latest code. The tutorial itself has already been updated on GitHub here:
https://github.com/dusty-nv/jetson-inference/blob/master/docs/detectnet-example-2.md
I didn’t apply the patch, but I tried the new code you linked to on Git, which seems to be the same as the my-detection.py example that ships as part of the Jetpack image. However I still don’t get any display or meaningful errors. I tried with both a rasp pi V2 cam as the default video source, and also /dev/video0 with my USB webcam. Output it as follows, but then it just goes back to the command prompt.
The other example code works with both cameras fine though, detectnet.py etc
jetson.inference -- detectNet loading build-in network 'ssd-mobilenet-v2'
detectNet -- loading detection network model from:
      -- model        networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
      -- input_blob   'Input'
      -- output_blob  'NMS'
      -- output_count 'NMS_1'
      -- class_labels networks/SSD-Mobilenet-v2/ssd_coco_labels.txt
      -- threshold    0.500000
      -- batch_size   1
[TRT]    loading NVIDIA plugins...
[TRT]    detected model format - UFF  (extension '.uff')
[TRT]    loading network plan from engine cache... /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.7103.GPU.FP16.engine
[TRT]    Deserialize required 6087330 microseconds.
[TRT]
[TRT]       -- layers       116
[TRT]       -- maxBatchSize 1
[TRT]       -- workspace    0
[TRT]       -- deviceMemory 35449856
[TRT]       -- bindings     3
[TRT]       binding 0
                -- index   0
                -- name    'Input'
                -- type    FP32
                -- in/out  INPUT
                -- # dims  3
                -- dim #0  3 (SPATIAL)
                -- dim #1  300 (SPATIAL)
                -- dim #2  300 (SPATIAL)
[TRT]       binding 1
                -- index   1
                -- name    'NMS'
                -- type    FP32
                -- in/out  OUTPUT
                -- # dims  3
                -- dim #0  1 (SPATIAL)
                -- dim #1  100 (SPATIAL)
                -- dim #2  7 (SPATIAL)
[TRT]       binding 2
                -- index   2
                -- name    'NMS_1'
                -- type    FP32
                -- in/out  OUTPUT
                -- # dims  3
                -- dim #1  1 (SPATIAL)
                -- dim #2  1 (SPATIAL)
[TRT]
[TRT]
[TRT]    detectNet -- maximum bounding boxes:  100
[TRT]    detectNet -- loaded 91 class info entries
[TRT]    detectNet -- number of object classes:  91
[gstreamer] gstCamera -- attempting to create device v4l2:///dev/video0
[gstreamer] gstCamera -- found v4l2 device: UVC Camera (046d:0825)
[gstreamer] v4l2-proplist, device.path=(string)/dev/video0, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)"UVC\ Camera\ \(046d:0825\)", v4l2.device.bus_info=(string)usb-70090000.xusb-2.1, v4l2.device.version=(uint)264588, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] gstCamera -- found 38 caps for v4l2 device /dev/video0
[gstreamer] gstCamera -- selected device profile:  codec=mjpeg format=unknown width=1280 height=720
[video]  created gstCamera from v4l2:///dev/video0
gstCamera video options:
  -- URI: v4l2:///dev/video0
     - protocol:  v4l2
  -- deviceType: v4l2
  -- ioType:     input
  -- codec:      mjpeg
  -- width:      1280
  -- height:     720
  -- frameRate:  30.000000
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
[OpenGL] glDisplay -- X screen 0 resolution:  1920x1080
[OpenGL] glDisplay -- X window resolution:    1920x1080
[OpenGL] glDisplay -- display device initialized (1920x1080)
[video]  created glDisplay from display://0
glDisplay video options:
  -- URI: display://0
     - protocol:  display
  -- deviceType: display
  -- ioType:     output
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- frameRate:  0.000000
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
Ah thanks, sorry about that - try re-cloning/re-building the repo and both the old and new my-detection.py should be working now. Just made a couple changes and confirmed both are working again here.
Thank you Dusty and xrobots.
I was having the same problem and that fixed half of it!
I did an update 4 days ago and it broke my working setup based on the 6 month old version of my-detection. I even reloaded the newest OS image on a different sd card and was sad to see the same behavior.
Now my current issue is slowed camera performance with the logitech c270 (dev/video0) displaying a persistent gstreamer qos message and another usb camera that worked before now crashes (dev/video1). I have seen buffer size and ringbuffer errors.
I have to use camera 1 because it has the appropriate wide angle lens.
I can view both cameras with:
video-viewer --input-width=640 --input-height=480 --input-codec=h.264 /dev/video0
or
video-viewer --input-width=640 --input-height=480 --input-codec=h.264 /dev/video1
Even if i do this video1 still has a buffer crash:
camera = jetson.utils.videoSource(“/dev/video1”, “–input-width=640 --input-height=480 --input-codec=h.264”)
Here are the results of v4l2-ctl --list-formats-ext:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘YUYV’
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.040s (25.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.200s (5.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Index       : 1
Pixel Format: 'MJPG' (compressed)
Here are the results of running the code with video0:
kel@kel-jetson:~/jetson-inference/python/examples$ python3 my-detection.py
– output_blob ‘NMS’
– batch_size 1
[TRT] Deserialize required 5154105 microseconds.
[TRT]
[TRT] – layers 118
[TRT] – workspace 0
[TRT] – deviceMemory 35425280
[TRT] – bindings 3
[TRT] binding 0
– index 0
– name ‘Input’
– type FP32
– in/out INPUT
– # dims 3
[TRT] binding 1
– index 1
– name ‘NMS’
– type FP32
– in/out OUTPUT
– # dims 3
[TRT] binding 2
– index 2
– name ‘NMS_1’
– type FP32
– in/out OUTPUT
– # dims 3
[TRT]
[TRT]
[gstreamer] gstCamera – found v4l2 device: USB 2.0 Camera
[gstreamer] v4l2-proplist, device.path=(string)/dev/video1, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)“USB\ 2.0\ Camera”, v4l2.device.bus_info=(string)usb-70090000.xusb-2.2, v4l2.device.version=(uint)264588, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] v4l2-proplist, device.path=(string)/dev/video0, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)“UVC\ Camera\ (046d:0825)”, v4l2.device.bus_info=(string)usb-70090000.xusb-2.1, v4l2.device.version=(uint)264588, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [8] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
– URI: v4l2:///dev/video0
- protocol: v4l2
– deviceType: v4l2
– ioType: input
– codec: mjpeg
– width: 1280
– height: 720
– frameRate: 30.000000
– bitRate: 0
– numBuffers: 4
– zeroCopy: true
– flipMethod: none
– loop: 0
[OpenGL] glDisplay – X screen 0 resolution: 3840x2160
[OpenGL] glDisplay – X window resolution: 3840x2160
[OpenGL] glDisplay – display device initialized (3840x2160)
– URI: display://0
- protocol: display
– deviceType: display
– ioType: output
– codec: raw
– width: 3840
– height: 2160
– frameRate: 0.000000
– bitRate: 0
– numBuffers: 4
– zeroCopy: true
– flipMethod: none
– loop: 0
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> nvjpegdec0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvjpegdec0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvjpegdec0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer message stream-start ==> pipeline0
[gstreamer] gstCamera – onPreroll
[gstreamer] gstCamera – map buffer size was less than max size (1008 vs 1382407)
[gstreamer] gstCamera recieve caps: video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
[gstreamer] gstCamera – recieved first frame, codec=mjpeg format=i420 width=1280 height=720 size=1382407
RingBuffer – allocated 4 buffers (1382407 bytes each, 5529628 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
RingBuffer – allocated 4 buffers (2764800 bytes each, 11059200 bytes total)
[OpenGL] glDisplay – set the window size to 1280x720
[gstreamer] gstreamer message qos ==> v4l2src0
[OpenGL] creating 1280x720 texture (GL_RGB8 format, 2764800 bytes)
[cuda] registered openGL texture for interop access (1280x720, GL_RGB8, 2764800 bytes)
[OpenGL] glDisplay – the window has been closed
[gstreamer] gstCamera – stopping pipeline, transitioning to GST_STATE_NULL
[gstreamer] gstCamera – pipeline stopped
And here is the resulting crash when running with video1:
– output_blob ‘NMS’
– batch_size 1
[TRT] Deserialize required 5142084 microseconds.
[TRT]
[TRT] – layers 118
[TRT] – workspace 0
[TRT] – bindings 3
[TRT] binding 0
– index 0
– name ‘Input’
– type FP32
– in/out INPUT
– # dims 3
[TRT] binding 1
– index 1
– name ‘NMS’
– type FP32
– in/out OUTPUT
– # dims 3
[TRT] binding 2
– index 2
– name ‘NMS_1’
– type FP32
– in/out OUTPUT
– # dims 3
[TRT]
[TRT]
[gstreamer] gstCamera – attempting to create device v4l2:///dev/video1
[gstreamer] gstCamera – found 16 caps for v4l2 device /dev/video1
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1;
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)15/1;
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1;
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [5] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [6] video/x-raw, format=(string)YUY2, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [7] video/x-raw, format=(string)YUY2, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [8] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [9] image/jpeg, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [10] image/jpeg, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [11] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [12] image/jpeg, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [13] image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [14] image/jpeg, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] [15] image/jpeg, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
[gstreamer] v4l2src device=/dev/video1 ! image/jpeg, width=(int)1280, height=(int)720 ! nvjpegdec ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully created device v4l2:///dev/video1
[video] created gstCamera from v4l2:///dev/video1
– URI: v4l2:///dev/video1
- protocol: v4l2
- port: 1
– deviceType: v4l2
– ioType: input
– codec: mjpeg
– width: 1280
– height: 720
– bitRate: 0
– numBuffers: 4
– zeroCopy: true
– flipMethod: none
– loop: 0
– URI: display://0
- protocol: display
– ioType: output
– codec: raw
– width: 3840
– height: 2160
– bitRate: 0
– numBuffers: 4
– zeroCopy: true
– flipMethod: none
– loop: 0
** (python3:13437): CRITICAL **: 18:43:55.459: gst_adapter_push: assertion ‘GST_IS_BUFFER (buf)’ failed
Any suggestions?
-Cheers and thanks for all your contributions Dusty.
Based on your v4l2-ctl formats, it doesn’t look like C270 actually supports H.264 - instead, try --input-codec=raw or --input-codec=mjpeg. It looks to already be using mjpeg mode, so you might want to try raw (yuy2).
If you continue to have issues with what worked before, you can revert to the 20200714 branch:
https://github.com/dusty-nv/jetson-inference/tree/20200714
