@dusty_nv I have successfully been using the jetson-inference library for a while now, and I have two jetson nanos, jetson 1 (B01 version 4gb, IMX219-83 csi camera, 128gb sd card) and jetson 2 (4gb jetson nano with only 1 csi camera lane A01 version I think, IMX219-160 csi camera, 64gb sd card). The detectnet example works on both jetsons all by itself. And my project code that uses detectnet works on jetson 1 and used to work on jetson 2. Below I’ve provided:
- error log from my code on jetson 2
- modified detectnet.cpp
- My code with the modified detectnet (works on jetson 1, used to work on jetson 2)
Can you help me pinpoint the issue? Thank you in advance! :)
- Here is my console output with the errors:
[WARNING] This channel is already in use, continuing anyway. Use setwarnings(false) to disable warnings. channel: 19
[WARNING] This channel is already in use, continuing anyway. Use setwarnings(false) to disable warnings. channel: 18
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstCamera -- attempting to create device csi://0
[gstreamer] gstCamera pipeline string:
[gstreamer] nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=30/1, format=(string)NV12 ! nvvidconv flip-method=2 ! video/x-raw(memory:NVMM) ! appsink name=mysink
[gstreamer] gstCamera successfully created device csi://0
[video] created gstCamera from csi://0
gstCamera video options:
-- URI: csi://0
- protocol: csi
-- deviceType: csi
-- ioType: input
-- width: 1280
-- height: 720
-- frameRate: 30
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: rotate-180
detectNet -- loading detection network model from:
-- model ../networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
-- input_blob 'Input'
-- output_blob 'NMS'
-- output_count 'NMS_1'
-- class_labels ../networks/SSD-Mobilenet-v2/ssd_coco_labels.txt
-- threshold 0.500000
-- batch_size 1
[TRT] TensorRT version 8.2.1
[TRT] loading NVIDIA plugins...
[TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[TRT] Registered plugin creator - ::GridAnchorRect_TRT version 1
[TRT] Registered plugin creator - ::NMS_TRT version 1
[TRT] Registered plugin creator - ::Reorg_TRT version 1
[TRT] Registered plugin creator - ::Region_TRT version 1
[TRT] Registered plugin creator - ::Clip_TRT version 1
[TRT] Registered plugin creator - ::LReLU_TRT version 1
[TRT] Registered plugin creator - ::PriorBox_TRT version 1
[TRT] Registered plugin creator - ::Normalize_TRT version 1
[TRT] Registered plugin creator - ::ScatterND version 1
[TRT] Registered plugin creator - ::RPROI_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
[TRT] Registered plugin creator - ::CropAndResize version 1
[TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT] Registered plugin creator - ::EfficientNMS_TRT version 1
[TRT] Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[TRT] Registered plugin creator - ::EfficientNMS_TFTRT_TRT version 1
[TRT] Registered plugin creator - ::Proposal version 1
[TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT] Registered plugin creator - ::Split version 1
[TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT] completed loading NVIDIA plugins.
[TRT] detected model format - UFF (extension '.uff')
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] [MemUsageChange] Init CUDA: CPU +229, GPU +0, now: CPU 252, GPU 3888 (MiB)
[TRT] [MemUsageSnapshot] Begin constructing builder kernel library: CPU 252 MiB, GPU 3882 MiB
[TRT] [MemUsageSnapshot] End constructing builder kernel library: CPU 282 MiB, GPU 3899 MiB
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] found engine cache file ../networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.8201.GPU.FP16.engine
[TRT] found model checksum ../networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.sha256sum
[TRT] echo "$(cat ../networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.sha256sum) ../networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff" | sha256sum --check --status
[TRT] model matched checksum ../networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.sha256sum
[TRT] loading network plan from engine cache... ../networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.8201.GPU.FP16.engine
[TRT] device GPU, loaded ../networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
[TRT] [MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 286, GPU 3897 (MiB)
[TRT] Loaded engine size: 33 MiB
[TRT] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[TRT] Using cublas as a tactic source
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +158, GPU -50, now: CPU 463, GPU 3857 (MiB)
[TRT] Using cuDNN as a tactic source
[TRT] [MemUsageChange] Init cuDNN: CPU +240, GPU +8, now: CPU 703, GPU 3865 (MiB)
[TRT] Deserialization required 10033012 microseconds.
[TRT] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +33, now: CPU 0, GPU 33 (MiB)
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +1, GPU +2, now: CPU 704, GPU 3893 (MiB)
[TRT] [MemUsageChange] Init cuDNN: CPU +0, GPU +0, now: CPU 704, GPU 3893 (MiB)
[TRT] Total per-runner device persistent memory is 22143488
[TRT] Total per-runner host persistent memory is 135488
[TRT] Allocated activation device memory of size 13360640
[TRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +34, now: CPU 0, GPU 67 (MiB)
[TRT]
[TRT] CUDA engine context initialized on device GPU:
[TRT] -- layers 124
[TRT] -- maxBatchSize 1
[TRT] -- deviceMemory 13360640
[TRT] -- bindings 3
[TRT] binding 0
-- index 0
-- name 'Input'
-- type FP32
-- in/out INPUT
-- # dims 3
-- dim #0 3
-- dim #1 300
-- dim #2 300
[TRT] binding 1
-- index 1
-- name 'NMS'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 1
-- dim #1 100
-- dim #2 7
[TRT] binding 2
-- index 2
-- name 'NMS_1'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 1
-- dim #1 1
-- dim #2 1
[TRT]
[TRT] binding to input 0 Input binding index: 0
[TRT] binding to input 0 Input dims (b=1 c=3 h=300 w=300) size=1080000
[TRT] binding to output 0 NMS binding index: 1
[TRT] binding to output 0 NMS dims (b=1 c=1 h=100 w=7) size=2800
[TRT] binding to output 1 NMS_1 binding index: 2
[TRT] binding to output 1 NMS_1 dims (b=1 c=1 h=1 w=1) size=4
[TRT]
[TRT] device GPU, ../networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff initialized.
[TRT] W = 7 H = 100 C = 1
[TRT] detectNet -- maximum bounding boxes: 100
[TRT] loaded 91 class labels
[TRT] detectNet -- number of object classes: 91
[TRT] loaded 0 class colors
[TRT] didn't load expected number of class colors (0 of 91)
[TRT] filling in remaining 91 class colors with default colors
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> nvvconv0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> nvarguscamerasrc0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvvconv0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvarguscamerasrc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvvconv0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvarguscamerasrc0
[gstreamer] gstreamer message stream-start ==> pipeline0
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 5
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
[gstreamer] gstCamera::Capture() -- a timeout occurred waiting for the next image buffer
[TRT] detectNet::Detect( 0x(nil), 1280, 720 ) -> invalid parameters
CONSUMER: Producer has connected; continuing.
[gstreamer] gstCamera -- onPreroll
[gstreamer] gstBufferManager recieve caps: video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)30/1
[gstreamer] gstBufferManager -- recieved first frame, codec=raw format=nv12 width=1280 height=720 size=1008
[gstreamer] gstBufferManager -- recieved NVMM memory
[cuda] allocated 4 ring buffers (8 bytes each, 32 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
[cuda] allocated 4 ring buffers (2764800 bytes each, 11059200 bytes total)
[cuda] cudaGetLastError()
[cuda] invalid resource handle (error 400) (hex 0x190)
[cuda] /home/crose72/Documents/GitHub/jetson-inference/utils/cuda/cudaYUV-NV12.cu:154
[cuda] cudaNV12ToRGB(input, (uchar3*)output, width, height, stream)
[cuda] /home/crose72/Documents/GitHub/jetson-inference/utils/cuda/cudaColorspace.cpp:43
[cuda] cudaConvertColor(latestYUV, mFormatYUV, nextRGB, format, mOptions->width, mOptions->height, stream)
[cuda] /home/crose72/Documents/GitHub/jetson-inference/utils/codec/gstBufferManager.cpp:445
[gstreamer] gstBufferManager -- unsupported image format (rgb8)
[gstreamer] supported formats are:
[gstreamer] * rgb8
[gstreamer] * rgba8
[gstreamer] * rgb32f
[gstreamer] * rgba32f
[gstreamer] gstCamera::Capture() -- an error occurred retrieving the next image buffer
[gstreamer] * rgb8
[gstreamer] * rgba8
- Modified detectnet.cpp (working)
* Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include "jetson-inference/detectNet.h"
#include "jetson-utils/videoSource.h"
#include "jetson-utils/videoOutput.h"
#include "jetson-inference/objectTracker.h"
#include <signal.h>
detectNet *net;
bool signal_recieved = false;
void sig_handler(int signo)
if (signo == SIGINT)
LogVerbose("received SIGINT\n");
signal_recieved = true;
int usage()
printf("usage: detectnet [--help] [--network=NETWORK] [--threshold=THRESHOLD] ...\n");
printf(" input [output]\n\n");
printf("Locate objects in a video/image stream using an object detection DNN.\n");
printf("See below for additional arguments that may not be shown above.\n\n");
printf("positional arguments:\n");
printf(" input resource URI of input stream (see videoSource below)\n");
printf(" output resource URI of output stream (see videoOutput below)\n\n");
printf("%s", detectNet::Usage());
printf("%s", objectTracker::Usage());
printf("%s", videoSource::Usage());
printf("%s", videoOutput::Usage());
printf("%s", Log::Usage());
return 0;
int main(int argc, char **argv)
* parse command line
commandLine cmdLine(argc, argv);
if (cmdLine.GetFlag("help"))
return usage();
* attach signal handler
if (signal(SIGINT, sig_handler) == SIG_ERR)
LogError("can't catch SIGINT\n");
* create input stream
videoOptions options1;
options1.resource = URI("csi://0");
options1.resource.protocol = "csi";
options1.resource.location = "0";
options1.deviceType = videoOptions::DeviceType::DEVICE_CSI;
options1.ioType = videoOptions::IoType::INPUT;
options1.width = 1280;
options1.height = 720;
options1.frameRate = 30;
options1.numBuffers = 4;
options1.zeroCopy = true;
options1.flipMethod = videoOptions::FlipMethod::FLIP_NONE;
videoSource *input = videoSource::Create(options1);
if (!input)
LogError("detectnet: failed to create input stream\n");
return 1;
* create output stream
videoOptions options2;
options2.resource = "display://0"; // Specify the display URI
options2.resource.protocol = "display";
options2.resource.location = "0";
options2.deviceType = videoOptions::DeviceType::DEVICE_DISPLAY;
options2.ioType = videoOptions::IoType::OUTPUT;
options2.width = 1920;
options2.height = 1080;
options2.frameRate = 30; // Adjust as needed
options2.numBuffers = 4;
options2.zeroCopy = true;
videoOutput *output = videoOutput::Create(options2);
if (!output)
LogError("detectnet: failed to create output stream\n");
return 1;
* create detection network
float detection_thresh = (float)0.7;
uint32_t max_batch_size = (uint32_t)4;
uint32_t min_frames = (uint32_t)25;
uint32_t drop_frames = (uint32_t)50;
float overlap_thresh = (float)0.5;
const char *model = "../../../../SquirrelDefender/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff";
const char *class_labels = "../../../../SquirrelDefender/networks/SSD-Mobilenet-v2/ssd_coco_labels.txt";
float thresh = (float)0.5;
const char *input_blob = "Input";
const char *output_blob = "NMS";
Dims3 inputDims(3, 720, 1280);
const char *output_count = "NMS_1";
// Validate input/output blobs
if (input_blob == nullptr || output_blob == nullptr)
LogError("Invalid input or output blob names\n");
return false;
net = detectNet::Create(model, class_labels, thresh, input_blob, inputDims, output_blob, output_count);
if (!net)
LogError("detectnet: failed to load detectNet model\n");
return 1;
// net->SetTracker(objectTrackerIOU::Create(min_frames, drop_frames, overlap_thresh));
if (!net)
LogError("detectNet: failed to set tracker\n");
return false;
// parse overlay flags
const uint32_t overlayFlags = detectNet::OverlayFlagsFromStr(cmdLine.GetString("overlay", "box,labels,conf"));
* processing loop
while (!signal_recieved)
// capture next image
uchar3 *image = NULL;
int status = 0;
if (!input->Capture(&image, &status))
if (status == videoSource::TIMEOUT)
continue;
break; // EOS
// detect objects in the frame
detectNet::Detection *detections = NULL;
const int numDetections = net->Detect(image, input->GetWidth(), input->GetHeight(), &detections, overlayFlags);
if (numDetections > 0)
LogVerbose("%i objects detected\n", numDetections);
for (int n = 0; n < numDetections; n++)
LogVerbose("\ndetected obj %i class #%u (%s) confidence=%f\n", n, detections[n].ClassID, net->GetClassDesc(detections[n].ClassID), detections[n].Confidence);
LogVerbose("bounding box %i (%.2f, %.2f) (%.2f, %.2f) w=%.2f h=%.2f\n", n, detections[n].Left, detections[n].Top, detections[n].Right, detections[n].Bottom, detections[n].Width(), detections[n].Height());
if (detections[n].TrackID >= 0) // is this a tracked object?
LogVerbose("tracking ID %i status=%i frames=%i lost=%i\n", detections[n].TrackID, detections[n].TrackStatus, detections[n].TrackFrames, detections[n].TrackLost);
// render outputs
if (output != NULL)
output->Render(image, input->GetWidth(), input->GetHeight());
// update the status bar
char str[256];
sprintf(str, "TensorRT %i.%i.%i | %s | Network %.0f FPS", NV_TENSORRT_MAJOR, NV_TENSORRT_MINOR, NV_TENSORRT_PATCH, precisionTypeToStr(net->GetPrecision()), net->GetNetworkFPS());
output->SetStatus(str);
// check if the user quit
if (!output->IsStreaming())
break;
// print out timing info
net->PrintProfilerTimes();
* destroy resources
LogVerbose("detectnet: shutting down...\n");
SAFE_DELETE(input);
SAFE_DELETE(output);
SAFE_DELETE(net);
LogVerbose("detectnet: shutdown complete.\n");
return 0;
- My project code (same as detecnet.cpp and works on jetson 1, but gives the error above on jetson 2)
