OpenGL in headless Mode
I try to run a program that uses the jetson inference repo for object detection in headless mode.
I use putty and xming with x11 forwarding on my windows machine.
First i got that output:
[OpenGL] failed to create X11 Window.
[OpenGL] failed to create OpenGL window
Process Process-1:
File “/usr/lib/python3.6/multiprocessing/process.py”, line 258, in _bootstrap
self.run()
File “/usr/lib/python3.6/multiprocessing/process.py”, line 93, in run
self._target(*self._args, **self._kwargs)
File “/home/dlinano/emotionAwareHMI/Incubator_V1/cameraRecognitionFunc.py”, line 19, in cameraRecognition
display = jetson.utils.glDisplay()
Exception: jetson.utils – failed to create glDisplay device
After that, i tried:
DISPLAY=:0
After that, the program seems to run, the terminal outputs all the predictions, but no window opens with the camera input & the predictions.
Is there something I did wrong or what do i have to add?
The terminal outputs the right predictions, but no window opens itself.
Console
Using TensorFlow backend.
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:526: FutureWarning: Passing (type, 1) or ‘1type’ as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / ‘(1,)type’.
_np_qint8 = np.dtype([(“qint8”, np.int8, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:527: FutureWarning: Passing (type, 1) or ‘1type’ as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / ‘(1,)type’.
_np_quint8 = np.dtype([(“quint8”, np.uint8, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:528: FutureWarning: Passing (type, 1) or ‘1type’ as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / ‘(1,)type’.
_np_qint16 = np.dtype([(“qint16”, np.int16, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:529: FutureWarning: Passing (type, 1) or ‘1type’ as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / ‘(1,)type’.
_np_quint16 = np.dtype([(“quint16”, np.uint16, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:530: FutureWarning: Passing (type, 1) or ‘1type’ as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / ‘(1,)type’.
_np_qint32 = np.dtype([(“qint32”, np.int32, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:535: FutureWarning: Passing (type, 1) or ‘1type’ as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / ‘(1,)type’.
np_resource = np.dtype([(“resource”, np.ubyte, 1)])
Current Time = ------------------------------------------------------------------------------------ 09:43:16
jetson.inference – imageNet loading build-in network ‘resnet-18’
imageNet – loading classification network model from:
– prototxt networks/ResNet-18/deploy.prototxt
– model networks/ResNet-18/ResNet-18.caffemodel
– class_labels networks/ilsvrc12_synset_words.txt
– input_blob ‘data’
– output_blob ‘prob’
– batch_size 1
[TRT] TensorRT version 5.0.6
[TRT] loading NVIDIA plugins…
[TRT] Plugin Creator registration succeeded - GridAnchor_TRT
[TRT] Plugin Creator registration succeeded - NMS_TRT
[TRT] Plugin Creator registration succeeded - Reorg_TRT
[TRT] Plugin Creator registration succeeded - Region_TRT
[TRT] Plugin Creator registration succeeded - Clip_TRT
[TRT] Plugin Creator registration succeeded - LReLU_TRT
[TRT] Plugin Creator registration succeeded - PriorBox_TRT
[TRT] Plugin Creator registration succeeded - Normalize_TRT
[TRT] Plugin Creator registration succeeded - RPROI_TRT
[TRT] detected model format - caffe (extension ‘.caffemodel’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file /usr/local/bin/networks/ResNet-18/ResNet-18.caffemodel.1.1.5006.GPU.FP16.engine
[TRT] loading network plan from engine cache… /usr/local/bin/networks/ResNet-18/ResNet-18.caffemodel.1.1.5006.GPU.FP16.engine
[TRT] device GPU, loaded /usr/local/bin/networks/ResNet-18/ResNet-18.caffemodel
[TRT] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[TRT] Glob Size is 33434528 bytes.
[TRT] Added linear block of size 1605632
[TRT] Added linear block of size 401408
[TRT] Deserialize required 3708764 microseconds.
[TRT]
[TRT] CUDA engine context initialized on device GPU:
[TRT] – layers 29
[TRT] – maxBatchSize 1
[TRT] – workspace 0
[TRT] – deviceMemory 2408448
[TRT] – bindings 2
[TRT] binding 0
– index 0
– name ‘data’
– type FP32
– in/out INPUT
– # dims 3
– dim #0 3 (CHANNEL)
– dim #1 224 (SPATIAL)
– dim #2 224 (SPATIAL)
[TRT] binding 1
– index 1
– name ‘prob’
– type FP32
– in/out OUTPUT
– # dims 3
– dim #0 1000 (CHANNEL)
– dim #1 1 (SPATIAL)
– dim #2 1 (SPATIAL)
[TRT]
[TRT] binding to input 0 data binding index: 0
[TRT] binding to input 0 data dims (b=1 c=3 h=224 w=224) size=602112
[TRT] binding to output 0 prob binding index: 1
[TRT] binding to output 0 prob dims (b=1 c=1000 h=1 w=1) size=4000
[TRT]
[TRT] device GPU, /usr/local/bin/networks/ResNet-18/ResNet-18.caffemodel initialized.
[TRT] imageNet – loaded 1000 class info entries
[TRT] imageNet – networks/ResNet-18/ResNet-18.caffemodel initialized.
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstCamera – attempting to create device v4l2:///dev/video0
[gstreamer] gstCamera – found v4l2 device: UVC Camera (046d:0825)
[gstreamer] v4l2-proplist, device.path=(string)/dev/video0, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)“UVC\ Camera\ (046d:0825)”, v4l2.device.bus_info=(string)usb-70090000.xusb-2.4, v4l2.device.version=(uint)264588, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] gstCamera – found 38 caps for v4l2 device /dev/video0
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [5] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 5/1 };
[gstreamer] [6] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [7] video/x-raw, format=(string)YUY2, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [8] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [9] video/x-raw, format=(string)YUY2, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [10] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [11] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [12] video/x-raw, format=(string)YUY2, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [13] video/x-raw, format=(string)YUY2, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [14] video/x-raw, format=(string)YUY2, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [15] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [16] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [17] video/x-raw, format=(string)YUY2, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [18] video/x-raw, format=(string)YUY2, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [19] image/jpeg, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [20] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [21] image/jpeg, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [22] image/jpeg, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [23] image/jpeg, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [24] image/jpeg, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [25] image/jpeg, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [26] image/jpeg, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [27] image/jpeg, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [28] image/jpeg, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [29] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [30] image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [31] image/jpeg, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [32] image/jpeg, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [33] image/jpeg, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [34] image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [35] image/jpeg, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [36] image/jpeg, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [37] image/jpeg, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] gstCamera – selected device profile: codec=raw format=yuyv width=640 height=480
[gstreamer] gstCamera pipeline string:
[gstreamer] v4l2src device=/dev/video0 ! video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480 ! appsink name=mysink
[gstreamer] gstCamera successfully created device v4l2:///dev/video0
[OpenGL] glDisplay – X screen 0 resolution: 640x480
[OpenGL] glDisplay – X window resolution: 640x480
[OpenGL] glDisplay – display device initialized (640x480)
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer message stream-start ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstCamera – onPreroll
[gstreamer] gstCamera recieve caps: video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
[gstreamer] gstCamera – recieved first frame, codec=raw format=yuyv width=640 height=480 size=614400
RingBuffer – allocated 4 buffers (614400 bytes each, 2457600 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
RingBuffer – allocated 4 buffers (4915200 bytes each, 19660800 bytes total)
class 0448 - 0.413330 (birdhouse)
Thank you for your Help.
Steffen
If you are forwarding, then it is likely some of the OpenGL and/or GPU content needs to run on the host PC and not the Jetson. See:
https://forums.developer.nvidia.com/t/running-graphical-cuda-sample-over-ssh-from-within-l4t-docker-container/113027/3
Does your operation work when running natively on the Jetson without forwarding? There is a very big difference between forwarding and a virtual server. Forwarding sends events, not results of events, and it is up to the PC to have all of the correct OpenGL and CUDA abilities when forwarding. When X is on the Jetson, and the program is running on the Jetson, then it is the Jetson’s libraries and GPU which does the work. A virtual desktop still runs locally to the Jetson, but instead of a physical display it has a program which can forward to another host (with the Jetson GPU and libraries doing the work).
An example of a virtual desktop which NVIDIA has tested on a Jetson is Vino. See “apt search vino”.
The sample may not X11 fordwarding. Suggest you try DeepStream SDK and enable RTSP streaming in sink so that you can stream the result to other devices. Please refer to
https://docs.nvidia.com/metropolis/deepstream/dev-guide/index.html#page/DeepStream_Development_Guide/deepstream_app_config.3.2.html#wwpID0ENHA
