How to migrate JetCam form VideoCapture
Hi expert
I have a program that is using opencv VideoCapture interface. But it cannot get the latest frame from capture usbcam (Logitech, Inc. Webcam C270). The result of the inference is always delayed by 6 seconds. In order to solve the issue, I want to migrate to jetcam.
import cv2
import tensorflow as tf
import tensornets as nets
<b>inputs = tf.placeholder(tf.float32, [None, 416, 416, 3]</b>)
model = nets.YOLOv3COCO(inputs, nets.Darknet19)
cap = cv2.VideoCapture("/dev/video0")
        frame = cap.read()[1]
        img=cv2.resize(frame,(416,416))
       <b> imge=np.array(img).reshape(-1,416,416,3)</b>
        preds = sess.run(model.preds, {inputs: model.preprocess(imge)})
but some error when migrate to jetcam
from jetcam.usb_camera import USBCamera
camera = USBCamera(width=416, height=416, format='brg8', capture_width=640, capture_height=480, capture_device=0)
<b>inputs = tf.placeholder(tf.float32, [None, 416, 416, 3])</b>
        camera.running = True
        frame = camera.read()
        start_time = time.time()
        preds = sess.run(model.preds, {inputs: model.preprocess(frame)})
error
evice (/job:localhost/replica:0/task:0/device:GPU:0 with 1500 MB memory) -> physical GPU (device: 0, name: NVIDIA Tegra X1, pci bus id: 0000:00:00.0, compute capability: 5.3)
  File "jetcam-show_last_frame.py", line 22, in <module>
  File "/home/hgnan/.local/lib/python3.6/site-packages/tensornets/preprocess.py", line 39, in _direct
    return __preprocess_dict__[model_name](inputs, target_size)
  File "/home/hgnan/.local/lib/python3.6/site-packages/tensornets/preprocess.py", line 112, in darknet_preprocess
    y = np.zeros((len(x), h, w, x.shape[3]))
Any idea for me.
On Nano, we support gstreamer and tegra_multimedia_api. Are you able to run the camera in gstreamer pipeline?
Below post shows how to run USB cam in a gstreamer pipeline:
[url]Logitech C930e on Jetson TX1 very slow and choppy video - Jetson TX1 - NVIDIA Developer Forums
I can able run the camera in gstreamer pipeline.
jetson@jetson-nano:~/deepstream_sdk_v4.0_jetson/samples/configs/deepstream-app$ v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
        Index       : 0
        Type        : Video Capture
        Pixel Format: 'YUYV'
                        Interval: Discrete 0.033s (30.000 fps)
                        Interval: Discrete 0.040s (25.000 fps)
                        Interval: Discrete 0.050s (20.000 fps)
                        Interval: Discrete 0.067s (15.000 fps)
                        Interval: Discrete 0.100s (10.000 fps)
                        Interval: Discrete 0.200s (5.000 fps)
                        Interval: Discrete 0.133s (7.500 fps)
        Index       : 1
        Pixel Format: 'MJPG' (compressed)
jetson@jetson-nano:~$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvoverlaysink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
 ^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:02:01.951714667
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
How to use jetcam inference for tensornets?
Do I need to reshape the frame before model.preprocess(frame) ?
deepstream-app supports yolo plugin and v4l2 source. Please follow
deepstream_sdk_v4.0_jetson\sources\objectDetector_Yolo\README
And adapt the source in the config file:
# Copyright (c) 2019 NVIDIA Corporation.  All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=1
num-sources=1
camera-v4l2-dev-node=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
gpu-id=0
cudadec-memtype=0
