Stream 4k webcam - GStreamer
Hi, I have Kodak PIXPRO SP360 4k camera connected to the Jetson Nano via USB cable.
I want to be able to see that video over browser, either with RTSP stream, Webrtc or something else.
It doesn’t matter how it works in terms of technology, as long as it works. So if you have any ideas or suggestions be free to share them.
I’m currently trying to run the basic setup.
./test-launch "nvarguscamerasrc ! video/x-raw(memory:NVMM), format=NV12, width=1920, height=1080, framerate=30/1 ! nvvidconv ! video/x-raw, width=640, height=480, format=NV12, framerate=30/1 ! omxh265enc ! rtph265pay name=pay0 pt=96 config-interval=1"
and
gst-launch-1.0 rtspsrc location=rtsp://127.0.0.1:8554/test ! queue ! decodebin ! videoconvert ! xvimagesink
and I’m getting the error saying
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://127.0.0.1:8554/test
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not get/set settings from/on resource.
Additional debug info:
gstrtspsrc.c(6999): gst_rtspsrc_setup_streams_start (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
SDP contains no streams
ERROR: pipeline doesn't want to preroll.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
(test-launch:22440): GLib-GObject-WARNING **: 11:36:46.018: invalid cast from 'GstRtpH265Pay' to 'GstBin'
(test-launch:22440): GStreamer-CRITICAL **: 11:36:46.018: gst_bin_get_by_name: assertion 'GST_IS_BIN (bin)' failed
I have also tried an option that worked for me on PC but I can’t get it to work on Jetson. The setup goes as follows.
Download Streameye from https://github.com/ccrisan/streameye and run:
netcat -l 8700 | ./streameye -p 1337
To send the webcam stream I run:
gst-launch-1.0 v4l2src device=/dev/video0 ! decodebin ! videoconvert ! videoscale ! videorate ! jpegenc quality=30 ! tcpclientsink host=127.0.0.1 port=8700
After this I get:
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
gstbasesrc.c(3064): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:03.944998186
We support USB cameras through uvc drivers. Please check FAQ
Q: I have a USB camera. How can I lauch it on Jetson Nano?
Hi, I don’t have a problem displaying webcam with Gstreamer or VLC.
I need to be able to access the video via browser from another PC.
Also, this may be important. When I run the commands from the post you’ve linked I get:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Linking ‘v4l2src ! decodebin’ looks not right. You should get supported formats through ‘v4l2-ctl’ and configure it into v4l2src.
I don’t understand why wouldn’t it work. It works on Ubuntu 18.04 laptop, with the same camera and same pipeline.
When I run
v4l2-ctl -d /dev/video1 --list-formats-ext
I get:
ioctl: VIDIOC_ENUM_FMT
	Index       : 0
	Type        : Video Capture
	Pixel Format: 'MJPG' (compressed)
		Size: Discrete 3840x2160
			Interval: Discrete 0.200s (5.000 fps)
		Size: Discrete 2880x2880
		Size: Discrete 2048x2048
		Size: Discrete 1440x1440
			Interval: Discrete 0.067s (15.000 fps)
		Size: Discrete 1920x1080
			Interval: Discrete 0.033s (30.000 fps)
Please try following commands:
$ sudo jetson_clocks
$ gst-launch-1.0 v4l2src device=/dev/video1 io-mode=2 ! image/jpeg,width=1280,height=720,framerate=30/1 ! nvjpegdec ! video/x-raw ! xvimagesink
There is a known memleak on r32.2.1. Please also apply the prebuilt lib:
https://elinux.org/L4T_Jetson/r32.2.1_patch
[MMAPI][DS4.0] Memory leak in MJPEG decoding
So this is “working”, it’s displaying 4k video in 5fps (that’s supported), but it goes to the green screen after some time. I think that will be fixed once I do the patch.
I can’t use this with the streameye, it gives me the following
2019-11-29 10:44:48: ERROR: input: jpeg size too large, discarding buffer
when I run:
gst-launch-1.0 v4l2src device=/dev/video1 io-mode=2 ! image/jpeg,width=640,height=360,framerate=5/1 ! nvjpegdec ! video/x-raw ! tcpclientsink host=127.0.0.1 port=8700
How can I use your pipeline with ./test-launch from gst-server examples in order to get RTSP that I can access from another device?
When I run:
./test-launch " v4l2src device=/dev/video1 io-mode=2 ! image/jpeg,width=1280,height=720,framerate=30/1 ! nvjpegdec ! video/x-raw ! xvimagesink name=pay0 pt=96 config-interval=1"
And try to capture RTSP stream with
I get the following error in first terminal:
** (test-launch:32689): CRITICAL **: 11:10:48.227: gst_rtsp_media_create_stream: assertion 'GST_IS_PAD (pad)' failed
(test-launch:32689): GStreamer-CRITICAL **: 11:10:48.227: gst_object_unref: assertion 'object != NULL' failed
And this in the one where I ran pipeline to capture rtsp:
Please refer to examples of using test-launch:
https://devtalk.nvidia.com/default/topic/1018689/jetson-tx2/vlc-playing-gstreamer-flow/post/5187270/#5187270
https://devtalk.nvidia.com/default/topic/1043770/jetson-tx2/problems-minimizing-latency-and-maximizing-quality-for-rtsp-and-mpeg-ts-/post/5295828/#5295828
I’ve tried it, you can see it in the comment above. I’m not sure which part of this pipeline needs to go with ./test-launch.
Those examples are more or less just the basic examples, I can’t seem to combine them.
In general, the pipeline is ‘source + encode + rtph26Xpay’. You may try
"v4l2src device=/dev/video1 io-mode=2 ! image/jpeg,width=1280,height=720,framerate=30/1 ! nvjpegdec ! video/x-raw ! omxh265enc ! rtph265pay name=pay0 pt=96"
When I run that and try to read the stream using
I get the following. In the window where I started the stream I get:
stream ready at rtsp://127.0.0.1:8554/test
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
NVMEDIA: H265 : Profile : 1
And in the one where I tried to read it I get:
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 279
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 279
WARNING: from element /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0: not negotiated
gstbasetransform.c(1415): gst_base_transform_reconfigure (): /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0:
not negotiated
And it just keep printing the warning.
You may try VLC player as the example does. Would be better if you can run example successfully as a reference.
I am trying that at the moment, and it doesn’t work. I am running the same pipeline and
vlc rtsp://127.0.0.1:8554/test
and I’m getting:
VLC media player 3.0.8 Vetinari (revision 3.0.8-0-gf350b6b5a7)
[00000055b0f2c600] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Created new TCP socket 38 for connection
Bus error (core dumped)
0:00:04.075103919 29935   0x55867b4590 WARN                     omx gstomx.c:2826:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /home/jetsontx2/.config:/etc/xdg/xdg-unity:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
0:00:04.091633187 29935   0x7fa8005720 FIXME           videodecoder gstvideodecoder.c:933:gst_video_decoder_drain_out:<nvjpegdec0> Sub-class should implement drain()
0:00:04.096427771 29935   0x7fa8005720 WARN          v4l2bufferpool gstv4l2bufferpool.c:790:gst_v4l2_buffer_pool_start:<v4l2src0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:05.566157767 29935   0x7fa8005720 FIXME           videodecoder gstvideodecoder.c:933:gst_video_decoder_drain_out:<nvjpegdec0> Sub-class should implement drain()
0:00:05.569537944 29935   0x7fa8005720 FIXME           videoencoder gstvideoencoder.c:661:gst_video_encoder_setcaps:<omxh265enc-omxh265enc0> GstVideoEncoder::reset() is deprecated
Framerate set to : 5 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 8
0:00:05.571147168 29935   0x7fa8005720 WARN             omxvideoenc gstomxvideoenc.c:1860:gst_omx_video_enc_set_format:<omxh265enc-omxh265enc0> Error setting temporal_tradeoff 0 : Vendor specific error (0x00000001)
0:00:05.633032247 29935   0x55867b4590 FIXME              rtspmedia rtsp-media.c:3841:gst_rtsp_media_suspend: suspend for dynamic pipelines needs fixing
0:00:05.634079772 29935   0x55867b4590 FIXME              rtspmedia rtsp-media.c:3841:gst_rtsp_media_suspend: suspend for dynamic pipelines needs fixing
0:00:05.634117756 29935   0x55867b4590 WARN               rtspmedia rtsp-media.c:3867:gst_rtsp_media_suspend: media 0x7fb00a0280 was not prepared
0:00:05.638013840 29935   0x55867b4590 FIXME             rtspclient rtsp-client.c:1657:handle_play_request:<GstRTSPClient@0x55869a1110> Add support for seek style (null)
0:00:05.638167505 29935   0x55867b4590 FIXME              rtspmedia rtsp-media.c:2437:gst_rtsp_media_seek_full:<GstRTSPMedia@0x7fb00a0280> Handle going back to 0 for none live not seekable streams.
0:00:06.427259002 29935   0x55867b4590 WARN               rtspmedia rtsp-media.c:4156:gst_rtsp_media_set_state: media 0x7fb00a0280 was not prepared
There is a know memleak. Please apply the patch.
With patch being applied, we can launch E-Con See3CAM_CU135 in executing the command:
$ ./test-launch "v4l2src device=/dev/video1 io-mode=2 ! image/jpeg,width=3840,height=2160,framerate=30/1 ! nvjpegdec ! video/x-raw ! omxh265enc ! rtph265pay name=pay0 pt=96"
Ok, I’ll try this as soon as I do the patch.
On that topic, I can’t find any instructions on the forum on how to apply these patches.
Please overwrite libnvjpeg.so
$ sudo cp -i libnvjpeg.so /usr/lib/aarch64-linux-gnu/tegra
[sudo] password for nvidia:
cp: overwrite '/usr/lib/aarch64-linux-gnu/tegra/libnvjpeg.so'? y
It still doesn’t work.
I’m trying:
./test-launch "v4l2src device=/dev/video0 io-mode=2 ! image/jpeg,width=3840,height=2160,framerate=5/1 ! nvjpegdec ! video/x-raw ! omxh265enc ! rtph265pay name=pay0 pt=96"
I am able to run
fprobe -v quiet -print_format json -show_streams rtsp://127.0.0.1:8554/test
And I get:
    "streams": [
            "index": 0,
            "codec_name": "hevc",
            "codec_long_name": "H.265 / HEVC (High Efficiency Video Coding)",
            "profile": "Main",
            "codec_type": "video",
            "codec_time_base": "0/1",
            "codec_tag_string": "[0][0][0][0]",
            "codec_tag": "0x0000",
            "width": 3840,
            "height": 2160,
            "coded_width": 3840,
            "coded_height": 2176,
            "has_b_frames": 0,
            "sample_aspect_ratio": "0:1",
            "display_aspect_ratio": "0:1",
            "pix_fmt": "yuv420p",
            "level": 120,
            "color_range": "tv",
            "refs": 1,
            "r_frame_rate": "5/1",
            "avg_frame_rate": "0/0",
            "time_base": "1/90000",
            "start_pts": 27361,
            "start_time": "0.304011",
            "disposition": {
                "default": 0,
                "dub": 0,
                "original": 0,
                "comment": 0,
                "lyrics": 0,
                "karaoke": 0,
                "forced": 0,
                "hearing_impaired": 0,
                "visual_impaired": 0,
                "clean_effects": 0,
                "attached_pic": 0,
                "timed_thumbnails": 0
But when I try to capture it with VLC using:
I get:
[0000005576fed600] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Seems to be an issue in vlc installed on Jetson Nano. We use VLC player on x86 PC.
On Nano, please try uridecodebin:
$ gst-launch-1.0 uridecodebin uri=rtsp://127.0.0.1:8554/test ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1920,height=1080' ! nvoverlaysink
If your TV supports 4K resolution, you can remove nvvidconv which does downscale to 1080p.
$ gst-launch-1.0 uridecodebin uri=rtsp://127.0.0.1:8554/test ! nvoverlaysink
