legion@legion-desktop:~$ gst-launch-1.0 -v v4l2src device=/dev/video0 ! nvvidconv ! nvv4l2h264enc insert-sps-pps=1 insert-vui=1 ! h264parse ! rtph264pay name=pay0 ! fakesink
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)10/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)10/1, pixel-aspect-ratio=(fraction)1/1, format=(string)I420, interlace-mode=(string)progressive
/GstPipeline:pipeline0/nvv4l2h264enc:nvv4l2h264enc0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, level=(string)NULL, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, level=(string)NULL, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2
Redistribute latency...
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
/GstPipeline:pipeline0/nvv4l2h264enc:nvv4l2h264enc0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)10/1, pixel-aspect-ratio=(fraction)1/1, format=(string)I420, interlace-mode=(string)progressive
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)10/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
H264: Profile = 66, Level = 0
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, profile=(string)constrained-baseline, level=(string)3.1, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, codec_data=(buffer)0142401fffe1001c6742401f965402802dd350000054000003000400000300523c2211a801000468ce3c80
/GstPipeline:pipeline0/GstRtpH264Pay:pay0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)42401f, sprop-parameter-sets=(string)"Z0JAH5ZUAoAt01AAAFQAAAMABAAAAwBSPCIRqA\=\=\,aM48gA\=\=", payload=(int)96, ssrc=(uint)2515986560, timestamp-offset=(uint)2128799388, seqnum-offset=(uint)7648, a-framerate=(string)10
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)42401f, sprop-parameter-sets=(string)"Z0JAH5ZUAoAt01AAAFQAAAMABAAAAwBSPCIRqA\=\=\,aM48gA\=\=", payload=(int)96, ssrc=(uint)2515986560, timestamp-offset=(uint)2128799388, seqnum-offset=(uint)7648, a-framerate=(string)10
/GstPipeline:pipeline0/GstRtpH264Pay:pay0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, profile=(string)constrained-baseline, level=(string)3.1, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, codec_data=(buffer)0142401fffe1001c6742401f965402802dd350000054000003000400000300523c2211a801000468ce3c80
/GstPipeline:pipeline0/GstRtpH264Pay:pay0: timestamp = 2128802837
/GstPipeline:pipeline0/GstRtpH264Pay:pay0: seqnum = 7648
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:02.596071539
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
legion@legion-desktop:~$ gst-launch-1.0 -v v4l2src device=/dev/video0 ! videoconvert ! nvvidconv ! nvv4l2h264enc insert-sps-pps=1 insert-vui=1 ! h264parse ! rtph264pay name=pay0 ! fakesink
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)10/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)10/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstRtpH264Pay:pay0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)42401f, sprop-parameter-sets=(string)"Z0JAH5ZUAoAt01AAAFQAAAMABAAAAwBSPCIRqA\=\=\,aM48gA\=\=", payload=(int)96, ssrc=(uint)4227956481, timestamp-offset=(uint)2721908892, seqnum-offset=(uint)20077, a-framerate=(string)10
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)42401f, sprop-parameter-sets=(string)"Z0JAH5ZUAoAt01AAAFQAAAMABAAAAwBSPCIRqA\=\=\,aM48gA\=\=", payload=(int)96, ssrc=(uint)4227956481, timestamp-offset=(uint)2721908892, seqnum-offset=(uint)20077, a-framerate=(string)10
/GstPipeline:pipeline0/GstRtpH264Pay:pay0: timestamp = 2721912552
/GstPipeline:pipeline0/GstRtpH264Pay:pay0: seqnum = 20077
Execution ended after 0:00:03.651083881
It’s running - nothing is happening, but the process is running and I need to end it with Ctrl+C
