Hi I am working on the Jetson Nano developer kit. I have not worked with gstreamer and I am testing out the jetson.inference and jetson.utils. I am trying to get the detectnet-camera python example working. I have a usb camera, which works fine in cheese, with the following v4l2-ctl -d /dev/video0 --list-formats-ext output:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'UYVY'
Interval: Discrete 0.019s (52.000 fps)
Interval: Discrete 0.077s (13.000 fps)
Size: Discrete 1920x1080
Interval: Discrete 0.167s (6.000 fps)
Index : 1
Pixel Format: 'MJPG' (compressed)
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1920x1072
Index : 2
Pixel Format: 'H264' (compressed)
When I run detectnet.py, the detections run fine but I get no display window. So I ran the following modified script, to cutout the detections and just get the display working:
import jetson.utils
camera = jetson.utils.gstCamera()
display = jetson.utils.glDisplay()
while display.IsOpen():
img, height, width = camera.CaptureRGBA()
display.RenderOnce(img, width, height)
display.SetTitle("Camera read and display test...")
which opens an empty display window and outputs the following:
jetson.utils.__init__.py
jetson.utils -- initializing Python 3.6 bindings...
jetson.utils -- registering module functions...
jetson.utils -- done registering module functions
jetson.utils -- registering module types...
jetson.utils -- done registering module types
jetson.utils -- done Python 3.6 binding initialization
jetson.utils -- PyCamera_New()
jetson.utils -- PyCamera_Init()
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVARGUS, camera 0
[gstreamer] gstCamera pipeline string:
nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=30/1, format=(string)NV12 ! nvvidconv flip-method=2 ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully initialized with GST_SOURCE_NVARGUS, camera 0
jetson.utils -- PyDisplay_New()
jetson.utils -- PyDisplay_Init()
[OpenGL] glDisplay -- X screen 0 resolution: 1920x1080
[OpenGL] glDisplay -- display device initialized
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> nvvconv0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> nvarguscamerasrc0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvvconv0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvarguscamerasrc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer msg new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvvconv0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvarguscamerasrc0
[gstreamer] gstreamer msg stream-start ==> pipeline0
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:532 No cameras available
[gstreamer] gstCamera onEOS
Any ideas on where I can look to get this working? Am I missing any arguments? The documentation on jetson.utils is sparse. Any help is appreciated.
**Update
After specifying the dimensions and the device by changing
to
camera = jetson.utils.gstCamera(1920, 1080, “/dev/video0”)
I get the following output
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVARGUS, camera /dev/video0
v4l2src device=/dev/video0 ! video/x-raw, width=(int)1920, height=(int)1080, format=YUY2 ! videoconvert ! video/x-raw, format=RGB ! videoconvert !appsink name=mysink
[gstreamer] gstCamera successfully initialized with GST_SOURCE_V4L2, camera /dev/video0
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert1
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert1
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert0
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstreamer v4l2src0 ERROR Internal data stream error.
[gstreamer] gstreamer Debugging info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
