please tell me the steps to follow. I am using Linux ubuntu.
You may refer to
[url]Logitech C930e on Jetson TX1 very slow and choppy video - Jetson TX1 - NVIDIA Developer Forums
Hi DaneLLL,
Thanks. From Linux ubuntu terminal, I can connect to USB camera now after installing V4L-utils package.
My Jetson Nano DetectNet-Camera program still not detecting USB cam Logitech C922.
I don’t know how to set the default camera to USB instead of CSI Rasberry Pi.
Can share with me some running source code?
I am new to Nvidia jetson nano product.
Please, Help.
Regards,
Rajesh
Thailand
Dear All
I get same issue. My USB Logitech webcam done well when use Cheese Webcame Booth. But when run camera module of Jetbot , camera dont’t display.
Please help
THanks,
And I also get the same issue. My USB Logitech webcam done well when use Cheese Webcame Booth. But when run camera module, camera dont’t display. My camera is Logitech C170.
when I use
./imagenet-camera
then I got
[gstreamer] initialized gstreamer, version 1.14.4.0
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVARGUS, camera 0
[gstreamer] gstCamera pipeline string:
nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=30/1, format=(string)NV12 ! nvvidconv flip-method=2 ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully initialized with GST_SOURCE_NVARGUS, camera 0
imagenet-camera: successfully initialized camera device
width: 1280
height: 720
depth: 12 (bpp)
imageNet -- loading classification network model from:
-- prototxt networks/googlenet.prototxt
-- model networks/bvlc_googlenet.caffemodel
-- class_labels networks/ilsvrc12_synset_words.txt
-- input_blob 'data'
-- output_blob 'prob'
-- batch_size 1
[TRT] TensorRT version 5.0.6
[TRT] loading NVIDIA plugins...
[TRT] completed loading NVIDIA plugins.
[TRT] detected model format - caffe (extension '.caffemodel')
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file networks/bvlc_googlenet.caffemodel.1.1.GPU.FP16.engine
[TRT] loading network profile from engine cache... networks/bvlc_googlenet.caffemodel.1.1.GPU.FP16.engine
[TRT] device GPU, networks/bvlc_googlenet.caffemodel loaded
[TRT] device GPU, CUDA engine context initialized with 2 bindings
[TRT] binding -- index 0
-- name 'data'
-- type FP32
-- in/out INPUT
-- # dims 3
-- dim #0 3 (CHANNEL)
-- dim #1 224 (SPATIAL)
-- dim #2 224 (SPATIAL)
[TRT] binding -- index 1
-- name 'prob'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 1000 (CHANNEL)
-- dim #1 1 (SPATIAL)
-- dim #2 1 (SPATIAL)
[TRT] binding to input 0 data binding index: 0
[TRT] binding to input 0 data dims (b=1 c=3 h=224 w=224) size=602112
[TRT] binding to output 0 prob binding index: 1
[TRT] binding to output 0 prob dims (b=1 c=1000 h=1 w=1) size=4000
device GPU, networks/bvlc_googlenet.caffemodel initialized.
[TRT] networks/bvlc_googlenet.caffemodel loaded
imageNet -- loaded 1000 class info entries
[OpenGL] glDisplay -- X screen 0 resolution: 1920x1080
[OpenGL] glDisplay -- display device initialized
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> nvvconv0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> nvarguscamerasrc0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvvconv0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvarguscamerasrc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer msg new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer msg stream-start ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvvconv0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvarguscamerasrc0
imagenet-camera: camera open for streaming
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
The same problem, as member 312529167, I am facing.
Any solution?
Hi Rajesh, 312529167 - see the command line parameters to imagenet-camera here:
https://github.com/dusty-nv/jetson-inference/blob/master/docs/imagenet-camera-2.md
(or run the program with --help to see usage info)
You want to specify the --camera option and provide it the V4L2 node you want to use (e.g. /dev/video0)
For example:
$ imagenet-camera --camera=/dev/video0
You can check which V4L2 /dev/video node to use with these commands:
$ sudo apt-get install v4l-utils
$ v4l2-ctl --list-formats-ext
Note that the usage of the --camera flag is the same for detectnet-camera program as well.
Thanks​ dusty_nv sir. I​ hope​ it would​ work.
Dusty_nv sir, Still same result.
I used your suggested coding.
But no change in camera initialize. Still using default CSI raspberry pi camera.
Please see the camera initialize code:
For USB camera, may be V4L2 should be included while initializing. But NVARGUS and nvarguscamerasrc is in output.
My camera model is Logitech C922 and I am plugged it in Jetson Nano USB3.0 slot.
Can you please share running source code?
Dear Dusty_nv sir,
I done it.
Steps:
- Installed fresh copy of jetson-inference from GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson.
- Given path on ubuntu root - jetson-inference/build/aarch64/bin
- Run command - ./imagenet-camera --camera=/dev/video1
- My USB camera Logitech C922 is connected to jetson nano along with Raspberry Pi camera so is used
USB camera name as /dev/video1 (if USB camera is alone than can use /dev/video0) - Raspberry Pi camera already working fine with all examples.
Detectnet-camera example also worked fine with USB camera.
Thanks a lot.
Regards,
Rajesh
