i’m trying to run imagenet-camera demo with Logitech Webcam C525.i am getting complete blank screen with following
[gstreamer] initialized gstreamer, version 1.14.1.0
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVCAMERA
[gstreamer] gstCamera pipeline string:
v4l2src device=/dev/video0 ! video/x-raw, width=(int)1280, height=(int)720, format=RGB ! videoconvert ! video/x-raw, format=RGB ! videoconvert !appsink name=mysink
[gstreamer] gstCamera successfully initialized with GST_SOURCE_V4L2
imagenet-camera: successfully initialized video device
width: 1280
height: 720
depth: 24 (bpp)
imageNet -- loading classification network model from:
-- prototxt networks/googlenet.prototxt
-- model networks/bvlc_googlenet.caffemodel
-- class_labels networks/ilsvrc12_synset_words.txt
-- input_blob 'data'
-- output_blob 'prob'
-- batch_size 2
[TRT] TensorRT version 5.0.3
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16, INT8
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file networks/bvlc_googlenet.caffemodel.2.1.GPU.FP16.engine
[TRT] loading network profile from engine cache... networks/bvlc_googlenet.caffemodel.2.1.GPU.FP16.engine
[TRT] device GPU, networks/bvlc_googlenet.caffemodel loaded
[TRT] device GPU, CUDA engine context initialized with 2 bindings
[TRT] networks/bvlc_googlenet.caffemodel input binding index: 0
[TRT] networks/bvlc_googlenet.caffemodel input dims (b=2 c=3 h=224 w=224) size=1204224
[cuda] cudaAllocMapped 1204224 bytes, CPU 0x21b996000 GPU 0x21b996000
[TRT] networks/bvlc_googlenet.caffemodel output 0 prob binding index: 1
[TRT] networks/bvlc_googlenet.caffemodel output 0 prob dims (b=2 c=1000 h=1 w=1) size=8000
[cuda] cudaAllocMapped 8000 bytes, CPU 0x21bb96000 GPU 0x21bb96000
device GPU, networks/bvlc_googlenet.caffemodel initialized.
[TRT] networks/bvlc_googlenet.caffemodel loaded
imageNet -- loaded 1000 class info entries
default X screen 0: 1920 x 1080
[OpenGL] glDisplay display window initialized
[OpenGL] creating 1280x720 texture
loaded image fontmapA.png (256 x 512) 2097152 bytes
[cuda] cudaAllocMapped 2097152 bytes, CPU 0x21bd96000 GPU 0x21bd96000
[cuda] cudaAllocMapped 8192 bytes, CPU 0x21bb98000 GPU 0x21bb98000
[gstreamer] gstreamer transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert1
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert1
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer msg new-clock ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstreamer msg stream-start ==> pipeline0
[gstreamer] gstCamera onEOS
[gstreamer] gstreamer v4l2src0 ERROR Internal data stream error.
[gstreamer] gstreamer Debugging info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
imagenet-camera: camera open for streaming
imagenet-camera: failed to capture frame
imagenet-camera: failed to convert from NV12 to RGBA
[TRT] imageNet::Classify( 0x(nil), 1280, 720 ) -> invalid parameters
[cuda] cudaNormalizeRGBA((float4*)imgRGBA, make_float2(0.0f, 255.0f), (float4*)imgRGBA, make_float2(0.0f, 1.0f), camera->GetWidth(), camera->GetHeight())
[cuda] invalid device pointer (error 17) (hex 0x11)
[cuda] /home/nvidia/Documents/jetson-inference/imagenet-camera/imagenet-camera.cpp:193
[cuda] registered 14745600 byte openGL texture for interop access (1280x720)
v4l2-ctl -V output is
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'YUYV'
Field : None
Bytes per Line : 1280
Size Image : 614400
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
lsusb output is
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 046d:0826 Logitech, Inc. HD Webcam C525
Bus 001 Device 004: ID 0461:4d22 Primax Electronics, Ltd
Bus 001 Device 003: ID 413c:2003 Dell Computer Corp. Keyboard
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
why am i getting blank screen ? is webcam not suitable (I already changed DEFAULT_CAMERA value) ?
if its suitable how to get past that.
