Hi all,
After following the tutorial here GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson., I was able to successfully modify the DEFAULT_CAMERA line at the top of imagenet-camera.cpp to accommodate a USB camera (Logitech C310). The commands that use imagenet-camera function as expected, such as ./imagenet-camera googlenet.
A few days ago, the commands that use detectnet-camera, such as ./detectnet-camera multiped, were working too! However, I ran it again today and got the following error:
nvidia@tegra-ubuntu:/media/nvidia/SSD1TB/home/nvidia/nvidia_digits/jetson-inference/build/aarch64/bin$ ./detectnet-camera multiped
detectnet-camera
args (2): 0 [./detectnet-camera] 1 [multiped]
[gstreamer] initialized gstreamer, version 1.8.3.0
[gstreamer] gstreamer decoder pipeline string:
nvcamerasrc fpsRange="30.0 30.0" ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12 ! nvvidconv flip-method=0 ! video/x-raw ! appsink name=mysink
detectnet-camera: successfully initialized video device
width: 1280
height: 720
depth: 12 (bpp)
detectNet -- loading detection network model from:
-- prototxt networks/multiped-500/deploy.prototxt
-- model networks/multiped-500/snapshot_iter_178000.caffemodel
-- input_blob 'data'
-- output_cvg 'coverage'
-- output_bbox 'bboxes'
-- mean_pixel 117.000000
-- threshold 0.500000
-- batch_size 2
[GIE] TensorRT version 2.1, build 2102
[GIE] attempting to open cache file networks/multiped-500/snapshot_iter_178000.caffemodel.2.tensorcache
[GIE] loading network profile from cache... networks/multiped-500/snapshot_iter_178000.caffemodel.2.tensorcache
[GIE] platform has FP16 support.
[GIE] networks/multiped-500/snapshot_iter_178000.caffemodel loaded
[GIE] CUDA engine context initialized with 3 bindings
[GIE] networks/multiped-500/snapshot_iter_178000.caffemodel input binding index: 0
[GIE] networks/multiped-500/snapshot_iter_178000.caffemodel input dims (b=2 c=3 h=512 w=1024) size=12582912
[cuda] cudaAllocMapped 12582912 bytes, CPU 0x102a00000 GPU 0x102a00000
[GIE] networks/multiped-500/snapshot_iter_178000.caffemodel output 0 coverage binding index: 1
[GIE] networks/multiped-500/snapshot_iter_178000.caffemodel output 0 coverage dims (b=2 c=2 h=32 w=64) size=32768
[cuda] cudaAllocMapped 32768 bytes, CPU 0x103600000 GPU 0x103600000
[GIE] networks/multiped-500/snapshot_iter_178000.caffemodel output 1 bboxes binding index: 2
[GIE] networks/multiped-500/snapshot_iter_178000.caffemodel output 1 bboxes dims (b=2 c=4 h=32 w=64) size=65536
[cuda] cudaAllocMapped 65536 bytes, CPU 0x103608000 GPU 0x103608000
networks/multiped-500/snapshot_iter_178000.caffemodel initialized.
[cuda] cudaAllocMapped 32 bytes, CPU 0x103800000 GPU 0x103800000
maximum bounding boxes: 8192
[cuda] cudaAllocMapped 131072 bytes, CPU 0x103a00000 GPU 0x103a00000
[cuda] cudaAllocMapped 65536 bytes, CPU 0x103618000 GPU 0x103618000
default X screen 0: 1920 x 1080
[OpenGL] glDisplay display window initialized
[OpenGL] creating 1280x720 texture
loaded image fontmapA.png (256 x 512) 2097152 bytes
[cuda] cudaAllocMapped 2097152 bytes, CPU 0x103c00000 GPU 0x103c00000
[cuda] cudaAllocMapped 8192 bytes, CPU 0x103e00000 GPU 0x103e00000
[gstreamer] gstreamer transitioning pipeline to GST_STATE_PLAYING
Socket read error. Camera Daemon stopped functioning.....
gst_nvcamera_open() failed ret=0
[gstreamer] gstreamer failed to set pipeline state to PLAYING (error 0)
detectnet-camera: failed to open camera for streaming
I’m trying to pinpoint what might be going wrong…can you please help?
