Does imagenet-camera work with a V4l2 device on TX2(R28.1)?
We tried to use a V4l2 yuv camera and got error-“failed to open camera for streaming.”
We modified the DEFAULT_CAMERA to 0 and set gstreamer decoder pipeline string as teh following:
v4l2src device=/dev/video0" ! video/x-raw, width=(int)1920, height=(int)1080, format=(string)I420 ! nvvidconv ! video/x-raw(memory:NVMM) ! appsink name=mysink
Thank you for any advice.
Here is the error log.
nvidia@tegra-ubuntu:~/TR/jetson-inference/build/aarch64/bin$ ./imagenet-camera
imagenet-camera
args (1): 0 [./imagenet-camera]
We just double checked jetson_infernce with a Logitech webcam.
We can open camera without issue. Here is our changes:
diff --git a/imagenet-camera/imagenet-camera.cpp b/imagenet-camera/imagenet-camera.cpp
index 24e25c6..fcdf8cb 100644
--- a/imagenet-camera/imagenet-camera.cpp
+++ b/imagenet-camera/imagenet-camera.cpp
@@ -34,7 +34,7 @@
#include "imageNet.h"
-#define DEFAULT_CAMERA -1 // -1 for onboard camera, or change to index of /dev/video V4L2 camera (>=0)
+#define DEFAULT_CAMERA 1 // -1 for onboard camera, or change to index of /dev/video V4L2 camera (>=0)
Could you clean build the project and try it again?
Plus, does Face-recognition support a v4l2 device?
On the same Tx2, face-recognition failed to run with a v4l2 device and showed “cudaPreImageNetMean failed”.
nvidia@tegra-ubuntu:~/Face-Recognition/build/aarch64/bin$ ./face-recognition
Building and running a GPU inference engine for /home/nvidia/Face-Recognition/data/deploy.prototxt, N=1…
[gstreamer] initialized gstreamer, version 1.8.3.0
[gstreamer] gstreamer decoder pipeline string:
v4l2src device=/dev/video0 ! video/x-raw, width=(int)1920, height=(int)1080, format=(string)I420 ! videoconvert ! video/x-raw, format=RGB ! videoconvert ! appsink name=mysink
successfully initialized video device
width: 1920
height: 1080
depth: 24 (bpp)
Bindings after deserializing:
Binding 0 (data): Input.
Binding 1 (coverage_fd): Output.
Binding 2 (bboxes_fd): Output.
Binding 3 (count_fd): Output.
Binding 4 (bbox_fr): Output.
Binding 5 (bbox_id): Output.
Binding 6 (softmax_fr): Output.
Binding 7 (label): Output.
loaded image /home/nvidia/Face-Recognition/data/fontmapA.png (256 x 512) 2097152 bytes
[cuda] cudaAllocMapped 2097152 bytes, CPU 0x102a00000 GPU 0x102a00000
[cuda] cudaAllocMapped 8192 bytes, CPU 0x102c00000 GPU 0x102c00000
default X screen 0: 1920 x 1200
[OpenGL] glDisplay display window initialized
[OpenGL] creating 1920x1080 texture
[gstreamer] gstreamer transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert1
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert1
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer msg new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer msg stream-start ==> pipeline0
Allocate memory: input blob
Allocate memory: coverage
Allocate memory: box
Allocate memory: count
Allocate memory: selected bbox
Allocate memory: selected index
Allocate memory: softmax
Allocate memory: label
failed to capture frame
failed to convert from NV12 to RGBA
[cuda] cudaPreImageNetMean((float4*)imgRGBA, camera->GetWidth(), camera->GetHeight(), data, dimsData.w(), dimsData.h(), make_float3(127.0f, 127.0f, 127.0f))
[cuda] invalid device pointer (error 17) (hex 0x11)
[cuda] /home/nvidia/Face-Recognition/face-recognition/face-recognition.cpp:224
Yes. Face recognition doesn’t support the v4l2 camera.
This sample targets for TensorRT plugin layer demonstration. We don’t enable it with v4l2 camera support.
Please refer to jeston_inference for the TensorRT+v4l2 camera use-case.
