Enabling camera on Jetson TX1 board
Just got my TX1 development system.
I see the camera on the board, but there is no /dev/video0.
How do you enable/use the camera?
Thanks,
K
I am also curious how to enable the camera. I have the camera on the board as well but no /dev/video0 also.
I too am curious about enabling the camera.
Rick
Im experiencing same issues I cant find any documentation on taking a picture with the TX1 and i can only get a /dev/video0 when i plug in a usb webcam
help us nvidia one konobe your our only hope!
At the time of launch the V4L2 driver wasn’t ready (which would make the /dev/video* node). However it will be coming in the next L4T update (R23.2). For now, you can access the camera through gstreamer and/or the nvgstcapture sample app.
(sorry for the delay, moving this post to the Jetson TX1 board.)
Regarding the nvgstcapture samples app, all i found on muy jetson board was a precompiled .so binary.
Is there a source code to be found anywhere?
We are planning to release the source to nvgstcapture/nvgstplayer in the next L4T version.
To get started today, here’s an example gstreamer-1.0 pipeline using the CSI camera element ā€˜nvcamera’:
gst-launch-1.0 nvcamerasrc fpsRange="30.0 30.0" ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvtee ! nvvidconv flip-method=2 ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvoverlaysink -e
edit 12/17: ā€˜video/xraw(memory:NVMM)’ needed to be ā€˜video/x-raw(memory:NVMM)’
I get this error message
Invalid FPSRange Input
WARNING: erroneous pipeline: could not link nvcamerasrc0 to nvtee0
Dusty - I just tried your example gstreamer pipe and got an ā€œinvalid FPSRange Inputā€ error. I’ll read through some docs to see why that wouldn’t work, but I also tried one value instead of two and smaller values - each attempt with no success. Any quick input would be appreciated!
Try this simple pipeline to get camera preview in screen:
gst-launch-1.0 nvcamerasrc ! ā€˜video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)I420, framerate=(fraction)30/1’ ! nvtee ! nvoverlaysink -e
br
ChenJian
@ dusty_nv,
Is the next update for L4T (R23.2) going to be 64-bit? I know that ros Moveit! has problems with 32-bit systems and the TX1 uses a 64-bit CPU, so if you guys make a 64-bit L4T update, that would be supremely awesome.
It will be included in the release after next, with the next release coming this month.
So probably a month or two from now?
  1. Release R23.2 will be released this month?
  2. gst-launch-1.0 supports other sensors, not ov5693?
  3. What kind ?
  4. How to add support for other sensor?
When I try to add another driver sensor, GStrimer exits with an error.
If support ov5693 is hardcode , please report it.
Well, January has ended and we still haven’t gotten any updates regarding Jetpack L4T (R23.2) . Any updates about that one?
Sorry, the update was pushed out to include critical kernel, DVFS and perf fixes. Current ETA is late Feb/March.
You can check investigate some drivers in http://developer.download.nvidia.com/embedded/L4T/r23_Release_v1.0/source/gstomx1_src.tbz2
or for V4L2, kernel source drivers/media/platform/soc_camera
And now it is March. Any ETA on R23.2 or R23.3?
R23.2 came out last week.
https://developer.nvidia.com/embedded/linux-tegra
Ah, good! Didn’t see it in the embedded software downloads area.
I have flashed my TX1 to the latest OS (the R23.2) and I still cannot see the CSI-2 camera that comes with the dev kit under /dev/video0.
In fact, I can’t use it in any C++ OpenCV application with the suggested gstreamer method without it throwing an error saying something about appslink.
Am I missing something here? I’m 99% sure its on my (the user’s) end.
