I flashed my Jetson TX1 with the latest Jetpack (Linux For Tegra R23.2), and the following command works perfectly:
gst-launch-1.0 nvcamerasrc fpsRange="30.0 30.0" ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvtee ! nvvidconv flip-method=2 ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvoverlaysink -e
I tried to use the following python program to receive images from webcam:
source: http://opencv-python-tutroals.readthedocs.org/en/latest/py_tutorials/py_gui/py_video_display/py_video_display.html
import numpy as np
import cv2
cap = cv2.VideoCapture(0)
while(True):
# Capture frame-by-frame
ret, frame = cap.read()
# Our operations on the frame come here
gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
# Display the resulting frame
cv2.imshow('frame',gray)
if cv2.waitKey(1) & 0xFF == ord('q'):
break
# When everything done, release the capture
cap.release()
cv2.destroyAllWindows()
I got the following error:
OpenCV Error: Assertion failed (scn == 3 || scn == 4) in cvtColor, file /hdd/buildbot/slave_jetson_tx_2/35-O4T-L4T-Jetson-L/opencv/modules/imgproc/src/color.cpp, line 3739
File "webcam.py", line 11, in <module>
cv2.error: /hdd/buildbot/slave_jetson_tx_2/35-O4T-L4T-Jetson-L/opencv/modules/imgproc/src/color.cpp:3739: error: (-215) scn == 3 || scn == 4 in function cvtColor
I know the problem is that it cannot receive images from webcam. I also changed the code to just show the received image from webcam, but it gives me error that means no image it get from camera.
I also tried to use C++ with the following code:
#include "opencv2/opencv.hpp"
using namespace cv;
int main(int argc, char** argv)
VideoCapture cap;
// open the default camera, use something different from 0 otherwise;
// Check VideoCapture documentation.
if(!cap.open(0))
return 0;
for(;;)
Mat frame;
cap >> frame;
if( frame.empty() ) break; // end of video stream
imshow("this is you, smile! :)", frame);
if( waitKey(1) == 27 ) break; // stop capturing by pressing ESC
// the camera will be closed automatically upon exit
// cap.close();
return 0;
and it compiled without any errors using
g++ webcam.cpp -o webcam `pkg-config --cflags --libs opencv`
But again, when Iâm running the program I receive this error:
$ ./webcam
Unable to stop the stream.: Device or resource busy
Unable to stop the stream.: Bad file descriptor
VIDIOC_STREAMON: Bad file descriptor
What Iâve missed? Is there any command I should run to activate webcam before running this program?
