I used nvidia jetson-inference detectnet-camera example and thought that USB cameras should work out of the box, however I cannot use my and error logs don’t specify exact problem.
My USB camera info:
nvidia@tegra-ubuntu:~/Downloads/jetson-inference/build/aarch64/bin$ v4l2-ctl -V
Format Video Capture:
Width/Height : 640/512
Pixel Format : 'RGB3'
Field : None
Bytes per Line : 1920
Size Image : 983040
Colorspace : sRGB
Transfer Function : Default
YCbCr Encoding : Default
Quantization : Default
Flags
Output from running jetson inference. The GUI actually displays the first frame form camera but then doesn’t update it anymore.
nvidia@tegra-ubuntu:~/Downloads/jetson-inference/build/aarch64/bin$ ./detectnet-camera --prototxt=$NET/deploy.prototxt --mod
el=$NET/snapshot_iter_6900.caffemodel
detectnet-camera
args (3): 0 [./detectnet-camera] 1 [--prototxt=/home/nvidia/Downloads/Viedsargs_caffe/deploy.prototxt] 2 [--model=/home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel]
[gstreamer] initialized gstreamer, version 1.8.3.0
[gstreamer] gstreamer decoder pipeline string:
v4l2src device=/dev/video0 ! video/x-raw, width=(int)640, height=(int)512, format=RGB ! videoconvert ! video/x-raw, format=RGB ! videoconvert !appsink name=mysink
detectnet-camera: successfully initialized video device
width: 640
height: 512
depth: 24 (bpp)
detectNet -- loading detection network model from:
-- prototxt /home/nvidia/Downloads/Viedsargs_caffe/deploy.prototxt
-- model /home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel
-- input_blob 'data'
-- output_cvg 'coverage'
-- output_bbox 'bboxes'
-- mean_pixel 0.000000
-- threshold 0.500000
-- batch_size 2
[GIE] TensorRT version 2.1.2, build 2102
[GIE] attempting to open cache file /home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel.2.tensorcache
[GIE] loading network profile from cache... /home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel.2.tensorcache
[GIE] platform has FP16 support.
[GIE] /home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel loaded
[GIE] CUDA engine context initialized with 3 bindings
[GIE] /home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel input binding index: 0
[GIE] /home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel input dims (b=2 c=3 h=2048 w=2560) size=125829120
[cuda] cudaAllocMapped 125829120 bytes, CPU 0x102a00000 GPU 0x102a00000
[GIE] /home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel output 0 coverage binding index: 1
[GIE] /home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel output 0 coverage dims (b=2 c=1 h=128 w=160) size=163840
[cuda] cudaAllocMapped 163840 bytes, CPU 0x10a200000 GPU 0x10a200000
[GIE] /home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel output 1 bboxes binding index: 2
[GIE] /home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel output 1 bboxes dims (b=2 c=4 h=128 w=160) size=655360
[cuda] cudaAllocMapped 655360 bytes, CPU 0x10a400000 GPU 0x10a400000
/home/nvidia/Downloads/Viedsargs_caffe/snapshot_iter_6900.caffemodel initialized.
[cuda] cudaAllocMapped 16 bytes, CPU 0x10a600000 GPU 0x10a600000
maximum bounding boxes: 81920
[cuda] cudaAllocMapped 1310720 bytes, CPU 0x10a4a0000 GPU 0x10a4a0000
[cuda] cudaAllocMapped 327680 bytes, CPU 0x10a800000 GPU 0x10a800000
default X screen 0: 1200 x 600
[OpenGL] glDisplay display window initialized
[OpenGL] creating 640x512 texture
loaded image fontmapA.png (256 x 512) 2097152 bytes
[cuda] cudaAllocMapped 2097152 bytes, CPU 0x10aa00000 GPU 0x10aa00000
[cuda] cudaAllocMapped 8192 bytes, CPU 0x10ac00000 GPU 0x10ac00000
[gstreamer] gstreamer transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert1
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert1
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer msg new-clock ==> pipeline0
[gstreamer] gstreamer msg stream-start ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstreamer decoder onPreroll
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10a850000 GPU 0x10a850000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10ae00000 GPU 0x10ae00000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10aef0000 GPU 0x10aef0000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10b000000 GPU 0x10b000000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10b0f0000 GPU 0x10b0f0000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10b200000 GPU 0x10b200000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10b2f0000 GPU 0x10b2f0000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10b400000 GPU 0x10b400000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10b4f0000 GPU 0x10b4f0000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10b600000 GPU 0x10b600000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10b6f0000 GPU 0x10b6f0000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10b800000 GPU 0x10b800000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10b8f0000 GPU 0x10b8f0000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10ba00000 GPU 0x10ba00000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10baf0000 GPU 0x10baf0000
[cuda] cudaAllocMapped 983040 bytes, CPU 0x10bc00000 GPU 0x10bc00000
[cuda] gstreamer camera -- allocated 16 ringbuffers, 983040 bytes each
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer msg async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
detectnet-camera: camera open for streaming
[cuda] gstreamer camera -- allocated 16 RGBA ringbuffers
[gstreamer] gstreamer decoder onEOS
0 bounding boxes detected
[cuda] registered 5242880 byte openGL texture for interop access (640x512)
detectnet-camera: failed to capture frame
detectnet-camera: failed to convert from NV12 to RGBA
detectNet::Detect( 0x(nil), 640, 512 ) -> invalid parameters
[cuda] cudaNormalizeRGBA((float4*)imgRGBA, make_float2(0.0f, 255.0f), (float4*)imgRGBA, make_float2(0.0f, 1.0f), camera->GetWidth(), camera->GetHeight())
[cuda] invalid device pointer (error 17) (hex 0x11)
[cuda] /home/nvidia/Downloads/jetson-inference/detectnet-camera/detectnet-camera.cpp:247
