USB Camera not recognized
I am reporting a common struggle faced by novice Jetson Nano developers
To Initial USB Camera interfaced to Jetson Nano
Steps followed
[1]: !ls -ltrh /dev/video*
​Output: crw-rw----+ 1 root video 81, 0 Sep 2 14:53 /dev/video0
[2] $ v4l2-ctl -d /dev/video0 --list-formats-ext
gst-launch-1.0 -v v4l2src device=/dev/video1 ! video/x-raw,framerate=30/1,width=1280,height=720 ! xvimagesink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
ERROR: pipeline doesn’t want to preroll.
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
[3] $ gst-launch-1.0 -v v4l2src device=/dev/video1 ! video/x-raw,framerate=30/1,width=1280,height=720 ! xvimagesink
Freeing pipeline …
RuntimeError Traceback (most recent call last)
/usr/local/lib/python3.6/dist-packages/jetcam-0.0.0-py3.6.egg/jetcam/usb_camera.py in init(self, *args, **kwargs)
23 if not re:
—> 24 raise RuntimeError(‘Could not read image from camera.’)
25
RuntimeError: Could not read image from camera.
During handling of the above exception, another exception occurred:
in
2
3 #TODO change capture_device if incorrect for your system
----> 4 camera = USBCamera(width=224, height=224, capture_width=640, capture_height=480, capture_device=0)
26 except:
27 raise RuntimeError(
—> 28 ‘Could not initialize camera. Please see error trace.’)
29
30 atexit.register(self.cap.release)
RuntimeError: Could not initialize camera. Please see error trace.
Please let me know which step is missed?
USB Camera is still not functional
Best Regards
Sreepada
Some reason to use video1 even /dev/video0 is there?
Blockquote
Please check Jetson Nano FAQ
Q: I have a USB camera. How can I lauch it on Jetson Nano?
Looks like your format is not set. Please set the exact mode including width,height,format,framerate.
Hello Dane,
Thank you for sharing Jetson Nano FAQ
USB Camera is functional.
$ gst-launch-1.0 -v v4l2src device=/dev/video0 ! ‘video/x-raw,format=YUY2,width=1280,height=720,framerate=10/1’ ! xvimagesink -ev
I have following suggestion,
  1. Please share the Jetson Nano FAQs link in Hello Camera URL
It helps novice to quickly follow the procedure
Best Regards
Sreepada
Hello MtHiker,
thank you for the feedback.
I observed that, when USB camera is unplug and connect back the device=/dev/video0 or /dev/video1 was dynamically updated.
I am able to run video now with
Please try
camera = USBCamera(width=224, height=224, capture_fps=10, capture_width=1280, capture_height=720, capture_device=0)
USB Camera is functional with the above command.
Topic can be closed.
Thank you
Best Regards
Sreepada
