I am having problems connecting my IP camera to my Jetson Nano, I have tried different terminal commands with no avail, but the same error keeps appearing in most cases:
gst-launch-1.0 rtspsrc location=rtsp://192.xxx.xxx.xxx:554/media/video1 ! rtph264depay ! h264parse ! avdec_h264 ! videoconvert ! gtksink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://192.xxx.xxx.xxx:554/media/video1
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not get/set settings from/on resource.
Additional debug info:
gstrtspsrc.c(7507): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
Server can not provide an SDP.
ERROR: pipeline doesn't want to preroll.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
The other variant of command I tried was the following:
gst-launch-1.0 rtspsrc location=rtsp://192.xxx.xxx.xxx/user=user&password=password&channel=1&stream=0./ ! decodebin ! gtksink
[1] 12716
[2] 12717
[3] 12718
bash: !: command not found
[2]- Done password=password
[3]+ Done channel=1
user@user-desktop:~$ Setting pipeline to PAUSED ...
Progress: (connect) Connecting to rtsp://192.xxx.xxx.xxx/user=user
^C
[1]+ Exit 1 gst-launch-1.0 rtspsrc location=rtsp://192.xxx.xxx.xxx/user=user
Looks like the URI is invalid. Could you check with the camera vendor to get correct URI?
If the URI is correct, you can simply launch it in uridecodebin:
Thank you for your feedback!
This just gave a new error:
gst-launch-1.0 uridecodebin uri=rtsp://192.xxx.xxx.xxx:544/user=admin_password=password:real_stream ! nvoverlaysink
Progress: (connect) Connecting to rtsp://192.168.1.11:544/user=admin_password:real_stream
ERROR: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source: Could not open resource for reading and writing.
gstrtspsrc.c(7469): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source:
Failed to connect. (Generic error)
So I found an app which displays the right URI this time it shows a black screen quickly and then closes it:
gst-launch-1.0 rtspsrc location=rtsp://192.xxx.xxx.xxx:544/user=admin_password=xxxxxxxx_channel=1_stream=0.sdp?real_stream ! rtph264depay ! h264parse ! avdec_h264 ! videoconvert ! gtksink
Progress: (connect) Connecting to rtsp://192.xxx.xxx.xxx:544/user=admin_password=xxxxxxxxchannel=1_stream=0.sdp?real_stream
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not open resource for reading and writing.
gstrtspsrc.c(7469): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
You may need to figure out a valid URI first. Are you able to get help from the IP camera vendor? Or you may share the brand and model ID here and other users might have experience of using it.
I used the software ONVIF found on source forge which displays the correct URI, as it actually showed a black screen for a second, so I am pretty sure the URI is fine. But the camera is XYTRON with the designation: XY-IP CAM36BF HK5.0MP POE
