Connect camera ip (Hikvision) to jetson tx2 without internet
How can I solve it?
Please provide more details to reproduce your issue, such as what have you done, SW version…etc. Thanks
(I used the wire from the IP camera to connect to the jetson TX2)
I use this code to show video capture
import cv2
cap = cv2.VideoCapture('rtsp://admin:phamquangnam123@192.168.1.64')
while True:
    ret, frame = cap.read()
    cv2.imshow("Capturing",frame)
    if cv2.waitKey(30) & 0xFF == ord('q'):
        break
cap.release()
cv2.destroyAllWindows()
but this is error
Hi kayccc,
I fixed my issue, I change some config in wire setting.
Thanks you
The URI looks invalid. You may check with vendor to have valid URI.
Two python samples for your reference:
