Dear Sir,
I’m using GStreamer command line to open IP Camera successfully:
gst-launch-1.0 rtspsrc location=rtsp://admin:123456@192.168.1.64:554 ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw, width=1920, height=1280, format=BGRx ! videoconvert ! appsink
But I using the same parameters in OpenCV, I can’t open the IP Camera.
Running result:
nvidia@tegra-ubuntu~:$ python ipcamera.py
nvidia@tegra-ubuntu~:$ Failed to open camera!
OpenCV source code:
# coding=utf-8
import sys
import argparse
import cv2
import numpy as np
if __name__ == "__main__":
image_width = 1920
image_height = 1080
rtsp_latency = 200
#uri = "rtsp://192.168.1.64:554/user=admin&password=123456&channel=1&stream=0.sdp?"
uri = "rtsp://admin:123456@192.168.1.64:554"
gst_str = ("rtspsrc location={} latency={} ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw, width=(int){}, height=(int){}, format=(string)BGRx ! videoconvert ! appsink sync=false").format(uri, rtsp_latency, image_width, image_height)
cap = cv2.VideoCapture(gst_str, cv2.CAP_GSTREAMER)
if not cap.isOpened():
sys.exit("Failed to open camera!")
#Display window setting
width = 640
height = 480
windowName = "CameraDemo"
cv2.namedWindow(windowName, cv2.WINDOW_NORMAL)
cv2.resizeWindow(windowName, width, height)
cv2.moveWindow(windowName, 0, 0)
cv2.setWindowTitle(windowName, "Camera Demo for Jetson TX2/TX1")
showHelp = True
showFullScreen = False
helpText = "'Esc' to Quit, 'H' to Toggle Help, 'F' to Toggle Fullscreen"
font = cv2.FONT_HERSHEY_PLAIN
image = ''
i = 0
while True:
if cv2.getWindowProperty(windowName, 0) < 0: #Check window opened
break;
ret_val, displayBuf = cap.read();
if showHelp == True:
cv2.putText(displayBuf, helpText, (11,20), font, 1.0, (32,32,32), 4, cv2.LINE_AA)
cv2.putText(displayBuf, helpText, (10,20), font, 1.0, (240,240,240), 1, cv2.LINE_AA)
#Display video
cv2.imshow(windowName, displayBuf)
key = cv2.waitKey(10)
#Save capture image
i += 1
image = "/home/nvidia/image" + str(i) + ".jpg"
cv2.imwrite(image,displayBuf)
if key == 27: # ESC key: quit program
break
elif key == ord('H') or key == ord('h'): # toggle help message
showHelp = not showHelp
elif key == ord('F') or key == ord('f'): # toggle fullscreen
showFullScreen = not showFullScreen
if showFullScreen == True:
cv2.setWindowProperty(windowName, cv2.WND_PROP_FULLSCREEN, cv2.WINDOW_FULLSCREEN)
else:
cv2.setWindowProperty(windowName, cv2.WND_PROP_FULLSCREEN, cv2.WINDOW_NORMAL)
cap.release()
cv2.destroyAllWindows()
