I have conned my GoPro hero 6 via a HDMI to USB capture card to the USB port of the Jetson nano 2gb. However I am not sure how to view the video feed from it.
I tired using Cheese, but it doesn’t show any output, and I have tried running the commands for USB cameras from here Taking Your First Picture with CSI or USB Camera | NVIDIA Developer but they usually result in just an error message and no video feed
You may try to start with your USB adapter not plugged in.
In a terminal, launch:
watch -n 1 'ls /dev/video*'
Then plug your camera in and note the new video node path that appears when you’ve plugged your USB adapter in. Assuming here /dev/video1, you would adapt.
Then, see what formats, resolutions and framerates your camera suppport. This requires v4l-tools;
sudo apt update
sudo apt install v4l-utils
# Query your cam modes, you would adpat video node number:
v4l2-ctl --device /dev/video1 --list-formats-ext
From that information, it would be possible to further advise.
Sorry for hijacking the OP post but I have a similar issue.
So I have run the following cmd lines and this is the output.
v4l2-ctl --device /dev/video2 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'MJPG' (compressed)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Index : 1
Pixel Format: 'YUYV'
Interval: Discrete 0.100s (10.000 fps)
Index : 2
Pixel Format: 'H264' (compressed)
So you would display your camera, assuming you have an X display, with:
# Raw mode (YUYV 4:2:2):
gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw, format=YUY2, width=1280, height=720, framerate=30/1 ! xvimagesink
# if not working fine, try adding mmap
gst-launch-1.0 v4l2src device=/dev/video2 io-mode=2 ! video/x-raw, format=YUY2, width=1280, height=720, framerate=30/1 ! xvimagesink
# MJPEG
gst-launch-1.0 v4l2src device=/dev/video2 ! image/jpeg,width=1280,height=720, framerate=30/1 ! jpegparse ! nvv4l2decoder mjpeg=1 ! nvvidconv ! xvimagesink
# or
gst-launch-1.0 v4l2src device=/dev/video2 ! image/jpeg,width=1280,height=720, framerate=30/1 ! jpegparse ! nvjpegdec ! 'video/x-raw(memory:NVMM),format=I420' ! nvvidconv ! xvimagesink
# Not sure for H264 through v4l2src...
gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-h264,width=1280,height=720,framerate=30/1 ! h264parse ! nvv4l2decoder ! nvvidconv ! xvimagesink
@nicholas.bissessar
I’d suggest to move back to your original topic or create a new one.
You may post there the ouput of lsusb -t.
You may also try H264 with io-mode=2.
Thank you for replying and sorry for the delayed response.
The USB connection doesn’t seem to be the issue as upon running:
v4l2-ctl -d /dev/video0 --list-formats-ext
I get:
Index : 0
Also when i try to run the command:
nvgstcapture-1.0 --camsrc=0 --cap-dev-node=0
it returns the following error:
$ nvgstcapture-1.0 --camsrc=0 --cap-dev-node=0
Encoder null, cannot set bitrate!
Encoder Profile = High
Runtime USB Camera Commands:
Help : 'h'
Quit : 'q'
Set Capture Mode:
mo:<val>
(1): image
(2): video
Get Capture Mode:
gmo
Capture: enter 'j' OR
followed by a timer (e.g., jx5000, capture after 5 seconds) OR
followed by multishot count (e.g., j:6, capture 6 images)
timer/multihot values are optional, capture defaults to single shot with timer=0s
Start Recording : enter '1'
Stop Recording : enter '0'
Set Preview Resolution:
pcr:<val> e.g., pcr:2
(0) : 176x144
(1) : 320x240
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
NOTE: Preview/Encode resolution will be same as Capture resolution for USB-Camera
Get Preview Resolution:
gpcr
Get Image Capture Resolution:
gicr
Get Video Capture Resolution:
gvcr
Set Capture Device Node:
cdn:<val> e.g., cdn:0
(0): /dev/video0
(1): /dev/video1
(2): /dev/video2
Get Capture Device Node:
gcdn
Runtime encoder configuration options:
Set Encoding Bit-rate(in bytes):
br:<val> e.g., br:4000000
Get Encoding Bit-rate(in bytes):
gbr
Set Encoding Profile(only for H.264):
ep:<val> e.g., ep:1
(0): Baseline
(1): Main
(2): High
Get Encoding Profile(only for H.264):
gep
Force IDR Frame on video Encoder(only for H.264):
Enter 'f'
** Message: 22:29:57.608: <main:4670> iterating capture loop ....
ERROR on bus: by /GstPipeline:capture_native_pipeline/GstBin:cap_bin/GstV4l2Src:v4l2src0: Internal data stream error.
debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:capture_native_pipeline/GstBin:cap_bin/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
** Message: 22:29:57.663: <main:4680> Capture completed
** Message: 22:29:57.665: <main:4729> Camera application will now exit
I tried running a simple USB webcam with it, and it seem to work fine with the above commands, but with me using a GoPro through a capture card the interference doesn’t seem to work and is what I need help with
For capturing frames through v4l2, please refer to
Jetson Nano FAQ
Q: I have a USB camera. How can I launch it on Jetson Nano?
But somehow it does not show information of width,height.framerate in the v4l2-ctl command. May need to get the information from vendor.
