I am just trying to capture the camera raw to a file at a certain resolution and frame rate . Could you please tell me how this command could do that capture?
nvidia@tegra-ubuntu:~/scripts/scfile$ sh -x ./e.sh
gst-launch-1.0 nvcamerasrc fpsRange=30 30 intent=3 ! video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, framerate=(fraction)30/1 ! nvvidconv ! video/x-raw, format=(string)I420, width=(int)1280, height=(int)720 ! filesink location=raw.420 -e
WARNING: erroneous pipeline: could not link nvcamerasrc0 to nvvconv0
since gstreamer go through ISP, you’re not able to capture the camera raw if you’re going through gstreamer pipeline.
the other way to capture camera raw files would be v4l2-ctl, which we called VI-mode.
here’s command for your reference.
however, there’s a known issue of TX2 that camera sensor with embedded metadata might got PXL_SOF failure.
here’s topic for your reference: https://devtalk.nvidia.com/default/topic/1007058/
thanks
@JerryChang does the v4l2-ctl work with bayer’s camera presented at the developers board?
By now it was found that recording from it could be captured with e.g:
For videoparse, I420 is the default format. You can use other formats, see available ones with
gst-inspect-1.0 videoparse
under properties/format.
For y4m, you may have to decode it first. With gstreamer, check y4mdec gstreamer plugin.
Otherwise, maybe ffmpeg can convert a y4m file to a I420 file.
Note: when I run the bigger file I get the following output:
gst-launch-1.0 -v filesrc location=/home/nvidia/ducks_take_off_2160p50.y4m ! y4mdec ! nvvidconv ! video/x-raw(memory:NVMM), format=I420 ! nvoverlaysink
Setting pipeline to PAUSED …
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingPipeline is PREROLLING …
/GstPipeline:pipeline0/GstY4mDec:y4mdec0.GstPad:src: caps = “video/x-raw,\ format=(string)I420,\ width=(int)3840,\ height=(int)2160,\ interlace-mode=(string)progressive,\ pixel-aspect-ratio=(fraction)1/1,\ chroma-site=(string)mpeg2,\ colorimetry=(string)bt2020,\ framerate=(fraction)50/1”
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = “video/x-raw(memory:NVMM),\ width=(int)3840,\ height=(int)2160,\ interlace-mode=(string)progressive,\ pixel-aspect-ratio=(fraction)1/1,\ framerate=(fraction)50/1,\ format=(string)I420”
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = “video/x-raw(memory:NVMM),\ width=(int)3840,\ height=(int)2160,\ interlace-mode=(string)progressive,\ pixel-aspect-ratio=(fraction)1/1,\ framerate=(fraction)50/1,\ format=(string)I420”
/GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = “video/x-raw(memory:NVMM),\ width=(int)3840,\ height=(int)2160,\ interlace-mode=(string)progressive,\ pixel-aspect-ratio=(fraction)1/1,\ framerate=(fraction)50/1,\ format=(string)I420”
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = “video/x-raw(memory:NVMM),\ width=(int)3840,\ height=(int)2160,\ interlace-mode=(string)progressive,\ pixel-aspect-ratio=(fraction)1/1,\ framerate=(fraction)50/1,\ format=(string)I420”
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = “video/x-raw,\ format=(string)I420,\ width=(int)3840,\ height=(int)2160,\ interlace-mode=(string)progressive,\ pixel-aspect-ratio=(fraction)1/1,\ chroma-site=(string)mpeg2,\ colorimetry=(string)bt2020,\ framerate=(fraction)50/1”
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
WARNING: from element /GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0: A lot of buffers are being dropped.
Additional debug info:
gstbasesink.c(2854): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0:
There may be a timestamping problem, or this computer is too slow.
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:12.979387839
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
