Running this command:
Honey_Patouceul:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! image/jpeg, width=1920, height=1080, framerate=30/1 ! jpegparse ! nvjpegdec ! 'video/x-raw(memory:NVMM),format=I420,width=1920,height=1080' ! omxh264enc ! h264parse ! qtmux ! filesink location=test_MJPG_H264enc.mp4 -e
I get the following output and error:
> $ gst-launch-1.0 -v v4l2src device=/dev/video0 ! image/jpeg, width=1920, height=1080, framerate=30/1 ! jpegparse ! nvjpegdec ! 'video/x-raw(memory:NVMM),format=I420,width=1920,height=1080' ! omxh264enc ! h264parse ! qtmux ! filesink location=test_MJPG_H264enc.mp4 -e
> Setting pipeline to PAUSED ...
> Pipeline is live and does not need PREROLL ...
> Setting pipeline to PLAYING ...
> New clock: GstSystemClock
> /GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)NULL, interlace-mode=(string)progressive
> /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)NULL, interlace-mode=(string)progressive
> /GstPipeline:pipeline0/GstJpegParse:jpegparse0.GstPad:sink: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)NULL, interlace-mode=(string)progressive
> /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = image/jpeg, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)NULL, interlace-mode=(string)progressive
> /GstPipeline:pipeline0/GstJpegParse:jpegparse0.GstPad:src: caps = image/jpeg, parsed=(boolean)true, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1
> /GstPipeline:pipeline0/GstNvJpegDec:nvjpegdec0.GstPad:sink: caps = image/jpeg, parsed=(boolean)true, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1
> /GstPipeline:pipeline0/GstNvJpegDec:nvjpegdec0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
> /GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
> Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
> ===== NVMEDIA: NVENC =====
> NvMMLiteBlockCreate : Block : BlockType = 4
> H264: Profile = 66, Level = 40
> /GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
> /GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
> NvMMLiteVideoEncDoWork: Surface resolution (0 x 0) smaller than encode resolution (1920 x 1080)
> VENC: NvMMLiteVideoEncDoWork: 4283: BlockSide error 0x4
> Event_BlockError from 0BlockAvcEnc : Error code - 4
> Sending error event from 0BlockAvcEncERROR: from element /GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0: GStreamer encountered a general supporting library error.
> Additional debug info:
> /dvs/git/dirty/git-master_linux/3rdparty/gst/gst-omx/omx/gstomxvideoenc.c(1331): gst_omx_video_enc_loop (): /GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0:
> OpenMAX component in error state Bad parameter (0x80001005)
> EOS on shutdown enabled -- waiting for EOS after Error
> Waiting for EOS...
> /GstPipeline:pipeline0/GstQTMux:qtmux0.GstPad:src: caps = video/quicktime, variant=(string)apple
> /GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/quicktime, variant=(string)apple
> /dvs/git/dirty/git-master_linux/3rdparty/gst/gst-omx/omx/gstomxvideoenc.c(2346): gst_omx_video_enc_handle_frame (): /GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0:
> ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
> gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
> streaming stopped, reason error (-5)
Honey_Patouceul:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! image/jpeg, width=1920, height=1080, framerate=30/1 ! jpegparse ! nvv4l2decoder mjpeg=1 ! 'video/x-raw(memory:NVMM),format=I420,width=1920,height=1080' ! omxh264enc ! h264parse ! qtmux ! filesink location=test_MJPG_H264enc.mp4 -e
I get the following output and error, but it hangs versus being terminated:
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 277
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 277
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:sink: caps = image/jpeg, parsed=(boolean)true, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
streaming stopped, reason not-negotiated (-4)
Waiting for EOS...
All that being said, if I add io-mode=2 to the input, the original command works.
