I was able to run the below pipeline in jetpack 4.4 version
gst-launch-1.0 -e v4l2src device=/dev/video2 ! queue ! video/x-raw, width=1920, height=1080, framerate=30/1 ! videorate ! video/x-raw, width=1920, height=1080, framerate=30/1 ! queue ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),format=RGBA” ! queue ! comp.sink_0 v4l2src device=/dev/video1 io-mode=2 do-timestamp=true ! queue ! image/jpeg,width=1920,height=1080, framerate=30/1 ! videorate ! image/jpeg,width=1920,height=1080,framerate=30/1 ! queue ! nvv4l2decoder mjpeg=1 ! nvvidconv ! queue ! video/x-raw ! queue ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),format=RGBA” ! queue ! comp.sink_1 nvcompositor background-w=1920 background-h=540 name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=960 sink_0::height=540 sink_1::xpos=960 sink_1::ypos=0 sink_1::width=960 sink_1::height=540 ! tee name=t1 t1. ! queue ! nvvidconv ! queue ! nvv4l2h264enc maxperf-enable=1 bitrate=4000000 profile=4 ! queue ! h264parse ! queue ! mux.video_0 audiomixer name=mixer ! queue ! audioconvert ! voaacenc ! mux.audio_0 alsasrc device=“hw:4,0” ! tee name=a1 ! queue ! audio/x-raw ! queue ! audioresample ! “audio/x-raw,rate=48000” ! queue ! mixer.sink_0 alsasrc device=“hw:3,0” ! tee name=a2 ! queue ! audio/x-raw ! queue ! audioresample ! “audio/x-raw,rate=48000” ! queue ! mixer.sink_1 mp4mux name=mux ! filesink location=“ff.mp4” t1. ! queue ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),format=NV12” ! queue ! nvoverlaysink display-id=1 overlay-x=0 overlay-y=0 overlay-w=1920 overlay-h=1080 overlay=1 audiomixer name=mix ! queue ! audioconvert ! alsasink device=“hw:0,3” a1. ! queue ! audio/x-raw ! queue ! mix.sink_0 a2. ! queue ! audio/x-raw ! queue ! mix.sink_1
I am trying to run the same pipeline in jetpack 4.6 and get the below error
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
NvMMLiteOpen : Block : BlockType = 277
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 277
Redistribute latency…
New clock: GstAudioSrcClock
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 100, Level = 0
NVMEDIA_ENC: bBlitMode is set to TRUE
WARNING: from element /GstPipeline:pipeline0/GstMP4Mux:mux: Can’t change input format at runtime.
Additional debug info:
gstqtmux.c(5757): gst_qt_mux_video_sink_set_caps (): /GstPipeline:pipeline0/GstMP4Mux:mux:
pad video_0 refused renegotiation to video/x-h264, stream-format=(string)avc, alignment=(string)au, profile=(string)high, level=(string)3.2, width=(int)1920, height=(int)540, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601, chroma-site=(string)jpeg, chroma-format=(string)4:2:0, bit-depth-luma=(uintOpening in BLOCKING MODE
pad video_0 refused renegotiation to video/x-h264, stream-format=(string)avc, alignment=(string)au, profile=(string)high, level=(string)3.2, width=(int)1920, height=(int)540, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt601, chroma-site=(string)jpeg, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, codec_data=(buffer)01640c20ffe1000c67640c20ac2ca8078045fb4001000468ee3cb0
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
EOS on shutdown enabled – waiting for EOS after Error
Waiting for EOS…
ERROR: from element /GstPipeline:pipeline0/GstQueue:queue0: Internal data stream error.
gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline0/GstQueue:queue0:
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src1: Internal data stream error.
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src1:
ERROR: from element /GstPipeline:pipeline0/GstQueue:queue4: Internal data stream error.
gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline0/GstQueue:queue4:
Waiting for EOS…
What can be the issue for this scenario?
