hello, i am doing object detection on jetson nano. I am using a camera with a usb port. When I look at it with the lsusb command, the camera appears. But I am getting this error. What do I need to do to run?
Pease follow the steps in Jetson Nano FAQ and check if you are able to launch the camera:
Q: I have a USB camera. How can I launch it on Jetson Nano?
Please set the exact format,width,height,framerate to the command. You can see the information in v4l2-ctl --list-formats-ext
Index : 0
Type : Video Capture
Pixel Format: ‘MJPG’ (compressed)
Size: Discrete 1920x1080
Interval: Discrete 0.017s (60.000 fps)
Index : 1
Pixel Format: 'YUYV'
this is the output of the command and i edited it like this → gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUYV,width=640,height=480,framerate=60/1 ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! nvoverlaysink
output: WARNING: erroneous pipeline: could not link v4l2src0 to nvvconv0, neither element can handle caps video/x-raw, format=(string)YUYV, width=(int)640, height=(int)480, framerate=(fraction)60/1
Please replace YUYV with YUY2. The format has a different naming in gstreamer.
the camera was turned on first.but later ı taked this output:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
Additional debug info:
gstv4l2src.c(658): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Buffer pool activation failed
Execution ended after 0:00:00.045830228
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
It looks like the camera is not stable, please try this and check if it can run continually without the error:
$ export DISPLAY=:0(or 1)
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=640,height=480,framerate=60/1 ! videoconvert ! xvimagesink
hi,It worked for 5 seconds, then stopped. now it turns on and off immediately.
*output:*Setting pipeline to PAUSED …
Execution ended after 0:00:00.048886246
Freeing pipeline …
The camera is not stable. Would suggest try other USB cameras.
As you mentioned above, when I ran the command, the camera worked. How can I work with gst-launch in my python file.
We suggest use DeepStream SDK in the topic so please give it a try. Please try this config file which is for USB camera:
/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/source1_usb_dec_infer_resnet_int8.txt
thank you.This is worked for me.
