Hi all,
Thank you for your time.
Lastly, I bought a USB camera using on my Jetson nano 8 GB. However, when I use qv4l2 to previewe the camera, it shows black screen and output the error below:
libv4l2: error turning on stream: Protocol error VIDIOC_STREAMON: Protocol error
1177×838 86.5 KB
I also tried vlc, which had no luck too.
I connect this USB camera on my laptop and it is working on windows OS. I have been stuck by this problem for almost two day and really really want to figure it out. I will appriciate for any helpful advice.
Here is my jetson’s info:
Jetpack version:4.6.3
L4T: 32.7.3
If you have any other info, I will be pleasure share it. Thank you in advance.
Please refer to the steps in Jetson Nano FAQ
Q: I have a USB camera. How can I launch it on Jetson Nano?
and see if you can launch the camera in gstreamer.
@DaneLLL
thank you for your reply
I try but no luck
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvoverlaysink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.000450947
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Update
After turning it on and off seven or eight times, the camera was finally ready to produce a picture. But after turning it off, there was a need to turn it on and off seven or eight times before it could produce a picture.
It may be an stability issue in the camera itself. Ideally it should be launched successfully each time.
