When I try to lanch the script nvgstcapture-1.0 --camsrc=0 --cap-dev-node= /dev/video0 I got this error:
ERROR on bus: by /GstPipeline:capture_native_pipeline/GstBin:cap_bin/GstV4l2Src:v4l2src0: Could not read from resource.
debug info:
gstv4l2bufferpool.c(1040): gst_v4l2_buffer_pool_poll (): /GstPipeline:capture_native_pipeline/GstBin:cap_bin/GstV4l2Src:v4l2src0:
poll error 1: Invalid argument (22)
I’ve followed the FAQ, but when I run v4l2-ctl -d /dev/video1 I get Failed to open /dev/video1: No such file or directory. I’ve tried also with video0 and video2, the same,
If the camera supports kernel UVC driver, you should see the device node present. Please re-plug the camera to either type-A port and check if there is new node:
Ok,
I’ve got this message:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
What should I do?Nothing happen, but the terminal is still on working.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not read from resource.
Additional debug info:
gstv4l2bufferpool.c(1040): gst_v4l2_buffer_pool_poll (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Execution ended after 0:00:34.541444459
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
