Just got my new Jetson nano B01 so new to it.
I can’t get the USB camera to work (Logitech, Inc. Webcam C270), either by command line or via applications such as cheese. Cheese just opens and closes. When trying to run in the command line I just get an error. I have tried a clean install and updating but nothing has worked.
It recognises the webcam as seen below…
dee@dee-desktop:~$ ls /dev/video*
/dev/video0
dee@dee-desktop:~$ lsusb
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 005: ID 04d9:0006 Holtek Semiconductor, Inc.
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 007: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
But get this error…
dee@dee-desktop:~$ nvgstcapture-1.0 --mode=2 --camsrc=0 --cap-dev-node=/dev/video0
Encoder null, cannot set bitrate!
Encoder Profile = High
/dev/video/dev/video0 does not exist
Runtime USB Camera Commands:
Help : ‘h’
Quit : ‘q’
Set Capture Mode:
mo:
(1): image
(2): video
Get Capture Mode:
gmo
Capture: enter ‘j’ OR
followed by a timer (e.g., jx5000, capture after 5 seconds) OR
followed by multishot count (e.g., j:6, capture 6 images)
timer/multihot values are optional, capture defaults to single shot with timer=0s
Start Recording : enter ‘1’
Stop Recording : enter ‘0’
Set Preview Resolution:
pcr: e.g., pcr:2
(0) : 176x144
(1) : 320x240
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
NOTE: Preview/Encode resolution will be same as Capture resolution for USB-Camera
Get Preview Resolution:
gpcr
Get Image Capture Resolution:
gicr
Get Video Capture Resolution:
gvcr
Set Capture Device Node:
cdn: e.g., cdn:0
(0): /dev/video0
(1): /dev/video1
(2): /dev/video2
Get Capture Device Node:
gcdn
Runtime encoder configuration options:
Set Encoding Bit-rate(in bytes):
br: e.g., br:4000000
Get Encoding Bit-rate(in bytes):
gbr
Set Encoding Profile(only for H.264):
ep: e.g., ep:1
(0): Baseline
(1): Main
(2): High
Get Encoding Profile(only for H.264):
gep
Force IDR Frame on video Encoder(only for H.264):
Enter ‘f’
bitrate = 4000000
Encoder control-rate = 1
Encoder EnableTwopassCBR = 0
Opening in BLOCKING MODE
Any ideas?
Thanks,
Dee
