I have connected 3 usb camera sources to the jetson nano board. The camera is working fine. After sometime the camera gets disconnected. I got the below demsg
dmesg | grep 2-1.2
[ 2.795805] usb 2-1.2: new SuperSpeed USB device number 4 using tegra-xusb
[ 2.816306] usb 2-1.2: LPM exit latency is zeroed, disabling LPM.
[ 2.816637] usb 2-1.2: Int endpoint with wBytesPerInterval of 1024 in config 1 interface 0 altsetting 0 ep 129: setting to 16
[ 2.831109] usb 2-1.2: New USB device found, idVendor=04b4, idProduct=00f8
[ 2.831115] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.831119] usb 2-1.2: Product: USB3.0 Capture Video
[ 2.831122] usb 2-1.2: Manufacturer: Cypress Semiconductor
[ 5.754807] uvcvideo 2-1.2:1.0: Entity type for entity Extension 3 was not initialized!
[ 5.767518] uvcvideo 2-1.2:1.0: Entity type for entity Processing 2 was not initialized!
[ 5.767523] uvcvideo 2-1.2:1.0: Entity type for entity Camera 1 was not initialized!
[ 5.767904] input: USB3.0 Capture Video as /devices/70090000.xusb/usb2/2-1/2-1.2/2-1.2:1.0/input/input5
[ 5.778200] input: HD Camera as /devices/70090000.xusb/usb2/2-1/2-1.3/2-1.3:1.0/input/input6
[ 5.789766] input: USB3.0 Capture Video as /devices/70090000.xusb/usb2/2-1/2-1.1/2-1.1.2/2-1.1.2:1.0/input/input7
[ 8.999535] usb 2-1.2: usb_suspend_both: status 0
[ 28.967508] usb 2-1.2: usb_suspend_both: status 0
[ 48.007525] usb 2-1.2: usb_suspend_both: status 0
[ 158.095278] usb 2-1.2: usb_suspend_both: status 0
[ 163.559616] usb 2-1.2: reset SuperSpeed USB device number 4 using tegra-xusb
[ 163.579827] usb 2-1.2: LPM exit latency is zeroed, disabling LPM.
[ 178.178710] usb 2-1.2: usb_suspend_both: status 0
[ 200.002218] usb 2-1.2: usb_suspend_both: status 0
[ 203.134227] usb 2-1.2: usb_suspend_both: status 0
[ 211.070119] usb 2-1.2: usb_suspend_both: status 0
[ 238.973710] usb 2-1.2: usb_suspend_both: status 0
[ 258.941486] usb 2-1.2: usb_suspend_both: status 0
[ 276.093330] usb 2-1.2: usb_suspend_both: status 0
[ 279.165326] usb 2-1.2: usb_suspend_both: status 0
[ 676.172807] usb 2-1.2: usb_suspend_both: status 0
[ 680.948714] usb 2-1.2: usb_suspend_both: status 0
[ 695.140476] usb 2-1.2: usb_suspend_both: status 0
[ 881.988152] usb 2-1.2: usb_suspend_both: status 0
[ 906.114492] usb 2-1.2: usb_suspend_both: status 0
[ 909.189367] usb 2-1.2: usb_suspend_both: status 0
[ 925.061924] usb 2-1.2: usb_suspend_both: status 0
[ 929.194061] usb 2-1.2: usb_suspend_both: status 0
[ 934.022346] usb 2-1.2: usb_suspend_both: status 0
[ 947.994683] usb 2-1.2: usb_suspend_both: status 0
[ 994.083901] usb 2-1.2: usb_suspend_both: status 0
[ 997.004092] usb 2-1.2: usb_suspend_both: status 0
[ 1002.024114] usb 2-1.2: usb_suspend_both: status 0
[ 1013.128328] usb 2-1.2: usb_suspend_both: status 0
[ 1064.073266] usb 2-1.2: usb_suspend_both: status 0
[ 1071.209366] usb 2-1.2: usb_suspend_both: status 0
[ 1100.169856] usb 2-1.2: usb_suspend_both: status 0
[ 1119.170071] usb 2-1.2: usb_suspend_both: status 0
[ 1135.158251] usb 2-1.2: usb_suspend_both: status 0
[ 1139.082348] usb 2-1.2: usb_suspend_both: status 0
[ 1155.210470] usb 2-1.2: usb_suspend_both: status 0
[ 1182.090791] usb 2-1.2: usb_suspend_both: status 0
[ 1186.186836] usb 2-1.2: usb_suspend_both: status 0
[ 1189.994879] usb 2-1.2: usb_suspend_both: status 0
[ 1216.171072] usb 2-1.2: usb_suspend_both: status 0
[ 1227.146913] usb 2-1.2: usb_suspend_both: status 0
[ 1232.010667] usb 2-1.2: usb_suspend_both: status 0
[ 1246.090065] usb 2-1.2: usb_suspend_both: status 0
[ 1263.241284] usb 2-1.2: usb_suspend_both: status 0
[ 1275.016784] usb 2-1.2: usb_suspend_both: status 0
[ 1294.216076] usb 2-1.2: usb_suspend_both: status 0
[ 1369.989635] usb 2-1.2: usb_suspend_both: status 0
[ 1376.997428] usb 2-1.2: usb_suspend_both: status 0
[ 1396.172947] usb 2-1.2: usb_suspend_both: status 0
[ 1469.059361] usb 2-1.2: usb_suspend_both: status 0
[ 1472.131321] usb 2-1.2: usb_suspend_both: status 0
[ 1489.027005] usb 2-1.2: usb_suspend_both: status 0
[ 1499.010829] usb 2-1.2: usb_suspend_both: status 0
[ 1530.102341] usb 2-1.2: usb_suspend_both: status 0
[ 1682.089589] usb 2-1.2: usb_suspend_both: status 0
[ 1686.144663] usb 2-1.2: usb_suspend_both: status 0
[ 1732.068290] usb 2-1.2: usb_suspend_both: status 0
[ 1735.172312] usb 2-1.2: usb_suspend_both: status 0
[ 1751.168170] usb 2-1.2: usb_suspend_both: status 0
[ 1835.135745] usb 2-1.2: usb_suspend_both: status 0
[ 1842.047734] usb 2-1.2: usb_suspend_both: status 0
[ 1845.119757] usb 2-1.2: usb_suspend_both: status 0
[ 1871.155587] usb 2-1.2: usb_suspend_both: status 0
[ 2098.047118] usb 2-1.2: usb_suspend_both: status 0
[ 2108.663545] usb 2-1.2: reset SuperSpeed USB device number 4 using tegra-xusb
[ 2113.899277] usb 2-1.2: device descriptor read/8, error -110
[ 2114.010969] usb 2-1.2: reset SuperSpeed USB device number 4 using tegra-xusb
[ 2119.275302] usb 2-1.2: device descriptor read/8, error -110
[ 2119.727484] usb 2-1.2: Device not responding to setup address.
[ 2119.957124] usb 2-1.2: Device not responding to setup address.
[ 2120.179092] usb 2-1.2: device not accepting address 4, error -71
[ 2120.739564] usb 2-1.2: Device not responding to setup address.
[ 2120.963621] usb 2-1.2: Device not responding to setup address.
[ 2121.179028] usb 2-1.2: device not accepting address 4, error -71
[ 2121.535412] usb 2-1.2: Device not responding to setup address.
[ 2121.767498] usb 2-1.2: Device not responding to setup address.
[ 2121.979353] usb 2-1.2: device not accepting address 4, error -71
[ 2121.989233] usb 2-1.2: USB disconnect, device number 4
[ 2122.395263] usb 2-1.2: Device not responding to setup address.
[ 2122.619235] usb 2-1.2: Device not responding to setup address.
[ 2122.831003] usb 2-1.2: device not accepting address 9, error -71
[ 2123.179354] usb 2-1.2: Device not responding to setup address.
[ 2123.407263] usb 2-1.2: Device not responding to setup address.
[ 2123.618952] usb 2-1.2: device not accepting address 10, error -71
[ 2124.035299] usb 2-1.2: Device not responding to setup address.
[ 2124.259322] usb 2-1.2: Device not responding to setup address.
[ 2124.470957] usb 2-1.2: device not accepting address 11, error -71
[ 2124.819284] usb 2-1.2: Device not responding to setup address.
[ 2125.043260] usb 2-1.2: Device not responding to setup address.
[ 2125.254986] usb 2-1.2: device not accepting address 12, error -71
And when v4l2-ctl --list-devices is entered below is the reply
Failed to open /dev/video0: No such file or directory
Sometimes the camera will fully dissapear and is not recognized even after restarting the jetson. It only works after power on after a shutdown
Is there a method to rescan the usb devices connected or What can be the issue for this?
Thanks in advanced
