Hello Expert
When I’m using a USB 3.0 camera, if I plug a device into another USB 3.0 port, it will cause camera data to stop.There was no printing in the dmesg log when reinserted camera, and there was no response to the insertion of other USB3.0 devices.The insertion of USB2.0 device can be recognized normally.
I have repeated this problem many times, sometimes there is no printing in the log, sometimes different error messages are printed:
[ 569.632734] usb 1-2.1: new full-speed USB device number 4 using tegra-xusb
[ 569.654334] usb 1-2.1: New USB device found, idVendor=23d0, idProduct=0c80
[ 569.654341] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 569.654345] usb 1-2.1: Product: HH400
[ 569.654348] usb 1-2.1: Manufacturer: Honeywell
[ 569.654352] usb 1-2.1: SerialNumber: 20154B45E1
[ 569.662829] input: Honeywell HH400 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:23D0:0C80.0007/input/input5
[ 569.721454] hid-generic 0003:23D0:0C80.0007: input,hidraw4: USB HID v1.01 Keyboard [Honeywell HH400] on usb-70090000.xusb-2.1/input0
[ 569.769183] tegra-xusb 70090000.xusb: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[ 569.790633] tegra-xusb 70090000.xusb: URB transfer length is wrong, xHC issue? req. len = 10, act. len = 429496726
180.301486] usb 1-2.1: new full-speed USB device number 13 using tegra-xusb
[ 180.322868] usb 1-2.1: New USB device found, idVendor=23d0, idProduct=0c80
[ 180.322874] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 180.322878] usb 1-2.1: Product: HH400
[ 180.322881] usb 1-2.1: Manufacturer: Honeywell
[ 180.322884] usb 1-2.1: SerialNumber: 20154B45E1
[ 180.331534] input: Honeywell HH400 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:23D0:0C80.0007/input/input5
[ 180.390313] hid-generic 0003:23D0:0C80.0007: input,hidraw4: USB HID v1.01 Keyboard [Honeywell HH400] on usb-70090000.xusb-2.1/input0
[ 180.440422] tegra-xusb 70090000.xusb: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[ 180.462229] tegra-xusb 70090000.xusb: URB transfer length is wrong, xHC issue? req. len = 10, act. len = 4294967266
[ 183.404524] tegra-xusb 70090000.xusb: WARN Event TRB for slot 4 ep 2 with no TDs queued?
[ 108.433385] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 108.581288] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 108.601330] usb 1-2: usb_suspend_both: status 0
[ 116.368806] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 116.660749] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 116.680766] usb 1-2: usb_suspend_both: status 0
[ 117.608722] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 117.816684] usb 1-2.1: new full-speed USB device number 8 using tegra-xusb
[ 117.837983] usb 1-2.1: New USB device found, idVendor=23d0, idProduct=0c80
[ 117.837989] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 117.837993] usb 1-2.1: Product: HH400
[ 117.837997] usb 1-2.1: Manufacturer: Honeywell
[ 117.838000] usb 1-2.1: SerialNumber: 20154B45E1
[ 117.846682] input: Honeywell HH400 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:23D0:0C80.0007/input/input5
[ 117.865575] tegra-xusb 70090000.xusb: WARN Event TRB for slot 4 ep 6 with no TDs queued?
[ 117.905496] hid-generic 0003:23D0:0C80.0007: input,hidraw4: USB HID v1.01 Keyboard [Honeywell HH400] on usb-70090000.xusb-2.1/input0
[ 118.201121] usb 2-1.2: reset SuperSpeed USB device number 3 using tegra-xusb
[ 118.221631] usb 2-1.2: LPM exit latency is zeroed, disabling LPM.
And this is case of none error log:
[ 59.356095] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 59.504344] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 59.524358] usb 1-2: usb_suspend_both: status 0
[ 70.273990] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 70.421905] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 70.441880] usb 1-2: usb_suspend_both: status 0
[ 71.513285] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 71.721155] usb 1-2.1: new full-speed USB device number 8 using tegra-xusb
[ 71.742461] usb 1-2.1: New USB device found, idVendor=23d0, idProduct=0c80
[ 71.742468] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 71.742472] usb 1-2.1: Product: HH400
[ 71.742476] usb 1-2.1: Manufacturer: Honeywell
[ 71.742479] usb 1-2.1: SerialNumber: 20079B3795
[ 71.750810] input: Honeywell HH400 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:23D0:0C80.0007/input/input5
[ 71.810153] hid-generic 0003:23D0:0C80.0007: input,hidraw4: USB HID v1.01 Keyboard [Honeywell HH400] on usb-70090000.xusb-2.1/input0
lsusb -v log when crashed:
el-x@gelx-desktop:~$ lsusb -vvv
Bus 002 Device 004: ID 1711:2010 Leica Microsystems
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2 ?
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 9
idVendor 0x1711 Leica Microsystems
idProduct 0x2010
bcdDevice 0.00
iManufacturer 1 (error)
iProduct 2 (error)
iSerial 3 (error)
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 116
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 224mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 3
bFunctionClass 239 Miscellaneous Device
bFunctionSubClass 5 USB3 Vision
bFunctionProtocol 0
iFunction 4 (error)
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 239 Miscellaneous Device
bInterfaceSubClass 5 USB3 Vision
bInterfaceProtocol 0
iInterface 5 (error)
** UNRECOGNIZED: 14 24 01 00 00 01 00 00 00 01 00 08 01 02 09 0a 0b 03 0c 0c
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 1
iInterface 6 (error)
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 2
iInterface 7 (error)
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
I think the maybe USB controller crashed. Is there a way to reset the USB3.0 controller by writing tegra-xusb registers?
I find that sometimes there are the following logs when I plug in or unplug USB devices, and sometimes there are none. I understand that this is triggered by USB detection interruption. May I ask why there is no log sometimes?
