tegra-xusb-mbox: Controller firmware hang
Hi all,
we use a TX2 on an auvidea carrier board with necessary DTB changes for USB applied. USB3 is working, we see all of our devices running. As our carrier board only has 1 USB3 port we use a hub to be able to use 3 USB3 cameras.
Everything is running fine but at some point the USB completly stops working. As the USB module(s) are compiled into the kernel we need to power off our device. The exact moment when the crash happens is not reproducable, it may happen after a few minutes already or after some 20 minutes.
Please find the kernel log here (2089 secs is application start, 2678 secs is USB crash):
[ 1887.871473] uvcvideo: Found UVC 1.00 device See3CAM_Stereo (2560:c114)
[ 1887.873591] input: See3CAM_Stereo as /devices/3530000.xhci/usb2/2-1/2-1.2/2-1.2:1.0/input/input6
[ 1887.876334] usb 2-1.2: usbfs: process 29247 (nodelet) did not claim interface 0 before use
[ 2089.042143] uvcvideo: Found UVC 1.00 device See3CAM_Stereo (2560:c114)
[ 2089.045224] input: See3CAM_Stereo as /devices/3530000.xhci/usb2/2-1/2-1.2/2-1.2:1.0/input/input7
[ 2089.046459] usb 2-1.2: usbfs: process 3973 (nodelet) did not claim interface 0 before use
[ 2678.752823] tegra-xusb-mbox 3538000.mailbox: Controller firmware hang
[ 2678.752837] tegra-xusb-mbox 3538000.mailbox: XUSB_CFG_ARU_MBOX_OWNER 0x0
[ 2678.752844] tegra-xusb-mbox 3538000.mailbox: XUSB_CFG_ARU_MBOX_CMD 0x80000000
[ 2678.752851] tegra-xusb-mbox 3538000.mailbox: XUSB_CFG_ARU_MBOX_DATA_IN 0x0
[ 2678.752857] tegra-xusb-mbox 3538000.mailbox: XUSB_CFG_ARU_MBOX_DATA_OUT 0x6000266
[ 2682.116195] xhci-tegra 3530000.xhci: xHCI host not responding to stop endpoint command.
[ 2682.116207] xhci-tegra 3530000.xhci: Assuming host is dying, halting host.
[ 2682.152937] xhci-tegra 3530000.xhci: Host not halted after 16000 microseconds.
[ 2682.152945] xhci-tegra 3530000.xhci: Non-responsive xHCI host is not halting.
[ 2682.152950] xhci-tegra 3530000.xhci: Completing active URBs anyway.
[ 2682.154638] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.154737] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.154775] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.154811] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.154847] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.154882] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.154917] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.154952] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.154986] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155022] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155058] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155090] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155123] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155158] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155192] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155227] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155262] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155297] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155331] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155365] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155402] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155436] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155470] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155505] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155543] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155579] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155615] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155651] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155687] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155722] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155757] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155792] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155827] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155862] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155895] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155929] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155963] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.155999] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.156035] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.156070] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.156106] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.156140] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.156173] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.156238] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.156275] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.156286] usb 2-1.1: usbfs: usb_submit_urb returned -108
[ 2682.156308] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.156337] usb 2-1.1: usbfs: usb_submit_urb returned -108
[ 2682.156344] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.156359] usb 2-1.1: usbfs: usb_submit_urb returned -108
[ 2682.156377] usb 2-1.2: usbfs: usb_submit_urb returned -108
[ 2682.156380] xhci-tegra 3530000.xhci: HC died; cleaning up
[ 2682.156387] usb 2-1.1: usbfs: usb_submit_urb returned -108
[ 2682.156530] usb 1-1: USB disconnect, device number 4
[ 2682.158542] usb 2-1: USB disconnect, device number 2
[ 2682.158555] usb 2-1.1: USB disconnect, device number 3
[ 2682.159626] usb 2-1.2: USB disconnect, device number 4
[ 2682.169845] usb 2-1.4: USB disconnect, device number 5
[ 2700.433902] xhci-tegra 3530000.xhci: Stopped the command ring failed, maybe the host is dead
[ 2700.470558] xhci-tegra 3530000.xhci: Host not halted after 16000 microseconds.
[ 2700.470566] xhci-tegra 3530000.xhci: Abort command ring failed
[ 2700.470573] xhci-tegra 3530000.xhci: HC died; cleaning up
[ 2700.499119] usb 1-2: USB disconnect, device number 2
Any advice what to do?
Best regards,
Martin
I am curious if this either stops occurring, or reduces in occurrence if you max out performance:
sudo nvpmodel -m 0
sudo ~ubuntu/jetson_clocks.sh
I’m not positive, but if this is:
#define ETOOMANYREFS    109     /* Too many references: cannot splice */
…then perhaps something just isn’t consuming data as fast as it is produced.
Actually we are already using the max performance modes with nvpmodel and jetson_clocks. CPU is heavily used in our case, GPU usage is moderate.
I was trying to find the “109” but only found the “108” in my log returned from usb_submit_urb which is
#define ESHUTDOWN       108     /* Cannot send after transport endpoint shutdown */
Did you mean that?
Who is actually not behaving correct in my case? The USB controller or any device? We tried different cameras of same type (econ Tara) and also other models.
I’m really just speculating here, but if there is just too much work, then the controller is behaving as it should, and so is the device. It would be USB informing you of a failure, but it wouldn’t be USB causing the failure. Some process consuming the data may be too slow.
Would you possibly be able to build a version of your program using almost everything as it is already used, but simply throwing away any USB data as quick as it arrives? It would be interesting if reducing the CPU work at dealing with the data to near zero would change the crash.
Hello Nvidia-team,
I am going through a similar USB firmware controller crash issue when I connect a Plantronics USB Speaker to Jetson Nano and reboot the system. Fyi, the kernel version on Jetson Nano is 4.9.
The same works on a Nuc with kernel version 4.15
Please find the Jetson Nano boot log below -
[ 6.395018] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 6.531702] systemd-journald[1889]: Received request to flush runtime journal from PID 1
[ 7.209391] tegra-xusb 70090000.xusb: cannot find firmware…retry after 1 second
[ 7.282138] nvs_dsm nvs_dsm: dsm_probe
[ 7.282161] nvs_dsm nvs_dsm: dsm_remove
[ 7.282164] nvs_dsm nvs_dsm: dsm_probe done
[ 8.226646] tegra-xusb 70090000.xusb: Firmware timestamp: 2017-11-03 13:36:19 UTC, Version: 50.20 release
[ 8.226684] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 8.226702] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 8.227572] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 8.227603] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 8.227720] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.227724] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.227727] usb usb1: Product: xHCI Host Controller
[ 8.227730] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 8.227733] usb usb1: SerialNumber: 70090000.xusb
[ 8.228217] hub 1-0:1.0: USB hub found
[ 8.228279] hub 1-0:1.0: 5 ports detected
[ 8.228679] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 8.228688] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 8.228760] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 8.228832] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.228836] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.228839] usb usb2: Product: xHCI Host Controller
[ 8.228841] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 8.228844] usb usb2: SerialNumber: 70090000.xusb
[ 8.229193] hub 2-0:1.0: USB hub found
[ 8.229251] hub 2-0:1.0: 4 ports detected
[ 8.330897] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 8.331104] usb usb2: usb_suspend_both: status 0
[ 8.554826] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 8.593892] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 8.593897] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.593901] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 8.593905] usb 1-2: Manufacturer: Generic
[ 8.596575] hub 1-2:1.0: USB hub found
[ 8.597669] hub 1-2:1.0: 4 ports detected
[ 8.703911] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 8.739538] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 8.739544] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.739548] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 8.739551] usb 2-1: Manufacturer: Generic
[ 8.744164] hub 2-1:1.0: USB hub found
[ 8.745587] hub 2-1:1.0: 4 ports detected
[ 8.886810] usb 1-2.3: new full-speed USB device number 3 using tegra-xusb
[ 8.902807] usb 2-1: usb_suspend_both: status 0
[ 8.902986] usb usb2: usb_suspend_both: status 0
[ 8.917225] usb 1-2.3: New USB device found, idVendor=047f, idProduct=014c
[ 8.917231] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.917235] usb 1-2.3: Product: Plantronics Calisto 3200
[ 8.917238] usb 1-2.3: Manufacturer: Plantronics
[ 8.917241] usb 1-2.3: SerialNumber: 6dc67eaff1db18ae9246b3fd4bf94220
[ 8.949852] usb 1-2.3: current rate 16000 is different from the runtime rate 48000
[ 9.279803] random: crng init done
[ 9.283211] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.373156] using random self ethernet address
[ 9.377648] using random host ethernet address
[ 9.396826] Mass Storage Function, version: 2009/09/11
[ 9.396832] LUN: removable file: (no medium)
[ 9.401465] using random self ethernet address
[ 9.406043] using random host ethernet address
[ 9.418604] rndis0: HOST MAC ca:2b:42:45:1a:6c
[ 9.418657] rndis0: MAC ca:2b:42:45:1a:6d
[ 9.420273] usb0: HOST MAC ca:2b:42:45:1a:6e
[ 9.420407] usb0: MAC ca:2b:42:45:1a:6f
[ 9.420437] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 9.459971] l4tbr0: port 1(rndis0) entered blocking state
[ 9.459976] l4tbr0: port 1(rndis0) entered disabled state
[ 9.460127] device rndis0 entered promiscuous mode
[ 9.464868] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 9.468940] l4tbr0: port 2(usb0) entered blocking state
[ 9.468945] l4tbr0: port 2(usb0) entered disabled state
[ 9.469091] device usb0 entered promiscuous mode
[ 9.475018] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 9.475025] l4tbr0: port 2(usb0) entered blocking state
[ 9.475028] l4tbr0: port 2(usb0) entered forwarding state
[ 9.715728] android_work: did not send uevent (0 0 (null))
[ 9.786544] android_work: sent uevent USB_STATE=CONNECTED
[ 9.845720] android_work: sent uevent USB_STATE=DISCONNECTED
[ 9.934634] android_work: sent uevent USB_STATE=CONNECTED
[ 9.936768] configfs-gadget gadget: high-speed config #1: c
[ 9.936797] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 9.936814] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 9.936829] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 9.936907] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 9.936922] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 9.936935] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 9.936963] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 9.936979] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 9.936998] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 9.937044] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 9.937124] l4tbr0: port 1(rndis0) entered blocking state
[ 9.937130] l4tbr0: port 1(rndis0) entered forwarding state
[ 9.937222] android_work: sent uevent USB_STATE=CONFIGURED
[ 9.945389] tegra-xudc-new 700d0000.xudc: ep 13 (type: 2, dir: in) enabled
[ 9.945405] tegra-xudc-new 700d0000.xudc: ep 8 (type: 2, dir: out) enabled
[ 9.945490] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 12.846545] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.847880] eth0: 0xffffff800a35e000, 00:04:4b:e5:50:59, IRQ 404
[ 12.902007] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.859736] tegra-xusb 70090000.xusb: controller firmware hang
[ 13.865657] tegra-xusb 70090000.xusb: hcd_reinit is disabled or in progress
[ 35.199225] INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 35.202847] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 35.202934] 2-…: (0 ticks this GP) idle=205/140000000000000/0 softirq=7476/7476 fqs=2531
[ 35.202947]
[ 35.202979] (detected by 0, t=5252 jiffies, g=233, c=232, q=833)
[ 35.202997] Task dump for CPU 2:
[ 35.203019] kworker/2:1 R
[ 35.203031] running task
[ 35.203058] 0 637 2 0x00000002
[ 35.203187] Workqueue: events xhci_handle_command_timeout
[ 35.203209] Call trace:
[ 35.203266] [] __switch_to+0x9c/0xc0
[ 35.203294] [] 0xffffffc0ecfec29c
[ 35.220679] 2-…: (0 ticks this GP) idle=205/140000000000000/0 softirq=7476/7476 fqs=2500
[ 35.229224] (detected by 3, t=5252 jiffies, g=730, c=729, q=18351)
[ 35.235644] Task dump for CPU 2:
[ 35.235669] kworker/2:1 R running task 0 637 2 0x00000002
[ 35.235832] Workqueue: events xhci_handle_command_timeout
[ 35.235872] Call trace:
[ 35.235928] [] __switch_to+0x9c/0xc0
[ 35.235963] [] 0xffffffc0ecfec29c
[ 36.263172] Watchdog detected hard LOCKUP on cpu 2
[ 36.263260] ------------[ cut here ]------------
[ 36.268140] WARNING: CPU: 1 PID: 0 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/kernel/watchdog_hld.c:143 watchdog_check_hardlockup_other_cpu+0xf8/0x120
[ 36.282618] Modules linked in: overlay nvs nvgpu bluedroid_pm ip_tables x_tables
[ 36.282816] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.9.140-tegra #1
[ 36.282840] Hardware name: jetson-nano (DT)
[ 36.282870] task: ffffffc0fa7baa00 task.stack: ffffffc0fa7c8000
[ 36.282928] PC is at watchdog_check_hardlockup_other_cpu+0xf8/0x120
[ 36.282976] LR is at watchdog_check_hardlockup_other_cpu+0xf8/0x120
[ 36.283010] pc : [] lr : [] pstate: 604001c5
[ 36.283031] sp : ffffffc0fefecd20
[ 36.283055] x29: ffffffc0fefecd20 x28: ffffff800a134db8
[ 36.283115] x27: ffffff80097fb000 x26: ffffff800a134000
[ 36.283170] x25: ffffff8009e26000 x24: 0000000000000000
[ 36.283223] x23: 000000000000001e x22: ffffff8009e27000
[ 36.283275] x21: 0000000000000002 x20: ffffff8009e28c30
[ 36.283327] x19: ffffff80097fb760 x18: 0000000000000000
[ 36.283377] x17: 000000000000a44f x16: 0000000000000000
[ 36.283427] x15: ffffffffffffffff x14: ffffff800a104240
[ 36.283478] x13: ffffff800a103e86 x12: 0000000034d5d91d
[ 36.283528] x11: 000000000000000b x10: 0000000000000313
[ 36.283581] x9 : ffffff8009e44380 x8 : 6e6f2050554b434f
[ 36.283633] x7 : 0000000000000026 x6 : ffffff800a103146
[ 36.283684] x5 : 00ffffffffffffff x4 : 0000000000000006
[ 36.283735] x3 : 0000000000000000 x2 : 0000000000000000
[ 36.283784] x1 : ffffffc0fa7baa00 x0 : 0000000000000026
[ 36.283857] —[ end trace 28219bfc8a03479d ]—
[ 36.288578] Call trace:
[ 36.288642] [] watchdog_check_hardlockup_other_cpu+0xf8/0x120
[ 36.288693] [] watchdog_timer_fn+0x98/0x2c0
[ 36.288743] [] __hrtimer_run_queues+0xd8/0x360
[ 36.288784] [] hrtimer_interrupt+0xa8/0x1e0
[ 36.288834] [] tegra210_timer_isr+0x38/0x48
[ 36.288881] [] __handle_irq_event_percpu+0x68/0x288
[ 36.288920] [] handle_irq_event_percpu+0x28/0x60
[ 36.288958] [] handle_irq_event+0x50/0x80
[ 36.289003] [] handle_fasteoi_irq+0xc8/0x1b8
[ 36.289040] [] generic_handle_irq+0x34/0x50
[ 36.289076] [] __handle_domain_irq+0x68/0xc0
[ 36.289115] [] gic_handle_irq+0x5c/0xb0
[ 36.289152] [] el1_irq+0xe8/0x18c
[ 36.289211] [] cpuidle_enter_state+0xb8/0x380
[ 36.289260] [] cpuidle_enter+0x34/0x48
[ 36.289302] [] call_cpuidle+0x44/0x70
[ 36.289338] [] cpu_startup_entry+0x1b0/0x200
[ 36.289385] [] secondary_start_kernel+0x190/0x1f8
[ 36.289416] [<0000000080f441a4>] 0x80f441a4
[ 41.893917] tegra-xusb 70090000.xusb: Stopped the command ring failed, maybe the host is dead
[ 41.938817] tegra-xusb 70090000.xusb: Host not halted after 16000 microseconds.
[ 41.946114] tegra-xusb 70090000.xusb: Abort command ring failed
[ 41.963639] r8168: eth0: link up
[ 41.964030] tegra-xusb 70090000.xusb: Timeout while waiting for configure endpoint command
[ 41.972440] usb 1-2.3: Not enough bandwidth for altsetting 0
[ 41.972654] usb 1-2.3: Not enough bandwidth for altsetting 1
[ 41.972796] usb 1-2.3: 3:1: cannot set freq 16000 to ep 0x83
[ 41.978561] usb 1-2.3: Not enough bandwidth for altsetting 0
[ 41.978795] usb 1-2.3: 6:1: cannot get min/max values for control 2 (id 6)
[ 41.985857] tegra-xusb 70090000.xusb: HC died; cleaning up
[ 41.991528] tegra-xusb 70090000.xusb: hcd_reinit is disabled or in progress
[ 41.992031] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 41.994002] usb 1-2: USB disconnect, device number 2
[ 41.994010] usb 1-2.3: USB disconnect, device number 3
[ 41.995701] usb 2-1: USB disconnect, device number 2
[ 43.105092] tegradc tegradc.0: blank - powerdown
[ 43.105101] tegradc tegradc.1: blank - powerdown
[ 43.551095] tegradc tegradc.0: blank - powerdown
[ 43.551108] tegradc tegradc.1: blank - powerdown
[ 43.559175] tegradc tegradc.0: blank - powerdown
[ 44.034871] tegradc tegradc.0: blank - powerdown
[ 44.034880] tegradc tegradc.1: blank - powerdown
[ 47.218780] tegra-xusb 70090000.xusb: xHCI host not responding to stop endpoint command.
[ 47.226897] tegra-xusb 70090000.xusb: Assuming host is dying, halting host.
[ 47.276442] tegra-xusb 70090000.xusb: Host not halted after 16000 microseconds.
[ 47.283811] tegra-xusb 70090000.xusb: Non-responsive xHCI host is not halting.
[ 47.291047] tegra-xusb 70090000.xusb: Completing active URBs anyway.
[ 47.297546] tegra-xusb 70090000.xusb: HC died; cleaning up
[ 47.303049] tegra-xusb 70090000.xusb: hcd_reinit is disabled or in progress
raj@raj-jetson:~$
Hi rajeshrwuvx,
You may start a new thread. This is for TX2.
Hey doksmf,
Were you able to figure out what was going on?? I’m running into the same issue running into the same issue. Please see the relevant section of the kernel log.
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.221089] 509-17000000.gp10b, pid 1165, refs: 2:
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.225933] channel status:  in use idle not busy
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.230969] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.230969] HEADER: 60400000 COUNT: 00000000
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.230969] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.252977]
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.254480] 510-17000000.gp10b, pid 1165, refs: 2:
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.259299] channel status:  in use idle not busy
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.264328] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.264328] HEADER: 60400000 COUNT: 00000000
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.264328] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.286427]
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.287930] 511-17000000.gp10b, pid 1165, refs: 2:
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.292798] channel status:  in use idle not busy
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.297803] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.297803] HEADER: 60400000 COUNT: 00000000
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.297803] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
Feb 11 08:42:34 tegra-ubuntu kernel: [  886.320637]
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.233374] xhci-tegra 3530000.xhci: Stopped the command ring failed, maybe the host is dead
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.281520] xhci-tegra 3530000.xhci: Host not halted after 16000 microseconds.
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.288766] xhci-tegra 3530000.xhci: Abort command ring failed
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.294652] xhci-tegra 3530000.xhci: HC died; cleaning up
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.301005] usb 1-1: USB disconnect, device number 2
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.306074] usb 1-1.2: USB disconnect, device number 4
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.315000] xsens_mt ttyUSB0: xsens_mt converter now disconnected from ttyUSB0
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.324817] xsens_mt 1-1.2:1.1: device disconnected
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.333203] usb 1-1.4: USB disconnect, device number 5
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.360944] usb 1-3: USB disconnect, device number 3
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.367351] usb 1-3.1: USB disconnect, device number 12
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.376416] usb 1-3.2: USB disconnect, device number 13
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.386633] usb 1-3.3: USB disconnect, device number 6
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.394041] usb 1-3.4: USB disconnect, device number 7
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.401614] usb 1-3.4.4: USB disconnect, device number 9
Feb 11 08:42:42 tegra-ubuntu kernel: [  894.408043] usb 1-3.4.4.4: USB disconnect, device number 11
I’m running a TX2 with 3 USB3 cameras on a hub. I have some heavy usage on the CPUs but haven’t maxed out the cores.
Although one thing that I have observed is that it usually doesn’t crash if I’m interacting with the system . I’m not sure if its relevant. Initially I suspected a thermal issue, thought it was happening due to over heating or something, but then I ventilated it a couple of fans (TX2 sits in an enclosure), But this still occurs from time to time…
I have another TX2 that I run the same setup on, but i haven’t encountered this problem on that … May be I have a faulty unit?
Any insight would be helpful…
Since there is only one USB3 port on default carrier board. You may consider to use PCIe-USB hub for more bandwidth. Please check
[url]https://devtalk.nvidia.com/default/topic/1027100[/url]
