This is the output of “cat kern.log.1 | grep -i usb” after boot:
May 6 05:40:13 tegra-ubuntu kernel: [ 2.598718] usbserial: USB Serial support registered for FTDI USB Serial Device
May 6 05:40:13 tegra-ubuntu kernel: [ 2.598758] usbserial: USB Serial support registered for GSM modem (1-port)
May 6 05:40:13 tegra-ubuntu kernel: [ 2.598798] usbserial: USB Serial support registered for pl2303
May 6 05:40:13 tegra-ubuntu kernel: [ 2.730592] usbhid: USB HID core driver
May 6 05:40:13 tegra-ubuntu kernel: [ 4.127934] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2abc95
May 6 05:40:13 tegra-ubuntu kernel: [ 4.135524] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
May 6 05:40:13 tegra-ubuntu kernel: [ 4.851740] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
May 6 05:40:13 tegra-ubuntu kernel: [ 4.899910] tegra-xotg xotg: Nvidia XUSB OTG Controller
May 6 05:40:13 tegra-ubuntu kernel: [ 7.170812] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
May 6 05:40:13 tegra-ubuntu kernel: [ 7.193820] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
May 6 05:40:13 tegra-ubuntu kernel: [ 7.200693] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
May 6 05:40:14 tegra-ubuntu kernel: [ 7.219431] hub 1-0:1.0: USB hub found
May 6 05:40:14 tegra-ubuntu kernel: [ 7.241691] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
May 6 05:40:14 tegra-ubuntu kernel: [ 7.249443] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
May 6 05:40:14 tegra-ubuntu kernel: [ 7.256247] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
May 6 05:40:14 tegra-ubuntu kernel: [ 7.279205] hub 2-0:1.0: USB hub found
May 6 05:40:14 tegra-ubuntu kernel: [ 7.528203] usb 1-2: new high-speed USB device number 2 using xhci-tegra
May 6 05:40:14 tegra-ubuntu kernel: [ 7.596625] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
May 6 05:40:14 tegra-ubuntu kernel: [ 7.612579] usb 2-1: New USB device found, idVendor=04b4, idProduct=6500
May 6 05:40:14 tegra-ubuntu kernel: [ 7.612582] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
May 6 05:40:14 tegra-ubuntu kernel: [ 7.614606] hub 2-1:1.0: USB hub found
May 6 05:40:14 tegra-ubuntu kernel: [ 7.664546] usb 1-2: New USB device found, idVendor=04b4, idProduct=6502
May 6 05:40:14 tegra-ubuntu kernel: [ 7.671260] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
May 6 05:40:14 tegra-ubuntu kernel: [ 7.679232] hub 1-2:1.0: USB hub found
Binary file (standard input) matches
May 6 05:40:13 tegra-ubuntu kernel: [ 0.143174] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
May 6 05:40:13 tegra-ubuntu kernel: [ 0.301059] usbcore: registered new interface driver usbfs
May 6 05:40:13 tegra-ubuntu kernel: [ 0.301120] usbcore: registered new interface driver hub
May 6 05:40:13 tegra-ubuntu kernel: [ 0.301237] usbcore: registered new device driver usb
May 6 05:40:13 tegra-ubuntu kernel: [ 0.367632] vdd-usb0-5v: 5000 mV
May 6 05:40:13 tegra-ubuntu kernel: [ 0.367817] vdd-usb1-5v: 5000 mV
May 6 05:40:13 tegra-ubuntu kernel: [ 2.597271] usbcore: registered new interface driver r8152
May 6 05:40:13 tegra-ubuntu kernel: [ 2.597309] usbcore: registered new interface driver asix
May 6 05:40:13 tegra-ubuntu kernel: [ 2.597335] usbcore: registered new interface driver ax88179_178a
May 6 05:40:13 tegra-ubuntu kernel: [ 2.597363] usbcore: registered new interface driver cdc_ether
May 6 05:40:13 tegra-ubuntu kernel: [ 2.597398] usbcore: registered new interface driver smsc95xx
May 6 05:40:13 tegra-ubuntu kernel: [ 2.597423] usbcore: registered new interface driver net1080
May 6 05:40:13 tegra-ubuntu kernel: [ 2.597450] usbcore: registered new interface driver cdc_subset
May 6 05:40:13 tegra-ubuntu kernel: [ 2.597500] usbcore: registered new interface driver zaurus
May 6 05:40:13 tegra-ubuntu kernel: [ 2.597547] usbcore: registered new interface driver cdc_ncm
May 6 05:40:13 tegra-ubuntu kernel: [ 2.597949] tegra-xotg xotg: usb2 phy is not available yet
May 6 05:40:13 tegra-ubuntu kernel: [ 2.598607] usbcore: registered new interface driver usb-storage
May 6 05:40:13 tegra-ubuntu kernel: [ 2.598673] usbcore: registered new interface driver usbserial
May 6 05:40:13 tegra-ubuntu kernel: [ 2.598698] usbcore: registered new interface driver ftdi_sio
May 6 05:40:13 tegra-ubuntu kernel: [ 2.598741] usbcore: registered new interface driver option
May 6 05:40:13 tegra-ubuntu kernel: [ 2.598781] usbcore: registered new interface driver pl2303
May 6 05:40:13 tegra-ubuntu kernel: [ 2.599006] tegra-usb-cd usb_cd: otg phy is not available yet
May 6 05:40:13 tegra-ubuntu kernel: [ 2.601483] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
May 6 05:40:13 tegra-ubuntu kernel: [ 2.724679] usbcore: registered new interface driver gspca_zc3xx
May 6 05:40:13 tegra-ubuntu kernel: [ 2.730591] usbcore: registered new interface driver usbhid
May 6 05:40:13 tegra-ubuntu kernel: [ 4.880274] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
May 6 05:40:13 tegra-ubuntu kernel: [ 4.978355] vdd-usb0-5v: disabling
May 6 05:40:13 tegra-ubuntu kernel: [ 4.978356] vdd-usb1-5v: disabling
May 6 05:40:13 tegra-ubuntu kernel: [ 7.207953] usb usb1: Product: xHCI Host Controller
May 6 05:40:13 tegra-ubuntu kernel: [ 7.212849] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
May 6 05:40:13 tegra-ubuntu kernel: [ 7.212851] usb usb1: SerialNumber: 3530000.xhci
May 6 05:40:14 tegra-ubuntu kernel: [ 7.263475] usb usb2: Product: xHCI Host Controller
May 6 05:40:14 tegra-ubuntu kernel: [ 7.268364] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
May 6 05:40:14 tegra-ubuntu kernel: [ 7.274293] usb usb2: SerialNumber: 3530000.xhci
This is the output of “dmesg | grep -i usb”:
[ 0.142790] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.301133] usbcore: registered new interface driver usbfs
[ 0.301201] usbcore: registered new interface driver hub
[ 0.301324] usbcore: registered new device driver usb
[ 0.364094] vdd-usb0-5v: 5000 mV
[ 0.364260] vdd-usb1-5v: 5000 mV
[ 2.597330] usbcore: registered new interface driver r8152
[ 2.597364] usbcore: registered new interface driver asix
[ 2.597391] usbcore: registered new interface driver ax88179_178a
[ 2.597417] usbcore: registered new interface driver cdc_ether
[ 2.597454] usbcore: registered new interface driver smsc95xx
[ 2.597481] usbcore: registered new interface driver net1080
[ 2.597506] usbcore: registered new interface driver cdc_subset
[ 2.597533] usbcore: registered new interface driver zaurus
[ 2.597576] usbcore: registered new interface driver cdc_ncm
[ 2.597922] tegra-xotg xotg: usb2 phy is not available yet
[ 2.598677] usbcore: registered new interface driver usb-storage
[ 2.598738] usbcore: registered new interface driver usbserial
[ 2.598765] usbcore: registered new interface driver ftdi_sio
[ 2.598784] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.598811] usbcore: registered new interface driver option
[ 2.598832] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.598856] usbcore: registered new interface driver pl2303
[ 2.598873] usbserial: USB Serial support registered for pl2303
[ 2.599108] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.601783] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.736363] usbcore: registered new interface driver gspca_zc3xx
[ 2.742293] usbcore: registered new interface driver usbhid
[ 2.742294] usbhid: USB HID core driver
[ 4.118056] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2abc95
[ 4.125443] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.835781] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 4.864708] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 4.877808] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 4.956345] vdd-usb0-5v: disabling
[ 4.956347] vdd-usb1-5v: disabling
[ 7.323037] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 7.351636] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.351639] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.351641] usb usb1: Product: xHCI Host Controller
[ 7.351643] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 7.351644] usb usb1: SerialNumber: 3530000.xhci
[ 7.351978] hub 1-0:1.0: USB hub found
[ 7.372678] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 7.372826] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 7.372829] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.372831] usb usb2: Product: xHCI Host Controller
[ 7.372833] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 7.372835] usb usb2: SerialNumber: 3530000.xhci
[ 7.373117] hub 2-0:1.0: USB hub found
[ 7.660656] usb 1-2: new high-speed USB device number 2 using xhci-tegra
[ 7.685063] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 7.705007] usb 2-1: New USB device found, idVendor=04b4, idProduct=6500
[ 7.711717] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.727826] hub 2-1:1.0: USB hub found
[ 7.792956] usb 1-2: New USB device found, idVendor=04b4, idProduct=6502
[ 7.799677] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.807568] hub 1-2:1.0: USB hub found
