Using Jetpack 3.3
Board: http://connecttech.com/product/orbitty-carrier-for-nvidia-jetson-tx2-tx1/
nvidia@tegra-ubuntu:~$ uname -a
Linux tegra-ubuntu 4.4.38-tegra #8 SMP PREEMPT Fri Nov 9 13:01:46 CST 2018 aarch64 aarch64 aarch64 GNU/Linux
Sep 24 01:13:56 tegra-ubuntu kernel: [1747576.188315] uvcvideo: Non-zero status (-71) in video completion handler.
Sep 24 01:13:56 tegra-ubuntu kernel: [1747576.380681] usb 1-1-port3: disabled by hub (EMI?), re-enabling...
Sep 24 01:13:56 tegra-ubuntu kernel: [1747576.391820] usb 1-1.3: USB disconnect, device number 13
Sep 24 01:13:57 tegra-ubuntu kernel: [1747576.615534] usb 1-1.3: new full-speed USB device number 14 using xhci-tegra
Sep 24 01:14:03 tegra-ubuntu kernel: [1747583.274797] tegra-xusb-mbox 3538000.mailbox: Controller firmware hang
Sep 24 01:14:03 tegra-ubuntu kernel: [1747583.287732] tegra-xusb-mbox 3538000.mailbox: XUSB_CFG_ARU_MBOX_OWNER 0x0
Sep 24 01:14:03 tegra-ubuntu kernel: [1747583.300826] tegra-xusb-mbox 3538000.mailbox: XUSB_CFG_ARU_MBOX_CMD 0x80000000
Sep 24 01:14:03 tegra-ubuntu kernel: [1747583.320130] tegra-xusb-mbox 3538000.mailbox: XUSB_CFG_ARU_MBOX_DATA_IN 0x0
Sep 24 01:14:03 tegra-ubuntu kernel: [1747583.333466] tegra-xusb-mbox 3538000.mailbox: XUSB_CFG_ARU_MBOX_DATA_OUT 0x0
Sep 24 01:14:07 tegra-ubuntu kernel: [1747586.643452] xhci-tegra 3530000.xhci: xHCI host not responding to stop endpoint command.
Sep 24 01:14:07 tegra-ubuntu kernel: [1747586.663803] xhci-tegra 3530000.xhci: Assuming host is dying, halting host.
Sep 24 01:14:07 tegra-ubuntu kernel: [1747586.720821] xhci-tegra 3530000.xhci: Host not halted after 16000 microseconds.
Sep 24 01:14:07 tegra-ubuntu kernel: [1747586.740425] xhci-tegra 3530000.xhci: Non-responsive xHCI host is not halting.
Sep 24 01:14:07 tegra-ubuntu kernel: [1747586.760020] xhci-tegra 3530000.xhci: Completing active URBs anyway.
Sep 24 01:14:07 tegra-ubuntu kernel: [1747586.773353] xhci-tegra 3530000.xhci: HC died; cleaning up
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.139381] mmc0: Timeout waiting for hardware interrupt.
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.150992] sdhci: =========== REGISTER DUMP (mmc0)===========
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.162930] sdhci: Sys addr: 0x00000008 | Version: 0x00000404
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.174767] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000000
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.186446] sdhci: Argument: 0x01801d01 | Trn mode: 0x0000003b
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.197982] sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000034
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.209539] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.220945] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.232182] sdhci: Timeout: 0x0000000e | Int stat: 0x00000000
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.243429] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.254532] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.265495] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.276380] sdhci: Cmd: 0x0000123a | Max curr: 0x00000000
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.287227] sdhci: Host ctl2: 0x0000300d
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.296060] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000080000010
Sep 24 01:14:17 tegra-ubuntu kernel: [1747597.307521] sdhci: ===========================================
Sep 24 01:14:18 tegra-ubuntu kernel: [1747597.971388] mmc2: Timeout waiting for hardware interrupt.
Sep 24 01:14:18 tegra-ubuntu kernel: [1747597.981950] sdhci: =========== REGISTER DUMP (mmc2)===========
Sep 24 01:14:18 tegra-ubuntu kernel: [1747597.992840] sdhci: Sys addr: 0x00000008 | Version: 0x00000404
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.003631] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000000
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.014474] sdhci: Argument: 0x00c7d6c0 | Trn mode: 0x0000002b
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.025186] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000016
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.035760] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.046183] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.056552] sdhci: Timeout: 0x0000000e | Int stat: 0x00000000
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.066750] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.076804] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.086717] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.096535] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.106350] sdhci: Host ctl2: 0x0000308b
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.114164] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000080000010
Sep 24 01:14:18 tegra-ubuntu kernel: [1747598.124659] sdhci: ===========================================
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.679325] INFO: rcu_preempt self-detected stall on CPU
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.688773] 0-...: (1 GPs behind) idle=3ef/2/0 softirq=208552339/208552339 fqs=5206
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.704783] (t=5250 jiffies g=80215546 c=80215545 q=1472)
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.714799] Task dump for CPU 0:
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.722438] swapper/0 R running task 0 0 0 0x00000002
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.739332] Call trace:
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.746774] [<ffffffc000089860>] dump_backtrace+0x0/0x100
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.757313] [<ffffffc000089a28>] show_stack+0x14/0x1c
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.767487] [<ffffffc0000cefe8>] sched_show_task+0xa8/0xfc
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.778068] [<ffffffc0000d1314>] dump_cpu_task+0x40/0x4c
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.788419] [<ffffffc0000fec28>] rcu_dump_cpu_stacks+0x94/0xe4
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.799245] [<ffffffc000102b88>] rcu_check_callbacks+0x4fc/0xaa0
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.810161] [<ffffffc000107624>] update_process_times+0x3c/0x6c
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.820928] [<ffffffc0001165a8>] tick_sched_handle.isra.16+0x20/0x78
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.832128] [<ffffffc000116644>] tick_sched_timer+0x44/0x7c
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.842526] [<ffffffc000107d64>] __hrtimer_run_queues+0x140/0x350
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.853503] [<ffffffc0001087c4>] hrtimer_interrupt+0x9c/0x1e0
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.864150] [<ffffffc000922574>] tegra186_timer_isr+0x24/0x30
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.874829] [<ffffffc0000f5650>] handle_irq_event_percpu+0x84/0x290
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.886123] [<ffffffc0000f58a0>] handle_irq_event+0x44/0x74
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.896697] [<ffffffc0000f8ba8>] handle_fasteoi_irq+0xb4/0x188
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.907541] [<ffffffc0000f4c70>] generic_handle_irq+0x24/0x38
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.918291] [<ffffffc0000f4f78>] __handle_domain_irq+0x60/0xb4
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.929128] [<ffffffc000081774>] gic_handle_irq+0x5c/0xb4
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.939528] [<ffffffc000084740>] el1_irq+0x80/0xf8
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.949245] [<ffffffc000718b0c>] xhci_handle_command_timeout+0x1f0/0x2e4
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.960950] [<ffffffc000105f84>] call_timer_fn+0x50/0x1bc
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.971284] [<ffffffc0001062b0>] run_timer_softirq+0x1ac/0x2a4
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.981997] [<ffffffc0000a8cfc>] __do_softirq+0x10c/0x368
Sep 24 01:14:28 tegra-ubuntu kernel: [1747607.992156] [<ffffffc0000a91b0>] irq_exit+0x84/0xdc
Sep 24 01:14:28 tegra-ubuntu kernel: [1747608.001618] [<ffffffc0000f4f84>] __handle_domain_irq+0x6c/0xb4
Sep 24 01:14:28 tegra-ubuntu kernel: [1747608.012009] [<ffffffc000081774>] gic_handle_irq+0x5c/0xb4
Sep 24 01:14:28 tegra-ubuntu kernel: [1747608.021909] [<ffffffc000084740>] el1_irq+0x80/0xf8
Sep 24 01:14:28 tegra-ubuntu kernel: [1747608.031121] [<ffffffc00080ca24>] cpuidle_enter+0x18/0x20
Sep 24 01:14:28 tegra-ubuntu kernel: [1747608.040805] [<ffffffc0000e8354>] call_cpuidle+0x28/0x50
Sep 24 01:14:28 tegra-ubuntu kernel: [1747608.050413] [<ffffffc0000e84f8>] cpu_startup_entry+0x17c/0x340
Sep 24 01:14:28 tegra-ubuntu kernel: [1747608.060611] [<ffffffc000b5eecc>] rest_init+0x84/0x8c
Sep 24 01:14:28 tegra-ubuntu kernel: [1747608.069928] [<ffffffc001118980>] start_kernel+0x3a0/0x3b4
Sep 24 01:14:28 tegra-ubuntu kernel: [1747608.079708] [<0000000080b65000>] 0x80b65000
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.784868] xhci-tegra 3530000.xhci: Stopped the command ring failed, maybe the host is dead
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.831997] xhci-tegra 3530000.xhci: Host not halted after 16000 microseconds.
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.842284] xhci-tegra 3530000.xhci: Abort command ring failed
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.850022] xhci-tegra 3530000.xhci: HC died; cleaning up
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.858072] mmcblk0: timed out sending r/w cmd command, card status 0x900
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.858079] mmcblk1: timed out sending r/w cmd command, card status 0x900
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.858085] usb 1-1-port3: couldn't allocate usb_device
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.858087] mmcblk1: not retrying timeout
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.858147] sdhci-tegra 3400000.sdhci: Tuning already done, restoring the best tap value : 32
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.858154] usb 1-1: USB disconnect, device number 2
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.858162] usb 1-1.1: USB disconnect, device number 6
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.863176] usb 2-1: USB disconnect, device number 2
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.866501] ch341-uart ttyUSB2: ch341-uart converter now disconnected from ttyUSB2
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.866540] ch341 1-1.1:1.0: device disconnected
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.867129] usb 1-1.2: USB disconnect, device number 4
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.868217] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.868256] cp210x 1-1.2:1.0: device disconnected
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.869015] cp210x ttyUSB1: cp210x converter now disconnected from ttyUSB1
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.869056] cp210x 1-1.2:1.1: device disconnected
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.928004] mmc2: tried to reset card
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.984642] mmcblk0: not retrying timeout
Sep 24 01:14:29 tegra-ubuntu kernel: [1747608.991229] blk_update_request: I/O error, dev mmcblk0, sector 25173249
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.867361] sysfs group ffffffc0012ffff8 not found for kobject 'event3'
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.875451] ------------[ cut here ]------------
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.881322] WARNING: at ffffffc000244d00 [verbose debug info unavailable]
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.889347] Modules linked in: sch_sfq sch_netem ifb fuse nf_conntrack_netlink nfnetlink br_netfilter ch341 overlay uvcvideo videobuf2_vmalloc ip6table_filter ipt_REJECT nf_reject_ipv4 xt_conntrack iptable_filter xt_nat ipt_MASQUERADE nf_nat_masquerade_ipv4 xt_addrtype iptable_nat nf_nat_ipv4 nf_nat ip_tables bcmdhd bluedroid_pm
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.924316]
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.927011] CPU: 5 PID: 4302 Comm: gst-launch-1.0 Tainted: G W 4.4.38-tegra #8
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.937726] Hardware name: quill (DT)
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.942614] task: ffffffc028f37080 ti: ffffffc0d726c000 task.ti: ffffffc0d726c000
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.952419] PC is at sysfs_remove_group+0x8c/0x94
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.958379] LR is at sysfs_remove_group+0x8c/0x94
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.964299] pc : [<ffffffc000244d00>] lr : [<ffffffc000244d00>] pstate: 80000045
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.973986] sp : ffffffc0d726f930
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.978521] x29: ffffffc0d726f930 x28: 0000000000000009
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.985065] x27: ffffffc000b6b000 x26: ffffffc028f37080
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.991592] x25: ffffffc0d23820c8 x24: ffffffc001328000
Sep 24 01:14:30 tegra-ubuntu kernel: [1747609.998113] x23: ffffffc001328a28 x22: ffffffc07aa23a60
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.004600] x21: ffffffc07aa240c0 x20: ffffffc0012ffff8
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.011076] x19: 0000000000000000 x18: 0000000000008090
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.017534] x17: 0000007f99d759a0 x16: ffffffc0001d5ba0
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.023978] x15: ffffffc000b6fa60 x14: ffffffc000b6fa60
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.030411] x13: 0000000000000001 x12: 0024789e5e368e7f
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.036851] x11: 00000000007f7ad0 x10: 00000000000008b0
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.043267] x9 : ffffffc0d726f6f0 x8 : ffffffc028f37990
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.049661] x7 : 0000000000000400 x6 : 00000000003fbd68
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.056039] x5 : 000000000000002d x4 : ffffffc028f37998
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.062399] x3 : ffffffc07b18bacc x2 : ffffffc1e0e4cb28
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.068741] x1 : 0000000000000000 x0 : 000000000000003b
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.075062]
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.077744] ---[ end trace 071b6c2859bfd058 ]---
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.083310] Call trace:
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.086677] [<ffffffc000244d00>] sysfs_remove_group+0x8c/0x94
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.093387] [<ffffffc000588c34>] dpm_sysfs_remove+0x58/0x68
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.100059] [<ffffffc00057c8c8>] device_del+0x40/0x200
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.106128] [<ffffffc0007660fc>] evdev_disconnect+0x24/0x58
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.112636] [<ffffffc0007610f4>] __input_unregister_device+0xa8/0x14c
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.120043] [<ffffffc000761df4>] input_unregister_device+0x50/0x70
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.127125] [<ffffffbffcee0450>] uvc_status_cleanup+0x34/0x40 [uvcvideo]
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.134763] [<ffffffbffced6344>] uvc_delete+0x1c/0x148 [uvcvideo]
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.141824] [<ffffffbffced657c>] uvc_release+0x34/0x3c [uvcvideo]
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.148815] [<ffffffc00078f30c>] v4l2_device_release+0xcc/0xf0
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.155529] [<ffffffc00057bfb8>] device_release+0x34/0x90
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.161804] [<ffffffc000343e5c>] kobject_cleanup+0x8c/0x194
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.168251] [<ffffffc000343cf8>] kobject_put+0x44/0x6c
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.174267] [<ffffffc00057c3c0>] put_device+0x14/0x1c
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.180205] [<ffffffc00078e69c>] v4l2_release+0x54/0x90
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.186339] [<ffffffc0001d6924>] __fput+0x90/0x1bc
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.192217] [<ffffffc0001d6aac>] ____fput+0xc/0x14
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.197907] [<ffffffc0000c02ec>] task_work_run+0xa8/0xc4
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.204106] [<ffffffc0000a786c>] do_exit+0x290/0x9a8
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.209964] [<ffffffc0000a7ff4>] do_group_exit+0x40/0xa8
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.216227] [<ffffffc0000b2ba8>] get_signal+0x21c/0x668
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.222477] [<ffffffc000089024>] do_signal+0x70/0x3a0
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.228413] [<ffffffc000089560>] do_notify_resume+0x60/0x74
Sep 24 01:14:30 tegra-ubuntu kernel: [1747610.234868] [<ffffffc000084ee8>] work_pending+0x1c/0x20
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.259362] sysfs group ffffffc0012ffff8 not found for kobject 'input3'
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.267170] ------------[ cut here ]------------
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.272812] WARNING: at ffffffc000244d00 [verbose debug info unavailable]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.280535] Modules linked in: sch_sfq sch_netem ifb fuse nf_conntrack_netlink nfnetlink br_netfilter ch341 overlay uvcvideo videobuf2_vmalloc ip6table_filter ipt_REJECT nf_reject_ipv4 xt_conntrack iptable_filter xt_nat ipt_MASQUERADE nf_nat_masquerade_ipv4 xt_addrtype iptable_nat nf_nat_ipv4 nf_nat ip_tables bcmdhd bluedroid_pm
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.314761]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.317344] CPU: 4 PID: 4302 Comm: gst-launch-1.0 Tainted: G W 4.4.38-tegra #8
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.327667] Hardware name: quill (DT)
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.332369] task: ffffffc028f37080 ti: ffffffc0d726c000 task.ti: ffffffc0d726c000
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.341770] PC is at sysfs_remove_group+0x8c/0x94
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.347550] LR is at sysfs_remove_group+0x8c/0x94
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.353338] pc : [<ffffffc000244d00>] lr : [<ffffffc000244d00>] pstate: 80000045
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.362816] sp : ffffffc0d726f960
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.367216] x29: ffffffc0d726f960 x28: 0000000000000009
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.373648] x27: ffffffc000b6b000 x26: ffffffc028f37080
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.380071] x25: ffffffc0d23820c8 x24: ffffffc001328000
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.386490] x23: ffffffc001328a28 x22: ffffffc1e198f430
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.392911] x21: ffffffc07aa23a70 x20: ffffffc0012ffff8
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.399323] x19: 0000000000000000 x18: 0000000000000014
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.405743] x17: 0000007f92b48528 x16: ffffffc00011a8fc
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.412165] x15: 0015c03c86a17983 x14: 0000000000000000
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.418833] x13: 00000001f4000000 x12: 000000000024996a
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.425273] x11: 000000000024996a x10: 00000000000008b0
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.431693] x9 : ffffffc0d726f720 x8 : ffffffc028f37990
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.438104] x7 : 0000000000000400 x6 : 000000000232b2cf
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.444498] x5 : 0000000000000000 x4 : ffffffc028f37998
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.450863] x3 : 0000000000000000 x2 : ffffffc123e18ca8
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.457261] x1 : 0000000000000000 x0 : 000000000000003b
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.463571]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.466232] ---[ end trace 071b6c2859bfd059 ]---
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.471771] Call trace:
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.475112] [<ffffffc000244d00>] sysfs_remove_group+0x8c/0x94
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.481800] [<ffffffc000588c34>] dpm_sysfs_remove+0x58/0x68
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.488293] [<ffffffc00057c8c8>] device_del+0x40/0x200
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.494332] [<ffffffc000761178>] __input_unregister_device+0x12c/0x14c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.501770] [<ffffffc000761df4>] input_unregister_device+0x50/0x70
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.508920] [<ffffffbffcee0450>] uvc_status_cleanup+0x34/0x40 [uvcvideo]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.516614] [<ffffffbffced6344>] uvc_delete+0x1c/0x148 [uvcvideo]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.523589] [<ffffffbffced657c>] uvc_release+0x34/0x3c [uvcvideo]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.530571] [<ffffffc00078f30c>] v4l2_device_release+0xcc/0xf0
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.537364] [<ffffffc00057bfb8>] device_release+0x34/0x90
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.543607] [<ffffffc000343e5c>] kobject_cleanup+0x8c/0x194
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.550027] [<ffffffc000343cf8>] kobject_put+0x44/0x6c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.556010] [<ffffffc00057c3c0>] put_device+0x14/0x1c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.561962] [<ffffffc00078e69c>] v4l2_release+0x54/0x90
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.568084] [<ffffffc0001d6924>] __fput+0x90/0x1bc
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.573747] [<ffffffc0001d6aac>] ____fput+0xc/0x14
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.579404] [<ffffffc0000c02ec>] task_work_run+0xa8/0xc4
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.585587] [<ffffffc0000a786c>] do_exit+0x290/0x9a8
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.591417] [<ffffffc0000a7ff4>] do_group_exit+0x40/0xa8
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.597598] [<ffffffc0000b2ba8>] get_signal+0x21c/0x668
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.603679] [<ffffffc000089024>] do_signal+0x70/0x3a0
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.609591] [<ffffffc000089560>] do_notify_resume+0x60/0x74
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.616021] [<ffffffc000084ee8>] work_pending+0x1c/0x20
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.623107] sysfs group ffffffc00131e598 not found for kobject 'input3'
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.631371] ------------[ cut here ]------------
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.637820] WARNING: at ffffffc000244d00 [verbose debug info unavailable]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.645962] Modules linked in: sch_sfq sch_netem ifb fuse nf_conntrack_netlink nfnetlink br_netfilter ch341 overlay uvcvideo videobuf2_vmalloc ip6table_filter ipt_REJECT nf_reject_ipv4 xt_conntrack iptable_filter xt_nat ipt_MASQUERADE nf_nat_masquerade_ipv4 xt_addrtype iptable_nat nf_nat_ipv4 nf_nat ip_tables bcmdhd bluedroid_pm
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.682319]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.685169] CPU: 1 PID: 4302 Comm: gst-launch-1.0 Tainted: G W 4.4.38-tegra #8
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.696133] Hardware name: quill (DT)
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.701242] task: ffffffc028f37080 ti: ffffffc0d726c000 task.ti: ffffffc0d726c000
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.711410] PC is at sysfs_remove_group+0x8c/0x94
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.717638] LR is at sysfs_remove_group+0x8c/0x94
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.723777] pc : [<ffffffc000244d00>] lr : [<ffffffc000244d00>] pstate: 60000045
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.734091] sp : ffffffc0d726f930
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.738924] x29: ffffffc0d726f930 x28: 0000000000000009
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.745768] x27: ffffffc000b6b000 x26: ffffffc028f37080
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.752617] x25: ffffffc0d23820c8 x24: ffffffc001328000
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.759877] x23: ffffffc00149a000 x22: ffffffc00131e310
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.766749] x21: ffffffc07aa23a70 x20: ffffffc00131e598
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.773633] x19: 0000000000000000 x18: 0000000000000014
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.780500] x17: 0000007f92b48528 x16: ffffffc00011a8fc
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.787361] x15: 0015c03c86a17983 x14: 6a626f6b20726f66
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.794237] x13: 20646e756f662074 x12: 6f6e203839356531
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.801117] x11: 3331303063666666 x10: 6666662070756f72
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.808130] x9 : 00000000000007c0 x8 : 0000000000000001
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.814992] x7 : ffffffc0d726c000 x6 : 0000000000000000
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.821855] x5 : 0000000000000000 x4 : 0000000000000000
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.828636] x3 : 0000000000000000 x2 : 0000000000000000
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.835375] x1 : 000000000000000c x0 : 000000000000003b
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.842129]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.845319] ---[ end trace 071b6c2859bfd05a ]---
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.851219] Call trace:
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.854424] [<ffffffc000244d00>] sysfs_remove_group+0x8c/0x94
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.860849] [<ffffffc000244d3c>] sysfs_remove_groups+0x34/0x4c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.867343] [<ffffffc00057bf04>] device_remove_attrs+0x5c/0x7c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.873820] [<ffffffc00057c988>] device_del+0x100/0x200
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.879691] [<ffffffc000761178>] __input_unregister_device+0x12c/0x14c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.886824] [<ffffffc000761df4>] input_unregister_device+0x50/0x70
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.893638] [<ffffffbffcee0450>] uvc_status_cleanup+0x34/0x40 [uvcvideo]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.900957] [<ffffffbffced6344>] uvc_delete+0x1c/0x148 [uvcvideo]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.907692] [<ffffffbffced657c>] uvc_release+0x34/0x3c [uvcvideo]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.914386] [<ffffffc00078f30c>] v4l2_device_release+0xcc/0xf0
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.920798] [<ffffffc00057bfb8>] device_release+0x34/0x90
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.926781] [<ffffffc000343e5c>] kobject_cleanup+0x8c/0x194
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.932942] [<ffffffc000343cf8>] kobject_put+0x44/0x6c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.938673] [<ffffffc00057c3c0>] put_device+0x14/0x1c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.944313] [<ffffffc00078e69c>] v4l2_release+0x54/0x90
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.950135] [<ffffffc0001d6924>] __fput+0x90/0x1bc
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.955614] [<ffffffc0001d6aac>] ____fput+0xc/0x14
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.961035] [<ffffffc0000c02ec>] task_work_run+0xa8/0xc4
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.966997] [<ffffffc0000a786c>] do_exit+0x290/0x9a8
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.972597] [<ffffffc0000a7ff4>] do_group_exit+0x40/0xa8
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.978529] [<ffffffc0000b2ba8>] get_signal+0x21c/0x668
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.984373] [<ffffffc000089024>] do_signal+0x70/0x3a0
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.990033] [<ffffffc000089560>] do_notify_resume+0x60/0x74
Sep 24 01:14:31 tegra-ubuntu kernel: [1747610.996224] [<ffffffc000084ee8>] work_pending+0x1c/0x20
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.002244] sysfs group ffffffc00131e400 not found for kobject 'input3'
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.009670] ------------[ cut here ]------------
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.014948] WARNING: at ffffffc000244d00 [verbose debug info unavailable]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.022399] Modules linked in: sch_sfq sch_netem ifb fuse nf_conntrack_netlink nfnetlink br_netfilter ch341 overlay uvcvideo videobuf2_vmalloc ip6table_filter ipt_REJECT nf_reject_ipv4 xt_conntrack iptable_filter xt_nat ipt_MASQUERADE nf_nat_masquerade_ipv4 xt_addrtype iptable_nat nf_nat_ipv4 nf_nat ip_tables bcmdhd bluedroid_pm
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.054651]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.056882] CPU: 1 PID: 4302 Comm: gst-launch-1.0 Tainted: G W 4.4.38-tegra #8
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.066493] Hardware name: quill (DT)
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.070875] task: ffffffc028f37080 ti: ffffffc0d726c000 task.ti: ffffffc0d726c000
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.079659] PC is at sysfs_remove_group+0x8c/0x94
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.085122] LR is at sysfs_remove_group+0x8c/0x94
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.090582] pc : [<ffffffc000244d00>] lr : [<ffffffc000244d00>] pstate: 80000045
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.099342] sp : ffffffc0d726f930
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.103425] x29: ffffffc0d726f930 x28: 0000000000000009
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.109555] x27: ffffffc000b6b000 x26: ffffffc028f37080
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.115674] x25: ffffffc0d23820c8 x24: ffffffc001328000
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.121778] x23: ffffffc00149a000 x22: ffffffc00131e310
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.127879] x21: ffffffc07aa23a70 x20: ffffffc00131e400
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.133980] x19: 0000000000000000 x18: 0000000000000014
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.140087] x17: 0000007f92b48528 x16: ffffffc00011a8fc
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.146196] x15: 0015c03c86a17983 x14: 6a626f6b20726f66
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.152304] x13: 20646e756f662074 x12: 6f6e203030346531
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.158420] x11: 3331303063666666 x10: 00000000000008b0
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.164539] x9 : ffffffc0d726f6f0 x8 : ffffffc028f37990
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.170652] x7 : 0000000000000400 x6 : 0000000000000000
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.176757] x5 : 0000000000000000 x4 : ffffffc028f37998
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.182839] x3 : ffffffc0477060cc x2 : ffffffc1eb493228
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.188916] x1 : 0000000000000000 x0 : 000000000000003b
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.194983]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.197584] ---[ end trace 071b6c2859bfd05b ]---
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.202907] Call trace:
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.206064] [<ffffffc000244d00>] sysfs_remove_group+0x8c/0x94
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.212528] [<ffffffc000244d3c>] sysfs_remove_groups+0x34/0x4c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.219061] [<ffffffc00057bf04>] device_remove_attrs+0x5c/0x7c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.225578] [<ffffffc00057c988>] device_del+0x100/0x200
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.231493] [<ffffffc000761178>] __input_unregister_device+0x12c/0x14c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.238700] [<ffffffc000761df4>] input_unregister_device+0x50/0x70
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.245596] [<ffffffbffcee0450>] uvc_status_cleanup+0x34/0x40 [uvcvideo]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.252969] [<ffffffbffced6344>] uvc_delete+0x1c/0x148 [uvcvideo]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.259742] [<ffffffbffced657c>] uvc_release+0x34/0x3c [uvcvideo]
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.266504] [<ffffffc00078f30c>] v4l2_device_release+0xcc/0xf0
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.272991] [<ffffffc00057bfb8>] device_release+0x34/0x90
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.279044] [<ffffffc000343e5c>] kobject_cleanup+0x8c/0x194
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.285269] [<ffffffc000343cf8>] kobject_put+0x44/0x6c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.291057] [<ffffffc00057c3c0>] put_device+0x14/0x1c
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.296762] [<ffffffc00078e69c>] v4l2_release+0x54/0x90
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.302642] [<ffffffc0001d6924>] __fput+0x90/0x1bc
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.308092] [<ffffffc0001d6aac>] ____fput+0xc/0x14
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.313536] [<ffffffc0000c02ec>] task_work_run+0xa8/0xc4
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.319499] [<ffffffc0000a786c>] do_exit+0x290/0x9a8
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.325116] [<ffffffc0000a7ff4>] do_group_exit+0x40/0xa8
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.331077] [<ffffffc0000b2ba8>] get_signal+0x21c/0x668
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.336954] [<ffffffc000089024>] do_signal+0x70/0x3a0
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.342653] [<ffffffc000089560>] do_notify_resume+0x60/0x74
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.348863] [<ffffffc000084ee8>] work_pending+0x1c/0x20
Sep 24 01:14:31 tegra-ubuntu kernel: [1747611.355018] sysfs group ffffffc0012ffff8 not found for kobject 'media1'
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.362628] ------------[ cut here ]------------
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.367914] WARNING: at ffffffc000244d00 [verbose debug info unavailable]
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.375370] Modules linked in: sch_sfq sch_netem ifb fuse nf_conntrack_netlink nfnetlink br_netfilter ch341 overlay uvcvideo videobuf2_vmalloc ip6table_filter ipt_REJECT nf_reject_ipv4 xt_conntrack iptable_filter xt_nat ipt_MASQUERADE nf_nat_masquerade_ipv4 xt_addrtype iptable_nat nf_nat_ipv4 nf_nat ip_tables bcmdhd bluedroid_pm
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.407697]
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.409925] CPU: 1 PID: 4302 Comm: gst-launch-1.0 Tainted: G W 4.4.38-tegra #8
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.419550] Hardware name: quill (DT)
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.423963] task: ffffffc028f37080 ti: ffffffc0d726c000 task.ti: ffffffc0d726c000
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.432785] PC is at sysfs_remove_group+0x8c/0x94
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.438253] LR is at sysfs_remove_group+0x8c/0x94
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.443711] pc : [<ffffffc000244d00>] lr : [<ffffffc000244d00>] pstate: 80000045
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.452497] sp : ffffffc0d726f960
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.456600] x29: ffffffc0d726f960 x28: 0000000000000009
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.462730] x27: ffffffc000b6b000 x26: ffffffc028f37080
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.468854] x25: ffffffc0d23820c8 x24: ffffffc001328000
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.474980] x23: ffffffc001328a28 x22: ffffffc1e198f430
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.481102] x21: ffffffc079a2c090 x20: ffffffc0012ffff8
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.487222] x19: 0000000000000000 x18: 0000000000000014
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.493352] x17: 0000007f92b48528 x16: ffffffc000b6fa60
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.499468] x15: ffffffc000b6fa60 x14: 0000000000000001
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.505586] x13: 0000000002d66411 x12: 003c0e7cd6894844
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.511704] x11: 0000000000000000 x10: 00000000000008b0
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.517839] x9 : ffffffc0d726f720 x8 : ffffffc028f37990
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.523955] x7 : 0000000000000400 x6 : 0000000002de5f8f
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.530079] x5 : 0000000000000000 x4 : ffffffc028f37998
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.536178] x3 : ffffffc0477060cc x2 : ffffffc1ece6e428
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.542272] x1 : 0000000000000000 x0 : 000000000000003b
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.548355]
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.550905] ---[ end trace 071b6c2859bfd05c ]---
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.556233] Call trace:
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.559387] [<ffffffc000244d00>] sysfs_remove_group+0x8c/0x94
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.565858] [<ffffffc000588c34>] dpm_sysfs_remove+0x58/0x68
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.572191] [<ffffffc00057c8c8>] device_del+0x40/0x200
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.578046] [<ffffffc00057cab0>] device_unregister+0x28/0x74
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.584411] [<ffffffc00078d65c>] media_devnode_unregister+0x44/0x50
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.591378] [<ffffffc00078d1dc>] media_device_unregister+0x5c/0x6c
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.598247] [<ffffffbffced646c>] uvc_delete+0x144/0x148 [uvcvideo]
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.605106] [<ffffffbffced657c>] uvc_release+0x34/0x3c [uvcvideo]
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.611885] [<ffffffc00078f30c>] v4l2_device_release+0xcc/0xf0
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.618405] [<ffffffc00057bfb8>] device_release+0x34/0x90
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.624470] [<ffffffc000343e5c>] kobject_cleanup+0x8c/0x194
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.630707] [<ffffffc000343cf8>] kobject_put+0x44/0x6c
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.636514] [<ffffffc00057c3c0>] put_device+0x14/0x1c
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.642232] [<ffffffc00078e69c>] v4l2_release+0x54/0x90
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.648125] [<ffffffc0001d6924>] __fput+0x90/0x1bc
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.653582] [<ffffffc0001d6aac>] ____fput+0xc/0x14
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.659040] [<ffffffc0000c02ec>] task_work_run+0xa8/0xc4
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.665031] [<ffffffc0000a786c>] do_exit+0x290/0x9a8
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.670653] [<ffffffc0000a7ff4>] do_group_exit+0x40/0xa8
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.676624] [<ffffffc0000b2ba8>] get_signal+0x21c/0x668
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.682505] [<ffffffc000089024>] do_signal+0x70/0x3a0
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.688208] [<ffffffc000089560>] do_notify_resume+0x60/0x74
Sep 24 01:14:32 tegra-ubuntu kernel: [1747611.694429] [<ffffffc000084ee8>] work_pending+0x1c/0x20
We also see the following error sometimes (maybe related):
nvidia@tegra-ubuntu:~$ cat /var/log/kern.log | grep -B5 -A5 GPS
Sep 23 18:26:37 tegra-ubuntu kernel: [1723136.320928] usb 1-1-port3: disabled by hub (EMI?), re-enabling...
Sep 23 18:26:37 tegra-ubuntu kernel: [1723136.329748] usb 1-1.3: USB disconnect, device number 11
Sep 23 18:26:37 tegra-ubuntu kernel: [1723136.562199] usb 1-1.3: new full-speed USB device number 12 using xhci-tegra
Sep 23 18:26:37 tegra-ubuntu kernel: [1723136.679247] usb 1-1.3: New USB device found, idVendor=1546, idProduct=01a6
Sep 23 18:26:37 tegra-ubuntu kernel: [1723136.688718] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 23 18:26:37 tegra-ubuntu kernel: [1723136.700011] usb 1-1.3: Product: u-blox 6 - GPS Receiver
Sep 23 18:26:37 tegra-ubuntu kernel: [1723136.707870] usb 1-1.3: Manufacturer: u-blox AG - www.u-blox.com
Sep 23 18:26:37 tegra-ubuntu kernel: [1723136.717157] usb 1-1.3: ep 0x83 - rounding interval to 1024 microframes, ep desc says 2040 microframes
Sep 23 18:26:37 tegra-ubuntu kernel: [1723136.734638] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Sep 23 18:26:37 tegra-ubuntu kernel: [1723137.028507] tegra-snd-t186ref-mobile-rt565x sound: ASoC: CODEC DAI sgtl5000 not registered
Sep 23 18:26:37 tegra-ubuntu kernel: [1723137.039917] tegra-snd-t186ref-mobile-rt565x sound: snd_soc_register_card failed (-517)
Sep 24 00:47:45 tegra-ubuntu kernel: [1746004.794497] usb 1-1-port3: disabled by hub (EMI?), re-enabling...
Sep 24 00:47:45 tegra-ubuntu kernel: [1746004.804632] usb 1-1.3: USB disconnect, device number 12
Sep 24 00:47:45 tegra-ubuntu kernel: [1746005.034975] usb 1-1.3: new full-speed USB device number 13 using xhci-tegra
Sep 24 00:47:45 tegra-ubuntu kernel: [1746005.152038] usb 1-1.3: New USB device found, idVendor=1546, idProduct=01a6
Sep 24 00:47:45 tegra-ubuntu kernel: [1746005.162394] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 24 00:47:45 tegra-ubuntu kernel: [1746005.174326] usb 1-1.3: Product: u-blox 6 - GPS Receiver
Sep 24 00:47:45 tegra-ubuntu kernel: [1746005.183758] usb 1-1.3: Manufacturer: u-blox AG - www.u-blox.com
Sep 24 00:47:45 tegra-ubuntu kernel: [1746005.192772] usb 1-1.3: ep 0x83 - rounding interval to 1024 microframes, ep desc says 2040 microframes
Sep 24 00:47:45 tegra-ubuntu kernel: [1746005.212587] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Sep 24 00:47:45 tegra-ubuntu kernel: [1746005.367100] tegra-snd-t186ref-mobile-rt565x sound: ASoC: CODEC DAI sgtl5000 not registered
Sep 24 00:47:45 tegra-ubuntu kernel: [1746005.378166] tegra-snd-t186ref-mobile-rt565x sound: snd_soc_register_card failed (-517)
Sep 24 01:31:18 tegra-ubuntu kernel: [ 8.457617] tegra-snd-t186ref-mobile-rt565x sound: ASoC: CODEC DAI sgtl5000 not registered
Sep 24 01:31:18 tegra-ubuntu kernel: [ 8.468197] tegra-snd-t186ref-mobile-rt565x sound: snd_soc_register_card failed (-517)
Sep 24 01:31:18 tegra-ubuntu kernel: [ 8.541748] usb 1-1.3: new full-speed USB device number 5 using xhci-tegra
Sep 24 01:31:18 tegra-ubuntu kernel: [ 8.654655] usb 1-1.3: New USB device found, idVendor=1546, idProduct=01a6
Sep 24 01:31:18 tegra-ubuntu kernel: [ 8.662650] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 24 01:31:18 tegra-ubuntu kernel: [ 8.672087] usb 1-1.3: Product: u-blox 6 - GPS Receiver
Sep 24 01:31:18 tegra-ubuntu kernel: [ 8.678565] usb 1-1.3: Manufacturer: u-blox AG - www.u-blox.com
Sep 24 01:31:18 tegra-ubuntu kernel: [ 8.685801] usb 1-1.3: ep 0x83 - rounding interval to 1024 microframes, ep desc says 2040 microframes
Sep 24 01:31:18 tegra-ubuntu kernel: [ 8.698015] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Sep 24 01:31:18 tegra-ubuntu kernel: [ 8.707413] tegra-snd-t186ref-mobile-rt565x sound: ASoC: CODEC DAI sgtl5000 not registered
Sep 24 01:31:18 tegra-ubuntu kernel: [ 8.718021] tegra-snd-t186ref-mobile-rt565x sound: snd_soc_register_card failed (-517)
Sep 24 06:11:38 tegra-ubuntu kernel: [16828.729166] usb 1-1-port3: disabled by hub (EMI?), re-enabling...
Sep 24 06:11:38 tegra-ubuntu kernel: [16828.736729] usb 1-1.3: USB disconnect, device number 5
Sep 24 06:11:38 tegra-ubuntu kernel: [16828.963975] usb 1-1.3: new full-speed USB device number 6 using xhci-tegra
Sep 24 06:11:38 tegra-ubuntu kernel: [16829.081010] usb 1-1.3: New USB device found, idVendor=1546, idProduct=01a6
Sep 24 06:11:38 tegra-ubuntu kernel: [16829.089510] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 24 06:11:38 tegra-ubuntu kernel: [16829.098799] usb 1-1.3: Product: u-blox 6 - GPS Receiver
Sep 24 06:11:38 tegra-ubuntu kernel: [16829.105381] usb 1-1.3: Manufacturer: u-blox AG - www.u-blox.com
Sep 24 06:11:38 tegra-ubuntu kernel: [16829.113783] usb 1-1.3: ep 0x83 - rounding interval to 1024 microframes, ep desc says 2040 microframes
Sep 24 06:11:38 tegra-ubuntu kernel: [16829.126689] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Sep 24 06:11:38 tegra-ubuntu kernel: [16829.136447] tegra-snd-t186ref-mobile-rt565x sound: ASoC: CODEC DAI sgtl5000 not registered
Sep 24 06:11:38 tegra-ubuntu kernel: [16829.144741] tegra-snd-t186ref-mobile-rt565x sound: snd_soc_register_card failed (-517)
Sep 24 06:29:46 tegra-ubuntu kernel: [17917.498949] usb 1-1-port3: disabled by hub (EMI?), re-enabling...
Sep 24 06:29:46 tegra-ubuntu kernel: [17917.506710] usb 1-1.3: USB disconnect, device number 6
Sep 24 06:29:47 tegra-ubuntu kernel: [17917.729516] usb 1-1.3: new full-speed USB device number 7 using xhci-tegra
Sep 24 06:29:47 tegra-ubuntu kernel: [17917.842671] usb 1-1.3: New USB device found, idVendor=1546, idProduct=01a6
Sep 24 06:29:47 tegra-ubuntu kernel: [17917.851401] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 24 06:29:47 tegra-ubuntu kernel: [17917.860894] usb 1-1.3: Product: u-blox 6 - GPS Receiver
Sep 24 06:29:47 tegra-ubuntu kernel: [17917.869021] usb 1-1.3: Manufacturer: u-blox AG - www.u-blox.com
Sep 24 06:29:47 tegra-ubuntu kernel: [17917.876517] usb 1-1.3: ep 0x83 - rounding interval to 1024 microframes, ep desc says 2040 microframes
Sep 24 06:29:47 tegra-ubuntu kernel: [17917.888974] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Sep 24 06:29:47 tegra-ubuntu kernel: [17917.903213] tegra-snd-t186ref-mobile-rt565x sound: ASoC: CODEC DAI sgtl5000 not registered
Sep 24 06:29:47 tegra-ubuntu kernel: [17917.912949] tegra-snd-t186ref-mobile-rt565x sound: snd_soc_register_card failed (-517)
Sep 24 06:37:29 tegra-ubuntu kernel: [18380.091324] usb 1-1-port3: disabled by hub (EMI?), re-enabling...
Sep 24 06:37:29 tegra-ubuntu kernel: [18380.098945] usb 1-1.3: USB disconnect, device number 7
Sep 24 06:37:29 tegra-ubuntu kernel: [18380.328421] usb 1-1.3: new full-speed USB device number 8 using xhci-tegra
Sep 24 06:37:29 tegra-ubuntu kernel: [18380.444460] usb 1-1.3: New USB device found, idVendor=1546, idProduct=01a6
Sep 24 06:37:29 tegra-ubuntu kernel: [18380.453809] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 24 06:37:29 tegra-ubuntu kernel: [18380.464459] usb 1-1.3: Product: u-blox 6 - GPS Receiver
Sep 24 06:37:29 tegra-ubuntu kernel: [18380.470416] usb 1-1.3: Manufacturer: u-blox AG - www.u-blox.com
Sep 24 06:37:29 tegra-ubuntu kernel: [18380.478353] usb 1-1.3: ep 0x83 - rounding interval to 1024 microframes, ep desc says 2040 microframes
Sep 24 06:37:29 tegra-ubuntu kernel: [18380.491565] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Sep 24 06:37:29 tegra-ubuntu kernel: [18380.502320] tegra-snd-t186ref-mobile-rt565x sound: ASoC: CODEC DAI sgtl5000 not registered
Sep 24 06:37:29 tegra-ubuntu kernel: [18380.510760] tegra-snd-t186ref-mobile-rt565x sound: snd_soc_register_card failed (-517)
Sep 24 06:59:30 tegra-ubuntu kernel: [19701.309122] usb 1-1-port3: disabled by hub (EMI?), re-enabling...
Sep 24 06:59:30 tegra-ubuntu kernel: [19701.316907] usb 1-1.3: USB disconnect, device number 8
Sep 24 06:59:30 tegra-ubuntu kernel: [19701.541520] usb 1-1.3: new full-speed USB device number 9 using xhci-tegra
Sep 24 06:59:30 tegra-ubuntu kernel: [19701.658703] usb 1-1.3: New USB device found, idVendor=1546, idProduct=01a6
Sep 24 06:59:30 tegra-ubuntu kernel: [19701.666903] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 24 06:59:30 tegra-ubuntu kernel: [19701.675736] usb 1-1.3: Product: u-blox 6 - GPS Receiver
Sep 24 06:59:30 tegra-ubuntu kernel: [19701.687348] usb 1-1.3: Manufacturer: u-blox AG - www.u-blox.com
Sep 24 06:59:30 tegra-ubuntu kernel: [19701.701984] usb 1-1.3: ep 0x83 - rounding interval to 1024 microframes, ep desc says 2040 microframes
Sep 24 06:59:31 tegra-ubuntu kernel: [19701.714462] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Sep 24 06:59:31 tegra-ubuntu kernel: [19701.723984] tegra-snd-t186ref-mobile-rt565x sound: ASoC: CODEC DAI sgtl5000 not registered
Sep 24 06:59:31 tegra-ubuntu kernel: [19701.732527] tegra-snd-t186ref-mobile-rt565x sound: snd_soc_register_card failed (-517)
Sep 24 07:13:52 tegra-ubuntu NetworkManager[791]: <info> [1569309232.4471] dns-mgr[0x6c4960]: init: dns=dnsmasq, rc-manager=resolvconf, plugin=dnsmasq
Sep 24 07:13:52 tegra-ubuntu NetworkManager[791]: <info> [1569309232.4494] rfkill1: found WiFi radio killswitch (at /sys/devices/3440000.sdhci/mmc_host/mmc1/mmc1:0001/mmc1:0001:2/ieee80211/phy0/rfkill1) (driver bcmsdh_sdmmc)
Sep 24 07:13:52 tegra-ubuntu NetworkManager[791]: <info> [1569309232.4497] rfkill2: found WiFi radio killswitch (at /sys/devices/3440000.sdhci/mmc_host/mmc1/mmc1:0001/mmc1:0001:2/rfkill/rfkill2) (driver bcmsdh_sdmmc)
Sep 24 07:13:52 tegra-ubuntu kernel: [ 9.155286] usb 1-1.3: New USB device found, idVendor=1546, idProduct=01a6
Sep 24 07:13:52 tegra-ubuntu kernel: [ 9.163342] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 24 07:13:52 tegra-ubuntu kernel: [ 9.172982] usb 1-1.3: Product: u-blox 6 - GPS Receiver
Sep 24 07:13:52 tegra-ubuntu kernel: [ 9.179568] usb 1-1.3: Manufacturer: u-blox AG - www.u-blox.com
Sep 24 07:13:52 tegra-ubuntu kernel: [ 9.186861] usb 1-1.3: ep 0x83 - rounding interval to 1024 microframes, ep desc says 2040 microframes
Sep 24 07:13:52 tegra-ubuntu kernel: [ 9.199191] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Sep 24 07:13:52 tegra-ubuntu kernel: [ 9.208109] tegra-snd-t186ref-mobile-rt565x sound: ASoC: CODEC DAI sgtl5000 not registered
Sep 24 07:13:52 tegra-ubuntu kernel: [ 9.218666] tegra-snd-t186ref-mobile-rt565x sound: snd_soc_register_card failed (-517)
After reboot devices are back.
It’s quite rare, we have dozens of devices and we saw it only several times,
but in one of our devices it happened twice in less than 24H
