PCIe doesn't work when software reboot
We use Renesas upd720201 as pcie to usb controller conncted to the PEX0* of TX2.
If TX2 boot from power on the upd720201 is working fine.
But if TX2 boot from software reset as reboot in the terminal, upd720201 don’t work.
These are the key mesg of dmesg
power on reset
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.775908] tegra-pcie 10003000.pcie-controller: 2x1, 1x1, 1x1 configuration
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.787987] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.796940] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.808961] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.903681] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.963712] dhd_module_init in
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.970436] tegra_net_perf_init: cannot get wifi sclk
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.977098] found wifi platform device bcmdhd_wlan
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.979710] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.979720] wifi_platform_get_country_code_map: could not get country_code_map
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.979721] wifi_plat_dev_drv_probe:platform country code map is not available
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.979731] Power-up adapter 'DHD generic adapter'
Jul 26 09:20:42 tegra-ubuntu kernel: [   13.979736] wifi_platform_set_power = 1
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.183115] wifi_platform_bus_enumerate device present 1
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.200984] wifi_platform_bus_enumerate device present 0
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.201346] F1 signature read @0x18000000=0x17214354
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.204724] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.205278] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.205335] wifi_platform_prealloc: failed to alloc static mem section 7
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.205343] wifi_platform_get_mac_addr
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.206793] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207035] wl_create_event_handler(): thread:wl_event_handler:1cb started
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207071] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1e4341a70
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207162] dhd_attach(): thread:dhd_watchdog_thread:1cc started
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207189] dhd_attach(): thread:dhd_dpc:1cd started
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207232] dhd_attach(): thread:dhd_rxf:1ce started
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207237] dhd_deferred_work_init: work queue initialized
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207390] Dongle Host Driver, version 1.201.82 (r)
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207390] Compiled in drivers/net/wireless/bcmdhd on Jan 22 2018 at 03:22:10
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207657] tegra_sysfs_register
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207684] Register interface [wlan0]  MAC: 00:04:4b:a5:ac:2e
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207687] dhd_prot_ioctl : bus is down. we have nothing to do
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.207771] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 59
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.208810] wifi_platform_set_power = 0
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.271099] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.675111] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.913087] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.915108] xhci-tegra 3530000.xhci: xHCI Host Controller
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.915124] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.915897] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.915917] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.916027] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.916030] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.916032] usb usb1: Product: xHCI Host Controller
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.916034] usb usb1: Manufacturer: Linux 4.4.38-sugey1sensor xhci-hcd
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.916035] usb usb1: SerialNumber: 3530000.xhci
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.916294] hub 1-0:1.0: USB hub found
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.916313] hub 1-0:1.0: 4 ports detected
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.936045] xhci-tegra 3530000.xhci: xHCI Host Controller
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.936053] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.936159] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.936162] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.936163] usb usb2: Product: xHCI Host Controller
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.936165] usb usb2: Manufacturer: Linux 4.4.38-sugey1sensor xhci-hcd
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.936166] usb usb2: SerialNumber: 3530000.xhci
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.936405] hub 2-0:1.0: USB hub found
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.936421] hub 2-0:1.0: 3 ports detected
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.936774] tegra-xotg xotg: otg: host 3530000.xhci registered
Jul 26 09:20:42 tegra-ubuntu kernel: [   14.947291] extcon-gpio-states external-connection:extcon@1: Cable state 2
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.075258] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.077273] tegra-pcie 10003000.pcie-controller: link 1 down, ignoring
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.077538] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.077542] pci_bus 0000:00: root bus resource [mem 0x50100000-0x57ffffff]
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.077545] pci_bus 0000:00: root bus resource [mem 0x58000000-0x7fffffff pref]
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.077547] pci_bus 0000:00: root bus resource [bus 00-ff]
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.077549] pci_bus 0000:00: root bus resource [io  0x1000-0xffff]
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.077571] pci 0000:00:01.0: [10de:10e5] type 01 class 0x060400
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.077663] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.077798] iommu: Adding device 0000:00:01.0 to group 55
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.077858] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.077996] pci 0000:01:00.0: [1912:0015] type 00 class 0x0c0330
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078054] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078180] pci 0000:01:00.0: PME# supported from D0 D3hot
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078315] iommu: Adding device 0000:01:00.0 to group 56
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078359] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078366] PCIE: ASPM not enabled
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078388] pci 0000:00:01.0: BAR 8: assigned [mem 0x50100000-0x501fffff]
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078392] pci 0000:01:00.0: BAR 0: assigned [mem 0x50100000-0x50101fff 64bit]
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078408] pci 0000:00:01.0: PCI bridge to [bus 01]
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078414] pci 0000:00:01.0:   bridge window [mem 0x50100000-0x501fffff]
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078474] pcieport 0000:00:01.0: enabling device (0000 -> 0002)
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078555] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078557] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078562] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078631] aer 0000:00:01.0:pcie02: service driver aer loaded
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.078688] pci 0000:01:00.0: enabling device (0000 -> 0002)
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.084802] pci 0000:01:00.0: xHCI HW not ready after 5 sec (HC bug?) status = 0x801
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.084897] xhci_hcd 0000:01:00.0: xHCI Host Controller
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.084904] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 3
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.159799] xhci_hcd 0000:01:00.0: hcc params 0x014051cf hci version 0x100 quirks 0x00000090
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.160097] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.160099] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.160101] usb usb3: Product: xHCI Host Controller
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.160102] usb usb3: Manufacturer: Linux 4.4.38-sugey1sensor xhci-hcd
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.160104] usb usb3: SerialNumber: 0000:01:00.0
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.160319] hub 3-0:1.0: USB hub found
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.160335] hub 3-0:1.0: 2 ports detected
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.160501] xhci_hcd 0000:01:00.0: xHCI Host Controller
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.160505] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 4
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.163147] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.163187] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.163189] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.163191] usb usb4: Product: xHCI Host Controller
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.163192] usb usb4: Manufacturer: Linux 4.4.38-sugey1sensor xhci-hcd
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.163194] usb usb4: SerialNumber: 0000:01:00.0
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.163398] hub 4-0:1.0: USB hub found
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.163413] hub 4-0:1.0: 2 ports detected
Jul 26 09:20:42 tegra-ubuntu kernel: [   15.163591] tegra-pcie 10003000.pcie-controller: speed change : Gen-1 -> Gen-2
software reset
Jul 26 09:20:41 tegra-ubuntu kernel: [   12.959451] Freeing unused kernel memory: 1144K (ffffffc0010ce000 - ffffffc0011ec000)
Jul 26 09:20:41 tegra-ubuntu kernel: [   12.959471] Freeing alternatives memory: 96K (ffffffc0011ec000 - ffffffc001204000)
Jul 26 09:20:41 tegra-ubuntu kernel: [   12.961133] random: nonblocking pool is initialized
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.301306] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.688237] tegra-pcie 10003000.pcie-controller: 2x1, 1x1, 1x1 configuration
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.690903] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.691336] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.693553] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.738850] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.840976] dhd_module_init in
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.841004] tegra_net_perf_init: cannot get wifi sclk
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.841068] found wifi platform device bcmdhd_wlan
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.842382] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.842391] wifi_platform_get_country_code_map: could not get country_code_map
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.842392] wifi_plat_dev_drv_probe:platform country code map is not available
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.842402] Power-up adapter 'DHD generic adapter'
Jul 26 09:20:41 tegra-ubuntu kernel: [   13.842406] wifi_platform_set_power = 1
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.043133] wifi_platform_bus_enumerate device present 1
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.060956] wifi_platform_bus_enumerate device present 0
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.061365] F1 signature read @0x18000000=0x17214354
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.064704] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.065211] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.065264] wifi_platform_prealloc: failed to alloc static mem section 7
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.065271] wifi_platform_get_mac_addr
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.066727] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.066954] wl_create_event_handler(): thread:wl_event_handler:1f4 started
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.066959] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1e0981a70
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.067065] dhd_attach(): thread:dhd_watchdog_thread:1f5 started
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.067126] dhd_attach(): thread:dhd_dpc:1f6 started
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.067172] dhd_attach(): thread:dhd_rxf:1f7 started
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.067177] dhd_deferred_work_init: work queue initialized
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.067331] Dongle Host Driver, version 1.201.82 (r)
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.067331] Compiled in drivers/net/wireless/bcmdhd on Jan 22 2018 at 03:22:10
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.067587] tegra_sysfs_register
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.067613] Register interface [wlan0]  MAC: 00:04:4b:a5:ac:2e
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.067616] dhd_prot_ioctl : bus is down. we have nothing to do
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.067707] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 18
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.068747] wifi_platform_set_power = 0
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.136673] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.541498] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.741125] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.743132] xhci-tegra 3530000.xhci: xHCI Host Controller
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.743148] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.743940] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.743962] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.744073] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.744076] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.744078] usb usb1: Product: xHCI Host Controller
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.744080] usb usb1: Manufacturer: Linux 4.4.38-sugey1sensor xhci-hcd
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.744081] usb usb1: SerialNumber: 3530000.xhci
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.744354] hub 1-0:1.0: USB hub found
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.744374] hub 1-0:1.0: 4 ports detected
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.760068] xhci-tegra 3530000.xhci: xHCI Host Controller
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.760078] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.760189] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.760192] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.760194] usb usb2: Product: xHCI Host Controller
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.760196] usb usb2: Manufacturer: Linux 4.4.38-sugey1sensor xhci-hcd
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.760197] usb usb2: SerialNumber: 3530000.xhci
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.760425] hub 2-0:1.0: USB hub found
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.760444] hub 2-0:1.0: 3 ports detected
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.760799] tegra-xotg xotg: otg: host 3530000.xhci registered
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.771404] extcon-gpio-states external-connection:extcon@1: Cable state 2
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.943300] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
Jul 26 09:20:41 tegra-ubuntu kernel: [   14.945314] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.351310] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.503127] usb 1-1: new full-speed USB device number 2 using xhci-tegra
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.635606] usb 1-1: New USB device found, idVendor=24ae, idProduct=2010
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.635610] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.635612] usb 1-1: Product: Rapoo 2.4G Wireless Device
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.635613] usb 1-1: Manufacturer: RAPOO
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.635810] usb 1-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.635827] usb 1-1: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.635842] usb 1-1: ep 0x83 - rounding interval to 64 microframes, ep desc says 80 microframes
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.636287] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.637969] input: RAPOO Rapoo 2.4G Wireless Device as /devices/3530000.xhci/usb1/1-1/1-1:1.0/0003:24AE:2010.0001/input/input4
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.638097] hid-generic 0003:24AE:2010.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-3530000.xhci-1/input0
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.639993] input: RAPOO Rapoo 2.4G Wireless Device as /devices/3530000.xhci/usb1/1-1/1-1:1.1/0003:24AE:2010.0002/input/input5
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.695271] hid-generic 0003:24AE:2010.0002: input,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-3530000.xhci-1/input1
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.707257] input: RAPOO Rapoo 2.4G Wireless Device as /devices/3530000.xhci/usb1/1-1/1-1:1.2/0003:24AE:2010.0003/input/input6
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.755154] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
Jul 26 09:20:41 tegra-ubuntu kernel: [   15.763410] hid-generic 0003:24AE:2010.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-3530000.xhci-1/input2
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.123199] cfg80211: World regulatory domain updated:
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.123203] cfg80211:  DFS Master region: unset
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.123203] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.123206] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.123208] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.123210] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.123212] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.123214] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.123216] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.123218] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.123219] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.159121] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.161137] tegra-pcie 10003000.pcie-controller: link 1 down, ignoring
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.161145] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
Jul 26 09:20:41 tegra-ubuntu kernel: [   16.161318] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
When power on reset there is no “link 0 retrying” mesg.
This is strange. Can you please help us with Make and model (if possible, purchase link) of the card?
Also, please give output of ‘sudo lspci -vv’
Now it is ok.
For we dont connected pxerst to PCIe IC, when reboot the PCIe device can not be reset.
