By modefing the file p2771-0000.conf.common in Linux_for_Tegra
deleting parameter “console=tty0” can solve my problem
fi;
ROOTFSSIZE=28GiB;
CMDLINE_ADD="console=ttyS0,115200n8 OS=l4t fbcon=map:0 net.ifnames=0";
target_board="t186ref";
ROOT_DEV="mmcblk0p12 ------------ internal eMMC.
sda1 ----------------- external USB devices. (USB memory stick, HDD)
eth0 ----------------- nfsroot via RJ45 Ethernet port.
eth1 ----------------- nfsroot via USB Ethernet interface.";
but that have anather question,I find the ubuntu system startup log like "[OK] Listening on udev Kernel Socket."is disappeared on tty0 and was printed in ttySo series port
Welcome to e[1mUbuntu 16.04 LTSe[0m!
[ 6.598050] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 6.710079] systemd[1]: Listening on udev Kernel Socket.
[e[0;32m OK e[0m] Listening on udev Kernel Socket.
[ 6.724006] systemd[1]: Listening on Journal Audit Socket.
[e[0;32m OK e[0m] Listening on Journal Audit Socket.
[ 6.736424] systemd[1]: Created slice User and Session Slice.
[e[0;32m OK e[0m] Created slice User and Session Slice.
[ 6.751925] systemd[1]: Listening on udev Control Socket.
[e[0;32m OK e[0m] Listening on udev Control Socket.
[ 6.763892] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[e[0;32m OK e[0m] Started Forward Password Requests to Wall Directory Watch.
[ 6.779812] systemd[1]: Reached target Swap.
[e[0;32m OK e[0m] Reached target Swap.
[ 6.791871] systemd[1]: Listening on Journal Socket (/dev/log).
[e[0;32m OK e[0m] Listening on Journal Socket (/dev/log).
[ 6.807880] systemd[1]: Listening on Journal Socket.
[e[0;32m OK e[0m] Listening on Journal Socket.
[ 6.819837] systemd[1]: Reached target Remote File Systems (Pre).
[e[0;32m OK e[0m] Reached target Remote File Systems (Pre).
[ 6.835831] systemd[1]: Reached target Remote File Systems.
[e[0;32m OK e[0m] Reached target Remote File Systems.
[ 6.848313] systemd[1]: Created slice System Slice.
[e[0;32m OK e[0m] Created slice System Slice.
[ 6.861184] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.880760] systemd[1]: Starting Load Kernel Modules...
[ 6.893462] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 6.912457] systemd[1]: Created slice system-serial\x2dgetty.slice.
[e[0;32m OK e[0m] Created slice system-serial\x2dgetty.slice.
[ 6.927865] systemd[1]: Reached target Slices.
[e[0;32m OK e[0m] Reached target Slices.
[ 6.941118] systemd[1]: Started Braille Device Support.
[e[0;32m OK e[0m] Started Braille Device Support.
[ 6.957720] systemd[1]: Starting Remount Root and Kernel File Systems...
Starting Remount Root and Kernel File Systems..[ 6.966488] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.980403] systemd[1]: Created slice system-getty.slice.
[e[0;32m OK e[0m] Created slice system-getty.slice.
[ 6.991861] systemd[1]: Reached target Encrypted Volumes.
[e[0;32m OK e[0m] Reached target Encrypted Volumes.
[ 7.003922] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[e[0;32m OK e[0m] Listening on /dev/initctl Compatibility Named Pipe.
[ 7.019924] systemd[1]: Started Trigger resolvconf update for networkd DNS.
[e[0;32m OK e[0m] Started Trigger resolvconf update for networkd DNS.
[ 7.038779] systemd[1]: Mounting Debug File System...
[ 7.051889] systemd[1]: Listening on Syslog Socket.
[e[0;32m OK e[0m] Listening on Syslog Socket.
[ 7.065397] systemd[1]: Starting Journal Service...
[ 7.078380] systemd[1]: Mounted Debug File System.
[e[0;32m OK e[0m] Mounted Debug File System.
[ 7.091893] systemd[1]: Mounted POSIX Message Queue File System.
[e[0;32m OK e[0m] Mounted POSIX Message Queue File System.
[ 7.109024] systemd[1]: Started Load Kernel Modules.
[e[0;32m OK e[0m] Started Load Kernel Modules.
[ 7.124883] systemd[1]: Started Create list of required static device nodes for the current kernel.
[e[0;32m OK e[0m] Started Create list of required sta...ce nodes for the current kernel.
[ 7.146054] systemd[1]: Started Remount Root and Kernel File Systems.
[e[0;32m OK e[0m] Started Remount Root and Kernel File Systems.
[ 7.160206] systemd[1]: Started Journal Service.
[e[0;32m OK e[0m] Started Journal Service.
Starting udev Coldplug all Devices...
Starting Load/Save Random Seed...
Starting Flush Journal to Persistent Storage...
Starting Create Static Device Nodes in /dev...
Starting Apply Kernel Variables...
Mounting Configuration File System...
[e[0;32m OK e[0m] Mounted Configuration File System.
[e[0;32m OK e[0m] Started Load/Save Random Seed.
[e[0;32m OK e[0m] Started Create Static Device Nodes in /dev.
[e[0;32m OK e[0m] Started Apply Kernel Variables.
[ 7.333554] systemd-journald[298]: Received request to flush runtime journal from PID 1
[e[0;32m OK e[0m] Started Flush Journal to Persistent Storage.
Starting udev Kernel Device Manager...
[e[0;32m OK e[0m] Reached target Local File Systems (Pre).
[e[0;32m OK e[0m] Started udev Kernel Device Manager.
[e[0;32m OK e[0m] Started udev Coldplug all Devices.
Starting lvm2.service...
[e[0;32m OK e[0m] Started Dispatch Password Requests to Console Directory Watch.
[e[0;32m OK e[0m] Started lvm2.service.
[e[0;32m OK e[0m] Reached target Local File Systems.
Starting Set console keymap...
Starting LSB: AppArmor initialization...
Starting Create Volatile Files and Directories...
Starting Tell Plymouth To Write Out Runtime Data...
[ 7.521837] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
Starting Clean up any mess left by 0dns-up...
[ 7.541472] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
[ 7.550102] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 7.558372] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[e[0;32m OK e[0m] Started Tell Plymouth To Write Out Runti[ 7.567964] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
me Data.
[e[0;32m OK e[0m] Found device /dev/ttyS0.
[e[0;32m OK e[0m] Started Set console keymap.
[e[0;32m OK e[0m] Started Create Volatile Files and Directories.
[e[0;32m OK e[0m] Started Clean up any mess left by 0dns-up.
[e[0;32m OK e[0m] Started LSB: AppArmor initialization.
[ 7.779427] dhd_module_init in
Starting Nameserver information manager...
[ 7.788446] tegra_net_perf_init: cannot get wifi sclk
Starting Update UTMP about System Boot/Shutdown...
[ 7.799876] found wifi platform device bcmdhd_wlan
[e[0;32m OK e[0m] Reached target Sound Card.
[ 7.809438] wifi_platform_get_country_code_map: could not get country_code_map
[ 7.818247] wifi_plat_dev_drv_probe:platform country code map is not available
[ 7.825516] Power-up adapter 'DHD generic adapter'
[ 7.830337] wifi_platform_set_power = 1
[e[0;32m OK e[0m] Started Nameserver information manager.
[e[0;32m OK e[0m] Started Update UTMP about System Boot/Shutdown.
[e[0;32m OK e[0m] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[e[0;32m OK e[0m] Reached target System Initialization.
[e[0;32m OK e[0m] Listening on GPS (Global Positioning System) Daemon Sockets.
Starting Socket activation for snappy daemon.
[e[0;32m OK e[0m] Listening on RPCbind Server Activation Socket.
Starting Docker Socket for the API.
[ 7.976897] cfg80211: World regulatory domain updated:
[ 7.982050] cfg80211: DFS Master region: unset
[ 7.986419] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.986425] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.986427] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.986429] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.986431] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.986433] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.986435] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.986437] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.986438] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 8.007816] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.031768] wifi_platform_bus_enumerate device present 1
[ 8.049502] wifi_platform_bus_enumerate device present 0
[ 8.049846] F1 signature read @0x18000000=0x17214354
[ 8.053338] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.053830] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.053884] wifi_platform_prealloc: failed to alloc static mem section 7
[ 8.053890] wifi_platform_get_mac_addr
[ 8.055242] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 8.055457] wl_create_event_handler(): thread:wl_event_handler:228 started
[ 8.055462] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1e3f21a70
[ 8.055558] dhd_attach(): thread:dhd_watchdog_thread:229 started
[ 8.055594] dhd_attach(): thread:dhd_dpc:22a started
[ 8.055629] dhd_attach(): thread:dhd_rxf:22b started
[ 8.055634] dhd_deferred_work_init: work queue initialized
[ 8.055821] Dongle Host Driver, version 1.201.82 (r)
[ 8.055821] Compiled in drivers/net/wireless/bcmdhd on May 17 2018 at 00:12:47
[ 8.056077] tegra_sysfs_register
[ 8.056101] Register interface [wlan0] MAC: 00:04:4b:8d:93:8d
[ 8.056101]
[ 8.056103] dhd_prot_ioctl : bus is down. we have nothing to do
[ 8.056180] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 20
[ 8.057218] wifi_platform_set_power = 0
[e[0;32m OK e[0m] Listening on CUPS Scheduler.
[e[0;32m OK e[0m] Listening on D-Bus System Message Bus Socket.
[e[0;32m OK e[0m] Started Daily apt activities.
[e[0;32m OK e[0m] Started Daily Cleanup of Temporary Directories.
[e[0;32m OK e[0m] Reached target Timers.
[e[0;32m OK e[0m] Started CUPS Scheduler.
[e[0;32m OK e[0m] Reached target Paths.
[e[0;32m OK e[0m] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[e[0;32m OK e[0m] Reached target Network (Pre).
Starting Raise network interfaces...
[e[0;32m OK e[0m] Listening on Socket activation for snappy daemon.
[e[0;32m OK e[0m] Listening on Docker Socket for the API.
Starting Load/Save RF Kill Switch Status...
[e[0;32m OK e[0m] Reached target Sockets.
[e[0;32m OK e[0m] Reached target Basic System.
Starting LSB: automatic crash report generation...
Starting Restore /etc/resolv.conf i...re the ppp link was shut down...
Starting Modem Manager...
Starting LSB: Speech Dispatcher...
Starting System Logging Service...
[ 8.411783] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
Starting Avahi mDNS/DNS-SD Stack...
[e[0;32m OK e[0m] Started GPS (Global Positioning System) Daemon.
[e[0;32m OK e[0m] Started Configure USB flashing port for device mode.
[e[0;32m OK e[0m] Started Run anacron jobs.
[e[0;32m OK e[0m] Started face capture server.
[ 8.551412] using random self ethernet address
[ 8.555913] using random host ethernet address
[ 8.565537] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-12-07 10:50:08 UTC, Version: 55.09 release
[ 8.573733] Mass Storage Function, version: 2009/09/11
[ 8.573737] LUN: removable file: (no medium)
[ 8.577905] using random self ethernet address
[ 8.577908] using random host ethernet address
[ 8.582429] usb0: HOST MAC 6e:cd:3d:3a:cc:b3
[ 8.582472] usb0: MAC 56:09:97:03:06:98
[ 8.582761] usb1: HOST MAC 76:5a:77:03:4a:24
[ 8.582772] usb1: MAC de:38:b7:3b:a3:17
[ 8.582792] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[e[0;32m OK e[0m] Started Regu[ 8.618457] xhci-tegra 3530000.xhci: xHCI Host Controller
lar background program processin[ 8.626618] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
g daemon.
[ 8.637766] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 8.646458] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 8.652439] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.659303] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.666511] usb usb1: Product: xHCI Host Controller
Starting NVIDIA specifi[ 8.671506] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
c first-boot script...
[ 8.680234] usb usb1: SerialNumber: 3530000.xhci
[ 8.687144] hub 1-0:1.0: USB hub found
[ 8.690992] hub 1-0:1.0: 4 ports detected
Starting Save/Restore Sound Card State...
[e[0;32m OK e[0m] Started D-Bus System Message Bus.
[ 8.710241] device usb0 entered promiscuous mode
[ 8.715448] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.720934] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 8.726485] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.730213] device usb1 entered promiscuous mode
[ 8.734170] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 8.734175] l4tbr0: port 2(usb1) entered forwarding state
[ 8.734187] l4tbr0: port 2(usb1) entered forwarding state
[ 8.755860] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.762735] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.770029] usb usb2: Product: xHCI Host Controller
[ 8.774984] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.780971] usb usb2: SerialNumber: 3530000.xhci
[ 8.786052] hub 2-0:1.0: USB hub found
[ 8.789935] hub 2-0:1.0: 3 ports detected
[ 8.794431] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 8.800389] android_work: did not send uevent (0 0 (null))
[ 8.829829] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.838398] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
How can I recover the ubuntu system startup log like “[OK] Listening on udev Kernel Socket.” to
the tty0 ?
