I opened a topic a few weeks ago: NX respawn CBOOT log to ttyTHS1
I still haven’t found a solution to my problem.
I think there is a few things going on in the different topics that differ from my case
I don’t want to disable boot on ttyTCU0, and I believe most of the topics deal with disabling the combined uart (TCU0). I still want to keep the log on TCU0 in my case, except that I also want to have boot log (not CBOOT as I understand that was not possible), on ttyTHS1.
Most of the topics deal with ttyTHS2, so some of the code changes would I am assuming have to adapt to that difference, to use ttyTHS1.
ttyTHS1 is uartb, serial 1 or 3110000.serial, from:
3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
in the ttyTHS2 case, I think it is uartc, serial 2 or c280000.serial
What I tried is the following:
bootargs = "console=ttyS1,115200 earlycon=uart8250,mmio32,0x03110000 fbcon=map:0 net.ifnames=0 rootfstype=ext4"
//stdout-path = &uartb;
serial@3110000 {
compatible = "nvidia,tegra20-uart"; // To load uart8250 driver
console-port;
sqa-automation-port;
status = "okay";
stdout-path = &uartb; is commented out as it gives me an error. I think I need to declare serial1 = &uartb somewhere. Not sure if needed.
I have also tried to update the bpmp dts file as follows:
serial {
port = <0x1>
has_input
And also the bct-misc-flash.cfg file as follows:
enable_combined_uart = 0;
spe_uart_instance = 0xff
This has no effect. Both bpmp and bct-misc-flash file seems to be related to disabling combined uart TCU0, which I don’t need, so maybe I shoudn’t touch those 2 files anyway
That doesn’t do it and I get the following at bootup (emmc), on the TCU0 UART (it stops at the last line and thus fails), and I get nothing on ttyTHS1:
[0004.349] I> ########## USB boot ##########
[0004.358] W> No valid slot number is found in scratch register
[0004.359] W> Return default slot: _a
[0004.370] I> USB Firmware Version: 60.06 release
[0004.424] I> regulator of usb2-0 already enabled
[0004.429] I> regulator of usb2-1 already enabled
[0004.434] I> regulator of usb2-2 already enabled
[0005.437] E> failed to initialize xhci controller
[0005.437] E> Error in init of XUSB host driver, err: 79790026
[0005.438] E> Failed to initialize device 5-0
[0005.438] E> USB boot failed, err: 2037973030
[0005.438] I> ########## Fixed storage boot ##########
[0005.439] I> Already published: 00010003
[0005.439] I> Look for boot partition
[0005.442] I> Fallback: assuming 0th partition is boot partition
[0005.448] I> Detect filesystem
[0005.475] I> Loading extlinux.conf ...
[0005.475] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0011.673] I> lookup_linear_dir:441: Invalid file block num
[0011.673] I> ext2_walk:142: 'extlinux' lookup failed
[0011.673] I> ext4_open_file:647: '/boot/extlinux/extlinux.conf' lookup failed
[0011.674] E> file /sdmmc_user/boot/extlinux/extlinux.conf open failed!!
[0011.674] E> Failed to find/load /boot/extlinux/extlinux.conf
[0011.677] I> Fallback: Load binaries from partition
[0011.682] W> No valid slot number is found in scratch register
[0011.687] W> Return default slot: _a
[0011.691] I> A/B: bin_type (37) slot 0
[0011.694] I> Loading kernel from partition
[0011.698] I> Loading partition kernel at 0xa42b0000 from device(0x1)
[0012.446] I> Validate kernel ...
[0012.446] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0012.843] W> No valid slot number is found in scratch register
[0012.844] W> Return default slot: _a
[0012.844] I> A/B: bin_type (38) slot 0
[0012.844] I> Loading kernel-dtb from partition
[0012.844] I> Loading partition kernel-dtb at 0x90000000 from device(0x1)
[0012.855] I> Validate kernel-dtb ...
[0012.856] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0012.859] I> Checking boot.img header magic ... [0012.859] I> [OK]
[0012.859] I> Kernel hdr @0xa42b0000
[0012.861] I> Kernel dtb @0x90000000
[0012.865] I> decompressor handler not found
[0012.869] I> Copying kernel image (40185864 bytes) from 0xa42b0800 to 0x80080000 ... [0012.886] I> Done
[0012.886] I> Move ramdisk (len: 0) from 0xa6904000 to 0x91000000
[0012.887] I> Updated bpmp info to DTB
[0012.888] I> Ramdisk: Base: 0x91000000; Size: 0x0
[0012.892] I> Updated initrd info to DTB
[0012.895] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0012.903] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0012.910] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0012.917] W> No valid slot number is found in scratch register
[0012.923] W> Return default slot: _a
[0012.926] I> Active slot suffix:
[0012.929] I> add_boot_slot_suffix: slot_suffix =
[0012.934] I> Linux Cmdline: console=ttyS1,115200 earlycon=uart8250,mmio32,0x03110000 video=tegrafb no_console_suspend=1 gpt usbcore.old_scheme
[0012.958] I> Updated bootarg info to DTB
[0012.961] W> MAC addr invalid!
[0012.964] E> Failed to get WIFI MAC address
[0012.968] W> MAC addr invalid!
[0012.971] E> Failed to get Bluetooth MAC address
[0012.976] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:07:54:46
[0012.982] W> "plugin-manager" doesn't exist, creating
[0012.987] I> Adding /chosen/plugin-manager/cvm
[0012.991] W> "chip-id" doesn't exist, creating
[0012.995] I> Adding /chosen/plugin-manager/chip-id
[0013.000] W> "configs" doesn't exist, creating
[0013.004] I> Adding /chosen/plugin-manager/configs
[0013.009] W> "ids" doesn't exist, creating
[0013.013] I> Adding /chosen/plugin-manager/ids
[0013.017] W> "odm-data" doesn't exist, creating
[0013.022] I> Adding /chosen/plugin-manager/odm-data
[0013.029] W> "memory" doesn't exist, creating
[0013.031] I> [0] START: 0x80000000, END: 0xac000000
[0013.035] I> [1] START: 0xac004000, END: 0xf09d0000
[0013.040] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0013.045] I> dram_block larger than 80000000
[0013.049] I> [3] START: 0x100000000, END: 0x280000000
[0013.054] I> added [base:0x80000000, size:0x2c000000] to /memory
[0013.059] I> added [base:0xac200000, size:0x44600000] to /memory
[0013.065] I> added [base:0x100000000, size:0x180000000] to /memory
[0013.072] I> Updated memory info to DTB
[0013.075] E> add_disp_param: failed to get display params for du=0
[0013.081] W> "reset" doesn't exist, creating
[0013.086] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0013.090] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0013.095] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0013.099] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0013.104] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0013.109] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0013.114] I> Deleted cpu@6 node in DT
[0013.117] I> Deleted cpu@7 node in DT
[0013.121] I> Deleted cluster3 node in FDT
[0013.125] I> Update arm-pmu in FDT
[0013.128] I> - update property: interrupts
[0013.132] I> - update property: interrupt-affinity
[0013.137] W> "misc-data" doesn't exist, creating
[0013.141] I> Boot-device: QSPI
[0013.143] W> Unknown boot device
[0013.147] I> Add storage-qspi to plugin-manager/misc-data
[0013.152] W> Unknown storage device
[0013.156] I> Add serial number:1421720027012 as DT property
[0013.161] I> Plugin-manager override starting
[0013.165] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0013.172] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0013.178] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0013.186] I> Disable plugin-manager status in FDT
[0013.187] I> Plugin-manager override finished successfully
[0013.192] I> tegrabl_load_kernel_and_dtb: Done
[0013.197] E> tegrabl_display_clear: display is not initialized
[0013.202] W> Boot logo display failed...
[0013.206] I> Kernel EP: 0x80080000, DTB: 0x90000000
