Crash logs from 2 different TX1's
I’ve been struggling with frequent crashes on the TX1 when reading from multiple USB3 cameras and using gstreamer to encode with omxvp8enc and send over UDP. I’ve seen it with many different cameras and gstreamer configurations. This frequently crashes when I start the gstreamer pipeline or after it has been running for a while. I haven’t noticed any issues with temperature. Here are 2 crash logs from the nvidia dev board and a connecttech carrier board. Same behavior on both. Both are also running Jetpack 2.3 (ubuntu 16.04). I lost network connection so was only able to collect these logs by plugging in a monitor and keyboard directly to the TX1. It requires a hard reset to come up again.
nvidia dev board
[ 4152.465992] tegra-xhci tegra-xhci: Firmware reinit.
[ 4153.193567] tegra-xhci tegra-xhci: xHCI host not responding to stop endpoint command.
[ 4153.193750] tegra-xhci tegra-xhci: Assuming host is dying, halting host.
[ 4153.315851] tegra-xhci tegra-xhci: Host not halted after 16000 microseconds.
[ 4153.315997] tegra-xhci tegra-xhci: Non-responsive xHCI host is not halting.
[ 4153.316065] tegra-xhci tegra-xhci: Completing active URBs anyway.
[ 4153.317361] r8152 2-1:1.0 eth0: Tx status -108
[ 4153.317516] r8152 2-1:1.0 eth0: Tx status -108
[ 4153.317652] r8152 2-1:1.0 eth0: Tx status -108
[ 4153.317784] r8152 2-1:1.0 eth0: Tx status -108
[ 4153.318417] tegra-xhci tegra-xhci: HC died; cleaning up
[ 4153.324337] tegra_xhci_hcd_reinit: hcd_reinit is disabled
[ 4153.325062] usb 1-3: USB disconnect, device number 3
[ 4153.329038] usb 2-1: USB disconnect, device number 2
[ 4153.442986] usb 2-2: USB disconnect, device number 3
[ 4153.442996] usb 2-2.1: USB disconnect, device number 4
[ 4153.523505] usb 2-2.2: USB disconnect, device number 5
[ 4153.634771] usb 2-2.3: USB disconnect, device number 6
[ 4153.767236] usb 2-2.4: USB disconnect, device number 7
[ 4302.619810] tegradc tegradc.1: vrr_setup failed
[ 4302.648170] tegradc tegradc.1: hdmi: plugged
[ 4302.663502] tegradc tegradc.1: blank - powerdown
[ 4302.877534] tegradc tegradc.1: blank - powerdown
[ 4302.877740] tegradc tegradc.1: unblank
[ 4302.906370] tegradc tegradc.1: nominal-pclk:241699200 parent:241698047 div:1.0 pclk:241698047 239282208~263452128
[ 4303.257997] tegradc tegradc.1: unblank
[ 4313.837394] extcon-gpio-states 1.extcon: Cable state 2
[ 4313.895878] otg state changed: SUSPEND --> HOST
[ 4313.896022] tegra_start_host(): enable ehci node
[ 4313.898037] tegra USB phy - inst[0] platform info:
[ 4313.898073] port_otg: yes
[ 4313.898098] has_hostpc: yes
[ 4313.898123] phy_interface: USB_PHY_INTF_UTMI
[ 4313.898147] op_mode: TEGRA_USB_OPMODE_HOST
[ 4313.898168] qc2_voltage: 0
[ 4313.898191] hot_plug: disabled
[ 4313.898214] remote_wakeup: enabled
[ 4313.899761] regulator_get() failed for (tegra-ehci.0,usb_vbus), -19
Connecttech board
* eth0 disappears from ifconfig
[58992.260629] tegra-xhci tegra-xhci: Firmware reinit.
[58992.987447] tegra-xhci tegra-xhci: xHCI host not responding to stop endpoint command.
[58992.987553] tegra-xhci tegra-xhci: Assuming host is dying, halting host.
[58993.083665] tegra-xhci tegra-xhci: Host not halted after 16000 microseconds.
[58993.083739] tegra-xhci tegra-xhci: Non-responsive xHCI host is not halting.
[58993.083775] tegra-xhci tegra-xhci: Completing active URBs anyway.
[58993.084599] r8152 2-1:1.0 eth0: Tx status -108
[58993.084693] r8152 2-1:1.0 eth0: Tx status -108
[58993.084769] r8152 2-1:1.0 eth0: Tx status -108
[58993.084840] r8152 2-1:1.0 eth0: Tx status -108
[58993.085068] tegra-xhci tegra-xhci: HC died; cleaning up
[58993.090640] tegra_xhci_hcd_reinit: hcd_reinit is disabled
[58993.092916] usb 1-3: USB disconnect, device number 4
[58993.094889] usb 2-1: USB disconnect, device number 2
[58993.217308] usb 2-2: USB disconnect, device number 8
[58993.217320] usb 2-2.1: USB disconnect, device number 9
[58993.342426] usb 2-2.2: USB disconnect, device number 10
[58993.475779] usb 2-2.3: USB disconnect, device number 11
[58993.614892] usb 2-2.4: USB disconnect, device number 12
[59260.104971] tegradc tegradc.1: vrr_setup failed
[59260.123176] tegradc tegradc.1: hdmi: plugged
[59260.130305] tegradc tegradc.1: blank - powerdown
[59260.376539] tegradc tegradc.1: blank - powerdown
[59260.376672] tegradc tegradc.1: unblank
[59260.405734] tegradc tegradc.1: nominal-pclk:241699200 parent:241698047 div:1.0 pclk:241698047 239282208~263452128
[59260.759289] tegradc tegradc.1: unblank
[59267.462193] extcon-gpio-states 1.extcon: Cable state 2
[59267.520541] otg state changed: SUSPEND --> HOST
[59267.520701] tegra_start_host(): enable ehci node
[59267.522181] tegra USB phy - inst[0] platform info:
[59267.522206] port_otg: yes
[59267.522222] has_hostpc: yes
[59267.522238] phy_interface: USB_PHY_INTF_UTMI
[59267.522254] op_mode: TEGRA_USB_OPMODE_HOST
[59267.522269] qc2_voltage: 0
[59267.522284] hot_plug: disabled
[59267.522301] remote_wakeup: enabled
[59267.523529] regulator_get() failed for (tegra-ehci.0,usb_vbus), -19
[59267.529847] usb_phy: failed regulator_get vdd_vbus_usb:-19, inst:0
[59267.631055] extcon-gpio-states 1.extcon: Cable state 2
[59268.543677] tegra-ehci tegra-ehci.0: Tegra EHCI Host Controller
[59268.543709] tegra-ehci tegra-ehci.0: new USB bus registered, assigned bus number 3
[59268.544087] tegra-ehci tegra-ehci.0: irq 52, io mem 0x7d000000
[59268.570559] tegra-ehci tegra-ehci.0: USB 2.0 started, EHCI 1.10
[59268.570629] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[59268.570638] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[59268.570645] usb usb3: Product: Tegra EHCI Host Controller
[59268.570652] usb usb3: Manufacturer: Linux 3.10.96-tegra ehci_hcd
[59268.570657] usb usb3: SerialNumber: tegra-ehci.0
[59268.571079] hub 3-0:1.0: USB hub found
[59268.571096] hub 3-0:1.0: 1 port detected
[59268.571234] Could not add tegra-ehci.0 to power domain using device tree
[59268.571428] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.571678] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[59268.571722] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.571931] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.572124] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.572284] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[59268.572320] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.572507] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.572675] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.572849] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.573020] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.573186] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.573347] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.578205] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.578445] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[59268.578481] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.578657] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.578826] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.578973] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[59268.579003] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.579183] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.579351] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.579518] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.579686] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.579850] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.580014] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.890857] usb 3-1: new high-speed USB device number 2 using tegra-ehci
[59268.938660] usb 3-1: New USB device found, idVendor=05e3, idProduct=0610
[59268.938767] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[59268.938920] usb 3-1: Product: USB2.0 Hub
[59268.939001] usb 3-1: Manufacturer: GenesysLogic
[59268.945099] hub 3-1:1.0: USB hub found
[59268.946433] hub 3-1:1.0: 4 ports detected
[59268.956846] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.958875] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[59268.959299] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.961922] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.962989] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.963879] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[59268.964080] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.965178] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.966185] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.967160] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.968164] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.969174] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59268.970210] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.230914] usb 3-1.1: new low-speed USB device number 3 using tegra-ehci
[59269.265751] usb 3-1.1: New USB device found, idVendor=04f2, idProduct=0939
[59269.265763] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[59269.265770] usb 3-1.1: Product: USB Optical Mouse
[59269.265776] usb 3-1.1: Manufacturer: PixArt
[59269.268527] input: PixArt USB Optical Mouse as /devices/tegra-ehci.0/usb3/3-1/3-1.1/3-1.1:1.0/input/input10
[59269.268679] hid-generic 0003:04F2:0939.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-tegra-ehci.0-1.1/input0
[59269.268972] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.269161] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[59269.269246] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.269377] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.269499] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.269604] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[59269.269624] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.269750] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.269870] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.269983] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.270099] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.270216] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.270361] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.351569] usb 3-1.2: new low-speed USB device number 4 using tegra-ehci
[59269.394661] usb 3-1.2: New USB device found, idVendor=04f2, idProduct=0833
[59269.394777] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[59269.394866] usb 3-1.2: Product: USB Keyboard
[59269.394941] usb 3-1.2: Manufacturer: CHICONY
[59269.410693] input: CHICONY USB Keyboard as /devices/tegra-ehci.0/usb3/3-1/3-1.2/3-1.2:1.0/input/input11
[59269.412311] hid-generic 0003:04F2:0833.0002: input,hidraw1: USB HID v1.11 Keyboard [CHICONY USB Keyboard] on usb-tegra-ehci.0-1.2/input0
[59269.413193] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.414284] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[59269.414536] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.415568] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.416565] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.417456] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[59269.417654] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.418851] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.419870] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.421815] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.423095] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.424134] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.426806] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.427790] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.428628] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[59269.428802] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.429799] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.431646] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.432574] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[59269.432785] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.434111] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.435542] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.435967] input: CHICONY USB Keyboard as /devices/tegra-ehci.0/usb3/3-1/3-1.2/3-1.2:1.1/input/input12
[59269.437550] hid-generic 0003:04F2:0833.0003: input,hiddev0,hidraw2: USB HID v1.11 Device [CHICONY USB Keyboard] on usb-tegra-ehci.0-1.2/input1
[59269.438006] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.438658] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.439248] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.439856] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.440786] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.441321] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[59269.441468] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.442084] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.442659] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.443164] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[59269.443438] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.444087] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.444654] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59269.445325] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[59275.028217] tegradc tegradc.1: unblank
It’s interesting that the failure seems to simultaneously involve more than one driver. USB, display, and ethernet all reset at the same time. At the end of that is a power regulator note:
It looks like it woke up from suspend. I’m wondering if this is just a subtle hit from suspend/power-saving. Take at a look at the performance scripts and information here, maybe try again with any suspend disabled:
http://elinux.org/Jetson/TX1_Controlling_Performance
Consider disabling ondemand while testing:
sudo update-rc.d -f ondemand remove
