I am trying to use a usb 3.1 camera on my jetson tx1.
it’s an ids camera :
the camera is running well for approximatly one minnute and then the jetson shutdown.
I am using the R28.2 release, 4.4.38-tegra kernel.
if I take a look at ./tegrastats during the crash nothing particular, no high temperature (all below 50 degree), but if I look at the /var/log/syslog file I see that line many times:
soctherm: OC ALARM 0x00000001
Apr 12 15:37:01 tegra-ubuntu kernel: [ 694.323843] soctherm: OC ALARM 0x00000001
Apr 12 15:37:01 tegra-ubuntu kernel: [ 694.964241] xhci-tegra 70090000.xusb: tegra_xhci_endpoint_soft_retry port 1 doesn't reach U0 in 300us, portsc 0x2d1
Apr 12 15:37:01 tegra-ubuntu kernel: [ 694.977563] xhci-tegra 70090000.xusb: tegra_xhci_endpoint_soft_retry port 1 doesn't reach U0 in 300us, portsc 0x2d1
Apr 12 15:37:01 tegra-ubuntu kernel: [ 695.074205] usb 2-2: USB disconnect, device number 10
Apr 12 15:37:01 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:remove_device() /sys/devices/70090000.xusb/usb2/2-2/2-2:1.0
Apr 12 15:37:01 tegra-ubuntu ofonod[779]: plugins/udevng.c:remove_device() /sys/devices/70090000.xusb/usb2/2-2/2-2:1.0
Apr 12 15:37:02 tegra-ubuntu kernel: [ 695.500321] usb 2-2: new SuperSpeed USB device number 11 using xhci-tegra
Apr 12 15:37:02 tegra-ubuntu kernel: [ 695.525189] usb 2-2: New USB device found, idVendor=1409, idProduct=30a0
Apr 12 15:37:02 tegra-ubuntu kernel: [ 695.532174] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Apr 12 15:37:02 tegra-ubuntu kernel: [ 695.540027] usb 2-2: Product: USB 3.0 Camera
Apr 12 15:37:02 tegra-ubuntu kernel: [ 695.544802] usb 2-2: Manufacturer: Camera Manufacturer
Apr 12 15:37:02 tegra-ubuntu mtp-probe: checking bus 2, device 11: "/sys/devices/70090000.xusb/usb2/2-2"
Apr 12 15:37:02 tegra-ubuntu mtp-probe: bus: 2, device: 11 was not an MTP device
Apr 12 15:37:03 tegra-ubuntu ueyeusbd[931]: [2-4-0x00000000] DevId: 1, SerNr: 4103551700
Apr 12 15:37:03 tegra-ubuntu ueyeusbd[931]: Model: UI300xSE-C, Type: 0x60, Capability Flags: 0x18 0x00 0x0C
Apr 12 15:37:03 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_usb_device() usb [1409:30a0]
Apr 12 15:37:03 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_usb_device() usb [1409:30a0]
Apr 12 15:37:03 tegra-ubuntu kernel: [ 696.954713] usb 2-2: USB disconnect, device number 11
Apr 12 15:37:03 tegra-ubuntu kernel: [ 697.199646] usb 2-2: new SuperSpeed USB device number 12 using xhci-tegra
Apr 12 15:37:03 tegra-ubuntu kernel: [ 697.227900] usb 2-2: New USB device found, idVendor=1409, idProduct=30a0
Apr 12 15:37:03 tegra-ubuntu kernel: [ 697.235036] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Apr 12 15:37:03 tegra-ubuntu kernel: [ 697.247572] usb 2-2: Product: USB 3.0 Camera
Apr 12 15:37:03 tegra-ubuntu kernel: [ 697.252322] usb 2-2: Manufacturer: Camera Manufacturer
Apr 12 15:37:04 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_usb_device() usbfs [(null):(null)]
Apr 12 15:37:04 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_usb_device() usbfs [(null):(null)]
Apr 12 15:37:04 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:remove_device() /sys/devices/70090000.xusb/usb2/2-2/2-2:1.0
Apr 12 15:37:04 tegra-ubuntu ofonod[779]: plugins/udevng.c:remove_device() /sys/devices/70090000.xusb/usb2/2-2/2-2:1.0
Apr 12 15:37:04 tegra-ubuntu mtp-probe: checking bus 2, device 12: "/sys/devices/70090000.xusb/usb2/2-2"
Apr 12 15:37:04 tegra-ubuntu mtp-probe: bus: 2, device: 12 was not an MTP device
Apr 12 15:37:05 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_modem_list()
Apr 12 15:37:05 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_modem_list()
Apr 12 15:37:06 tegra-ubuntu ueyeusbd[931]: [2-4-0x00000000] DevId: 1, SerNr: 4103551700
Apr 12 15:37:06 tegra-ubuntu ueyeusbd[931]: Model: UI300xSE-C, Type: 0x60, Capability Flags: 0x18 0x3F 0x1C
Apr 12 15:37:06 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_usb_device() usb [1409:30a0]
Apr 12 15:37:06 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_usb_device() usb [1409:30a0]
Apr 12 15:37:07 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_usb_device() usbfs [(null):(null)]
Apr 12 15:37:07 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_usb_device() usbfs [(null):(null)]
Apr 12 15:37:08 tegra-ubuntu kernel: [ 701.941701] soctherm: OC ALARM 0x00000001
Apr 12 15:37:08 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_modem_list()
Apr 12 15:37:08 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_modem_list()
Apr 12 15:37:09 tegra-ubuntu kernel: [ 703.008037] soctherm: OC ALARM 0x00000001
Apr 12 15:37:10 tegra-ubuntu kernel: [ 704.196089] soctherm: OC ALARM 0x00000001
Apr 12 15:37:12 tegra-ubuntu kernel: [ 705.305006] soctherm: OC ALARM 0x00000001
Apr 12 15:37:13 tegra-ubuntu kernel: [ 706.414528] soctherm: OC ALARM 0x00000001
Apr 12 15:37:14 tegra-ubuntu kernel: [ 707.627532] soctherm: OC ALARM 0x00000001
Apr 12 15:37:15 tegra-ubuntu kernel: [ 708.775487] soctherm: OC ALARM 0x00000001
Apr 12 15:37:16 tegra-ubuntu kernel: [ 709.913115] soctherm: OC ALARM 0x00000001
Apr 12 15:37:17 tegra-ubuntu kernel: [ 711.013758] soctherm: OC ALARM 0x00000001
Apr 12 15:37:18 tegra-ubuntu kernel: [ 712.270942] soctherm: OC ALARM 0x00000001
Apr 12 15:37:19 tegra-ubuntu kernel: [ 713.043552] xhci-tegra 70090000.xusb: tegra_xhci_endpoint_soft_retry port 1 doesn't reach U0 in 300us, portsc 0x2d1
Apr 12 15:37:19 tegra-ubuntu kernel: [ 713.055881] xhci-tegra 70090000.xusb: tegra_xhci_endpoint_soft_retry port 1 doesn't reach U0 in 300us, portsc 0x2d1
Apr 12 15:37:20 tegra-ubuntu kernel: [ 713.358193] usb 2-2: USB disconnect, device number 12
Apr 12 15:37:20 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:remove_device() /sys/devices/70090000.xusb/usb2/2-2/2-2:1.0
Apr 12 15:37:20 tegra-ubuntu ofonod[779]: plugins/udevng.c:remove_device() /sys/devices/70090000.xusb/usb2/2-2/2-2:1.0
Apr 12 15:37:20 tegra-ubuntu kernel: [ 713.603101] usb 2-2: new SuperSpeed USB device number 13 using xhci-tegra
Apr 12 15:37:20 tegra-ubuntu kernel: [ 713.633116] usb 2-2: New USB device found, idVendor=1409, idProduct=30a0
Apr 12 15:37:20 tegra-ubuntu kernel: [ 713.645319] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Apr 12 15:37:20 tegra-ubuntu kernel: [ 713.654573] usb 2-2: Product: USB 3.0 Camera
Apr 12 15:37:20 tegra-ubuntu kernel: [ 713.658867] usb 2-2: Manufacturer: Camera Manufacturer
Apr 12 15:37:20 tegra-ubuntu mtp-probe: checking bus 2, device 13: "/sys/devices/70090000.xusb/usb2/2-2"
Apr 12 15:37:20 tegra-ubuntu mtp-probe: bus: 2, device: 13 was not an MTP device
Apr 12 15:37:21 tegra-ubuntu ueyeusbd[931]: [2-4-0x00000000] DevId: 1, SerNr: 4103551700
Apr 12 15:37:21 tegra-ubuntu ueyeusbd[931]: Model: UI300xSE-C, Type: 0x60, Capability Flags: 0x18 0x00 0x0C
Apr 12 15:37:21 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_usb_device() usb [1409:30a0]
Apr 12 15:37:21 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_usb_device() usb [1409:30a0]
Apr 12 15:37:21 tegra-ubuntu kernel: [ 714.898654] usb 2-2: USB disconnect, device number 13
Apr 12 15:37:21 tegra-ubuntu kernel: [ 715.151169] usb 2-2: new SuperSpeed USB device number 14 using xhci-tegra
Apr 12 15:37:21 tegra-ubuntu kernel: [ 715.177810] usb 2-2: New USB device found, idVendor=1409, idProduct=30a0
Apr 12 15:37:21 tegra-ubuntu kernel: [ 715.184693] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Apr 12 15:37:21 tegra-ubuntu kernel: [ 715.192679] usb 2-2: Product: USB 3.0 Camera
Apr 12 15:37:21 tegra-ubuntu kernel: [ 715.197492] usb 2-2: Manufacturer: Camera Manufacturer
Apr 12 15:37:22 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_usb_device() usbfs [(null):(null)]
Apr 12 15:37:22 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_usb_device() usbfs [(null):(null)]
Apr 12 15:37:22 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:remove_device() /sys/devices/70090000.xusb/usb2/2-2/2-2:1.0
Apr 12 15:37:22 tegra-ubuntu ofonod[779]: plugins/udevng.c:remove_device() /sys/devices/70090000.xusb/usb2/2-2/2-2:1.0
Apr 12 15:37:22 tegra-ubuntu mtp-probe: checking bus 2, device 14: "/sys/devices/70090000.xusb/usb2/2-2"
Apr 12 15:37:22 tegra-ubuntu mtp-probe: bus: 2, device: 14 was not an MTP device
Apr 12 15:37:23 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_modem_list()
Apr 12 15:37:23 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_modem_list()
Apr 12 15:37:24 tegra-ubuntu ueyeusbd[931]: [2-4-0x00000000] DevId: 1, SerNr: 4103551700
Apr 12 15:37:24 tegra-ubuntu ueyeusbd[931]: Model: UI300xSE-C, Type: 0x60, Capability Flags: 0x18 0x3F 0x1C
Apr 12 15:37:24 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_usb_device() usb [1409:30a0]
Apr 12 15:37:24 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_usb_device() usb [1409:30a0]
Apr 12 15:37:25 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_usb_device() usbfs [(null):(null)]
Apr 12 15:37:25 tegra-ubuntu rsyslogd-2007: action 'action 9' suspended, next retry is Fri Apr 12 15:37:55 2019 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Apr 12 15:37:25 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_usb_device() usbfs [(null):(null)]
Apr 12 15:37:26 tegra-ubuntu kernel: [ 719.809055] soctherm: OC ALARM 0x00000001
Apr 12 15:37:26 tegra-ubuntu ofonod[779]: ofonod[779]: plugins/udevng.c:check_modem_list()
Apr 12 15:37:26 tegra-ubuntu ofonod[779]: plugins/udevng.c:check_modem_list()
Apr 12 15:37:28 tegra-ubuntu kernel: [ 721.429506] soctherm: OC ALARM 0x00000001
Apr 12 15:37:29 tegra-ubuntu kernel: [ 722.994086] soctherm: OC ALARM 0x00000001
Apr 12 15:37:31 tegra-ubuntu kernel: [ 724.637810] soctherm: OC ALARM 0x00000001
Apr 12 15:37:32 tegra-ubuntu kernel: [ 726.239361] soctherm: OC ALARM 0x00000001
Apr 12 15:37:34 tegra-ubuntu kernel: [ 727.845818] soctherm: OC ALARM 0x00000001
\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\0
0\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\
00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00
